Hidden service
Stonecold
Hidden service
Post by Stonecold »
Is there any way to configure or modify Folding@home so that it runs as a hidden service in the background and cannot be accessed in the system tray? Is there a way to do that or is there some third party program that hides it? Just wondering.
Re: Hidden service
Services cannot be hidden, but you can run the client w/ nothing in the tray. Unfortunately, most peopple that ask this questios have nefarious intentions. No offense intended.
Stonecold
Re: Hidden service
Post by Stonecold »
None taken! How do you run the client without the tray icon?
Re: Hidden service
You need a console client. In configuration, answer yes to the option " Launch automatically, install as a service in this directory (yes/no) [no]?". You might have to answer yes to "Change advanced options (yes/no) [no]?" to get access to the option.
Also, keep in mind that GPU client won't run when installed as service.
derrickmcc
Hardware configuration: 2 x GTX 460 (825/1600/1650)
AMD Athlon II X2 250 3.0Ghz
Kingston 2Gb DDR2 1066 Mhz
MSI K9A2 Platinum
Western Digital 500Gb Sata II
LiteOn DVD
Coolermaster 900W UCP
Antec 902
Windows XP SP3
Re: Hidden service
Post by derrickmcc »
toTOW wrote:You need a console client. In configuration, answer yes to the option " Launch automatically, install as a service in this directory (yes/no) [no]?". You might have to answer yes to "Change advanced options (yes/no) [no]?" to get access to the option.
GPU client will run as a service on Windows XP, but not on later versions of Windows (Vista, Windows7)
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Re: Hidden service
Post by MtM »
Adding to that, V7 can also run as service if only smp or uniprocessor slots are configured ( xp would enable gpu's as well ).
Stonecold
Re: Hidden service
Post by Stonecold »
derrickmcc wrote:GPU client will run as a service on Windows XP, but not on later versions of Windows (Vista, Windows7)
Why did they drop that feature?
MtM
Re: Hidden service
Post by MtM »
Not a Stanford design issue, windows xp was the latest which allowed a service direct hardware access. All later versions don't allow it to minimize the possibilities of a security exploit, so if you want to complain do it to Microsoft for trying to make their software less vulnerable to hackers and malware :lol:
Stonecold
Re: Hidden service
Post by Stonecold »
Is there a way to re-enable it on Windows 7? I'm not worried about hackers, and as for malware I could probably find a way to only allow a specific service/program hardware access. Also, by direct hardware access do you mean low-level hardware access in particular or access to hardware in general?
MtM
Re: Hidden service
Post by MtM »
Nope, it's just no accessible anymore.
http://folding.stanford.edu/English/FAQ-NVIDIA#ntoc14
Stonecold
Re: Hidden service
Post by Stonecold »
I've found out how to run it as a hidden service. I use the program cmdow (it works great!) with the command-line client.
MtM
Re: Hidden service
Post by MtM »
Stonecold wrote:I've found out how to run it as a hidden service. I use the program cmdow (it works great!) with the command-line client.
Just to be clear as to prevent people from thinking otherwise, it's not a service as you can't run gpu clients under a service. You're probably running some tool which hides the cmd window so you don't see it, but it's not the same as running on as a service. I am happy you found something which does what you wanted to do.
Stonecold
Re: Hidden service
Post by Stonecold »
I'm not thinking of the GPU client, only SMP (or uniprocessor).
Re: Hidden service
Then why didn't you use the service provided by FAH? There's no need for an add-on program (though there's really no harm in using it if you choose to). Microsoft's security prohibition against running the GPU in a service is a distinct problem. There are other possible advantages of a Windows service which may or may not apply to you. A Windows service can start before you log on and can remain running if you log out but don't shut down (e.g.- if there are multiple Windows user accounts). It's also one of the possible solutions on systems where Windows Update decides to reboot.
Stonecold
Re: Hidden service
Post by Stonecold »
bruce wrote:Then why didn't you use the service provided by FAH? There's no need for an add-on program (though there's really no harm in using it if you choose to).
I don't want it to be detected AS a service, but I want it to imitate one (sort of) while still being able to run in the background.
