Project: 7600 (Run 19, Clone 3, Gen 40)
Post by calxalot »
Repeatedly crashes, core a4.
Been going on for days without dumping, but this machine is running 7.1.44.
I created a new slot so I could continue folding while I waited to see if the WU is ever dumped.
Client probably won't dump it until expiration date of 2-26.
18:50:35:************************* Folding@home Client *************************
18:50:35:Started thread 1 on PID 1047
18:50:35:    Website: http://folding.stanford.edu/
18:50:35:  Copyright: (c) 2009-2012 Stanford University
18:50:35:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:50:35:       Args:
18:50:35:     Config: /Library/Application Support/FAHClient/config.xml
18:50:35:******************************** Build ********************************
18:50:35:    Version: 7.1.44
18:50:35:       Date: Jan 18 2012
18:50:35:       Time: 18:53:25
18:50:35:    SVN Rev: 3233
18:50:35:     Branch: fah/trunk/client
18:50:35:   Compiler: Intel(R) C++ g++ 4.2 mode 1110
18:50:35:    Options: -std=gnu++98 -diag-disable 279 -O3 -funroll-loops -msse3
18:50:35:             -axSSSE3,SSE4.1,SSE4.2 -openmp -restrict
18:50:35:   Platform: darwin 10.5.0
18:50:35:       Bits: 32
18:50:35:       Mode: Release
18:50:35:******************************* System ********************************
18:50:35:        CPU: Intel(R) Xeon(R) CPU E5462 @ 2.80GHz
18:50:35:     CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
18:50:35:       CPUs: 8
18:50:35:     Memory: 2.00GiB
18:50:35:Free Memory: 1.12GiB
18:50:35:    Threads: POSIX_THREADS
18:50:35: On Battery: false
18:50:35: UTC offset: -8
18:50:35:        PID: 1047
18:50:35:        CWD: /Library/Application Support/FAHClient
18:50:35:         OS: Darwin 11.2.0 x86_64
18:50:35:    OS Arch: AMD64
18:50:35:       GPUs: 1
18:50:35:      GPU 0: NVIDIA:1 G92 [GeForce 8800 GT]
18:50:35:       CUDA: Not detected
18:50:35:***********************************************************************
18:50:35:<config>
18:50:35:
18:50:35:  <!-- User Information -->
18:50:35:  <passkey v='********************************'/>
18:50:35:  <team v='1971'/>
18:50:35:  <user v='calxalot'/>
18:50:35:
18:50:35:  <!-- Work Unit Control -->
18:50:35:  <dump-after-deadline v='true'/>
18:50:35:
18:50:35:  <!-- Folding Slots -->
18:50:35:  <slot id='0' type='SMP'>
18:50:35:    <cpus v='-1'/>
18:50:35:  </slot>
18:50:35:  <slot id='1' type='SMP'>
18:50:35:  </slot>
18:50:35:</config>
18:50:35:Trying to access database...
18:50:35:Successfully acquired database lock
18:50:36:Enabled folding slot 00: READY smp:8
18:50:36:Enabled folding slot 01: READY smp:8
15:05:32:WU00:FS00:Starting
15:05:32:WU00:FS00:Removing old file './work/00/logfile_01-20120206-022330.txt'
15:05:32:WU00:FS00:Running FahCore: //Applications/fahclient.app/Contents/MacOS/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 00 -suffix 01 -version 701 -lifeline 92 -checkpoint 15 -np 8 -forceasm
15:05:32:WU00:FS00:Started FahCore on PID 1014
15:05:32:WU00:FS00:Core PID:1018
15:05:32:WU00:FS00:FahCore 0xa4 started
15:05:32:WU00:FS00:0xa4:
15:05:32:WU00:FS00:0xa4:*------------------------------*
15:05:32:WU00:FS00:0xa4:Folding@Home Gromacs Core
15:05:32:WU00:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
15:05:32:WU00:FS00:0xa4:Preparing to commence simulation
15:05:32:WU00:FS00:0xa4:- Ensuring status. Please wait.
15:05:41:WU00:FS00:0xa4:- Assembly optimizations manually forced on.
15:05:41:WU00:FS00:0xa4:- Not checking prior termination.
15:05:41:WU00:FS00:0xa4:- Expanded 21571 -> 505776 (decompressed 2344.7 percent)
15:05:41:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=21571 data_size=505776, decompressed_data_size=505776 diff=0
15:05:41:WU00:FS00:0xa4:- Digital signature verified
15:05:41:WU00:FS00:0xa4:Project: 7600 (Run 19, Clone 3, Gen 40)
15:05:41:WU00:FS00:0xa4:Assembly optimizations on if available.
15:05:41:WU00:FS00:0xa4:Entering M.D.
15:05:47:WU00:FS00:0xa4:Mapping NT from 8 to 8
15:05:48:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
sortofageek
Re: Project: 7600 (Run 19, Clone 3, Gen 40)
Post by sortofageek »
I'm sorry to hear of your troubles with this WU. Unfortunately, you probably need to look for issues on your end as another donor has successfully completed this one.
Note to other donor:
Your WU (P7600 R19 C3 G40) was added to the stats database on 2012-02-07 09:10:35 for 937 points of credit.
