When I went to bed last night the below SMP WU was around 98% complete. I must have been really creamed I left the PC on,
Fortunately I had backed up both WUs I'm currently processing, therefore I restored Project: 2653 (Run 12, Clone 198, Gen 94) which left here complete at 05:37, I know for a fact I've seen two FAH stats updates with no addition to my team score.
Can I assume from that I've lost it now
Cheers *hondo*
[22:56:28] Project: 2653 (Run 12, Clone 198, Gen 94)
[22:56:28]
[22:56:30] Entering M.D.
[22:56:36] Calling FAH init
[22:56:37] in POPC
[22:56:37] Writing local files
[22:56:37] Completed 499359 out of 500000 steps (99 percent)
[22:56:37] PC
[22:56:38] Extra SSE boost OK.
[22:58:38] Writing local files
[22:58:39] Completed 500000 out of 500000 steps (100 percent)
[22:58:39] Writing final coordinates.
[22:58:40] Past main M.D. loop
[22:58:40] Will end MPI now
--- Opening Log file [April 12 05:30:21]
# SMP Client ##################################################################
Folding@Home Client Version 5.91beta6
http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home Windows SMP Client V1.01
Executable: C:\Program Files\Folding@Home Windows SMP Client V1.01\fah.exe
[05:30:21] - Ask before connecting: No
[05:30:21] - Use IE connection settings: Yes
[05:30:21] - User name: *hondo* (Team 51078)
[05:30:21] - User ID: 113681DD64663A1A
[05:30:21] - Machine ID: 1
[05:30:21]
[05:30:22] Loaded queue successfully.
[05:30:22]
[05:30:22] + Processing work unit
[05:30:22] Core required: FahCore_a1.exe
[05:30:22] Core found.
[05:30:22] Working on Unit 06 [April 12 05:30:22]
[05:30:22] + Working ...
[05:30:22]
[05:30:22] *------------------------------*
[05:30:22] Folding@Home Gromacs SMP Core
[05:30:22] Version 1.74 (March 10, 2007)
[05:30:22]
[05:30:22] Preparing to commence simulation
[05:30:22] - Ensuring status. Please wait.
[05:30:39] - User disabled assembly optimizations.
[05:30:39] Examination of work files indicates 8 consecutive improper terminations of core.
[05:30:43] - Expanded 2434288 -> 12912405 (decompressed 530.4 percent)
[05:30:44]
[05:30:44] Project: 2653 (Run 12, Clone 198, Gen 94)
[05:30:44]
[05:30:45] Entering M.D.
[05:30:51] Calling FAH init
[05:30:52] Read topology
[05:30:52] g local files
[05:30:52] Completed 500000 out of 500000 steps (100 percent)
[05:30:52] Extra SSE boost OK.
[05:30:52] s
[05:30:53] Extra SSE boost OK.
[05:30:53] Writing final coordinates.
[05:30:54] Past main M.D. loop
[05:30:54] Will end MPI now
[05:31:54]
[05:31:54] Finished Work Unit:
[05:31:54] - Reading up to 3726624 from "work/wudata_06.arc": Read 3726624
[05:31:54] - Reading up to 1946640 from "work/wudata_06.xtc": Read 1946640
[05:31:54] goefile size: 0
[05:31:54] logfile size: 59258
[05:31:54] Leaving Run
[05:31:55] - Writing 5738170 bytes of core data to disk...
[05:31:55] ... Done.
[05:31:55] - Failed to delete work/wudata_06.sas
[05:31:55] - Failed to delete work/wudata_06.goe
[05:31:55] Warning: check for stray files
[05:31:55] - Shutting down core
[05:33:55]
[05:33:55] Folding@home Core Shutdown: FINISHED_UNIT
[05:33:55]
[05:34:02] CoreStatus = 64 (100)
[05:34:02] Sending work to server
[05:34:02] + Attempting to send results
[05:37:10] + Results successfully sent
[05:37:10] Thank you for your contribution to Folding@Home.
[05:37:10] + Number of Units Completed: 28
