Project: 7621 (Run 299, Clone 0, Gen 170)
hiigaran
Post by hiigaran »
you may remember me from the Project: 7621 (Run 811, Clone 0, Gen 85) thread. well im back, and having the exact same problem with this new WU as i did with the previous one. ive followed all the steps from the first thread, and everything happening now is exactly as it was with the other WU. the worst bit about it is that its always EUE near the end of the unit, generally around 65% and up.
...what now?
Re: Project: 7621 (Run 299, Clone 0, Gen 170)
There's nothing in the WU Database so I have marked it for a follow-up.
hiigaran
Post by hiigaran »
alrighty. let me know if you need anything else
hiigaran
Post by hiigaran »
just an update, i managed to complete this work unit last night. possibly just a one-off
That's correct:
Hi hiigaran (team 212997),
Your WU (P7621 R299 C0 G170) was added to the stats database on 2012-01-15 16:04:43 for 5187 points of credit.
It could be possible that it was a fluke but if its common (which I hope isn't the case) than it requires some investigation.
hiigaran
Post by hiigaran »
well in any case, ill keep you updated if there are any other problems
