Project 7135 R0 C11 G475 Client-core communications error
SwingOp3
Post by SwingOp3 »
As the title says my machine could not start working on this unit as it would error out at 0% multiple times. After much checking I ended up changing machine id and have picked up another unit that is doing fine.
I have not seen any previous issues with this wu on this forum before so I'm not sure if its me or the wu.
Edit: I see now that "C0000005" indicates a Windows memory error.
My apologies if I cried, "Wolf".
Re: Project 7135 R0 C11 G475 Client-core communications erro
Welcome to the F@H Forum SwingOp3,
There are three failures in the WU Database so I have marked it as a bad WU:
The WU (P7135,R0,C11,G475) has been reported as a bad WU.
Thanks for your report.
