Project 6097 - base points?
Simba123
Post by Simba123 »
Currently running Project: 6097 (Run 0, Clone 99, Gen 62)
I looked in the project page but it's not listed there. I'm wondering what it's
base points is and how many atoms are involved.
So far at 31% on a 4.5 Ghz i7-2600k it has a 7:11 tpf so I'm
assuming it's a big-ish one.
cheers
Re: Project 6097 - base points?
You can find information here in the Beta Forum (viewtopic.php?f=66&t=19799). Out of curiosity, are you using any beta team flags?
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Post by artoar_11 »
PantherX wrote:You can find information here in the Beta Forum (viewtopic.php?f=66&t=19799). Out of curiosity, are you using any beta team flags?
From several days I receive 6097 (98/99) with normal flags (Win/Linux). From the Project Summary been removed :)
http://www.linuxforge.net/bonuscalc2.php
