is down loaded & freezes at the same spot. Have also deleted cores to force the Client to grab new ones, Card is a Geforce 9800GTX+
here's the tail end of the log
04:52:56] + Processing work unit
[04:52:56] Core required: FahCore_11.exe
[04:52:56] Core found.
[04:52:56] Working on queue slot 01 [January 29 04:52:56 UTC]
[04:52:56] + Working ...
[04:52:56]
[04:52:56] *------------------------------*
[04:52:56] Folding@Home GPU Core
[04:52:56] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:52:56]
[04:52:56] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:52:56] Build host: amoeba
[04:52:56] Board Type: Nvidia
[04:52:56] Core :
[04:52:56] Preparing to commence simulation
[04:52:56] - Looking at optimizations...
[04:52:56] - Files status OK
[04:52:56] - Expanded 62884 -> 336799 (decompressed 535.5 percent)
[04:52:56] Called DecompressByteArray: compressed_data_size=62884 data_size=336799, decompressed_data_size=336799 diff=0
[04:52:56] - Digital signature verified
[04:52:56]
[04:52:56] Project: 10503 (Run 125, Clone 0, Gen 229)
[04:52:56]
[04:52:57] Assembly optimizations on if available.
[04:52:57] Entering M.D.
Reading file work/wudata_01.tpr, VERSION 3.1.4 (single precision)
Reading sasa-enabled ir 0 0
Initializing Nvidia gpu library
[04:53:03] Tpr hash work/wudata_01.tpr: 2945865243 2149262024 577597960 968175448 1759220863
[04:53:04]
[04:53:04] Calling fah_main args: 14 usage=100
[04:53:04]
