Did my PC screw this WU
*hondo*
Hardware configuration: Geoforce 250 GTS Active for F@H
4 Core Intel not used at all for F@H
Post by *hondo* »
Hi :) Did my PC screw this WU at 23:46:33 am I wasting time carrying on with it?
Any feed back would be great
Thanks
23:45:29] Working on queue slot 04 [January 31 23:45:29 UTC]
[23:45:29] + Working ...
[23:45:29]
[23:45:29] *------------------------------*
[23:45:29] Folding@Home Gromacs SMP Core
[23:45:29] Version 2.27 (Dec. 15, 2010)
[23:45:29]
[23:45:29] Preparing to commence simulation
[23:45:29] - Ensuring status. Please wait.
[23:45:38] - Looking at optimizations...
[23:45:38] - Working with standard loops on this execution.
[23:45:38] - Previous termination of core was improper.
[23:45:38] - Going to use standard loops.
[23:45:38] - Files status OK
[23:45:39] - Expanded 785909 -> 1456592 (decompressed 185.3 percent)
[23:45:39] Called DecompressByteArray: compressed_data_size=785909 data_size=1456592, decompressed_data_size=1456592 diff=0
[23:45:39] - Digital signature verified
[23:45:39]
[23:45:39] Project: 10128 (Run 6, Clone 0, Gen 53)
[23:45:39]
[23:45:39] Entering M.D.
[23:45:45] Using Gromacs checkpoints
[23:45:45] Mapping NT from 4 to 4
[23:45:45] Resuming from checkpoint
[23:45:45] Verified work/wudata_04.log
[23:45:45] Verified work/wudata_04.trr
[23:45:45] Verified work/wudata_04.xtc
[23:45:45] Verified work/wudata_04.edr
[23:45:45] Completed 868932 out of 2000000 steps  (43%)
[23:46:33] CoreStatus = C0000005 (-1073741819)
[b][23:46:33] Client-core communications error: Did my PC scew this WU
[23:46:33] Deleting current work unit & continuing...[/b]
Folding@Home Client Shutdown at user request.
Folding@Home Client Shutdown.
--- Opening Log file [February 1 13:42:35 UTC]
                       Folding@Home Client Version 6.34
                          http://folding.stanford.edu
Launch directory: C:\FAH
Executable: C:\FAH\FAH6.exe -smp.exe
Arguments: -smp
[13:42:35] - Ask before connecting: No
[13:42:35] - User name: *hondo* (Team 51078)
[13:42:35] - User ID: 3DA18C29517EB049
[13:42:35] - Machine ID: 4
[13:42:35]
[13:42:35] Loaded queue successfully.
[13:42:35]
[13:42:35] + Processing work unit
[13:42:35] Core required: FahCore_a3.exe
[13:42:35] Core found.
[13:42:35] Working on queue slot 04 [February 1 13:42:35 UTC]
[13:42:35] + Working ...
[13:42:37]
[13:42:37] *------------------------------*
[13:42:37] Folding@Home Gromacs SMP Core
[13:42:37] Version 2.27 (Dec. 15, 2010)
[13:42:37]
[13:42:37] Preparing to commence simulation
[13:42:37] - Looking at optimizations...
[13:42:37] - Files status OK
[13:42:37] - Expanded 785909 -> 1456592 (decompressed 185.3 percent)
[13:42:37] Called DecompressByteArray: compressed_data_size=785909 data_size=1456592, decompressed_data_size=1456592 diff=0
[13:42:37] - Digital signature verified
[13:42:37]
[13:42:37] Project: 10128 (Run 6, Clone 0, Gen 53)
[13:42:37]
[13:42:37] Assembly optimizations on if available.
[13:42:37] Entering M.D.
[13:42:43] Using Gromacs checkpoints
[13:42:44] Mapping NT from 4 to 4
[13:42:44] Resuming from checkpoint
[13:42:44] Verified work/wudata_04.log
[13:42:44] Verified work/wudata_04.trr
[13:42:44] Verified work/wudata_04.xtc
[13:42:44] Verified work/wudata_04.edr
[13:42:44] Completed 868932 out of 2000000 steps  (43%)
[13:48:05] Completed 880000 out of 2000000 steps  (44%)
[13:58:36] Completed 900000 out of 2000000 steps  (45%)
[14:08:36] Completed 920000 out of 2000000 steps  (46%)
[14:18:34] Completed 940000 out of 2000000 steps  (47%)
[14:28:40] Completed 960000 out of 2000000 steps  (48%)
[14:38:32] Completed 980000 out of 2000000 steps  (49%)
[14:49:27] Completed 1000000 out of 2000000 steps  (50%)
[14:59:27] Completed 1020000 out of 2000000 steps  (51%)
[15:09:23] Completed 1040000 out of 2000000 steps  (52%)
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Re: Did my PC screw this WU
Post by MtM »
As you noticed the work unit resumed from checkpoint so it's not 'screwed' at all.
If you would like, posting the log between [code][/code] tags makes the forum look cleaner.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
http://fahwiki.net/index.php/CoreStatus_codes#C0000005 but careful because the information on that page could be outdated.
Still accurate. Wouldn't hurt to double chech proper memory settings and run it through memtest
*hondo*
Post by *hondo* »
Thank you both, MtM yes, I agree with you, I couldn't figure out from where it appeared to go wrong, I fully expected to be starting from zero % but decided to consult with you guys I wasn't sure if I should delete or leave well alone, I'm glad I left it now.
Jeese_v Thanks for the link some interesting stuff in there, I'm rather concerned about the line below the PC is little more than 3 months old
It can also be caused by faulty memory or a bad memory controller, so you should consider both possibilities.
Thanks very much again Guys.
*hondo*
Post by *hondo* »
7im wrote:Still accurate. Wouldn't hurt to double chech proper memory settings and run it through memtest
Thanks 7im how long would you suggest to run memtest for? TBH this PC has given me a few headaches but not so far enough to take it back, in the main the issues have related to the PC not picking up USB devices which means I need to plug out and return after which all is fine, annoyingly this doesn't happen all the time. Also I get the odd BSOD I could do with getting this sorted once and for all, are you aware of any freebie software that would test out the whole PC?
Thanks hondo
MtM
Post by MtM »
Isn't
printed only in the scenario that the wu 'failed' after the user quit the client ( in which case the client would stop the core which in this case isn't working nicely so you get a client-core communication error ). However since it can resume from checkpoint unless you happen to stop the client when its actually writing a checkpoint, this is a 'cosmetic' issue? It's an old core look at the last update time, it doesn't exit cleanly. Not that it would ever hurt anything except time to fold wu's if you're not sure and want to rule some hw problem out.
*hondo*
Post by *hondo* »
MtM I happened to be looking at the WU in progress immediately I saw the error I closed the WU down, because I wanted to complete a virgin windows install I copied the FAH folder to a USB stick and pasted this file back into C:/ after the install was completed, I was very surprised when I realised the client carried on from where it left off, I was fully expecting a complete new WU :)
MtM
Post by MtM »
Ok that explains the exit messages right after the core status. Then, disregard the above statement ;)
Interesting: You did complete it successfully.
Hi *hondo* (team 51078),
Your WU (P10128 R6 C0 G53) was added to the stats database on 2012-02-01 16:10:02 for 5445.58 points of credit.
*hondo*
Post by *hondo* »
Thanx Bruce, I didn't know that you had posted a reply, however you're bang on the nail, just checked it out on EOC it went up while I was sleeping last night.
I was about to feed this info back to the Guys on here, but you beat me to it. :)
Thank the Lord I wasn't too tempted to delete the WU before mentioning it on here first.
Thanks Guys once again
