[19:29:34] Project: 7631 (Run 6, Clone 0, Gen 0)
[19:29:34]
[19:29:35] Assembly optimizations on if available.
[19:29:35] Entering M.D.
[19:29:37] Tpr hash work/wudata_01.tpr: 1109549229 1342504204 3731273943 2669196714 4114874954
[19:29:37] GPU device info: vendor=0 device=0 name=<NA> match=0
[19:29:37] Working on Protein in water
[19:29:37] Client config found, loading data.
[19:29:37] Starting GUI Server
[19:31:06] Setting checkpoint frequency: 20000
[19:31:06] Completed 3 out of 2000000 steps (0%).
[19:51:39] Completed 20000 out of 2000000 steps (1%).
[19:51:39] mdrun_gpu returned 52
[19:51:39] NANs detected on GPU
[19:51:39]
[19:51:39] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:51:43] CoreStatus = 7A (122)
[19:51:43] Sending work to server
[19:51:43] Project: 7631 (Run 6, Clone 0, Gen 0)
[19:51:43] - Error: Could not get length of results file work/wuresults_01.dat
[19:51:43] - Error: Could not read unit 01 file. Removing from queue.
[19:51:43] - Preparing to get new work unit...
[19:51:43] Cleaning up work directory
[19:51:43] + Attempting to get work packet
[19:51:43] Gpu type=3 species=21.
[19:51:43] - Connecting to assignment server
[19:51:44] - Successful: assigned to (171.64.65.105).
[19:51:44] + News From Folding@Home: Welcome to Folding@Home
[19:51:44] Loaded queue successfully.
[19:51:44] Gpu type=3 species=21.
[19:51:49] + Closed connections
[19:51:54]
[19:51:54] + Processing work unit
[19:51:54] Core required: FahCore_15.exe
[19:51:54] Core found.
[19:51:54] Working on queue slot 02 [January 5 19:51:54 UTC]
[19:51:54] + Working ...
[19:51:54]
[19:51:54] *------------------------------*
[19:51:54] Folding@Home GPU Core
[19:51:54] Version 2.22 (Thu Dec 8 17:08:05 PST 2011)
[19:51:54] Build host SimbiosNvdWin7
[19:51:54] Board Type NVIDIA/CUDA
[19:51:54] Core 15
[19:51:54]
[19:51:54] Window's signal control handler registered.
[19:51:54] Preparing to commence simulation
[19:51:54] - Looking at optimizations...
[19:51:54] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[19:51:54] - Created dyn
[19:51:54] - Files status OK
[19:51:54] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:51:54] - Expanded 430708 -> 974568 (decompressed 226.2 percent)
[19:51:54] Called DecompressByteArray: compressed_data_size=430708 data_size=974568, decompressed_data_size=974568 diff=0
[19:51:54] - Digital signature verified
[19:51:54]
[19:51:54] Project: 7631 (Run 6, Clone 0, Gen 0)
[19:51:54]
[19:51:54] Assembly optimizations on if available.
[19:51:54] Entering M.D.
[19:51:56] Tpr hash work/wudata_02.tpr: 1109549229 1342504204 3731273943 2669196714 4114874954
[19:51:56] GPU device info: vendor=0 device=0 name=<NA> match=0
[19:51:57] Working on Protein in water
[19:51:57] Client config found, loading data.
[19:51:57] Starting GUI Server
[19:53:27] Setting checkpoint frequency: 20000
[19:53:27] Completed 3 out of 2000000 steps (0%).
[20:14:00] Completed 20000 out of 2000000 steps (1%).
[20:14:00] mdrun_gpu returned 52
[20:14:00] NANs detected on GPU
[20:14:00]
[20:14:00] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:14:03] CoreStatus = 7A (122)
[20:14:03] Sending work to server
[20:14:03] Project: 7631 (Run 6, Clone 0, Gen 0)
[20:14:03] - Error: Could not get length of results file work/wuresults_02.dat
[20:14:03] - Error: Could not read unit 02 file. Removing from queue.
[20:14:03] - Preparing to get new work unit...
[20:14:03] Cleaning up work directory
[20:14:03] + Attempting to get work packet
[20:14:03] Gpu type=3 species=21.
[20:14:03] - Connecting to assignment server
[20:14:05] - Successful: assigned to (171.64.65.105).
[20:14:05] + News From Folding@Home: Welcome to Folding@Home
[20:14:05] Loaded queue successfully.
[20:14:05] Gpu type=3 species=21.
[20:14:09] + Closed connections
[20:14:14]
[20:14:14] + Processing work unit
[20:14:14] Core required: FahCore_15.exe
[20:14:14] Core found.
[20:14:14] Working on queue slot 03 [January 5 20:14:14 UTC]
[20:14:14] + Working ...
[20:14:15]
[20:14:15] *------------------------------*
[20:14:15] Folding@Home GPU Core
[20:14:15] Version 2.22 (Thu Dec 8 17:08:05 PST 2011)
[20:14:15] Build host SimbiosNvdWin7
[20:14:15] Board Type NVIDIA/CUDA
[20:14:15] Core 15
[20:14:15]
[20:14:15] Window's signal control handler registered.
[20:14:15] Preparing to commence simulation
[20:14:15] - Looking at optimizations...
[20:14:15] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[20:14:15] - Created dyn
[20:14:15] - Files status OK
[20:14:15] sizeof(CORE_PACKET_HDR) = 512 file=<>
[20:14:15] - Expanded 430708 -> 974568 (decompressed 226.2 percent)
[20:14:15] Called DecompressByteArray: compressed_data_size=430708 data_size=974568, decompressed_data_size=974568 diff=0
[20:14:16] - Digital signature verified
[20:14:16]
[20:14:16] Project: 7631 (Run 6, Clone 0, Gen 0)
[20:14:16]
[20:14:16] Assembly optimizations on if available.
[20:14:16] Entering M.D.
[20:14:18] Tpr hash work/wudata_03.tpr: 1109549229 1342504204 3731273943 2669196714 4114874954
[20:14:18] GPU device info: vendor=0 device=0 name=<NA> match=0
[20:14:18] Working on Protein in water
[20:14:18] Client config found, loading data.
[20:14:18] Starting GUI Server
[20:15:47] Setting checkpoint frequency: 20000
[20:15:47] Completed 3 out of 2000000 steps (0%).
[20:16:28] + Working...
[20:36:20] Completed 20000 out of 2000000 steps (1%).
[20:36:20] mdrun_gpu returned 52
[20:36:20] NANs detected on GPU
[20:36:20]
[20:36:20] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:36:23] CoreStatus = 7A (122)
[20:36:23] Sending work to server
[20:36:23] Project: 7631 (Run 6, Clone 0, Gen 0)
[20:36:23] - Error: Could not get length of results file work/wuresults_03.dat
[20:36:23] - Error: Could not read unit 03 file. Removing from queue.
[20:36:23] - Preparing to get new work unit...
[20:36:23] Cleaning up work directory
[20:36:23] + Attempting to get work packet
[20:36:23] Gpu type=3 species=21.
[20:36:23] - Connecting to assignment server
[20:36:25] - Successful: assigned to (171.64.65.105).
[20:36:25] + News From Folding@Home: Welcome to Folding@Home
[20:36:25] Loaded queue successfully.
[20:36:25] Gpu type=3 species=21.
[20:36:29] + Closed connections
[20:36:34]
[20:36:34] + Processing work unit
[20:36:34] Core required: FahCore_15.exe
[20:36:34] Core found.
[20:36:34] Working on queue slot 04 [January 5 20:36:34 UTC]
[20:36:34] + Working ...
[20:36:35]
[20:36:35] *------------------------------*
[20:36:35] Folding@Home GPU Core
[20:36:35] Version 2.22 (Thu Dec 8 17:08:05 PST 2011)
[20:36:35] Build host SimbiosNvdWin7
[20:36:35] Board Type NVIDIA/CUDA
[20:36:35] Core 15
[20:36:35]
[20:36:35] Window's signal control handler registered.
[20:36:35] Preparing to commence simulation
[20:36:35] - Looking at optimizations...
[20:36:35] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[20:36:35] - Created dyn
[20:36:35] - Files status OK
[20:36:35] sizeof(CORE_PACKET_HDR) = 512 file=<>
[20:36:35] - Expanded 430708 -> 974568 (decompressed 226.2 percent)
[20:36:35] Called DecompressByteArray: compressed_data_size=430708 data_size=974568, decompressed_data_size=974568 diff=0
[20:36:35] - Digital signature verified
[20:36:35]
[20:36:35] Project: 7631 (Run 6, Clone 0, Gen 0)
[20:36:35]
[20:36:35] Assembly optimizations on if available.
[20:36:35] Entering M.D.
[20:36:37] Tpr hash work/wudata_04.tpr: 1109549229 1342504204 3731273943 2669196714 4114874954
[20:36:37] GPU device info: vendor=0 device=0 name=<NA> match=0
[20:36:38] Working on Protein in water
[20:36:38] Client config found, loading data.
[20:36:38] Starting GUI Server
[20:38:08] Setting checkpoint frequency: 20000
[20:38:08] Completed 3 out of 2000000 steps (0%).
[20:58:42] Completed 20000 out of 2000000 steps (1%).
[20:58:42] mdrun_gpu returned 52
[20:58:42] NANs detected on GPU
[20:58:42]
[20:58:42] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:58:45] CoreStatus = 7A (122)
[20:58:45] Sending work to server
[20:58:45] Project: 7631 (Run 6, Clone 0, Gen 0)
[20:58:45] - Error: Could not get length of results file work/wuresults_04.dat
[20:58:45] - Error: Could not read unit 04 file. Removing from queue.
[20:58:45] - Preparing to get new work unit...
[20:58:45] Cleaning up work directory
[20:58:45] + Attempting to get work packet
[20:58:45] Gpu type=3 species=21.
[20:58:45] - Connecting to assignment server
[20:58:47] - Successful: assigned to (171.64.65.105).
[20:58:47] + News From Folding@Home: Welcome to Folding@Home
[20:58:47] Loaded queue successfully.
[20:58:47] Gpu type=3 species=21.
[20:58:52] + Closed connections
[20:58:57]
[20:58:57] + Processing work unit
[20:58:57] Core required: FahCore_15.exe
[20:58:57] Core found.
[20:58:57] Working on queue slot 05 [January 5 20:58:57 UTC]
[20:58:57] + Working ...
[20:58:57]
[20:58:57] *------------------------------*
[20:58:57] Folding@Home GPU Core
[20:58:57] Version 2.22 (Thu Dec 8 17:08:05 PST 2011)
[20:58:57] Build host SimbiosNvdWin7
[20:58:57] Board Type NVIDIA/CUDA
[20:58:57] Core 15
[20:58:57]
[20:58:57] Window's signal control handler registered.
[20:58:57] Preparing to commence simulation
[20:58:57] - Looking at optimizations...
[20:58:57] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[20:58:57] - Created dyn
[20:58:57] - Files status OK
[20:58:57] sizeof(CORE_PACKET_HDR) = 512 file=<>
[20:58:57] - Expanded 430708 -> 974568 (decompressed 226.2 percent)
[20:58:57] Called DecompressByteArray: compressed_data_size=430708 data_size=974568, decompressed_data_size=974568 diff=0
[20:58:57] - Digital signature verified
[20:58:57]
[20:58:57] Project: 7631 (Run 6, Clone 0, Gen 0)
[20:58:57]
[20:58:57] Assembly optimizations on if available.
[20:58:57] Entering M.D.
[20:59:00] Tpr hash work/wudata_05.tpr: 1109549229 1342504204 3731273943 2669196714 4114874954
[20:59:00] GPU device info: vendor=0 device=0 name=<NA> match=0
[20:59:00] Working on Protein in water
[20:59:00] Client config found, loading data.
[20:59:00] Starting GUI Server
[21:00:28] Setting checkpoint frequency: 20000
[21:00:28] Completed 3 out of 2000000 steps (0%).
[21:21:04] Completed 20000 out of 2000000 steps (1%).
[21:21:04] mdrun_gpu returned 52
[21:21:04] NANs detected on GPU
[21:21:04]
[21:21:04] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:21:08] CoreStatus = 7A (122)
[21:21:08] Sending work to server
[21:21:08] Project: 7631 (Run 6, Clone 0, Gen 0)
[21:21:08] - Error: Could not get length of results file work/wuresults_05.dat
[21:21:08] - Error: Could not read unit 05 file. Removing from queue.
[21:21:08] EUE limit exceeded. Pausing 24 hours
