Uploading to 129.74.85.16 - not like results, dumping
Ripper36
Post by Ripper36 »
I had a work unit 7006 0:34:67 from work server 129.74.85.15
Upload to that server was not accepted so the unit results uploaded to 129.74.85.16
100% upload, but the server didn't like the results and dumped the unit.
I've never seen this before - what should I do?
log excerpt
22:59:26:Unit 00:Completed 10000000 out of 10000000 steps  (100%)
22:59:26:Unit 00:DynamicWrapper: Finished Work Unit: sleep=10000
22:59:31:Unit 03:Completed   3500000 out of 50000000 steps (7%).
22:59:36:Unit 00:
22:59:36:Unit 00:Finished Work Unit:
22:59:36:Unit 00:- Reading up to 2131908 from "00/wudata_01.trr": Read 2131908
22:59:36:Unit 00:trr file hash check passed.
22:59:36:Unit 00:- Reading up to 220256 from "00/wudata_01.xtc": Read 220256
22:59:36:Unit 00:xtc file hash check passed.
22:59:36:Unit 00:edr file hash check passed.
22:59:36:Unit 00:logfile size: 80342
22:59:36:Unit 00:Leaving Run
22:59:40:Unit 00:- Writing 2456978 bytes of core data to disk...
22:59:40:Unit 00:Done: 2456466 -> 1890732 (compressed to 76.9 percent)
22:59:40:Unit 00:  ... Done.
22:59:40:Unit 00:- Shutting down core
22:59:40:Unit 00:
22:59:40:Unit 00:Folding@home Core Shutdown: FINISHED_UNIT
22:59:41:FahCore, running Unit 00, returned: FINISHED_UNIT (100 = 0x64)
22:59:41:Sending unit results: id:00 state:SEND error:OK project:7006 run:0 clone:34 gen:67 core:0xa4 unit:0x000000d80001329c4dfb8e9f033cc191
22:59:41:Unit 00: Uploading 1.80MiB to 129.74.85.15
23:00:15:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
23:00:15:SocketDevice::write(): Socket not open
23:00:15:WARNING: Exception: Failed to send results to work server: Upload failed
23:00:15:Trying to send results to collection server
23:00:15:Unit 00: Uploading 1.80MiB to 129.74.85.16
23:00:15:Connecting to 129.74.85.16:8080
23:00:22:Unit 00: 1.73%
23:05:45:Unit 00: Upload complete
23:05:45:Server responded WORK_QUIT (404)
23:05:45:WARNING: Server did not like results, dumping
full log :
*********************** Log Started 2012-01-12T19:31:41 ************************
19:31:41:************************* Folding@home Client *************************
19:31:41:      Website: http://folding.stanford.edu/
19:31:41:    Copyright: (c) 2009-2011 Stanford University
19:31:41:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:31:41:         Args: --lifeline 3724 --command-port=36330
19:31:41:       Config: C:/Users/John/AppData/Roaming/FAHClient/config.xml
19:31:41:******************************** Build ********************************
19:31:41:      Version: 7.1.38
19:31:41:         Date: Oct 6 2011
19:31:41:         Time: 19:57:04
19:31:41:      SVN Rev: 3080
19:31:41:       Branch: fah/trunk/client
19:31:41:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
19:31:41:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
19:31:41:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
19:31:41:     Platform: win32 XP
19:31:41:         Bits: 32
19:31:41:         Mode: Release
19:31:41:******************************* System ********************************
19:31:41:          CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
19:31:41:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
19:31:41:         CPUs: 8
19:31:41:       Memory: 15.92GiB
19:31:41:  Free Memory: 14.00GiB
19:31:41:      Threads: WINDOWS_THREADS
19:31:41:   On Battery: false
19:31:41:   UTC offset: 11
19:31:41:          PID: 3476
19:31:41:          CWD: C:/Users/John/AppData/Roaming/FAHClient
19:31:41:           OS: Windows 7 Ultimate
19:31:41:      OS Arch: AMD64
19:31:41:         GPUs: 2
19:31:41:        GPU 0: FERMI:1 GF110 [Geforce GTX 570 HD]
19:31:41:        GPU 1: FERMI:1 GF110 [Geforce GTX 570 HD]
19:31:41:         CUDA: 2.0
19:31:41:  CUDA Driver: 4010
19:31:41:Win32 Service: false
19:31:41:***********************************************************************
19:31:41:<config>
19:31:41:  <service-description v='Folding@home Client'/>
19:31:41:  <service-restart v='true'/>
19:31:41:  <service-restart-delay v='5000'/>
19:31:41:
19:31:41:  <!-- Client Control -->
19:31:41:  <cycle-rate v='4'/>
19:31:41:  <cycles v='-1'/>
19:31:41:  <data-directory v='.'/>
19:31:41:  <disable-project-lookup v='false'/>
19:31:41:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
19:31:41:  <exit-when-done v='false'/>
19:31:41:  <threads v='4'/>
19:31:41:
19:31:41:  <!-- Configuration -->
19:31:41:  <config-rotate v='true'/>
19:31:41:  <config-rotate-dir v='configs'/>
19:31:41:  <config-rotate-max v='16'/>
19:31:41:
19:31:41:  <!-- Debugging -->
19:31:41:  <assignment-servers>
19:31:41:    assign3.stanford.edu:8080 assign4.stanford.edu:80
19:31:41:  </assignment-servers>
19:31:41:  <capture-directory v='capture'/>
19:31:41:  <capture-sockets v='false'/>
19:31:41:  <debug-sockets v='false'/>
19:31:41:  <exception-locations v='true'/>
19:31:41:  <gpu-assignment-servers>
19:31:41:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
19:31:41:  </gpu-assignment-servers>
19:31:41:  <stack-traces v='false'/>
19:31:41:
19:31:41:  <!-- Error Handling -->
19:31:41:  <max-slot-errors v='5'/>
19:31:41:  <max-unit-errors v='5'/>
19:31:41:
19:31:41:  <!-- FahCore Control -->
19:31:41:  <checkpoint v='15'/>
19:31:41:  <core-dir v='cores'/>
19:31:41:  <core-priority v='idle'/>
19:31:41:  <cpu-affinity v='false'/>
19:31:41:  <cpu-usage v='100'/>
19:31:41:  <no-assembly v='false'/>
19:31:41:
19:31:41:  <!-- Folding Slot Configuration -->
19:31:41:  <client-subtype v='STDCLI'/>
19:31:41:  <client-type v='normal'/>
19:31:41:  <cpu-species v='X86_PENTIUM_II'/>
19:31:41:  <cpu-type v='AMD64'/>
19:31:41:  <cpus v='-1'/>
19:31:41:  <cuda-index v='0'/>
19:31:41:  <gpu v='false'/>
19:31:41:  <gpu-usage v='95'/>
19:31:41:  <max-packet-size v='normal'/>
19:31:41:  <opencl-index v='0'/>
19:31:41:  <os-species v='UNKNOWN'/>
19:31:41:  <os-type v='WIN32'/>
19:31:41:  <project-key v='0'/>
19:31:41:  <smp v='true'/>
19:31:41:
19:31:41:  <!-- Logging -->
19:31:41:  <log v='log.txt'/>
19:31:41:  <log-color v='false'/>
19:31:41:  <log-crlf v='true'/>
19:31:41:  <log-date v='false'/>
19:31:41:  <log-debug v='true'/>
19:31:41:  <log-domain v='false'/>
19:31:41:  <log-header v='true'/>
19:31:41:  <log-level v='true'/>
19:31:41:  <log-no-info-header v='true'/>
19:31:41:  <log-redirect v='false'/>
19:31:41:  <log-rotate v='true'/>
19:31:41:  <log-rotate-dir v='logs'/>
19:31:41:  <log-rotate-max v='16'/>
19:31:41:  <log-short-level v='false'/>
19:31:41:  <log-simple-domains v='true'/>
19:31:41:  <log-thread-id v='false'/>
19:31:41:  <log-time v='true'/>
19:31:41:  <log-to-screen v='true'/>
19:31:41:  <log-truncate v='false'/>
19:31:41:  <verbosity v='5'/>
19:31:41:
19:31:41:  <!-- Network -->
19:31:41:  <proxy v=':8080'/>
19:31:41:  <proxy-enable v='false'/>
19:31:41:  <proxy-pass v=''/>
19:31:41:  <proxy-user v=''/>
19:31:41:
19:31:41:  <!-- Process Control -->
19:31:41:  <child v='false'/>
19:31:41:  <daemon v='false'/>
19:31:41:  <pid v='false'/>
19:31:41:  <pid-file v='Folding@home Client.pid'/>
19:31:41:  <respawn v='false'/>
19:31:41:  <service v='false'/>
19:31:41:
19:31:41:  <!-- Remote Command Server -->
19:31:41:  <command-address v='0.0.0.0'/>
19:31:41:  <command-allow v='127.0.0.1,192.168.1.0/24'/>
19:31:41:  <command-allow-no-pass v='127.0.0.1'/>
19:31:41:  <command-deny v='0.0.0.0/0'/>
19:31:41:  <command-deny-no-pass v='0.0.0.0/0'/>
19:31:41:  <command-port v='36330'/>
19:31:41:  <password v='*******'/>
19:31:41:
19:31:41:  <!-- Slot Control -->
19:31:41:  <max-shutdown-wait v='60'/>
19:31:41:  <pause-on-battery v='false'/>
19:31:41:  <pause-on-start v='false'/>
19:31:41:
19:31:41:  <!-- User Information -->
19:31:41:  <machine-id v='0'/>
19:31:41:  <passkey v='********************************'/>
19:31:41:  <team v='24'/>
19:31:41:  <user v='jrimmer'/>
19:31:41:
19:31:41:  <!-- Work Unit Control -->
19:31:41:  <dump-after-deadline v='true'/>
19:31:41:  <max-queue v='16'/>
19:31:41:  <max-units v='0'/>
19:31:41:  <next-unit-percentage v='99'/>
19:31:41:
19:31:41:  <!-- Folding Slots -->
19:31:41:  <slot id='0' type='SMP'>
19:31:41:    <client-type v='bigadv'/>
19:31:41:  </slot>
19:31:41:  <slot id='1' type='GPU'/>
19:31:41:  <slot id='2' type='GPU'/>
19:31:41:</config>
19:31:41:Trying to access database...
19:31:41:Successfully acquired database lock
19:31:41:Enabled folding slot 00: READY smp:8
19:31:41:Enabled folding slot 01: READY gpu:0:"GF110 [Geforce GTX 570 HD]"
19:31:41:Enabled folding slot 02: READY gpu:1:"GF110 [Geforce GTX 570 HD]"
19:31:41:Started thread 3 on PID 3476
19:31:41:Started thread 1 on PID 3476
19:31:41:Starting Unit 00
19:31:41:Started thread 5 on PID 3476
19:31:41:Started thread 4 on PID 3476
19:31:41:Started thread 6 on PID 3476
19:31:41:Running core: C:/Users/John/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -lifeline 3476 -version 701 -checkpoint 15 -np 8
19:31:41:Started core on PID 4020
19:31:41:FahCore 0xa4 started
19:31:41:Started thread 7 on PID 3476
19:31:42:Starting Unit 01
19:31:42:Running core: C:/Users/John/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -lifeline 3476 -version 701 -checkpoint 15 -gpu 1
19:31:42:Started core on PID 4032
19:31:42:FahCore 0x15 started
19:31:42:Started thread 8 on PID 3476
19:31:42:Starting Unit 03
19:31:42:Running core: C:/Users/John/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 03 -suffix 01 -lifeline 3476 -version 701 -checkpoint 15 -gpu 0
19:31:42:Started core on PID 3624
19:31:42:Started thread 9 on PID 3476
19:31:42:Unit 00:
19:31:42:Unit 00:*------------------------------*
19:31:42:Unit 00:Folding@Home Gromacs GB Core
19:31:42:Unit 00:Version 2.27 (Dec. 15, 2010)
19:31:42:Unit 00:
19:31:42:Unit 00:Preparing to commence simulation
19:31:42:Unit 00:- Ensuring status. Please wait.
19:31:42:Unit 01:
19:31:42:Unit 01:*------------------------------*
19:31:42:Unit 01:Folding@Home GPU Core
19:31:42:Unit 01:Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
19:31:42:Unit 01:Build host             SimbiosNvdWin7
19:31:42:Unit 01:Board Type             NVIDIA/CUDA
19:31:42:Unit 01:Core                   15
19:31:42:Unit 01:GPU device id          1
19:31:42:Unit 01:
19:31:42:Unit 01:Window's signal control handler registered.
19:31:42:Unit 03:
19:31:42:Unit 01:Preparing to commence simulation
19:31:42:Unit 03:*------------------------------*
19:31:42:Unit 01:- Ensuring status. Please wait.
19:31:42:Unit 03:Folding@Home GPU Core
19:31:42:Unit 03:Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
19:31:42:Unit 03:Build host             SimbiosNvdWin7
19:31:42:Unit 03:Board Type             NVIDIA/CUDA
19:31:42:Unit 03:Core                   15
19:31:42:Unit 03:
19:31:42:Unit 03:Window's signal control handler registered.
19:31:42:Unit 03:Preparing to commence simulation
19:31:42:Unit 03:- Ensuring status. Please wait.
19:31:44:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
19:31:44:Started thread 10 on PID 3476
19:31:51:Unit 03:- Looking at optimizations...
19:31:51:Unit 01:- Looking at optimizations...
19:31:51:Unit 03:- Working with standard loops on this execution.
19:31:51:Unit 01:- Working with standard loops on this execution.
19:31:51:Unit 03:- Previous termination of core was improper.
19:31:51:Unit 01:- Previous termination of core was improper.
19:31:51:Unit 03:- Files status OK
19:31:51:Unit 01:- Files status OK
19:31:51:Unit 03:sizeof(CORE_PACKET_HDR) = 512 file=<>
19:31:51:Unit 01:sizeof(CORE_PACKET_HDR) = 512 file=<>
19:31:51:Unit 03:- Expanded 44949 -> 171827 (decompressed 382.2 percent)
19:31:51:Unit 01:- Expanded 45053 -> 171827 (decompressed 381.3 percent)
19:31:51:Unit 03:Called DecompressByteArray: compressed_data_size=44949 data_size=171827, decompressed_data_size=171827 diff=0
19:31:51:Unit 01:Called DecompressByteArray: compressed_data_size=45053 data_size=171827, decompressed_data_size=171827 diff=0
19:31:51:Unit 03:- Digital signature verified
19:31:51:Unit 01:- Digital signature verified
19:31:51:Unit 03:
19:31:51:Unit 01:
19:31:51:Unit 03:Project: 6801 (Run 7115, Clone 1, Gen 32)
19:31:51:Unit 01:Project: 6801 (Run 5747, Clone 1, Gen 75)
19:31:51:Unit 03:
19:31:51:Unit 01:
19:31:51:Unit 03:Entering M.D.
19:31:51:Unit 01:Entering M.D.
19:31:51:Unit 00:- Looking at optimizations...
19:31:51:Unit 00:- Working with standard loops on this execution.
19:31:51:Unit 00:- Previous termination of core was improper.
19:31:51:Unit 00:- Files status OK
19:31:51:Unit 00:- Expanded 55367 -> 206116 (decompressed 372.2 percent)
19:31:51:Unit 00:Called DecompressByteArray: compressed_data_size=55367 data_size=206116, decompressed_data_size=206116 diff=0
19:31:51:Unit 00:- Digital signature verified
19:31:51:Unit 00:
19:31:51:Unit 00:Project: 7006 (Run 0, Clone 34, Gen 67)
19:31:51:Unit 00:
19:31:51:Unit 00:Entering M.D.
19:31:53:Unit 01:Will resume from checkpoint file 01/wudata_01.ckp
19:31:53:Unit 03:Will resume from checkpoint file 03/wudata_01.ckp
19:31:53:Unit 01:Tpr hash 01/wudata_01.tpr:  1201357789 2174333327 180670006 547839887 17497090
19:31:53:Unit 03:Tpr hash 03/wudata_01.tpr:  1110974814 26343690 36136508 2464699006 956069791
19:31:53:Unit 01:calling fah_main gpuDeviceId=1
19:31:53:Unit 03:calling fah_main gpuDeviceId=0
19:31:53:Unit 01:Working on ALZHEIMER'S DISEASE AMYLOID
19:31:53:Unit 03:Working on ALZHEIMER'S DISEASE AMYLOID
19:31:53:Unit 01:Client config unavailable.
19:31:53:Unit 03:Client config unavailable.
19:31:53:Unit 01:Starting GUI Server
19:31:53:Unit 03:Starting GUI Server
19:31:57:Unit 00:Using Gromacs checkpoints
19:31:57:Unit 00:Mapping NT from 8 to 8
19:31:57:Unit 00:Resuming from checkpoint
19:31:57:Unit 00:Verified 00/wudata_01.log
19:31:57:Unit 00:Verified 00/wudata_01.trr
19:31:57:Unit 00:Verified 00/wudata_01.xtc
19:31:57:Unit 00:Verified 00/wudata_01.edr
19:31:57:Unit 00:Completed 3900001 out of 10000000 steps  (39%)
19:32:59:Unit 01:Resuming from checkpoint
19:32:59:Unit 01:fcCheckPointResume: retreived and current tpr file hash:
19:32:59:Unit 01:   0   1201357789   1201357789
19:32:59:Unit 01:   1   2174333327   2174333327
19:32:59:Unit 01:   2    180670006    180670006
19:32:59:Unit 01:   3    547839887    547839887
19:32:59:Unit 01:   4     17497090     17497090
19:32:59:Unit 01:fcCheckPointResume: file hashes same.
19:32:59:Unit 01:fcCheckPointResume: state restored.
19:32:59:Unit 01:fcCheckPointResume: name 01/wudata_01.log Verified 01/wudata_01.log
19:32:59:Unit 01:fcCheckPointResume: name 01/wudata_01.trr Verified 01/wudata_01.trr
19:32:59:Unit 01:fcCheckPointResume: name 01/wudata_01.xtc Verified 01/wudata_01.xtc
19:32:59:Unit 01:fcCheckPointResume: name 01/wudata_01.edr Verified 01/wudata_01.edr
19:32:59:Unit 01:fcCheckPointResume: state restored 2
19:32:59:Unit 01:Resumed from checkpoint
19:32:59:Unit 01:Setting checkpoint frequency: 500000
19:32:59:Unit 01:Completed  13500001 out of 50000000 steps (27%).
19:33:00:Unit 03:Resuming from checkpoint
19:33:00:Unit 03:fcCheckPointResume: retreived and current tpr file hash:
19:33:00:Unit 03:   0   1110974814   1110974814
19:33:00:Unit 03:   1     26343690     26343690
19:33:00:Unit 03:   2     36136508     36136508
19:33:00:Unit 03:   3   2464699006   2464699006
19:33:00:Unit 03:   4    956069791    956069791
19:33:00:Unit 03:fcCheckPointResume: file hashes same.
19:33:00:Unit 03:fcCheckPointResume: state restored.
19:33:00:Unit 03:fcCheckPointResume: name 03/wudata_01.log Verified 03/wudata_01.log
19:33:00:Unit 03:fcCheckPointResume: name 03/wudata_01.trr Verified 03/wudata_01.trr
19:33:00:Unit 03:fcCheckPointResume: name 03/wudata_01.xtc Verified 03/wudata_01.xtc
19:33:00:Unit 03:fcCheckPointResume: name 03/wudata_01.edr Verified 03/wudata_01.edr
19:33:00:Unit 03:fcCheckPointResume: state restored 2
19:33:00:Unit 03:Resumed from checkpoint
19:33:00:Unit 03:Setting checkpoint frequency: 500000
19:33:00:Unit 03:Completed  31500001 out of 50000000 steps (63%).
19:34:23:Unit 01:Completed  14000000 out of 50000000 steps (28%).
19:34:23:Unit 03:Completed  32000000 out of 50000000 steps (64%).
19:34:59:Unit 00:Completed 4000000 out of 10000000 steps  (40%)
19:35:47:Unit 03:Completed  32500000 out of 50000000 steps (65%).
19:36:06:Unit 01:Completed  14500000 out of 50000000 steps (29%).
19:37:11:Unit 03:Completed  33000000 out of 50000000 steps (66%).
19:38:10:Unit 00:Completed 4100000 out of 10000000 steps  (41%)
19:38:34:Unit 03:Completed  33500000 out of 50000000 steps (67%).
19:38:41:Unit 01:Completed  15000000 out of 50000000 steps (30%).
19:39:58:Unit 03:Completed  34000000 out of 50000000 steps (68%).
19:41:19:Unit 00:Completed 4200000 out of 10000000 steps  (42%)
19:41:21:Unit 01:Completed  15500000 out of 50000000 steps (31%).
19:41:21:Unit 03:Completed  34500000 out of 50000000 steps (69%).
19:42:45:Unit 03:Completed  35000000 out of 50000000 steps (70%).
19:44:09:Unit 03:Completed  35500000 out of 50000000 steps (71%).
19:44:26:Unit 00:Completed 4300000 out of 10000000 steps  (43%)
19:44:27:Unit 01:Completed  16000000 out of 50000000 steps (32%).
19:45:32:Unit 03:Completed  36000000 out of 50000000 steps (72%).
19:46:56:Unit 03:Completed  36500000 out of 50000000 steps (73%).
19:47:35:Unit 00:Completed 4400000 out of 10000000 steps  (44%)
19:47:50:Unit 01:Completed  16500000 out of 50000000 steps (33%).
19:48:20:Unit 03:Completed  37000000 out of 50000000 steps (74%).
19:49:43:Unit 03:Completed  37500000 out of 50000000 steps (75%).
19:50:40:Unit 00:Completed 4500000 out of 10000000 steps  (45%)
19:51:07:Unit 03:Completed  38000000 out of 50000000 steps (76%).
19:51:07:Unit 01:Completed  17000000 out of 50000000 steps (34%).
19:52:30:Unit 03:Completed  38500000 out of 50000000 steps (77%).
19:53:38:Unit 00:Completed 4600000 out of 10000000 steps  (46%)
19:53:54:Unit 03:Completed  39000000 out of 50000000 steps (78%).
19:54:15:Unit 01:Completed  17500000 out of 50000000 steps (35%).
19:55:18:Unit 03:Completed  39500000 out of 50000000 steps (79%).
19:56:36:Unit 00:Completed 4700000 out of 10000000 steps  (47%)
19:56:41:Unit 03:Completed  40000000 out of 50000000 steps (80%).
19:57:30:Unit 01:Completed  18000000 out of 50000000 steps (36%).
19:58:05:Unit 03:Completed  40500000 out of 50000000 steps (81%).
19:59:29:Unit 03:Completed  41000000 out of 50000000 steps (82%).
19:59:34:Unit 00:Completed 4800000 out of 10000000 steps  (48%)
20:00:52:Unit 03:Completed  41500000 out of 50000000 steps (83%).
20:01:08:Unit 01:Completed  18500000 out of 50000000 steps (37%).
20:02:16:Unit 03:Completed  42000000 out of 50000000 steps (84%).
20:02:31:Unit 00:Completed 4900000 out of 10000000 steps  (49%)
20:03:39:Unit 03:Completed  42500000 out of 50000000 steps (85%).
20:04:56:Unit 01:Completed  19000000 out of 50000000 steps (38%).
20:05:03:Unit 03:Completed  43000000 out of 50000000 steps (86%).
20:05:28:Unit 00:Completed 5000000 out of 10000000 steps  (50%)
20:06:27:Unit 03:Completed  43500000 out of 50000000 steps (87%).
20:07:50:Unit 03:Completed  44000000 out of 50000000 steps (88%).
20:08:25:Unit 00:Completed 5100000 out of 10000000 steps  (51%)
20:08:49:Unit 01:Completed  19500000 out of 50000000 steps (39%).
20:09:14:Unit 03:Completed  44500000 out of 50000000 steps (89%).
20:10:38:Unit 03:Completed  45000000 out of 50000000 steps (90%).
20:11:24:Unit 00:Completed 5200000 out of 10000000 steps  (52%)
20:12:01:Unit 03:Completed  45500000 out of 50000000 steps (91%).
20:12:01:Unit 01:Completed  20000000 out of 50000000 steps (40%).
20:13:25:Unit 03:Completed  46000000 out of 50000000 steps (92%).
20:14:23:Unit 00:Completed 5300000 out of 10000000 steps  (53%)
20:14:48:Unit 03:Completed  46500000 out of 50000000 steps (93%).
20:15:20:Unit 01:Completed  20500000 out of 50000000 steps (41%).
20:16:12:Unit 03:Completed  47000000 out of 50000000 steps (94%).
20:17:22:Unit 00:Completed 5400000 out of 10000000 steps  (54%)
20:17:36:Unit 03:Completed  47500000 out of 50000000 steps (95%).
20:18:59:Unit 03:Completed  48000000 out of 50000000 steps (96%).
20:19:10:Unit 01:Completed  21000000 out of 50000000 steps (42%).
20:20:18:Unit 00:Completed 5500000 out of 10000000 steps  (55%)
20:20:23:Unit 03:Completed  48500000 out of 50000000 steps (97%).
20:21:47:Unit 03:Completed  49000000 out of 50000000 steps (98%).
20:23:05:Unit 01:Completed  21500000 out of 50000000 steps (43%).
20:23:10:Unit 03:Completed  49500000 out of 50000000 steps (99%).
20:23:11:Connecting to assign-GPU.stanford.edu:80
20:23:13:News: Welcome to Folding@Home
20:23:13:Assigned to work server 171.64.65.64
20:23:13:Requesting new work unit for slot 01: RUNNING gpu:0:"GF110 [Geforce GTX 570 HD]" from 171.64.65.64
20:23:13:Connecting to 171.64.65.64:8080
20:23:18:Unit 00:Completed 5600000 out of 10000000 steps  (56%)
20:23:20:Slot 01: Downloading 43.85KiB
20:23:22:Slot 01: Download complete
20:23:22:Received Unit: id:02 state:DOWNLOAD error:OK project:6800 run:21472 clone:0 gen:49 core:0x15 unit:0x000000330a3b1e644ddbf6c65f5c52a8
20:24:34:Unit 03:Completed  50000000 out of 50000000 steps (100%).
20:24:34:Unit 03:Finished fah_main status=0
20:24:34:Unit 03:Successful run
20:24:34:Unit 03:DynamicWrapper: Finished Work Unit: sleep=10000
20:24:44:Unit 03:Reserved 2473292 bytes for xtc file; Cosm status=0
20:24:44:Unit 03:Allocated 2473292 bytes for xtc file
20:24:44:Unit 03:- Reading up to 2473292 from "03/wudata_01.xtc": Read 2473292
20:24:44:Unit 03:Read 2473292 bytes from xtc file; available packet space=783957172
20:24:44:Unit 03:xtc file hash check passed.
20:24:44:Unit 03:Reserved 76680 76680 783957172 bytes for arc file=<03/wudata_01.trr> Cosm status=0
20:24:44:Unit 03:Allocated 76680 bytes for arc file
20:24:44:Unit 03:- Reading up to 76680 from "03/wudata_01.trr": Read 76680
20:24:44:Unit 03:Read 76680 bytes from arc file; available packet space=783880492
20:24:44:Unit 03:trr file hash check passed.
20:24:44:Unit 03:Allocated 544 bytes for edr file
20:24:44:Unit 03:Read bedfile
20:24:44:Unit 03:edr file hash check passed.
20:24:44:Unit 03:Allocated 120594 bytes for logfile
20:24:44:Unit 03:Read logfile
20:24:44:Unit 03:GuardedRun: success in DynamicWrapper
20:24:44:Unit 03:GuardedRun: done
20:24:44:Unit 03:Run: GuardedRun completed.
20:24:46:Unit 03:+ Opened results file
20:24:46:Unit 03:- Writing 2671622 bytes of core data to disk...
20:24:47:Unit 03:Done: 2671110 -> 2516504 (compressed to 94.2 percent)
20:24:47:Unit 03:  ... Done.
20:24:47:Unit 03:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
20:24:47:Unit 03:Shutting down core
20:24:47:Unit 03:
20:24:47:Unit 03:Folding@home Core Shutdown: FINISHED_UNIT
20:24:47:FahCore, running Unit 03, returned: FINISHED_UNIT (100 = 0x64)
20:24:47:Sending unit results: id:03 state:SEND error:OK project:6801 run:7115 clone:1 gen:32 core:0x15 unit:0x000000220a3b1e644d94bbc6354525b3
20:24:47:Unit 03: Uploading 2.40MiB to 171.64.65.64
20:24:47:Starting Unit 02
20:24:47:Connecting to 171.64.65.64:8080
20:24:47:Running core: C:/Users/John/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -lifeline 3476 -version 701 -checkpoint 15 -gpu 0
20:24:47:Started core on PID 2320
20:24:47:FahCore 0x15 started
20:24:47:Started thread 11 on PID 3476
20:24:48:Unit 02:
20:24:48:Unit 02:*------------------------------*
20:24:48:Unit 02:Folding@Home GPU Core
20:24:48:Unit 02:Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
20:24:48:Unit 02:Build host             SimbiosNvdWin7
20:24:48:Unit 02:Board Type             NVIDIA/CUDA
20:24:48:Unit 02:Core                   15
20:24:48:Unit 02:
20:24:48:Unit 02:Window's signal control handler registered.
20:24:48:Unit 02:Preparing to commence simulation
20:24:48:Unit 02:- Looking at optimizations...
20:24:48:Unit 02:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
20:24:48:Unit 02:- Created dyn
20:24:48:Unit 02:- Files status OK
20:24:48:Unit 02:sizeof(CORE_PACKET_HDR) = 512 file=<>
20:24:48:Unit 02:- Expanded 44386 -> 169787 (decompressed 382.5 percent)
20:24:48:Unit 02:Called DecompressByteArray: compressed_data_size=44386 data_size=169787, decompressed_data_size=169787 diff=0
20:24:48:Unit 02:- Digital signature verified
20:24:48:Unit 02:
20:24:48:Unit 02:Project: 6800 (Run 21472, Clone 0, Gen 49)
20:24:48:Unit 02:
20:24:48:Unit 02:Assembly optimizations on if available.
20:24:48:Unit 02:Entering M.D.
20:24:49:Unit 02:Tpr hash 02/wudata_01.tpr:  1548217216 1351938851 3635865990 1940864606 4032933584
20:24:49:Unit 02:calling fah_main gpuDeviceId=0
20:24:49:Unit 02:Working on PEPTIDE (1-42)
20:24:49:Unit 02:Client config unavailable.
20:24:49:Unit 02:Starting GUI Server
20:24:54:Unit 03: 1.63%
20:25:00:Unit 03: 3.74%
20:25:06:Unit 03: 6.18%
20:25:12:Unit 03: 9.11%
20:25:18:Unit 03: 11.23%
20:25:24:Unit 03: 12.86%
20:25:30:Unit 03: 15.46%
20:25:36:Unit 03: 18.06%
20:25:42:Unit 03: 18.88%
20:25:49:Unit 03: 20.02%
20:25:55:Unit 02:Setting checkpoint frequency: 500000
20:25:55:Unit 02:Completed         3 out of 50000000 steps (0%).
20:25:56:Unit 03: 20.67%
20:25:57:Unit 00:Completed 5700000 out of 10000000 steps  (57%)
20:26:02:Unit 03: 22.29%
20:26:08:Unit 03: 24.25%
20:26:14:Unit 03: 26.36%
20:26:21:Unit 03: 28.48%
20:26:22:Unit 01:Completed  22000000 out of 50000000 steps (44%).
20:26:27:Unit 03: 30.43%
20:26:33:Unit 03: 30.92%
20:26:39:Unit 03: 32.55%
20:26:45:Unit 03: 34.66%
20:26:51:Unit 03: 36.29%
20:26:57:Unit 03: 38.24%
20:27:03:Unit 03: 40.52%
20:27:11:Unit 03: 41.50%
20:27:17:Unit 03: 42.15%
20:27:20:Unit 02:Completed    500000 out of 50000000 steps (1%).
20:27:23:Unit 03: 43.78%
20:27:29:Unit 03: 46.22%
20:27:35:Unit 03: 48.01%
20:27:42:Unit 03: 49.47%
20:27:48:Unit 03: 50.77%
20:27:54:Unit 03: 51.75%
20:28:01:Unit 03: 52.89%
20:28:07:Unit 03: 54.03%
20:28:15:Unit 03: 56.47%
20:28:23:Unit 03: 58.10%
20:28:29:Unit 03: 59.23%
20:28:35:Unit 03: 61.02%
20:28:41:Unit 03: 62.81%
20:28:45:Unit 02:Completed   1000000 out of 50000000 steps (2%).
20:28:47:Unit 03: 64.12%
20:28:53:Unit 03: 66.23%
20:29:00:Unit 03: 67.21%
20:29:06:Unit 03: 68.51%
20:29:12:Unit 03: 71.11%
20:29:18:Unit 03: 71.60%
20:29:24:Unit 03: 73.39%
20:29:28:Unit 00:Completed 5800000 out of 10000000 steps  (58%)
20:29:30:Unit 03: 75.02%
20:29:36:Unit 03: 76.65%
20:29:43:Unit 03: 77.14%
20:29:49:Unit 03: 78.11%
20:29:50:Unit 01:Completed  22500000 out of 50000000 steps (45%).
20:29:57:Unit 03: 79.09%
20:30:03:Unit 03: 81.20%
20:30:09:Unit 03: 82.99%
20:30:10:Unit 02:Completed   1500000 out of 50000000 steps (3%).
20:30:15:Unit 03: 84.13%
20:30:21:Unit 03: 85.43%
20:30:28:Unit 03: 87.06%
20:30:35:Unit 03: 88.85%
20:30:41:Unit 03: 89.99%
20:30:47:Unit 03: 91.94%
20:30:53:Unit 03: 93.08%
20:30:59:Unit 03: 94.38%
20:31:05:Unit 03: 96.01%
20:31:12:Unit 03: 97.80%
20:31:18:Unit 03: 98.62%
20:31:24:Unit 03: Upload complete
20:31:24:Server responded WORK_ACK (400)
20:31:24:Final credit estimate, 1348.00 points
20:31:24:Cleaning up Unit 03
20:31:36:Unit 02:Completed   2000000 out of 50000000 steps (4%).
20:33:01:Unit 00:Completed 5900000 out of 10000000 steps  (59%)
20:33:01:Unit 02:Completed   2500000 out of 50000000 steps (5%).
20:33:14:Unit 01:Completed  23000000 out of 50000000 steps (46%).
20:34:27:Unit 02:Completed   3000000 out of 50000000 steps (6%).
20:35:52:Unit 02:Completed   3500000 out of 50000000 steps (7%).
20:36:26:Unit 00:Completed 6000000 out of 10000000 steps  (60%)
20:36:53:Unit 01:Completed  23500000 out of 50000000 steps (47%).
20:37:18:Unit 02:Completed   4000000 out of 50000000 steps (8%).
20:38:43:Unit 02:Completed   4500000 out of 50000000 steps (9%).
20:39:41:Unit 01:Completed  24000000 out of 50000000 steps (48%).
20:40:04:Unit 00:Completed 6100000 out of 10000000 steps  (61%)
20:40:08:Unit 02:Completed   5000000 out of 50000000 steps (10%).
20:41:34:Unit 02:Completed   5500000 out of 50000000 steps (11%).
20:42:59:Unit 02:Completed   6000000 out of 50000000 steps (12%).
20:43:18:Unit 01:Completed  24500000 out of 50000000 steps (49%).
20:43:32:Unit 00:Completed 6200000 out of 10000000 steps  (62%)
20:44:25:Unit 02:Completed   6500000 out of 50000000 steps (13%).
20:45:50:Unit 02:Completed   7000000 out of 50000000 steps (14%).
20:46:55:Unit 00:Completed 6300000 out of 10000000 steps  (63%)
20:47:15:Unit 02:Completed   7500000 out of 50000000 steps (15%).
20:47:28:Unit 01:Completed  25000000 out of 50000000 steps (50%).
20:48:41:Unit 02:Completed   8000000 out of 50000000 steps (16%).
20:50:06:Unit 02:Completed   8500000 out of 50000000 steps (17%).
20:50:18:Unit 00:Completed 6400000 out of 10000000 steps  (64%)
20:51:32:Unit 02:Completed   9000000 out of 50000000 steps (18%).
20:51:41:Unit 01:Completed  25500000 out of 50000000 steps (51%).
20:52:57:Unit 02:Completed   9500000 out of 50000000 steps (19%).
20:53:42:Unit 00:Completed 6500000 out of 10000000 steps  (65%)
20:54:22:Unit 02:Completed  10000000 out of 50000000 steps (20%).
20:55:34:Unit 01:Completed  26000000 out of 50000000 steps (52%).
20:55:48:Unit 02:Completed  10500000 out of 50000000 steps (21%).
20:57:10:Unit 00:Completed 6600000 out of 10000000 steps  (66%)
20:57:13:Unit 02:Completed  11000000 out of 50000000 steps (22%).
20:58:39:Unit 02:Completed  11500000 out of 50000000 steps (23%).
20:59:06:Unit 01:Completed  26500000 out of 50000000 steps (53%).
21:00:04:Unit 02:Completed  12000000 out of 50000000 steps (24%).
21:00:35:Unit 00:Completed 6700000 out of 10000000 steps  (67%)
21:01:29:Unit 02:Completed  12500000 out of 50000000 steps (25%).
21:02:48:Unit 01:Completed  27000000 out of 50000000 steps (54%).
21:02:55:Unit 02:Completed  13000000 out of 50000000 steps (26%).
21:04:03:Unit 00:Completed 6800000 out of 10000000 steps  (68%)
21:04:20:Unit 02:Completed  13500000 out of 50000000 steps (27%).
21:05:45:Unit 02:Completed  14000000 out of 50000000 steps (28%).
21:06:26:Unit 01:Completed  27500000 out of 50000000 steps (55%).
21:07:11:Unit 02:Completed  14500000 out of 50000000 steps (29%).
21:07:28:Unit 00:Completed 6900000 out of 10000000 steps  (69%)
21:08:36:Unit 02:Completed  15000000 out of 50000000 steps (30%).
21:10:02:Unit 02:Completed  15500000 out of 50000000 steps (31%).
21:10:19:Unit 01:Completed  28000000 out of 50000000 steps (56%).
21:10:53:Unit 00:Completed 7000000 out of 10000000 steps  (70%)
21:11:27:Unit 02:Completed  16000000 out of 50000000 steps (32%).
21:12:53:Unit 02:Completed  16500000 out of 50000000 steps (33%).
21:13:42:Unit 01:Completed  28500000 out of 50000000 steps (57%).
21:14:18:Unit 02:Completed  17000000 out of 50000000 steps (34%).
21:14:26:Unit 00:Completed 7100000 out of 10000000 steps  (71%)
21:15:43:Unit 02:Completed  17500000 out of 50000000 steps (35%).
21:17:09:Unit 02:Completed  18000000 out of 50000000 steps (36%).
21:17:10:Unit 01:Completed  29000000 out of 50000000 steps (58%).
21:17:55:Unit 00:Completed 7200000 out of 10000000 steps  (72%)
21:18:34:Unit 02:Completed  18500000 out of 50000000 steps (37%).
21:19:59:Unit 02:Completed  19000000 out of 50000000 steps (38%).
21:20:45:Unit 01:Completed  29500000 out of 50000000 steps (59%).
21:21:23:Unit 00:Completed 7300000 out of 10000000 steps  (73%)
21:21:25:Unit 02:Completed  19500000 out of 50000000 steps (39%).
21:22:50:Unit 02:Completed  20000000 out of 50000000 steps (40%).
21:24:16:Unit 02:Completed  20500000 out of 50000000 steps (41%).
21:24:25:Unit 01:Completed  30000000 out of 50000000 steps (60%).
21:24:51:Unit 00:Completed 7400000 out of 10000000 steps  (74%)
21:25:41:Unit 02:Completed  21000000 out of 50000000 steps (42%).
21:27:07:Unit 02:Completed  21500000 out of 50000000 steps (43%).
21:28:16:Unit 00:Completed 7500000 out of 10000000 steps  (75%)
21:28:19:Unit 01:Completed  30500000 out of 50000000 steps (61%).
21:28:32:Unit 02:Completed  22000000 out of 50000000 steps (44%).
21:29:57:Unit 02:Completed  22500000 out of 50000000 steps (45%).
21:31:23:Unit 02:Completed  23000000 out of 50000000 steps (46%).
21:31:36:Unit 00:Completed 7600000 out of 10000000 steps  (76%)
21:32:12:Unit 01:Completed  31000000 out of 50000000 steps (62%).
21:32:48:Unit 02:Completed  23500000 out of 50000000 steps (47%).
21:34:14:Unit 02:Completed  24000000 out of 50000000 steps (48%).
21:35:07:Unit 00:Completed 7700000 out of 10000000 steps  (77%)
21:35:39:Unit 02:Completed  24500000 out of 50000000 steps (49%).
21:35:59:Unit 01:Completed  31500000 out of 50000000 steps (63%).
21:37:04:Unit 02:Completed  25000000 out of 50000000 steps (50%).
21:38:28:Unit 00:Completed 7800000 out of 10000000 steps  (78%)
21:38:30:Unit 02:Completed  25500000 out of 50000000 steps (51%).
21:39:55:Unit 02:Completed  26000000 out of 50000000 steps (52%).
21:40:19:Unit 01:Completed  32000000 out of 50000000 steps (64%).
21:41:21:Unit 02:Completed  26500000 out of 50000000 steps (53%).
21:41:50:Unit 00:Completed 7900000 out of 10000000 steps  (79%)
21:42:46:Unit 02:Completed  27000000 out of 50000000 steps (54%).
21:44:11:Unit 02:Completed  27500000 out of 50000000 steps (55%).
21:44:53:Unit 01:Completed  32500000 out of 50000000 steps (65%).
21:45:10:Unit 00:Completed 8000000 out of 10000000 steps  (80%)
21:45:37:Unit 02:Completed  28000000 out of 50000000 steps (56%).
21:47:02:Unit 02:Completed  28500000 out of 50000000 steps (57%).
21:48:27:Unit 02:Completed  29000000 out of 50000000 steps (58%).
21:48:37:Unit 00:Completed 8100000 out of 10000000 steps  (81%)
21:48:39:Unit 01:Completed  33000000 out of 50000000 steps (66%).
21:49:53:Unit 02:Completed  29500000 out of 50000000 steps (59%).
21:51:18:Unit 02:Completed  30000000 out of 50000000 steps (60%).
21:51:58:Unit 00:Completed 8200000 out of 10000000 steps  (82%)
21:52:43:Unit 01:Completed  33500000 out of 50000000 steps (67%).
21:52:44:Unit 02:Completed  30500000 out of 50000000 steps (61%).
21:54:09:Unit 02:Completed  31000000 out of 50000000 steps (62%).
21:55:22:Unit 00:Completed 8300000 out of 10000000 steps  (83%)
21:55:35:Unit 02:Completed  31500000 out of 50000000 steps (63%).
21:57:00:Unit 02:Completed  32000000 out of 50000000 steps (64%).
21:57:00:Unit 01:Completed  34000000 out of 50000000 steps (68%).
21:58:25:Unit 02:Completed  32500000 out of 50000000 steps (65%).
21:58:42:Unit 00:Completed 8400000 out of 10000000 steps  (84%)
21:59:51:Unit 02:Completed  33000000 out of 50000000 steps (66%).
22:01:14:Unit 01:Completed  34500000 out of 50000000 steps (69%).
22:01:16:Unit 02:Completed  33500000 out of 50000000 steps (67%).
22:02:06:Unit 00:Completed 8500000 out of 10000000 steps  (85%)
22:02:41:Unit 02:Completed  34000000 out of 50000000 steps (68%).
22:04:07:Unit 02:Completed  34500000 out of 50000000 steps (69%).
22:05:16:Unit 01:Completed  35000000 out of 50000000 steps (70%).
22:05:30:Unit 00:Completed 8600000 out of 10000000 steps  (86%)
22:05:32:Unit 02:Completed  35000000 out of 50000000 steps (70%).
22:06:58:Unit 02:Completed  35500000 out of 50000000 steps (71%).
22:08:23:Unit 02:Completed  36000000 out of 50000000 steps (72%).
22:08:53:Unit 00:Completed 8700000 out of 10000000 steps  (87%)
22:09:34:Unit 01:Completed  35500000 out of 50000000 steps (71%).
22:09:49:Unit 02:Completed  36500000 out of 50000000 steps (73%).
22:11:14:Unit 02:Completed  37000000 out of 50000000 steps (74%).
22:12:14:Unit 00:Completed 8800000 out of 10000000 steps  (88%)
22:12:39:Unit 02:Completed  37500000 out of 50000000 steps (75%).
22:13:41:Unit 01:Completed  36000000 out of 50000000 steps (72%).
22:14:05:Unit 02:Completed  38000000 out of 50000000 steps (76%).
22:15:30:Unit 02:Completed  38500000 out of 50000000 steps (77%).
22:15:42:Unit 00:Completed 8900000 out of 10000000 steps  (89%)
22:16:56:Unit 02:Completed  39000000 out of 50000000 steps (78%).
22:17:01:Unit 01:Completed  36500000 out of 50000000 steps (73%).
22:18:21:Unit 02:Completed  39500000 out of 50000000 steps (79%).
22:19:25:Unit 00:Completed 9000000 out of 10000000 steps  (90%)
22:19:37:Unit 01:Completed  37000000 out of 50000000 steps (74%).
22:19:46:Unit 02:Completed  40000000 out of 50000000 steps (80%).
22:21:12:Unit 02:Completed  40500000 out of 50000000 steps (81%).
22:21:24:Unit 01:Completed  37500000 out of 50000000 steps (75%).
22:22:37:Unit 02:Completed  41000000 out of 50000000 steps (82%).
22:23:01:Unit 01:Completed  38000000 out of 50000000 steps (76%).
22:23:50:Unit 00:Completed 9100000 out of 10000000 steps  (91%)
22:24:02:Unit 02:Completed  41500000 out of 50000000 steps (83%).
22:24:38:Unit 01:Completed  38500000 out of 50000000 steps (77%).
22:25:28:Unit 02:Completed  42000000 out of 50000000 steps (84%).
22:26:15:Unit 01:Completed  39000000 out of 50000000 steps (78%).
22:26:53:Unit 02:Completed  42500000 out of 50000000 steps (85%).
22:27:53:Unit 01:Completed  39500000 out of 50000000 steps (79%).
22:28:19:Unit 02:Completed  43000000 out of 50000000 steps (86%).
22:28:24:Unit 00:Completed 9200000 out of 10000000 steps  (92%)
22:29:32:Unit 01:Completed  40000000 out of 50000000 steps (80%).
22:29:44:Unit 02:Completed  43500000 out of 50000000 steps (87%).
22:31:09:Unit 02:Completed  44000000 out of 50000000 steps (88%).
22:31:11:Unit 01:Completed  40500000 out of 50000000 steps (81%).
22:32:35:Unit 02:Completed  44500000 out of 50000000 steps (89%).
22:32:52:Unit 01:Completed  41000000 out of 50000000 steps (82%).
22:32:54:Unit 00:Completed 9300000 out of 10000000 steps  (93%)
22:34:00:Unit 02:Completed  45000000 out of 50000000 steps (90%).
22:34:34:Unit 01:Completed  41500000 out of 50000000 steps (83%).
22:35:26:Unit 02:Completed  45500000 out of 50000000 steps (91%).
22:36:17:Unit 01:Completed  42000000 out of 50000000 steps (84%).
22:36:51:Unit 02:Completed  46000000 out of 50000000 steps (92%).
22:37:20:Unit 00:Completed 9400000 out of 10000000 steps  (94%)
22:38:00:Unit 01:Completed  42500000 out of 50000000 steps (85%).
22:38:16:Unit 02:Completed  46500000 out of 50000000 steps (93%).
22:39:42:Unit 02:Completed  47000000 out of 50000000 steps (94%).
22:39:44:Unit 01:Completed  43000000 out of 50000000 steps (86%).
22:41:07:Unit 02:Completed  47500000 out of 50000000 steps (95%).
22:41:27:Unit 01:Completed  43500000 out of 50000000 steps (87%).
22:41:44:Unit 00:Completed 9500000 out of 10000000 steps  (95%)
22:42:33:Unit 02:Completed  48000000 out of 50000000 steps (96%).
22:43:10:Unit 01:Completed  44000000 out of 50000000 steps (88%).
22:43:58:Unit 02:Completed  48500000 out of 50000000 steps (97%).
22:44:54:Unit 01:Completed  44500000 out of 50000000 steps (89%).
22:45:23:Unit 02:Completed  49000000 out of 50000000 steps (98%).
22:46:09:Unit 00:Completed 9600000 out of 10000000 steps  (96%)
22:46:37:Unit 01:Completed  45000000 out of 50000000 steps (90%).
22:46:49:Unit 02:Completed  49500000 out of 50000000 steps (99%).
22:46:50:Connecting to assign-GPU.stanford.edu:80
22:46:51:News: Welcome to Folding@Home
22:46:51:Assigned to work server 171.64.65.64
22:46:51:Requesting new work unit for slot 01: RUNNING gpu:0:"GF110 [Geforce GTX 570 HD]" from 171.64.65.64
22:46:51:Connecting to 171.64.65.64:8080
22:46:55:Slot 01: Downloading 42.70KiB
22:46:57:Slot 01: Download complete
22:46:57:Received Unit: id:03 state:DOWNLOAD error:OK project:6800 run:19067 clone:0 gen:119 core:0x15 unit:0x000000810a3b1e644ddbf52e13079dbe
22:48:14:Unit 02:Completed  50000000 out of 50000000 steps (100%).
22:48:14:Unit 02:Finished fah_main status=0
22:48:14:Unit 02:Successful run
22:48:14:Unit 02:DynamicWrapper: Finished Work Unit: sleep=10000
22:48:21:Unit 01:Completed  45500000 out of 50000000 steps (91%).
22:48:24:Unit 02:Reserved 244096 bytes for xtc file; Cosm status=0
22:48:24:Unit 02:Allocated 244096 bytes for xtc file
22:48:24:Unit 02:- Reading up to 244096 from "02/wudata_01.xtc": Read 244096
22:48:24:Unit 02:Read 244096 bytes from xtc file; available packet space=786186368
22:48:24:Unit 02:xtc file hash check passed.
22:48:24:Unit 02:Reserved 75840 75840 786186368 bytes for arc file=<02/wudata_01.trr> Cosm status=0
22:48:24:Unit 02:Allocated 75840 bytes for arc file
22:48:24:Unit 02:- Reading up to 75840 from "02/wudata_01.trr": Read 75840
22:48:24:Unit 02:Read 75840 bytes from arc file; available packet space=786110528
22:48:24:Unit 02:trr file hash check passed.
22:48:24:Unit 02:Allocated 544 bytes for edr file
22:48:24:Unit 02:Read bedfile
22:48:24:Unit 02:edr file hash check passed.
22:48:24:Unit 02:Allocated 120379 bytes for logfile
22:48:24:Unit 02:Read logfile
22:48:24:Unit 02:GuardedRun: success in DynamicWrapper
22:48:24:Unit 02:GuardedRun: done
22:48:24:Unit 02:Run: GuardedRun completed.
22:48:26:Unit 02:+ Opened results file
22:48:26:Unit 02:- Writing 441371 bytes of core data to disk...
22:48:26:Unit 02:Done: 440859 -> 329796 (compressed to 74.8 percent)
22:48:26:Unit 02:  ... Done.
22:48:26:Unit 02:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
22:48:26:Unit 02:Shutting down core
22:48:26:Unit 02:
22:48:26:Unit 02:Folding@home Core Shutdown: FINISHED_UNIT
22:48:26:FahCore, running Unit 02, returned: FINISHED_UNIT (100 = 0x64)
22:48:26:Sending unit results: id:02 state:SEND error:OK project:6800 run:21472 clone:0 gen:49 core:0x15 unit:0x000000330a3b1e644ddbf6c65f5c52a8
22:48:26:Unit 02: Uploading 322.57KiB to 171.64.65.64
22:48:26:Connecting to 171.64.65.64:8080
22:48:26:Starting Unit 03
22:48:26:Running core: C:/Users/John/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 03 -suffix 01 -lifeline 3476 -version 701 -checkpoint 15 -gpu 0
22:48:26:Started core on PID 1004
22:48:26:FahCore 0x15 started
22:48:26:Started thread 12 on PID 3476
22:48:27:Unit 03:
22:48:27:Unit 03:*------------------------------*
22:48:27:Unit 03:Folding@Home GPU Core
22:48:27:Unit 03:Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
22:48:27:Unit 03:Build host             SimbiosNvdWin7
22:48:27:Unit 03:Board Type             NVIDIA/CUDA
22:48:27:Unit 03:Core                   15
22:48:27:Unit 03:
22:48:27:Unit 03:Window's signal control handler registered.
22:48:27:Unit 03:Preparing to commence simulation
22:48:27:Unit 03:- Looking at optimizations...
22:48:27:Unit 03:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
22:48:27:Unit 03:- Created dyn
22:48:27:Unit 03:- Files status OK
22:48:27:Unit 03:sizeof(CORE_PACKET_HDR) = 512 file=<>
22:48:27:Unit 03:- Expanded 43217 -> 169787 (decompressed 392.8 percent)
22:48:27:Unit 03:Called DecompressByteArray: compressed_data_size=43217 data_size=169787, decompressed_data_size=169787 diff=0
22:48:27:Unit 03:- Digital signature verified
22:48:27:Unit 03:
22:48:27:Unit 03:Project: 6800 (Run 19067, Clone 0, Gen 119)
22:48:27:Unit 03:
22:48:27:Unit 03:Assembly optimizations on if available.
22:48:27:Unit 03:Entering M.D.
22:48:28:Unit 03:Tpr hash 03/wudata_01.tpr:  1858718194 1352286393 504723314 2347898536 3663132257
22:48:28:Unit 03:calling fah_main gpuDeviceId=0
22:48:28:Unit 03:Working on PEPTIDE (1-42)
22:48:28:Unit 03:Client config unavailable.
22:48:29:Unit 03:Starting GUI Server
22:48:32:Unit 02: 12.40%
22:48:38:Unit 02: 24.80%
22:48:44:Unit 02: 42.16%
22:48:50:Unit 02: 60.76%
22:48:56:Unit 02: 78.12%
22:49:02:Unit 02: 88.04%
22:49:08:Unit 02: Upload complete
22:49:08:Server responded WORK_ACK (400)
22:49:08:Final credit estimate, 1298.00 points
22:49:09:Cleaning up Unit 02
22:49:34:Unit 03:Setting checkpoint frequency: 500000
22:49:34:Unit 03:Completed         3 out of 50000000 steps (0%).
22:49:44:Unit 00:Completed 9700000 out of 10000000 steps  (97%)
22:49:53:Unit 01:Completed  46000000 out of 50000000 steps (92%).
22:50:59:Unit 03:Completed    500000 out of 50000000 steps (1%).
22:51:26:Unit 01:Completed  46500000 out of 50000000 steps (93%).
22:52:24:Unit 03:Completed   1000000 out of 50000000 steps (2%).
22:53:00:Unit 00:Completed 9800000 out of 10000000 steps  (98%)
22:53:06:Unit 01:Completed  47000000 out of 50000000 steps (94%).
22:53:50:Unit 03:Completed   1500000 out of 50000000 steps (3%).
22:54:49:Unit 01:Completed  47500000 out of 50000000 steps (95%).
22:55:15:Unit 03:Completed   2000000 out of 50000000 steps (4%).
22:56:13:Unit 00:Completed 9900000 out of 10000000 steps  (99%)
22:56:14:Connecting to assign3.stanford.edu:8080
22:56:15:News: Welcome to Folding@Home
22:56:15:Assigned to work server 171.64.65.104
22:56:15:Requesting new work unit for slot 00: RUNNING smp:8 from 171.64.65.104
22:56:15:Connecting to 171.64.65.104:8080
22:56:17:Slot 00: Downloading 331.59KiB
22:56:26:Slot 00: 95.01%
22:56:28:Slot 00: Download complete
22:56:28:Received Unit: id:02 state:DOWNLOAD error:OK project:7611 run:2 clone:78 gen:32 core:0xa4 unit:0x0000002b664f2dd04df0f55e38a5f00b
22:56:34:Unit 01:Completed  48000000 out of 50000000 steps (96%).
22:56:40:Unit 03:Completed   2500000 out of 50000000 steps (5%).
22:58:06:Unit 03:Completed   3000000 out of 50000000 steps (6%).
22:58:20:Unit 01:Completed  48500000 out of 50000000 steps (97%).
22:59:36:Unit 00:
22:59:40:Unit 00:
22:59:41:Starting Unit 02
22:59:41:Connecting to 129.74.85.15:8080
22:59:41:Running core: C:/Users/John/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -lifeline 3476 -version 701 -checkpoint 15 -np 8
22:59:41:Started core on PID 2496
22:59:41:FahCore 0xa4 started
22:59:41:Started thread 13 on PID 3476
22:59:41:Unit 02:
22:59:41:Unit 02:*------------------------------*
22:59:41:Unit 02:Folding@Home Gromacs GB Core
22:59:41:Unit 02:Version 2.27 (Dec. 15, 2010)
22:59:41:Unit 02:
22:59:41:Unit 02:Preparing to commence simulation
22:59:41:Unit 02:- Looking at optimizations...
22:59:41:Unit 02:- Created dyn
22:59:41:Unit 02:- Files status OK
22:59:41:Unit 02:- Expanded 339039 -> 644556 (decompressed 190.1 percent)
22:59:41:Unit 02:Called DecompressByteArray: compressed_data_size=339039 data_size=644556, decompressed_data_size=644556 diff=0
22:59:41:Unit 02:- Digital signature verified
22:59:41:Unit 02:
22:59:41:Unit 02:Project: 7611 (Run 2, Clone 78, Gen 32)
22:59:41:Unit 02:
22:59:41:Unit 02:Assembly optimizations on if available.
22:59:41:Unit 02:Entering M.D.
22:59:47:Unit 02:Mapping NT from 8 to 8
22:59:47:Unit 02:Completed 0 out of 2000000 steps  (0%)
23:00:07:Unit 01:Completed  49000000 out of 50000000 steps (98%).
23:00:28:Unit 00: 3.90%
23:00:34:Unit 00: 5.85%
23:00:40:Unit 00: 8.23%
23:00:46:Unit 00: 10.83%
23:00:52:Unit 00: 13.21%
23:00:57:Unit 03:Completed   4000000 out of 50000000 steps (8%).
23:00:58:Unit 00: 14.73%
23:01:04:Unit 00: 16.89%
23:01:11:Unit 00: 19.93%
23:01:17:Unit 00: 21.44%
23:01:24:Unit 00: 23.17%
23:01:30:Unit 00: 25.56%
23:01:36:Unit 00: 27.94%
23:01:42:Unit 00: 30.10%
23:01:48:Unit 00: 33.57%
23:01:53:Unit 01:Completed  49500000 out of 50000000 steps (99%).
23:01:54:Connecting to assign-GPU.stanford.edu:80
23:01:55:Unit 00: 34.44%
23:01:57:News: Welcome to Folding@Home
23:01:57:Assigned to work server 171.67.108.54
23:01:57:Requesting new work unit for slot 02: RUNNING gpu:1:"GF110 [Geforce GTX 570 HD]" from 171.67.108.54
23:01:57:Connecting to 171.67.108.54:8080
23:01:59:Slot 02: Downloading 43.93KiB
23:02:01:Slot 02: Download complete
23:02:01:Received Unit: id:04 state:DOWNLOAD error:OK project:6802 run:0 clone:38 gen:600 core:0x15 unit:0x000002766652edc64e03a0355c793839
23:02:01:Unit 00: 36.17%
23:02:07:Unit 00: 38.55%
23:02:14:Unit 00: 41.15%
23:02:21:Unit 00: 42.23%
23:02:22:Unit 03:Completed   4500000 out of 50000000 steps (9%).
23:02:27:Unit 00: 43.75%
23:02:33:Unit 00: 46.35%
23:02:39:Unit 00: 48.51%
23:02:45:Unit 00: 51.11%
23:02:51:Unit 00: 54.58%
23:02:57:Unit 00: 56.31%
23:03:04:Unit 00: 58.04%
23:03:10:Unit 00: 59.78%
23:03:16:Unit 00: 61.51%
23:03:22:Unit 00: 63.89%
23:03:28:Unit 00: 66.06%
23:03:35:Unit 00: 68.01%
23:03:41:Unit 01:Completed  50000000 out of 50000000 steps (100%).
23:03:41:Unit 00: 69.52%
23:03:42:Unit 01:Finished fah_main status=0
23:03:42:Unit 01:Successful run
23:03:42:Unit 01:DynamicWrapper: Finished Work Unit: sleep=10000
23:03:47:Unit 03:Completed   5000000 out of 50000000 steps (10%).
23:03:49:Unit 00: 71.47%
23:03:52:Unit 01:Reserved 2466908 bytes for xtc file; Cosm status=0
23:03:52:Unit 01:Allocated 2466908 bytes for xtc file
23:03:52:Unit 01:- Reading up to 2466908 from "01/wudata_01.xtc": Read 2466908
23:03:52:Unit 01:Read 2466908 bytes from xtc file; available packet space=783963556
23:03:52:Unit 01:xtc file hash check passed.
23:03:52:Unit 01:Reserved 76680 76680 783963556 bytes for arc file=<01/wudata_01.trr> Cosm status=0
23:03:52:Unit 01:Allocated 76680 bytes for arc file
23:03:52:Unit 01:- Reading up to 76680 from "01/wudata_01.trr": Read 76680
23:03:52:Unit 01:Read 76680 bytes from arc file; available packet space=783886876
23:03:52:Unit 01:trr file hash check passed.
23:03:52:Unit 01:Allocated 544 bytes for edr file
23:03:52:Unit 01:Read bedfile
23:03:52:Unit 01:edr file hash check passed.
23:03:52:Unit 01:Allocated 120595 bytes for logfile
23:03:52:Unit 01:Read logfile
23:03:52:Unit 01:GuardedRun: success in DynamicWrapper
23:03:52:Unit 01:GuardedRun: done
23:03:52:Unit 01:Run: GuardedRun completed.
23:03:55:Unit 01:+ Opened results file
23:03:55:Unit 01:- Writing 2665239 bytes of core data to disk...
23:03:56:Unit 00: 74.94%
23:03:56:Unit 01:Done: 2664727 -> 2509505 (compressed to 94.1 percent)
23:03:56:Unit 01:  ... Done.
23:03:56:Unit 01:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
23:03:56:Unit 01:Shutting down core
23:03:56:Unit 01:
23:03:56:Unit 01:Folding@home Core Shutdown: FINISHED_UNIT
23:03:56:FahCore, running Unit 01, returned: FINISHED_UNIT (100 = 0x64)
23:03:56:Sending unit results: id:01 state:SEND error:OK project:6801 run:5747 clone:1 gen:75 core:0x15 unit:0x000000530a3b1e644d94b7a5a8e45968
23:03:56:Unit 01: Uploading 2.39MiB to 171.64.65.64
23:03:56:Connecting to 171.64.65.64:8080
23:03:57:Starting Unit 04
23:03:57:Running core: C:/Users/John/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 04 -suffix 01 -lifeline 3476 -version 701 -checkpoint 15 -gpu 1
23:03:57:Started core on PID 4168
23:03:57:FahCore 0x15 started
23:03:57:Started thread 14 on PID 3476
23:03:57:Unit 04:
23:03:57:Unit 04:*------------------------------*
23:03:57:Unit 04:Folding@Home GPU Core
23:03:57:Unit 04:Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
23:03:57:Unit 04:Build host             SimbiosNvdWin7
23:03:57:Unit 04:Board Type             NVIDIA/CUDA
23:03:57:Unit 04:Core                   15
23:03:57:Unit 04:GPU device id          1
23:03:57:Unit 04:
23:03:57:Unit 04:Window's signal control handler registered.
23:03:57:Unit 04:Preparing to commence simulation
23:03:57:Unit 04:- Looking at optimizations...
23:03:57:Unit 04:DeleteFrameFiles: successfully deleted file=04/wudata_01.ckp
23:03:57:Unit 04:- Created dyn
23:03:57:Unit 04:- Files status OK
23:03:57:Unit 04:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:03:57:Unit 04:- Expanded 44468 -> 167707 (decompressed 377.1 percent)
23:03:57:Unit 04:Called DecompressByteArray: compressed_data_size=44468 data_size=167707, decompressed_data_size=167707 diff=0
23:03:57:Unit 04:- Digital signature verified
23:03:57:Unit 04:
23:03:57:Unit 04:Project: 6802 (Run 0, Clone 38, Gen 600)
23:03:57:Unit 04:
23:03:57:Unit 04:Assembly optimizations on if available.
23:03:57:Unit 04:Entering M.D.
23:03:59:Unit 04:Tpr hash 04/wudata_01.tpr:  22322692 2060490871 3954136266 3632927397 1217471035
23:03:59:Unit 04:calling fah_main gpuDeviceId=1
23:03:59:Unit 04:Working on ALZHEIMER'S DISEASE AMYLOID
23:03:59:Unit 04:Client config unavailable.
23:03:59:Unit 04:Starting GUI Server
23:04:02:Unit 00: 77.32%
23:04:03:Unit 01: 1.63%
23:04:08:Unit 00: 78.83%
23:04:10:Unit 01: 3.10%
23:04:14:Unit 00: 79.48%
23:04:16:Unit 01: 4.73%
23:04:23:Unit 01: 5.71%
23:04:24:Unit 00: 81.87%
23:04:29:Unit 01: 7.34%
23:04:30:Unit 00: 82.73%
23:04:37:Unit 01: 8.49%
23:04:38:Unit 00: 84.03%
23:04:43:Unit 01: 9.95%
23:04:46:Unit 00: 86.63%
23:04:50:Unit 01: 11.75%
23:04:54:Unit 00: 87.50%
23:04:56:Unit 01: 13.87%
23:05:00:Unit 00: 88.58%
23:05:02:Unit 01: 15.18%
23:05:04:Unit 04:Setting checkpoint frequency: 500000
23:05:04:Unit 04:Completed         3 out of 50000000 steps (0%).
23:05:06:Unit 00: 89.88%
23:05:08:Unit 01: 16.32%
23:05:12:Unit 00: 90.96%
23:05:13:Unit 03:Completed   5500000 out of 50000000 steps (11%).
23:05:14:Unit 01: 18.60%
23:05:18:Unit 00: 92.26%
23:05:20:Unit 01: 20.07%
23:05:24:Unit 00: 94.43%
23:05:26:Unit 01: 22.68%
23:05:30:Unit 00: 95.51%
23:05:32:Unit 01: 24.15%
23:05:36:Unit 00: 97.68%
23:05:38:Unit 01: 25.13%
23:05:42:Unit 00: 100.00%
23:05:45:Unit 01: 26.76%
23:05:45:Cleaning up Unit 00
Re: Uploading to 129.74.85.16 - not like results, dumping
Back off the overclocking a little. Corrupted data in the WU is the most common cause of this message.
ViTe
Post by ViTe »
I have no overclocking and today I've got the same problem. And I've never seen this before :) All my WUs always was fine.
I tried to upload this unit 4-5 times but never was able to fit into 15 minutes (temporary used pretty slow 3G connection). After 15 minutes of uploading - restart.
And... At last! Uploaded 100% in almost 15 minutes but... "Server did not like results, dumping".
(BTW... Why we have just 15 minutes per upload?)
01:45:08:Sending unit results: id:03 state:SEND error:OK project:7903 run:131 clone:9 gen:5 core:0xa4 unit:0x0000000800ac9c214eca685fd266d73c
01:45:09:Unit 03: Uploading 28.83MiB to 129.74.85.16
01:45:09:Connecting to 129.74.85.16:8080
01:45:10:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
01:45:15:Unit 03: 0.05%
01:45:21:Unit 03: 0.26%
01:59:09:Unit 03: 97.77%
01:59:15:Unit 03: 98.55%
01:59:21:Unit 03: 99.37%
01:59:26:Unit 03: Upload complete
01:59:26:Server responded WORK_QUIT (404)
01:59:26:WARNING: Server did not like results, dumping
01:59:26:Cleaning up Unit 03
If the data is corrupt, science can't use the data and the server dumps it. There's no way to know if the data was corrupted by overclocking (etc.) or other local hardware issues or during the transmission phase. All the server knows is that it got a complete WU which was defective. The fact that it couldn't upload in 4-5 times is probably an indication that it's a problem in the network but like I said, that's a guess.
You have a server with (say, 400) connections and 375 are in use either uploading or downloading WUs. As time passes, most people finish uploading or downloading, freeing a connection and others come looking for a connection so the 375 is NOT a constant. Some connections simply do not finish uploading, the computer simply stops sending or accepting data without an error indication. If, during 15 minutes, that happens 25 times, the server will have 375 active connections an 25 defunct connections and none will be available if somebody needs to connect. Apparently (I don't actually know) the server clears any connection that is older than 15 minutes as a way of clearing defunct connections. Unfortunately, it may clear a few really slow connections at the same time.
For uniprocessor WUs, the client has a setting for WU size that was used a lot in the days of dial-up modems. It's supposed to limit the size of the upload or download data package to keep it from giving you work that's inconsistent with your internet speed. Most people don't use it, so I can't guarantee it works, but try it and see. In v7, the setting is 'max-packet-size' of 'small' or 'normal' or 'big'
Please note that not all Servers have the timeout of 15 minutes. They vary according to the upload size of the wuresult and the researchers do keep the limits reasonably consistent with the projects on that server.
