171.67.108.11
SKeptical_Thinker
Hardware configuration: XP-32 Pro SP-3
Antec NSK-2480 with two Thermaltake 120mm Smart Fans
Gigabyte ga-ma78gm-s2h 780G IGP
BE-2350 with 10.5 x multiplier, 1.250V in BIOS, clock at 272 (2.856GHz)
EVGA 8800 GS
Ninja Mini CPU HS
GeIL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
Seagate 500GB SATA hard drive
ASUS 18X DVD±R DVD Burner PATA Model DRW-1814BL
171.67.108.11
Post by SKeptical_Thinker »
I don't know that anything is really wrong, as I see that points have been awarded.
If this should be in the V7 beta forum, please move it there.
Short form:
21:09:25:WU01:FS00:0x11:Entering M.D.
21:09:30:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:09:30:WU00:FS00:Trying to send results to collection server
21:09:30:WU00:FS00:Uploading 97.61KiB to 171.67.108.25
21:09:30:WU00:FS00:Connecting to 171.67.108.25:8080
Log extract:
*********************** Log Started 2012-02-04T19:35:40 ************************
19:35:41:************************* Folding@home Client *************************
19:35:41:      Website: http://folding.stanford.edu/
19:35:41:    Copyright: (c) 2009-2012 Stanford University
19:35:41:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:35:41:         Args: --lifeline 2092 --command-port=36330
19:35:41:       Config: C:/Documents and Settings/**/Application
19:35:41:               Data/FAHClient/config.xml
19:35:41:******************************** Build ********************************
19:35:41:      Version: 7.1.43
19:35:41:         Date: Jan 2 2012
19:35:41:         Time: 12:33:05
19:35:41:      SVN Rev: 3223
19:35:41:       Branch: fah/trunk/client
19:35:41:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
19:35:41:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
19:35:41:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
19:35:41:     Platform: win32 XP
19:35:41:         Bits: 32
19:35:41:         Mode: Release
19:35:41:******************************* System ********************************
19:35:41:          CPU: AMD Athlon(tm) X2 Dual Core Processor BE-2350
19:35:41:       CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
19:35:41:         CPUs: 2
19:35:41:       Memory: 3.25GiB
19:35:41:  Free Memory: 2.84GiB
19:35:41:      Threads: WINDOWS_THREADS
19:35:41:   On Battery: false
19:35:41:   UTC offset: -5
19:35:41:          PID: 3456
19:35:41:          CWD: C:/Documents and Settings/**/Application
19:35:41:           OS: Microsoft Windows XP Service Pack 3
19:35:41:      OS Arch: X86
19:35:41:         GPUs: 1
19:35:41:        GPU 0: NVIDIA:1 G92 [GeForce 8800 GS]
19:35:41:         CUDA: 1.1
19:35:41:  CUDA Driver: 4010
19:35:41:Win32 Service: false
19:35:41:***********************************************************************
19:35:41:<config>
19:35:41:  <!-- Folding Slot Configuration -->
19:35:41:  <gpu v='true'/>
19:35:41:
19:35:41:  <!-- User Information -->
19:35:41:  <passkey v='********************************'/>
19:35:41:  <team v='31574'/>
19:35:41:  <user v='SKeptical_Thinker'/>
19:35:41:
19:35:41:  <!-- Folding Slots -->
19:35:41:</config>
19:35:41:Trying to access database...
19:35:41:Successfully acquired database lock
19:35:41:Enabled folding slot 00: READY gpu:0:"G92 [GeForce 8800 GS]"
19:35:41:Enabled folding slot 01: READY smp:2
19:35:41:WU02:FS01:Starting
19:35:41:WU02:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/**n/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 02 -suffix 01 -version 701 -checkpoint 15 -np 2
19:35:41:WU02:FS01:Started FahCore on PID 3752
19:35:41:WU02:FS01:Core PID:3764
19:35:41:WU02:FS01:FahCore 0xa4 started
19:35:41:WU00:FS00:Starting
19:35:41:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/**/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 00 -suffix 01 -version 701 -checkpoint 15 -gpu 0
19:35:41:WU00:FS00:Started FahCore on PID 3784
19:35:41:WU00:FS00:Core PID:3796
19:35:41:WU00:FS00:FahCore 0x11 started
19:35:42:WU02:FS01:0xa4:
19:35:42:WU02:FS01:0xa4:*------------------------------*
19:35:42:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
19:35:42:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
19:35:42:WU02:FS01:0xa4:Preparing to commence simulation
19:35:42:WU02:FS01:0xa4:- Looking at optimizations...
19:35:42:WU02:FS01:0xa4:- Files status OK
19:35:42:WU02:FS01:0xa4:- Expanded 663703 -> 1297016 (decompressed 195.4 percent)
19:35:42:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=663703 data_size=1297016, decompressed_data_size=1297016 diff=0
19:35:42:WU02:FS01:0xa4:- Digital signature verified
19:35:42:WU02:FS01:0xa4:Project: 7200 (Run 44, Clone 8, Gen 87)
19:35:42:WU02:FS01:0xa4:Assembly optimizations on if available.
19:35:42:WU02:FS01:0xa4:Entering M.D.
19:35:42:WU00:FS00:0x11:
19:35:42:WU00:FS00:0x11:*------------------------------*
19:35:42:WU00:FS00:0x11:Folding@Home GPU Core
19:35:42:WU00:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
19:35:42:WU00:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
19:35:42:WU00:FS00:0x11:Build host: amoeba
19:35:42:WU00:FS00:0x11:Board Type: Nvidia
19:35:42:WU00:FS00:0x11:Core      :
19:35:42:WU00:FS00:0x11:Preparing to commence simulation
19:35:42:WU00:FS00:0x11:- Looking at optimizations...
19:35:42:WU00:FS00:0x11:- Files status OK
19:35:42:WU00:FS00:0x11:- Expanded 46690 -> 252912 (decompressed 541.6 percent)
19:35:42:WU00:FS00:0x11:Called DecompressByteArray: compressed_data_size=46690 data_size=252912, decompressed_data_size=252912 diff=0
19:35:42:WU00:FS00:0x11:- Digital signature verified
19:35:42:WU00:FS00:0x11:Project: 5765 (Run 8, Clone 335, Gen 1643)
19:35:42:WU00:FS00:0x11:Assembly optimizations on if available.
19:35:42:WU00:FS00:0x11:Entering M.D.
19:35:44:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
19:35:48:WU02:FS01:0xa4:Using Gromacs checkpoints
19:35:48:WU00:FS00:0x11:Will resume from checkpoint file
19:35:48:WU00:FS00:0x11:Tpr hash 00/wudata_01.tpr:  2410141226 1077848644 2430942917 1976319576 976247348
19:35:48:WU00:FS00:0x11:Calling fah_main args: 14 usage=100
19:35:48:WU02:FS01:0xa4:Mapping NT from 2 to 2
19:35:48:WU00:FS00:0x11:Working on Protein
19:35:49:WU02:FS01:0xa4:Resuming from checkpoint
19:35:49:WU02:FS01:0xa4:Verified 02/wudata_01.log
19:35:49:WU02:FS01:0xa4:Verified 02/wudata_01.trr
19:35:49:WU02:FS01:0xa4:Verified 02/wudata_01.xtc
19:35:49:WU02:FS01:0xa4:Verified 02/wudata_01.edr
19:35:49:WU02:FS01:0xa4:Completed 219566 out of 750000 steps  (29%)
19:35:49:WU00:FS00:0x11:Client config unavailable.
19:35:49:WU00:FS00:0x11:Resuming from checkpoint
19:35:49:WU00:FS00:0x11:fcCheckPointResume: retreived and current tpr file hash:
19:35:49:WU00:FS00:0x11:   0   2410141226   2410141226
19:35:49:WU00:FS00:0x11:   1   1077848644   1077848644
19:35:49:WU00:FS00:0x11:   2   2430942917   2430942917
19:35:49:WU00:FS00:0x11:   3   1976319576   1976319576
19:35:49:WU00:FS00:0x11:   4    976247348    976247348
19:35:49:WU00:FS00:0x11:fcCheckPointResume: file hashes same.
19:35:49:WU00:FS00:0x11:fcCheckPointResume: state restored.
19:35:49:WU00:FS00:0x11:Verified 00/wudata_01.log
19:35:49:WU00:FS00:0x11:Verified 00/wudata_01.edr
19:35:49:WU00:FS00:0x11:Verified 00/wudata_01.xtc
19:35:49:WU00:FS00:0x11:Completed 24%
19:35:49:WU00:FS00:0x11:Starting GUI Server
19:37:10:WU00:FS00:0x11:Completed 25%
19:38:23:WU00:FS00:0x11:Completed 26%
19:39:35:WU00:FS00:0x11:Completed 27%
19:40:48:WU00:FS00:0x11:Completed 28%
19:42:06:WU00:FS00:0x11:Completed 29%
19:43:21:WU00:FS00:0x11:Completed 30%
19:44:36:WU00:FS00:0x11:Completed 31%
19:45:50:WU00:FS00:0x11:Completed 32%
19:47:03:WU00:FS00:0x11:Completed 33%
19:48:17:WU00:FS00:0x11:Completed 34%
19:49:32:WU00:FS00:0x11:Completed 35%
19:50:42:WU02:FS01:0xa4:Completed 225000 out of 750000 steps  (30%)
19:50:47:WU00:FS00:0x11:Completed 36%
19:52:03:WU00:FS00:0x11:Completed 37%
19:53:18:WU00:FS00:0x11:Completed 38%
19:54:33:WU00:FS00:0x11:Completed 39%
19:55:46:WU00:FS00:0x11:Completed 40%
19:57:00:WU00:FS00:0x11:Completed 41%
19:58:14:WU00:FS00:0x11:Completed 42%
19:59:30:WU00:FS00:0x11:Completed 43%
20:00:48:WU00:FS00:0x11:Completed 44%
20:02:02:WU00:FS00:0x11:Completed 45%
20:03:18:WU00:FS00:0x11:Completed 46%
20:04:33:WU00:FS00:0x11:Completed 47%
20:05:46:WU00:FS00:0x11:Completed 48%
20:07:01:WU00:FS00:0x11:Completed 49%
20:08:14:WU00:FS00:0x11:Completed 50%
20:09:27:WU00:FS00:0x11:Completed 51%
20:10:39:WU00:FS00:0x11:Completed 52%
20:11:51:WU00:FS00:0x11:Completed 53%
20:13:04:WU00:FS00:0x11:Completed 54%
20:14:02:WU02:FS01:0xa4:Completed 232500 out of 750000 steps  (31%)
20:14:17:WU00:FS00:0x11:Completed 55%
20:15:29:WU00:FS00:0x11:Completed 56%
20:16:40:WU00:FS00:0x11:Completed 57%
20:17:53:WU00:FS00:0x11:Completed 58%
20:19:06:WU00:FS00:0x11:Completed 59%
20:20:21:WU00:FS00:0x11:Completed 60%
20:21:33:WU00:FS00:0x11:Completed 61%
20:22:45:WU00:FS00:0x11:Completed 62%
20:23:57:WU00:FS00:0x11:Completed 63%
20:25:09:WU00:FS00:0x11:Completed 64%
20:26:20:WU00:FS00:0x11:Completed 65%
20:27:33:WU00:FS00:0x11:Completed 66%
20:28:48:WU00:FS00:0x11:Completed 67%
20:30:04:WU00:FS00:0x11:Completed 68%
20:31:19:WU00:FS00:0x11:Completed 69%
20:32:32:WU00:FS00:0x11:Completed 70%
20:33:48:WU00:FS00:0x11:Completed 71%
20:35:04:WU00:FS00:0x11:Completed 72%
20:36:21:WU00:FS00:0x11:Completed 73%
20:37:33:WU00:FS00:0x11:Completed 74%
20:38:44:WU00:FS00:0x11:Completed 75%
20:39:56:WU00:FS00:0x11:Completed 76%
20:41:08:WU00:FS00:0x11:Completed 77%
20:41:41:WU02:FS01:0xa4:Completed 240000 out of 750000 steps  (32%)
20:42:20:WU00:FS00:0x11:Completed 78%
20:43:31:WU00:FS00:0x11:Completed 79%
20:44:43:WU00:FS00:0x11:Completed 80%
20:45:55:WU00:FS00:0x11:Completed 81%
20:47:06:WU00:FS00:0x11:Completed 82%
20:48:18:WU00:FS00:0x11:Completed 83%
20:49:30:WU00:FS00:0x11:Completed 84%
20:50:43:WU00:FS00:0x11:Completed 85%
20:51:55:WU00:FS00:0x11:Completed 86%
20:53:10:WU00:FS00:0x11:Completed 87%
20:54:23:WU00:FS00:0x11:Completed 88%
20:55:38:WU00:FS00:0x11:Completed 89%
20:56:53:WU00:FS00:0x11:Completed 90%
20:58:07:WU00:FS00:0x11:Completed 91%
20:59:20:WU00:FS00:0x11:Completed 92%
21:00:33:WU00:FS00:0x11:Completed 93%
21:01:45:WU00:FS00:0x11:Completed 94%
21:03:01:WU00:FS00:0x11:Completed 95%
21:04:14:WU00:FS00:0x11:Completed 96%
21:05:27:WU00:FS00:0x11:Completed 97%
21:06:42:WU00:FS00:0x11:Completed 98%
21:07:56:WU00:FS00:0x11:Completed 99%
21:07:57:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
21:07:59:WU01:FS00:News: Welcome to Folding@Home
21:07:59:WU01:FS00:Assigned to work server 171.67.108.21
21:07:59:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"G92 [GeForce 8800 GS]" from 171.67.108.21
21:07:59:WU01:FS00:Connecting to 171.67.108.21:8080
21:08:00:WU01:FS00:Downloading 61.89KiB
21:08:00:WU01:FS00:Download complete
21:08:00:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:10503 run:141 clone:0 gen:442 core:0x11 unit:0x0000034d6652eda54b716a9300003714
21:08:00:WU01:FS00:Downloading project 10503 description
21:08:00:WU01:FS00:Connecting to fah-web.stanford.edu:80
21:08:01:WU01:FS00:Project 10503 description downloaded successfully
21:09:05:WU02:FS01:0xa4:Completed 247500 out of 750000 steps  (33%)
21:09:10:WU00:FS00:0x11:Completed 100%
21:09:10:WU00:FS00:0x11:Successful run
21:09:10:WU00:FS00:0x11:DynamicWrapper: Finished Work Unit: sleep=10000
21:09:20:WU00:FS00:0x11:Reserved 75920 bytes for xtc file; Cosm status=0
21:09:20:WU00:FS00:0x11:Allocated 75920 bytes for xtc file
21:09:20:WU00:FS00:0x11:- Reading up to 75920 from "00/wudata_01.xtc": Read 75920
21:09:20:WU00:FS00:0x11:Read 75920 bytes from xtc file; available packet space=786354544
21:09:20:WU00:FS00:0x11:xtc file hash check passed.
21:09:20:WU00:FS00:0x11:Reserved 15168 15168 786354544 bytes for arc file=<00/wudata_01.trr> Cosm status=0
21:09:20:WU00:FS00:0x11:Allocated 15168 bytes for arc file
21:09:20:WU00:FS00:0x11:- Reading up to 15168 from "00/wudata_01.trr": Read 15168
21:09:20:WU00:FS00:0x11:Read 15168 bytes from arc file; available packet space=786339376
21:09:20:WU00:FS00:0x11:trr file hash check passed.
21:09:20:WU00:FS00:0x11:Allocated 560 bytes for edr file
21:09:20:WU00:FS00:0x11:Read bedfile
21:09:20:WU00:FS00:0x11:edr file hash check passed.
21:09:20:WU00:FS00:0x11:Allocated 33560 bytes for logfile
21:09:20:WU00:FS00:0x11:Read logfile
21:09:20:WU00:FS00:0x11:GuardedRun: success in DynamicWrapper
21:09:20:WU00:FS00:0x11:GuardedRun: done
21:09:20:WU00:FS00:0x11:Run: GuardedRun completed.
21:09:23:WU00:FS00:0x11:+ Opened results file
21:09:23:WU00:FS00:0x11:- Writing 125720 bytes of core data to disk...
21:09:23:WU00:FS00:0x11:Done: 125208 -> 99441 (compressed to 79.4 percent)
21:09:23:WU00:FS00:0x11:  ... Done.
21:09:23:WU00:FS00:0x11:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
21:09:24:WU00:FS00:0x11:Shutting down core
21:09:24:WU00:FS00:0x11:Folding@home Core Shutdown: FINISHED_UNIT
21:09:24:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:09:24:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5765 run:8 clone:335 gen:1643 core:0x11 unit:0x7a683b384f2d802e066b014f00081685
21:09:24:WU00:FS00:Uploading 97.61KiB to 171.67.108.11
21:09:24:WU00:FS00:Connecting to 171.67.108.11:8080
21:09:24:WU01:FS00:Starting
21:09:24:WU01:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/**/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 01 -suffix 01 -version 701 -checkpoint 15 -gpu 0
21:09:24:WU01:FS00:Started FahCore on PID 1048
21:09:24:WU01:FS00:Core PID:1696
21:09:24:WU01:FS00:FahCore 0x11 started
21:09:25:WU01:FS00:0x11:*------------------------------*
21:09:25:WU01:FS00:0x11:Folding@Home GPU Core
21:09:25:WU01:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
21:09:25:WU01:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
21:09:25:WU01:FS00:0x11:Build host: amoeba
21:09:25:WU01:FS00:0x11:Board Type: Nvidia
21:09:25:WU01:FS00:0x11:Core      :
21:09:25:WU01:FS00:0x11:Preparing to commence simulation
21:09:25:WU01:FS00:0x11:- Looking at optimizations...
21:09:25:WU01:FS00:0x11:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
21:09:25:WU01:FS00:0x11:- Created dyn
21:09:25:WU01:FS00:0x11:- Files status OK
21:09:25:WU01:FS00:0x11:- Expanded 62860 -> 336799 (decompressed 535.7 percent)
21:09:25:WU01:FS00:0x11:Called DecompressByteArray: compressed_data_size=62860 data_size=336799, decompressed_data_size=336799 diff=0
21:09:25:WU01:FS00:0x11:- Digital signature verified
21:09:25:WU01:FS00:0x11:Project: 10503 (Run 141, Clone 0, Gen 442)
21:09:25:WU01:FS00:0x11:Assembly optimizations on if available.
21:09:31:WU01:FS00:0x11:Tpr hash 01/wudata_01.tpr:  1061793160 2684178100 1403494390 3304979594 2238594378
21:09:31:WU01:FS00:0x11:Calling fah_main args: 14 usage=100
21:09:31:WU01:FS00:0x11:Working on Protein
21:09:33:WU01:FS00:0x11:Client config unavailable.
21:09:33:WU01:FS00:0x11:Starting GUI Server
21:10:00:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:10:00:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5765 run:8 clone:335 gen:1643 core:0x11 unit:0x7a683b384f2d802e066b014f00081685
21:10:00:WU00:FS00:Uploading 97.61KiB to 171.67.108.11
21:10:00:WU00:FS00:Connecting to 171.67.108.11:8080
21:10:02:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:10:02:WU00:FS00:Trying to send results to collection server
21:10:02:WU00:FS00:Uploading 97.61KiB to 171.67.108.25
21:10:02:WU00:FS00:Connecting to 171.67.108.25:8080
21:10:32:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:11:00:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5765 run:8 clone:335 gen:1643 core:0x11 unit:0x7a683b384f2d802e066b014f00081685
21:11:00:WU00:FS00:Uploading 97.61KiB to 171.67.108.11
21:11:00:WU00:FS00:Connecting to 171.67.108.11:8080
21:11:02:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:11:02:WU00:FS00:Trying to send results to collection server
21:11:02:WU00:FS00:Uploading 97.61KiB to 171.67.108.25
21:11:02:WU00:FS00:Connecting to 171.67.108.25:8080
21:11:32:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:11:34:WU01:FS00:0x11:Completed 1%
21:12:37:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5765 run:8 clone:335 gen:1643 core:0x11 unit:0x7a683b384f2d802e066b014f00081685
21:12:37:WU00:FS00:Uploading 97.61KiB to 171.67.108.11
21:12:37:WU00:FS00:Connecting to 171.67.108.11:8080
21:12:40:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:12:40:WU00:FS00:Trying to send results to collection server
21:12:40:WU00:FS00:Uploading 97.61KiB to 171.67.108.25
21:12:40:WU00:FS00:Connecting to 171.67.108.25:8080
21:13:10:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:13:33:WU01:FS00:0x11:Completed 2%
21:15:15:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5765 run:8 clone:335 gen:1643 core:0x11 unit:0x7a683b384f2d802e066b014f00081685
21:15:15:WU00:FS00:Uploading 97.61KiB to 171.67.108.11
21:15:15:WU00:FS00:Connecting to 171.67.108.11:8080
21:15:17:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:15:17:WU00:FS00:Trying to send results to collection server
21:15:17:WU00:FS00:Uploading 97.61KiB to 171.67.108.25
21:15:17:WU00:FS00:Connecting to 171.67.108.25:8080
21:15:33:WU01:FS00:0x11:Completed 3%
21:15:47:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:17:35:WU01:FS00:0x11:Completed 4%
21:19:29:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5765 run:8 clone:335 gen:1643 core:0x11 unit:0x7a683b384f2d802e066b014f00081685
21:19:29:WU00:FS00:Uploading 97.61KiB to 171.67.108.11
21:19:29:WU00:FS00:Connecting to 171.67.108.11:8080
21:19:31:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:19:31:WU00:FS00:Trying to send results to collection server
21:19:31:WU00:FS00:Uploading 97.61KiB to 171.67.108.25
21:19:31:WU00:FS00:Connecting to 171.67.108.25:8080
21:19:35:WU01:FS00:0x11:Completed 5%
21:20:01:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:21:36:WU01:FS00:0x11:Completed 6%
21:23:34:WU01:FS00:0x11:Completed 7%
21:25:32:WU01:FS00:0x11:Completed 8%
21:26:20:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5765 run:8 clone:335 gen:1643 core:0x11 unit:0x7a683b384f2d802e066b014f00081685
21:26:20:WU00:FS00:Uploading 97.61KiB to 171.67.108.11
21:26:20:WU00:FS00:Connecting to 171.67.108.11:8080
21:26:26:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:26:26:WU00:FS00:Trying to send results to collection server
21:26:26:WU00:FS00:Uploading 97.61KiB to 171.67.108.25
21:26:26:WU00:FS00:Connecting to 171.67.108.25:8080
21:26:56:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:27:31:WU01:FS00:0x11:Completed 9%
21:29:29:WU01:FS00:0x11:Completed 10%
21:31:27:WU01:FS00:0x11:Completed 11%
21:33:17:WU02:FS01:0xa4:Completed 255000 out of 750000 steps  (34%)
21:33:25:WU01:FS00:0x11:Completed 12%
21:35:23:WU01:FS00:0x11:Completed 13%
21:37:22:WU01:FS00:0x11:Completed 14%
21:37:26:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5765 run:8 clone:335 gen:1643 core:0x11 unit:0x7a683b384f2d802e066b014f00081685
21:37:26:WU00:FS00:Uploading 97.61KiB to 171.67.108.11
21:37:26:WU00:FS00:Connecting to 171.67.108.11:8080
21:37:32:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:37:32:WU00:FS00:Trying to send results to collection server
21:37:32:WU00:FS00:Uploading 97.61KiB to 171.67.108.25
21:37:32:WU00:FS00:Connecting to 171.67.108.25:8080
21:38:02:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:39:19:WU01:FS00:0x11:Completed 15%
21:41:17:WU01:FS00:0x11:Completed 16%
21:43:14:WU01:FS00:0x11:Completed 17%
21:45:12:WU01:FS00:0x11:Completed 18%
21:47:09:WU01:FS00:0x11:Completed 19%
21:49:07:WU01:FS00:0x11:Completed 20%
21:51:04:WU01:FS00:0x11:Completed 21%
21:53:01:WU02:FS01:0xa4:Completed 262500 out of 750000 steps  (35%)
21:53:02:WU01:FS00:0x11:Completed 22%
21:54:59:WU01:FS00:0x11:Completed 23%
21:55:23:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5765 run:8 clone:335 gen:1643 core:0x11 unit:0x7a683b384f2d802e066b014f00081685
21:55:23:WU00:FS00:Uploading 97.61KiB to 171.67.108.11
21:55:23:WU00:FS00:Connecting to 171.67.108.11:8080
21:55:29:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
21:55:29:WU00:FS00:Trying to send results to collection server
21:55:29:WU00:FS00:Uploading 97.61KiB to 171.67.108.25
21:55:29:WU00:FS00:Connecting to 171.67.108.25:8080
21:55:59:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:56:57:WU01:FS00:0x11:Completed 24%
21:58:54:WU01:FS00:0x11:Completed 25%
22:00:52:WU01:FS00:0x11:Completed 26%
22:02:49:WU01:FS00:0x11:Completed 27%
22:04:47:WU01:FS00:0x11:Completed 28%
22:06:45:WU01:FS00:0x11:Completed 29%
22:08:42:WU01:FS00:0x11:Completed 30%
22:10:40:WU01:FS00:0x11:Completed 31%
22:12:07:WU02:FS01:0xa4:Completed 270000 out of 750000 steps  (36%)
22:12:37:WU01:FS00:0x11:Completed 32%
22:14:35:WU01:FS00:0x11:Completed 33%
22:16:32:WU01:FS00:0x11:Completed 34%
22:18:30:WU01:FS00:0x11:Completed 35%
22:20:27:WU01:FS00:0x11:Completed 36%
22:22:25:WU01:FS00:0x11:Completed 37%
22:24:22:WU01:FS00:0x11:Completed 38%
22:24:25:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5765 run:8 clone:335 gen:1643 core:0x11 unit:0x7a683b384f2d802e066b014f00081685
22:24:25:WU00:FS00:Uploading 97.61KiB to 171.67.108.11
22:24:25:WU00:FS00:Connecting to 171.67.108.11:8080
22:24:31:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
22:24:31:WU00:FS00:Trying to send results to collection server
22:24:31:WU00:FS00:Uploading 97.61KiB to 171.67.108.25
22:24:31:WU00:FS00:Connecting to 171.67.108.25:8080
22:25:01:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
These exceptions are still appearing in the log file.
SKeptical_Thinker
EVGA 8800 GS
Ninja Mini CPU HS
Re: 171.67.108.11
This is still going on and it appears that uploading has become intermittent or has stopped altogther:
09:20:58:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:5769 run:3 clone:17 gen:637 core:0x11 unit:0x6c64d63d4f2de859027d001100031689
09:20:58:WU01:FS00:Uploading 97.51KiB to 171.67.108.11
09:20:58:WU01:FS00:Connecting to 171.67.108.11:8080
09:20:58:WU05:FS00:Sending unit results: id:05 state:SEND error:OK project:5770 run:5 clone:48 gen:396 core:0x11 unit:0x6863efc64f2e204f018c00300005168a
09:20:58:WU05:FS00:Uploading 97.42KiB to 171.67.108.11
09:20:58:WU05:FS00:Connecting to 171.67.108.11:8080
09:20:58:WU04:FS00:Sending unit results: id:04 state:SEND error:OK project:5768 run:0 clone:246 gen:464 core:0x11 unit:0x43c704eb4f2e044a01d000f600001688
09:20:59:WU04:FS00:Uploading 97.52KiB to 171.67.108.11
09:20:59:WU04:FS00:Connecting to 171.67.108.11:8080
09:20:59:WU07:FS00:Sending unit results: id:07 state:SEND error:OK project:5767 run:3 clone:217 gen:918 core:0x11 unit:0x4044309a4f2e582a039600d900031687
09:20:59:WU07:FS00:Uploading 97.26KiB to 171.67.108.11
09:20:59:WU07:FS00:Connecting to 171.67.108.11:8080
09:20:59:WU08:FS00:Sending unit results: id:08 state:SEND error:OK project:5767 run:3 clone:57 gen:829 core:0x11 unit:0x0e1ab3ac4f2e742d033d003900031687
09:20:59:WU08:FS00:Uploading 97.50KiB to 171.67.108.11
09:20:59:WU08:FS00:Connecting to 171.67.108.11:8080
09:21:01:WARNING:WU05:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
09:21:01:WU05:FS00:Trying to send results to collection server
09:21:01:WU05:FS00:Uploading 97.42KiB to 171.67.108.25
09:21:01:WU05:FS00:Connecting to 171.67.108.25:8080
09:21:02:WARNING:WU04:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
09:21:02:WU04:FS00:Trying to send results to collection server
09:21:02:WU04:FS00:Uploading 97.52KiB to 171.67.108.25
09:21:02:WU04:FS00:Connecting to 171.67.108.25:8080
09:21:03:WARNING:WU07:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
09:21:03:WU07:FS00:Trying to send results to collection server
09:21:03:WU07:FS00:Uploading 97.26KiB to 171.67.108.25
09:21:03:WU07:FS00:Connecting to 171.67.108.25:8080
09:21:04:WARNING:WU08:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
09:21:04:WU08:FS00:Trying to send results to collection server
09:21:04:WU08:FS00:Uploading 97.50KiB to 171.67.108.25
09:21:04:WU08:FS00:Connecting to 171.67.108.25:8080
09:21:05:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
09:21:05:WU01:FS00:Trying to send results to collection server
09:21:05:WU01:FS00:Uploading 97.51KiB to 171.67.108.25
09:21:05:WU01:FS00:Connecting to 171.67.108.25:8080
09:21:33:ERROR:WU05:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
09:21:33:WU06:FS00:Sending unit results: id:06 state:SEND error:OK project:5769 run:10 clone:98 gen:572 core:0x11 unit:0x248b1de84f2e3c3e023c0062000a1689
09:21:33:WU06:FS00:Uploading 97.43KiB to 171.67.108.11
09:21:33:ERROR:WU07:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
09:21:33:WU06:FS00:Connecting to 171.67.108.11:8080
09:21:34:ERROR:WU04:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
09:21:34:ERROR:WU08:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
09:21:35:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
09:21:35:WARNING:WU06:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
09:21:35:WU06:FS00:Trying to send results to collection server
09:21:35:WU06:FS00:Uploading 97.43KiB to 171.67.108.25
09:21:35:WU06:FS00:Connecting to 171.67.108.25:8080
09:22:05:ERROR:WU06:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
09:22:16:WU02:FS01:0xa4:Completed 160000 out of 250000 steps  (64%)
09:26:54:WU02:FS01:0xa4:Completed 162500 out of 250000 steps  (65%)
09:31:38:WU02:FS01:0xa4:Completed 165000 out of 250000 steps  (66%)
09:36:17:WU02:FS01:0xa4:Completed 167500 out of 250000 steps  (67%)
09:41:02:WU02:FS01:0xa4:Completed 170000 out of 250000 steps  (68%)
09:45:41:WU02:FS01:0xa4:Completed 172500 out of 250000 steps  (69%)
09:50:26:WU02:FS01:0xa4:Completed 175000 out of 250000 steps  (70%)
09:55:04:WU02:FS01:0xa4:Completed 177500 out of 250000 steps  (71%)
09:59:43:WU02:FS01:0xa4:Completed 180000 out of 250000 steps  (72%)
10:04:29:WU02:FS01:0xa4:Completed 182500 out of 250000 steps  (73%)
10:09:11:WU02:FS01:0xa4:Completed 185000 out of 250000 steps  (74%)
10:13:56:WU02:FS01:0xa4:Completed 187500 out of 250000 steps  (75%)
10:18:39:WU02:FS01:0xa4:Completed 190000 out of 250000 steps  (76%)
******************************** Date: 06/02/12 ********************************
10:23:27:WU02:FS01:0xa4:Completed 192500 out of 250000 steps  (77%)
10:28:09:WU02:FS01:0xa4:Completed 195000 out of 250000 steps  (78%)
10:32:56:WU02:FS01:0xa4:Completed 197500 out of 250000 steps  (79%)
10:37:40:WU02:FS01:0xa4:Completed 200000 out of 250000 steps  (80%)
10:42:27:WU02:FS01:0xa4:Completed 202500 out of 250000 steps  (81%)
10:47:08:WU02:FS01:0xa4:Completed 205000 out of 250000 steps  (82%)
10:51:56:WU02:FS01:0xa4:Completed 207500 out of 250000 steps  (83%)
10:56:37:WU02:FS01:0xa4:Completed 210000 out of 250000 steps  (84%)
11:01:24:WU02:FS01:0xa4:Completed 212500 out of 250000 steps  (85%)
11:06:08:WU02:FS01:0xa4:Completed 215000 out of 250000 steps  (86%)
11:10:55:WU02:FS01:0xa4:Completed 217500 out of 250000 steps  (87%)
11:15:38:WU02:FS01:0xa4:Completed 220000 out of 250000 steps  (88%)
11:20:26:WU02:FS01:0xa4:Completed 222500 out of 250000 steps  (89%)
11:25:09:WU02:FS01:0xa4:Completed 225000 out of 250000 steps  (90%)
11:29:53:WU02:FS01:0xa4:Completed 227500 out of 250000 steps  (91%)
11:34:42:WU02:FS01:0xa4:Completed 230000 out of 250000 steps  (92%)
11:39:24:WU02:FS01:0xa4:Completed 232500 out of 250000 steps  (93%)
11:44:12:WU02:FS01:0xa4:Completed 235000 out of 250000 steps  (94%)
11:48:54:WU02:FS01:0xa4:Completed 237500 out of 250000 steps  (95%)
11:53:46:WU02:FS01:0xa4:Completed 240000 out of 250000 steps  (96%)
11:58:37:WU02:FS01:0xa4:Completed 242500 out of 250000 steps  (97%)
12:06:45:WU02:FS01:0xa4:Completed 245000 out of 250000 steps  (98%)
12:14:55:WU02:FS01:0xa4:Completed 247500 out of 250000 steps  (99%)
12:14:56:WU00:FS01:Connecting to assign3.stanford.edu:8080
12:14:56:WU00:FS01:News: Welcome to Folding@Home
12:14:56:WU00:FS01:Assigned to work server 171.64.65.99
12:14:56:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:2 from 171.64.65.99
12:14:56:WU00:FS01:Connecting to 171.64.65.99:8080
12:14:58:WU00:FS01:Downloading 1.96MiB
12:15:03:WU00:FS01:Download complete
12:15:03:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:OK project:7808 run:4 clone:446 gen:23 core:0xa4 unit:0x000000250a3b1e874e30f988b912dffa
12:15:03:WU00:FS01:Downloading project 7808 description
12:15:03:WU00:FS01:Connecting to fah-web.stanford.edu:80
12:15:07:WU00:FS01:Project 7808 description downloaded successfully
12:21:31:WU02:FS01:0xa4:Completed 250000 out of 250000 steps  (100%)
12:21:32:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
12:21:42:WU02:FS01:0xa4:
12:21:42:WU02:FS01:0xa4:Finished Work Unit:
12:21:42:WU02:FS01:0xa4:- Reading up to 801456 from "02/wudata_01.trr": Read 801456
12:21:42:WU02:FS01:0xa4:trr file hash check passed.
12:21:42:WU02:FS01:0xa4:- Reading up to 475440 from "02/wudata_01.xtc": Read 475440
12:21:42:WU02:FS01:0xa4:xtc file hash check passed.
12:21:42:WU02:FS01:0xa4:edr file hash check passed.
12:21:42:WU02:FS01:0xa4:logfile size: 24069
12:21:42:WU02:FS01:0xa4:Leaving Run
12:21:42:WU02:FS01:0xa4:- Writing 1306369 bytes of core data to disk...
12:21:43:WU02:FS01:0xa4:Done: 1305857 -> 1243886 (compressed to 95.2 percent)
12:21:43:WU02:FS01:0xa4:  ... Done.
12:21:43:WU02:FS01:0xa4:- Shutting down core
12:21:43:WU02:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
12:21:44:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:21:44:WU02:FS01:Sending unit results: id:02 state:SEND error:OK project:8011 run:1 clone:1607 gen:43 core:0xa4 unit:0x0000004a6652edcc4efd7b5da5d2e654
12:21:44:WU02:FS01:Uploading 1.19MiB to 171.67.108.60
12:21:44:WU02:FS01:Connecting to 171.67.108.60:8080
12:21:44:WU00:FS01:Starting
12:21:44:WU00:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/Matthew L. Martin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 701 -checkpoint 15 -np 2
12:21:45:WU00:FS01:Started FahCore on PID 2760
12:21:45:WU00:FS01:Core PID:1440
12:21:45:WU00:FS01:FahCore 0xa4 started
12:21:45:WU00:FS01:0xa4:
12:21:45:WU00:FS01:0xa4:*------------------------------*
12:21:45:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
12:21:45:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
12:21:45:WU00:FS01:0xa4:Preparing to commence simulation
12:21:45:WU00:FS01:0xa4:- Looking at optimizations...
12:21:45:WU00:FS01:0xa4:- Created dyn
12:21:45:WU00:FS01:0xa4:- Files status OK
12:21:45:WU00:FS01:0xa4:- Expanded 2053992 -> 5365960 (decompressed 261.2 percent)
12:21:45:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2053992 data_size=5365960, decompressed_data_size=5365960 diff=0
12:21:45:WU00:FS01:0xa4:- Digital signature verified
12:21:45:WU00:FS01:0xa4:Project: 7808 (Run 4, Clone 446, Gen 23)
12:21:46:WU00:FS01:0xa4:Assembly optimizations on if available.
12:21:46:WU00:FS01:0xa4:Entering M.D.
12:21:50:WU02:FS01:Upload 42.13%
12:21:52:WU00:FS01:0xa4:Mapping NT from 2 to 2
12:21:53:WU00:FS01:0xa4:Completed 0 out of 1500000 steps  (0%)
12:21:56:WU02:FS01:Upload 84.26%
12:22:03:WU02:FS01:Upload complete
12:22:03:WU02:FS01:Server responded WORK_ACK (400)
12:22:03:WU02:FS01:Final credit estimate, 338.00 points
12:22:03:WU02:FS01:Cleaning up
13:22:27:WU00:FS01:0xa4:Completed 15000 out of 1500000 steps  (1%)
14:23:01:WU00:FS01:0xa4:Completed 30000 out of 1500000 steps  (2%)
14:42:58:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:5769 run:3 clone:17 gen:637 core:0x11 unit:0x6c64d63d4f2de859027d001100031689
14:42:58:WU01:FS00:Uploading 97.51KiB to 171.67.108.11
14:42:58:WU01:FS00:Connecting to 171.67.108.11:8080
14:42:58:WU05:FS00:Sending unit results: id:05 state:SEND error:OK project:5770 run:5 clone:48 gen:396 core:0x11 unit:0x6863efc64f2e204f018c00300005168a
14:42:58:WU05:FS00:Uploading 97.42KiB to 171.67.108.11
14:42:58:WU05:FS00:Connecting to 171.67.108.11:8080
14:42:58:WU04:FS00:Sending unit results: id:04 state:SEND error:OK project:5768 run:0 clone:246 gen:464 core:0x11 unit:0x43c704eb4f2e044a01d000f600001688
14:42:58:WU04:FS00:Uploading 97.52KiB to 171.67.108.11
14:42:58:WU04:FS00:Connecting to 171.67.108.11:8080
14:42:59:WU07:FS00:Sending unit results: id:07 state:SEND error:OK project:5767 run:3 clone:217 gen:918 core:0x11 unit:0x4044309a4f2e582a039600d900031687
14:42:59:WU07:FS00:Uploading 97.26KiB to 171.67.108.11
14:42:59:WU07:FS00:Connecting to 171.67.108.11:8080
14:42:59:WU08:FS00:Sending unit results: id:08 state:SEND error:OK project:5767 run:3 clone:57 gen:829 core:0x11 unit:0x0e1ab3ac4f2e742d033d003900031687
14:42:59:WU08:FS00:Uploading 97.50KiB to 171.67.108.11
14:42:59:WU08:FS00:Connecting to 171.67.108.11:8080
14:43:01:WARNING:WU05:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
14:43:01:WU05:FS00:Trying to send results to collection server
14:43:01:WU05:FS00:Uploading 97.42KiB to 171.67.108.25
14:43:01:WU05:FS00:Connecting to 171.67.108.25:8080
14:43:02:WARNING:WU04:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
14:43:02:WU04:FS00:Trying to send results to collection server
14:43:02:WU04:FS00:Uploading 97.52KiB to 171.67.108.25
14:43:02:WU04:FS00:Connecting to 171.67.108.25:8080
14:43:03:WARNING:WU07:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
14:43:03:WU07:FS00:Trying to send results to collection server
14:43:03:WU07:FS00:Uploading 97.26KiB to 171.67.108.25
14:43:03:WU07:FS00:Connecting to 171.67.108.25:8080
14:43:04:WARNING:WU08:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
14:43:04:WU08:FS00:Trying to send results to collection server
14:43:04:WU08:FS00:Uploading 97.50KiB to 171.67.108.25
14:43:04:WU08:FS00:Connecting to 171.67.108.25:8080
14:43:05:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
14:43:05:WU01:FS00:Trying to send results to collection server
14:43:05:WU01:FS00:Uploading 97.51KiB to 171.67.108.25
14:43:05:WU01:FS00:Connecting to 171.67.108.25:8080
14:43:33:ERROR:WU07:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
14:43:33:WU06:FS00:Sending unit results: id:06 state:SEND error:OK project:5769 run:10 clone:98 gen:572 core:0x11 unit:0x248b1de84f2e3c3e023c0062000a1689
14:43:33:WU06:FS00:Uploading 97.43KiB to 171.67.108.11
14:43:33:WU06:FS00:Connecting to 171.67.108.11:8080
14:43:34:ERROR:WU04:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
14:43:34:ERROR:WU08:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
14:43:35:WARNING:WU06:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
14:43:35:WU06:FS00:Trying to send results to collection server
14:43:35:WU06:FS00:Uploading 97.43KiB to 171.67.108.25
14:43:35:WU06:FS00:Connecting to 171.67.108.25:8080
14:43:35:ERROR:WU05:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
14:43:35:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
14:44:05:ERROR:WU06:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
15:23:38:WU00:FS01:0xa4:Completed 45000 out of 1500000 steps  (3%)
16:24:15:WU00:FS01:0xa4:Completed 60000 out of 1500000 steps  (4%)
17:24:49:WU00:FS01:0xa4:Completed 75000 out of 1500000 steps  (5%)
18:25:27:WU00:FS01:0xa4:Completed 90000 out of 1500000 steps  (6%)
19:25:59:WU00:FS01:0xa4:Completed 105000 out of 1500000 steps  (7%)
20:26:37:WU00:FS01:0xa4:Completed 120000 out of 1500000 steps  (8%)
20:42:58:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:5769 run:3 clone:17 gen:637 core:0x11 unit:0x6c64d63d4f2de859027d001100031689
20:42:58:WU01:FS00:Uploading 97.51KiB to 171.67.108.11
20:42:58:WU01:FS00:Connecting to 171.67.108.11:8080
20:42:58:WU05:FS00:Sending unit results: id:05 state:SEND error:OK project:5770 run:5 clone:48 gen:396 core:0x11 unit:0x6863efc64f2e204f018c00300005168a
20:42:58:WU05:FS00:Uploading 97.42KiB to 171.67.108.11
20:42:58:WU05:FS00:Connecting to 171.67.108.11:8080
20:42:59:WU04:FS00:Sending unit results: id:04 state:SEND error:OK project:5768 run:0 clone:246 gen:464 core:0x11 unit:0x43c704eb4f2e044a01d000f600001688
20:42:59:WU04:FS00:Uploading 97.52KiB to 171.67.108.11
20:42:59:WU04:FS00:Connecting to 171.67.108.11:8080
20:42:59:WU07:FS00:Sending unit results: id:07 state:SEND error:OK project:5767 run:3 clone:217 gen:918 core:0x11 unit:0x4044309a4f2e582a039600d900031687
20:42:59:WU07:FS00:Uploading 97.26KiB to 171.67.108.11
20:42:59:WU07:FS00:Connecting to 171.67.108.11:8080
20:42:59:WU08:FS00:Sending unit results: id:08 state:SEND error:OK project:5767 run:3 clone:57 gen:829 core:0x11 unit:0x0e1ab3ac4f2e742d033d003900031687
20:42:59:WU08:FS00:Uploading 97.50KiB to 171.67.108.11
20:42:59:WU08:FS00:Connecting to 171.67.108.11:8080
20:43:01:WARNING:WU05:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
20:43:01:WU05:FS00:Trying to send results to collection server
20:43:01:WU05:FS00:Uploading 97.42KiB to 171.67.108.25
20:43:01:WU05:FS00:Connecting to 171.67.108.25:8080
20:43:02:WARNING:WU04:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
20:43:02:WU04:FS00:Trying to send results to collection server
20:43:02:WU04:FS00:Uploading 97.52KiB to 171.67.108.25
20:43:02:WU04:FS00:Connecting to 171.67.108.25:8080
20:43:03:WARNING:WU07:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
20:43:03:WU07:FS00:Trying to send results to collection server
20:43:03:WU07:FS00:Uploading 97.26KiB to 171.67.108.25
20:43:03:WU07:FS00:Connecting to 171.67.108.25:8080
20:43:04:WARNING:WU08:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
20:43:04:WU08:FS00:Trying to send results to collection server
20:43:04:WU08:FS00:Uploading 97.50KiB to 171.67.108.25
20:43:04:WU08:FS00:Connecting to 171.67.108.25:8080
20:43:05:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
20:43:05:WU01:FS00:Trying to send results to collection server
20:43:05:WU01:FS00:Uploading 97.51KiB to 171.67.108.25
20:43:05:WU01:FS00:Connecting to 171.67.108.25:8080
20:43:33:ERROR:WU07:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:43:33:WU06:FS00:Sending unit results: id:06 state:SEND error:OK project:5769 run:10 clone:98 gen:572 core:0x11 unit:0x248b1de84f2e3c3e023c0062000a1689
20:43:33:WU06:FS00:Uploading 97.43KiB to 171.67.108.11
20:43:33:WU06:FS00:Connecting to 171.67.108.11:8080
20:43:34:ERROR:WU05:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:43:34:ERROR:WU08:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:43:35:WARNING:WU06:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
20:43:35:WU06:FS00:Trying to send results to collection server
20:43:35:WU06:FS00:Uploading 97.43KiB to 171.67.108.25
20:43:35:ERROR:WU04:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:43:35:WU06:FS00:Connecting to 171.67.108.25:8080
20:43:35:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:44:05:ERROR:WU06:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
Re: 171.67.108.11
There is another thread about 512 KB WUs. IIRC, they said delete the WUs and move on, but you should double check that is still the current recommendation...
