Project: 6803 (Run 6, Clone 19, Gen 672)
DocJonz
Post by DocJonz »
This WU seems to be causing one of my GTX 560's some headaches. No OC, temps frosty, has been Folding for at least several months .....
[21:55:58] Completed  50000000 out of 50000000 steps (100%).
[21:55:58] Finished fah_main status=0
[21:55:58] Successful run
[21:55:58] DynamicWrapper: Finished Work Unit: sleep=10000
[21:56:08] Reserved 241152 bytes for xtc file; Cosm status=0
[21:56:08] Allocated 241152 bytes for xtc file
[21:56:08] - Reading up to 241152 from "work/wudata_09.xtc": Read 241152
[21:56:08] Read 241152 bytes from xtc file; available packet space=786189312
[21:56:08] xtc file hash check passed.
[21:56:08] Reserved 74880 74880 786189312 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[21:56:08] Allocated 74880 bytes for arc file
[21:56:08] - Reading up to 74880 from "work/wudata_09.trr": Read 74880
[21:56:08] Read 74880 bytes from arc file; available packet space=786114432
[21:56:08] trr file hash check passed.
[21:56:08] Allocated 544 bytes for edr file
[21:56:08] Read bedfile
[21:56:08] edr file hash check passed.
[21:56:08] Allocated 36697 bytes for logfile
[21:56:08] Read logfile
[21:56:08] GuardedRun: success in DynamicWrapper
[21:56:08] GuardedRun: done
[21:56:08] Run: GuardedRun completed.
[21:56:09] + Opened results file
[21:56:09] - Writing 353785 bytes of core data to disk...
[21:56:09] Done: 353273 -> 321521 (compressed to 91.0 percent)
[21:56:09]   ... Done.
[21:56:09] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[21:56:10] Shutting down core
[21:56:10]
[21:56:10] Folding@home Core Shutdown: FINISHED_UNIT
[21:56:12] CoreStatus = 64 (100)
[21:56:12] Sending work to server
[21:56:12] Project: 6802 (Run 3, Clone 90, Gen 532)
[21:56:12] - Read packet limit of 540015616... Set to 524286976.
[21:56:12] + Attempting to send results [January 2 21:56:12 UTC]
[21:56:12] Gpu type=3 species=21.
[21:56:16] + Results successfully sent
[21:56:16] Thank you for your contribution to Folding@Home.
[21:56:16] + Number of Units Completed: 69
[21:56:20] - Preparing to get new work unit...
[21:56:20] Cleaning up work directory
[21:56:20] + Attempting to get work packet
[21:56:20] Passkey found
[21:56:20] Gpu type=3 species=21.
[21:56:20] - Connecting to assignment server
[21:56:21] - Successful: assigned to (171.67.108.54).
[21:56:21] + News From Folding@Home: Welcome to Folding@Home
[21:56:22] Loaded queue successfully.
[21:56:22] Gpu type=3 species=21.
[21:56:23] + Closed connections
[21:56:23]
[21:56:23] + Processing work unit
[21:56:23] Core required: FahCore_15.exe
[21:56:23] Core found.
[21:56:23] Working on queue slot 00 [January 2 21:56:23 UTC]
[21:56:23] + Working ...
[21:56:23]
[21:56:23] *------------------------------*
[21:56:23] Folding@Home GPU Core
[21:56:23] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[21:56:23] Build host             SimbiosNvdWin7
[21:56:23] Board Type             NVIDIA/CUDA
[21:56:23] Core                   15
[21:56:23]
[21:56:23] Window's signal control handler registered.
[21:56:23] Preparing to commence simulation
[21:56:23] - Looking at optimizations...
[21:56:23] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
[21:56:23] - Created dyn
[21:56:23] - Files status OK
[21:56:23] sizeof(CORE_PACKET_HDR) = 512 file=<>
[21:56:23] - Expanded 43887 -> 170279 (decompressed 387.9 percent)
[21:56:23] Called DecompressByteArray: compressed_data_size=43887 data_size=170279, decompressed_data_size=170279 diff=0
[21:56:23] - Digital signature verified
[21:56:23]
[21:56:23] Project: 6803 (Run 6, Clone 19, Gen 672)
[21:56:23]
[21:56:23] Assembly optimizations on if available.
[21:56:23] Entering M.D.
[21:56:25] Tpr hash work/wudata_00.tpr:  591817243 4011593156 3029219069 2484438418 1808607228
[21:56:25] calling fah_main gpuDeviceId=0
[21:56:25] Working on ALZHEIMER'S DISEASE AMYLOID
[21:56:25] Client config found, loading data.
[21:56:26] Starting GUI Server
[21:57:26] Setting checkpoint frequency: 500000
[21:57:26] Completed         3 out of 50000000 steps (0%).
[21:58:57] Completed    500000 out of 50000000 steps (1%).
[21:58:57] mdrun_gpu returned 52
[21:58:57] NANs detected on GPU
[21:58:57]
[21:58:57] Folding@home Core Shutdown: UNSTABLE_MACHINE
[21:58:59] CoreStatus = 7A (122)
[21:58:59] Sending work to server
[21:58:59] Project: 6803 (Run 6, Clone 19, Gen 672)
[21:58:59] - Read packet limit of 540015616... Set to 524286976.
[21:58:59] - Error: Could not get length of results file work/wuresults_00.dat
[21:58:59] - Error: Could not read unit 00 file. Removing from queue.
[21:58:59] - Preparing to get new work unit...
[21:58:59] Cleaning up work directory
[21:58:59] + Attempting to get work packet
[21:58:59] Passkey found
[21:58:59] Gpu type=3 species=21.
[21:58:59] - Connecting to assignment server
[21:59:00] - Successful: assigned to (171.67.108.54).
[21:59:00] + News From Folding@Home: Welcome to Folding@Home
[21:59:00] Loaded queue successfully.
[21:59:00] Gpu type=3 species=21.
[21:59:02] + Closed connections
[21:59:07]
[21:59:07] + Processing work unit
[21:59:07] Core required: FahCore_15.exe
[21:59:07] Core found.
[21:59:07] Working on queue slot 01 [January 2 21:59:07 UTC]
[21:59:07] + Working ...
[21:59:07]
[21:59:07] *------------------------------*
[21:59:07] Folding@Home GPU Core
[21:59:07] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[21:59:07] Build host             SimbiosNvdWin7
[21:59:07] Board Type             NVIDIA/CUDA
[21:59:07] Core                   15
[21:59:07]
[21:59:07] Window's signal control handler registered.
[21:59:07] Preparing to commence simulation
[21:59:07] - Looking at optimizations...
[21:59:07] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[21:59:07] - Created dyn
[21:59:07] - Files status OK
[21:59:07] sizeof(CORE_PACKET_HDR) = 512 file=<>
[21:59:07] - Expanded 43887 -> 170279 (decompressed 387.9 percent)
[21:59:07] Called DecompressByteArray: compressed_data_size=43887 data_size=170279, decompressed_data_size=170279 diff=0
[21:59:07] - Digital signature verified
[21:59:07]
[21:59:07] Project: 6803 (Run 6, Clone 19, Gen 672)
[21:59:07]
[21:59:07] Assembly optimizations on if available.
[21:59:07] Entering M.D.
[21:59:09] Tpr hash work/wudata_01.tpr:  591817243 4011593156 3029219069 2484438418 1808607228
[21:59:09] calling fah_main gpuDeviceId=0
[21:59:09] Working on ALZHEIMER'S DISEASE AMYLOID
[21:59:09] Client config found, loading data.
[21:59:09] Starting GUI Server
[22:00:10] Setting checkpoint frequency: 500000
[22:00:10] Completed         3 out of 50000000 steps (0%).
[22:01:40] Completed    500000 out of 50000000 steps (1%).
[22:01:40] mdrun_gpu returned 52
[22:01:40] NANs detected on GPU
[22:01:40]
[22:01:40] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:01:43] CoreStatus = 7A (122)
[22:01:43] Sending work to server
[22:01:43] Project: 6803 (Run 6, Clone 19, Gen 672)
[22:01:43] - Read packet limit of 540015616... Set to 524286976.
[22:01:43] - Error: Could not get length of results file work/wuresults_01.dat
[22:01:43] - Error: Could not read unit 01 file. Removing from queue.
[22:01:43] - Preparing to get new work unit...
[22:01:43] Cleaning up work directory
[22:01:43] + Attempting to get work packet
[22:01:43] Passkey found
[22:01:43] Gpu type=3 species=21.
[22:01:43] - Connecting to assignment server
[22:01:44] - Successful: assigned to (171.67.108.54).
[22:01:44] + News From Folding@Home: Welcome to Folding@Home
[22:01:44] Loaded queue successfully.
[22:01:44] Gpu type=3 species=21.
[22:01:45] + Closed connections
[22:01:50]
[22:01:50] + Processing work unit
[22:01:50] Core required: FahCore_15.exe
[22:01:50] Core found.
[22:01:50] Working on queue slot 02 [January 2 22:01:50 UTC]
[22:01:50] + Working ...
[22:01:51]
[22:01:51] *------------------------------*
[22:01:51] Folding@Home GPU Core
[22:01:51] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[22:01:51] Build host             SimbiosNvdWin7
[22:01:51] Board Type             NVIDIA/CUDA
[22:01:51] Core                   15
[22:01:51]
[22:01:51] Window's signal control handler registered.
[22:01:51] Preparing to commence simulation
[22:01:51] - Looking at optimizations...
[22:01:51] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[22:01:51] - Created dyn
[22:01:51] - Files status OK
[22:01:51] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:01:51] - Expanded 43887 -> 170279 (decompressed 387.9 percent)
[22:01:51] Called DecompressByteArray: compressed_data_size=43887 data_size=170279, decompressed_data_size=170279 diff=0
[22:01:51] - Digital signature verified
[22:01:51]
[22:01:51] Project: 6803 (Run 6, Clone 19, Gen 672)
[22:01:51]
[22:01:51] Assembly optimizations on if available.
[22:01:51] Entering M.D.
[22:01:53] Tpr hash work/wudata_02.tpr:  591817243 4011593156 3029219069 2484438418 1808607228
[22:01:53] calling fah_main gpuDeviceId=0
[22:01:53] Working on ALZHEIMER'S DISEASE AMYLOID
[22:01:53] Client config found, loading data.
[22:01:53] Starting GUI Server
[22:02:54] Setting checkpoint frequency: 500000
[22:02:54] Completed         3 out of 50000000 steps (0%).
[22:04:24] Completed    500000 out of 50000000 steps (1%).
[22:04:24] mdrun_gpu returned 52
[22:04:24] NANs detected on GPU
[22:04:24]
[22:04:24] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:04:27] CoreStatus = 7A (122)
[22:04:27] Sending work to server
[22:04:27] Project: 6803 (Run 6, Clone 19, Gen 672)
[22:04:27] - Read packet limit of 540015616... Set to 524286976.
[22:04:27] - Error: Could not get length of results file work/wuresults_02.dat
[22:04:27] - Error: Could not read unit 02 file. Removing from queue.
[22:04:27] - Preparing to get new work unit...
[22:04:27] Cleaning up work directory
[22:04:27] + Attempting to get work packet
[22:04:27] Passkey found
[22:04:27] Gpu type=3 species=21.
[22:04:27] - Connecting to assignment server
[22:04:28] - Successful: assigned to (171.67.108.54).
[22:04:28] + News From Folding@Home: Welcome to Folding@Home
[22:04:28] Loaded queue successfully.
[22:04:28] Gpu type=3 species=21.
[22:04:29] + Closed connections
[22:04:34]
[22:04:34] + Processing work unit
[22:04:34] Core required: FahCore_15.exe
[22:04:34] Core found.
[22:04:34] Working on queue slot 03 [January 2 22:04:34 UTC]
[22:04:34] + Working ...
[22:04:34]
[22:04:34] *------------------------------*
[22:04:34] Folding@Home GPU Core
[22:04:34] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[22:04:34] Build host             SimbiosNvdWin7
[22:04:34] Board Type             NVIDIA/CUDA
[22:04:34] Core                   15
[22:04:34]
[22:04:34] Window's signal control handler registered.
[22:04:34] Preparing to commence simulation
[22:04:34] - Looking at optimizations...
[22:04:34] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[22:04:34] - Created dyn
[22:04:34] - Files status OK
[22:04:34] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:04:34] - Expanded 43887 -> 170279 (decompressed 387.9 percent)
[22:04:34] Called DecompressByteArray: compressed_data_size=43887 data_size=170279, decompressed_data_size=170279 diff=0
[22:04:34] - Digital signature verified
[22:04:34]
[22:04:34] Project: 6803 (Run 6, Clone 19, Gen 672)
[22:04:34]
[22:04:34] Assembly optimizations on if available.
[22:04:34] Entering M.D.
[22:04:36] Tpr hash work/wudata_03.tpr:  591817243 4011593156 3029219069 2484438418 1808607228
[22:04:36] calling fah_main gpuDeviceId=0
[22:04:36] Working on ALZHEIMER'S DISEASE AMYLOID
[22:04:36] Client config found, loading data.
[22:04:37] Starting GUI Server
[22:05:37] Setting checkpoint frequency: 500000
[22:05:37] Completed         3 out of 50000000 steps (0%).
[22:07:08] Completed    500000 out of 50000000 steps (1%).
[22:07:08] mdrun_gpu returned 52
[22:07:08] NANs detected on GPU
[22:07:08]
[22:07:08] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:07:10] CoreStatus = 7A (122)
[22:07:10] Sending work to server
[22:07:10] Project: 6803 (Run 6, Clone 19, Gen 672)
[22:07:10] - Read packet limit of 540015616... Set to 524286976.
[22:07:10] - Error: Could not get length of results file work/wuresults_03.dat
[22:07:10] - Error: Could not read unit 03 file. Removing from queue.
[22:07:10] - Preparing to get new work unit...
[22:07:10] Cleaning up work directory
[22:07:10] + Attempting to get work packet
[22:07:10] Passkey found
[22:07:10] Gpu type=3 species=21.
[22:07:10] - Connecting to assignment server
[22:07:11] - Successful: assigned to (171.67.108.54).
[22:07:11] + News From Folding@Home: Welcome to Folding@Home
[22:07:12] Loaded queue successfully.
[22:07:12] Gpu type=3 species=21.
[22:07:13] + Closed connections
[22:07:18]
[22:07:18] + Processing work unit
[22:07:18] Core required: FahCore_15.exe
[22:07:18] Core found.
[22:07:18] Working on queue slot 04 [January 2 22:07:18 UTC]
[22:07:18] + Working ...
[22:07:18]
[22:07:18] *------------------------------*
[22:07:18] Folding@Home GPU Core
[22:07:18] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[22:07:18] Build host             SimbiosNvdWin7
[22:07:18] Board Type             NVIDIA/CUDA
[22:07:18] Core                   15
[22:07:18]
[22:07:18] Window's signal control handler registered.
[22:07:18] Preparing to commence simulation
[22:07:18] - Looking at optimizations...
[22:07:18] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[22:07:18] - Created dyn
[22:07:18] - Files status OK
[22:07:18] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:07:18] - Expanded 43887 -> 170279 (decompressed 387.9 percent)
[22:07:18] Called DecompressByteArray: compressed_data_size=43887 data_size=170279, decompressed_data_size=170279 diff=0
[22:07:18] - Digital signature verified
[22:07:18]
[22:07:18] Project: 6803 (Run 6, Clone 19, Gen 672)
[22:07:18]
[22:07:18] Assembly optimizations on if available.
[22:07:18] Entering M.D.
[22:07:20] Tpr hash work/wudata_04.tpr:  591817243 4011593156 3029219069 2484438418 1808607228
[22:07:20] calling fah_main gpuDeviceId=0
[22:07:20] Working on ALZHEIMER'S DISEASE AMYLOID
[22:07:20] Client config found, loading data.
[22:07:21] Starting GUI Server
[22:08:21] Setting checkpoint frequency: 500000
[22:08:21] Completed         3 out of 50000000 steps (0%).
[22:09:52] Completed    500000 out of 50000000 steps (1%).
[22:09:52] mdrun_gpu returned 52
[22:09:52] NANs detected on GPU
[22:09:52]
[22:09:52] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:09:54] CoreStatus = 7A (122)
[22:09:54] Sending work to server
[22:09:54] Project: 6803 (Run 6, Clone 19, Gen 672)
[22:09:54] - Read packet limit of 540015616... Set to 524286976.
[22:09:54] - Error: Could not get length of results file work/wuresults_04.dat
[22:09:54] - Error: Could not read unit 04 file. Removing from queue.
[22:09:54] EUE limit exceeded. Pausing 24 hours.
[01:41:10] + Working...
Mod Note: Followup report closed Feb 7, 2012. There is still no data in the db for Gen 672 of this WU or beyond.
Re: P6803 (R6, C19, G672)
Nothing in the WU Database:
No data back from query
Furthermore, I don't think that I would see any error report in the WU Database because of these lines:
Nonetheless, I have marked it for a followup.
DocJonz
Post by DocJonz »
Thanks for checking.
Interestingly, this is the first WU issue I've had in ages, across any of my machines - looks like the QA processes have been improved ..... ?
DocJonz
Post by DocJonz »
I've just had a separate rig, also with a GTX 560Ti, pick up this WU and drop out in exactly the same way ......
