Project: 6903 (Run 5, Clone 23, Gen 7)
tear
Hardware configuration: None
Post by tear »
I picked a small WU which was tagged as P6903 (FahCore, instead of starting, leaks memory until all memory is exhausted).
[16:51:35] Sent data
[16:51:35] Connecting to http://130.237.232.237:8080/
[16:51:37] Posted data.
[16:51:37] Initial: 0000; - Receiving payload (expected size: 1652190)
[16:51:53] - Downloaded at ~100 kB/s
[16:51:53] - Averaged speed for that direction ~660 kB/s
[16:51:53] + Received work.
[16:51:53] + Closed connections
[16:51:53]
[16:51:53] + Processing work unit
[16:51:53] Core required: FahCore_a5.exe
[16:51:53] Core found.
[16:51:53] Working on queue slot 05 [January 17 16:51:53 UTC]
[16:51:53] + Working ...
[16:51:53] - Calling './FahCore_a5.exe -dir work/ -nice 19 -suffix 05 -np 48 -checkpoint 15 -forceasm -verbose -lifeline 26280 -version 634'
[16:51:53]
[16:51:53] *------------------------------*
[16:51:53] Folding@Home Gromacs SMP Core
[16:51:53] Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
[16:51:53]
[16:51:53] Preparing to commence simulation
[16:51:53] - Assembly optimizations manually forced on.
[16:51:53] - Not checking prior termination.
[16:51:53] - Expanded 1651678 -> 12713984 (decompressed 769.7 percent)
[16:51:53] Called DecompressByteArray: compressed_data_size=1651678 data_size=12713984, decompressed_data_size=12713984 diff=0
[16:51:53] - Digital signature verified
[16:51:53]
[16:51:53] Project: 6903 (Run 5, Clone 23, Gen 7)
[16:51:53]
[16:51:53] Assembly optimizations on if available.
[16:51:53] Entering M.D.
[16:52:00] Mapping NT from 48 to 48
1.6MB doesn't look right...
One man's ceiling is another man's floor.
musky
Re: Project: 6903 (Run 5, Clone 23, Gen 7)
Post by musky »
Same unit, same issue this morning.
Nothing in the WU Database yet.
Grandpa_01
Post by Grandpa_01 »
I see over at the [H] another folder has gotten this WU and is having problems with it. Perhaps it needs to be rechecked and removed from circulation.
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Could it be an expression of this issue : viewtopic.php?f=19&t=20692 ?
sortofageek
Post by sortofageek »
Just for the record, this WU was completed successfully by another donor.
Your WU (P6903 R5 C23 G7) was added to the stats database on 2012-02-24 17:08:56 for 238663 points of credit.
