From my log:
15:14:47:Sending unit results: id:02 state:SEND error:OK project:5768 run:7 clone:229 gen:368 core:0x11 unit:0x413492b34f08503a017000e500071688
15:14:47:Unit 02: Uploading 88.72KiB to 171.67.108.11
15:14:47:Connecting to 171.67.108.11:8080
15:14:48:WARNING: WorkServer connection failed on port 8080 trying 80
15:14:48:Connecting to 171.67.108.11:80
15:14:51:WARNING: Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
15:14:51:Trying to send results to collection server
15:14:51:Unit 02: Uploading 88.72KiB to 171.67.108.25
15:14:51:Connecting to 171.67.108.25:8080
15:14:52:WARNING: WorkServer connection failed on port 8080 trying 80
15:14:52:Connecting to 171.67.108.25:80
15:14:55:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
171.67.108.11 reject
starkreiten
Re: WU won't upload
Looks like that work server is rejecting connections and the collection server is in standby. The Client will keep trying to send your WU until it gets there, no worries.
Of course, I could be wrong....
- AMD 1090t Win7/64 2xGTX460 SMP + 2xGPU
- Intel U7300 LMDE/64 2xUniprocessor
gwildperson
Re: WU won't upload
This type of problem is generally reported in the forum "Issues with a specific server" where you will often find other reports associated with the same server. A moderator will probably move it there.
See Subject: Troubleshooting Server Connectivity Issues (Do This First) for more information.
Mod Edit: Topic Moved - PantherX
