FAHWatch7
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
FAHWatch7
Post by MtM »
Current version: 0.1.0.6C last updated 2/7/2012 11:49AM gmt+1
Homepage -> http://code.google.com/p/cftunity/
Link to old thread
Update:
Pictures can't show the menu items so for a good impression just download and give it a try :)
zip archive -> http://code.google.com/p/cftunity/downl ... p&can=2&q=
installer -> http://code.google.com/p/cftunity/downl ... p&can=2&q=
I do have some notes ->
  • Position and window state is stored, columns can be reordered but order isn't saved on exit. Hiding columns you don't need isn't working either ( but I'll add the functionality later ).
  • I been adding fields to the db since there was an interest for them ( and then found out it's way easier as well just because it means I don't have to load all the frame data to get tpf values :) thx GreyWiskers! ). But, having sqlite database browser and FAHWatch7 open at the same time will cause problems ( database locking ).
  • Options for notifications can be set, but they don't yet work.
  • Performance statistics give an overview of your current hardware configuration only. Hardware statistics and project statistics give an overview of all configurations. For example ->
    I switched the hd4350 around between pc's, but all work units are counted in hardware and project statistics, where with performance statistics all work units which are not run in current configuration are discarded.
  • PPD is calculated as total credit divided by (datetime the last unit completed - datetime the fist workunit was downloaded) everywhere except in project statistics where average for projects is just that, avg for project.
There are current 3 command line options
'simplebrowser' for bypassing the netapi calls completely ( without the flag a timer detects a stalled attempt and also shows the standard folderbrowser dialog ).
'whitelist' which will run the fahclient lspci command and displays results matching actual gpu pciID's.
'diagnostic' which will report the hardware information from openhardwaremonitorlib.dll, opencl/cuda/cal enumeration and client info and event log entries matching FAHClient/FAHControl/FahCore_xx.
It's not feature complete (edit: BY FAR), 0.0.9.2 offered live monitoring which I dropped to concentrate on history overview and statistics ( which did pay off I think, even if I didn't manage to add a graph generating function yet ). Note 0.0.9.2 does not work with the last release due to changed log formatting.
The uninstaller leaves the program folder since it doesn't delete the database and log files, this will be fixed ( I need to change the data location to application data anyway ).
zacken542
Re: FAHWatch7
Post by zacken542 »
Uppgrade FAH to V7.1.43 now FAHwatch7 not finding any more data
need a new version I think
Sven Åke
MtM
Re: FAHWatch7
Post by MtM »
I am aware of it already, and there will be an update shortly :)
MtM
Re: FAHWatch7
Post by MtM »
MtM wrote:I am aware of it already, and there will be an update shortly :)
Well not shortly, but alas -> http://code.google.com/p/cftunity/downl ... p&can=2&q=
No live monitoring yet, sorry. Designing a layout with sensor readings and work unit information is causing me some headaches :(
Edit:
Calxalot is participating in the SOPA blackout ( thumbsup! )
Welcome to calxalot's software.
I'm participating in the SOPA Blackout.
I forgot to change the psummary url back to stanford.edu, so if you install in the options screen change the psummary ur to:
http://fah-web.stanford.edu/psummary.html
The reason I default to his psummary is because it has a higher retention which is useful since FAHWatch goes back as far as your logs hold data, and psummary in my own experience already did not have any references to projects I completed. My log rotation is standard, so people with higher values will for sure benefit from the default calxalot psummary copy.
I should perhaps always try to default to Stanfords psummary when another url isn't reachable, that's not a bad idea :!:
Grandpa_01
Re: FAHWatch7
Post by Grandpa_01 »
I do not know if this will help or not but It is not parsing on my wifes rig. I have not tried it on the others yet.
[1/19/2012] * 5:11:08 PM - ****** FAHWatch7_preview 0.1.0.0 logging started ******
[1/19/2012] * 5:11:08 PM - DEBUG: Application init started, splash: True
[1/19/2012] * 5:11:08 PM - Found FAHClient folders!
[1/19/2012] * 5:11:08 PM - DEBUG: Start slot parse
[1/19/2012] * 5:11:08 PM - DEBUG: Parsed 0:SMP
[1/19/2012] * 5:11:08 PM - DEBUG: Slot added
[1/19/2012] * 5:11:08 PM - Client config obtained
[1/19/2012] * 5:11:08 PM - Client info obtained
[1/19/2012] * 5:11:08 PM - Initializing database access
[1/19/2012] * 5:11:08 PM - DEBUG: tryopencon 0 called, dtNow=2000-01-01T00:00:00 TimeOut=00:00:05 tsWait=00:00:00
[1/19/2012] * 5:11:08 PM - DEBUG: sqliteconnection 0 state changed from Closed to Open
[1/19/2012] * 5:11:08 PM - Created sqlitecommand for instance 0
[1/19/2012] * 5:11:08 PM - DEBUG: sqliteconnection 0 commited a transaction - True
[1/19/2012] * 5:11:08 PM - Starting hardware detection
[1/19/2012] * 5:11:09 PM - Getting environment information:
[1/19/2012] * 5:11:09 PM - Administrator rights detected.
[1/19/2012] * 5:11:09 PM - Platform: Windows7
[1/19/2012] * 5:11:09 PM - DEBUG: Diagnostics being saved to C:\Users\Barbie\AppData\Roaming\FAHClient
[1/19/2012] * 5:11:09 PM - No settings stored, showing first run wizard.
[1/19/2012] * 5:12:40 PM - DEBUG: createtransaction:0
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 1
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 2
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 3
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 4
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 5
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 6
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 7
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 8
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 9
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 10
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 11
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 12
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 13
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 14
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 15
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 16
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 17
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 18
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 19
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 20
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 21
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 22
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 23
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 24
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 25
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 26
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 27
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 28
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 29
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 30
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 31
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 32
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 33
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 34
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 35
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 36
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 37
[1/19/2012] * 5:12:40 PM - DEBUG: endtransaction:0
[1/19/2012] * 5:12:40 PM - DEBUG: sqliteconnection 0 commited a transaction - True
[1/19/2012] * 5:12:40 PM - DEBUG: Continuing from initial options form
[1/19/2012] * 5:12:40 PM - Initializing project info
[1/19/2012] * 5:12:42 PM - GetProjects took 1606.8028ms.
[1/19/2012] * 5:12:42 PM - Creating projectinfo table
[1/19/2012] * 5:12:42 PM - DEBUG: sqliteconnection 0 commited a transaction - True
[1/19/2012] * 5:12:42 PM - New project information downloaded
[1/19/2012] * 5:12:49 PM - Parsing logs started at 1/19/2012 5:12:49 PM
[1/19/2012] * 5:12:49 PM - Started logparser
[1/19/2012] * 5:12:49 PM - DEBUG: Started parselog thread for BARBIE-PC on threadid: 8
[1/19/2012] * 5:12:49 PM - DEBUG: Parsing client BARBIE-PC
[1/19/2012] * 5:12:49 PM - DEBUG: Processing log_20120114_010605
[1/19/2012] * 5:12:49 PM - DEBUG: Stripping log of chrw(10)
[1/19/2012] * 5:12:49 PM - DEBUG: Start slot parse
[1/19/2012] * 5:12:49 PM - DEBUG: Parsed 0:SMP
[1/19/2012] * 5:12:49 PM - DEBUG: Parsed 0:SMP, parsing
    <client-type v="beta" />
[1/19/2012] * 5:12:49 PM - DEBUG: Slot added
[1/19/2012] * 5:12:49 PM - DEBUG: Processing log_20120114_014410
[1/19/2012] * 5:12:49 PM - DEBUG: Processing log_20120114_014517
[1/19/2012] * 5:12:49 PM - DEBUG: -Downloaded: 2012-01-14T01:44:12
[1/19/2012] * 5:12:49 PM - DEBUG: -StartDownload: 2012-01-14T01:44:11
[1/19/2012] * 5:12:49 PM - DEBUG: -DownloadSize: 612.39KiB
[1/19/2012] * 5:12:49 PM - DEBUG: -(2)Hardware for work unit detected: smp:12
[1/19/2012] * 5:12:49 PM - DEBUG: -(2)set work server to: 171.67.108.60
[1/19/2012] * 5:12:49 PM - DEBUG: Processing log_20120114_014604
[1/19/2012] * 5:12:49 PM - CRITICAL: An item with the same key has already been added.
[1/19/2012] * 5:12:49 PM - CRITICAL:  - Err.source: mscorlib Line: 0 - Err.number : 5
[1/19/2012] * 5:12:49 PM - CRITICAL:  - Err.description: An item with the same key has already been added.
[1/19/2012] * 5:12:49 PM - CRITICAL:  - stacktrace:    at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
   at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
   at FAHWatch7.clsClientInfo.FAHClientInfo.ParseString(String TheString)
[1/19/2012] * 5:12:49 PM - CRITICAL: The given key was not present in the dictionary.
[1/19/2012] * 5:12:49 PM - CRITICAL:  - Err.description: The given key was not present in the dictionary.
[1/19/2012] * 5:12:49 PM - CRITICAL:  - stacktrace:    at System.ThrowHelper.ThrowKeyNotFoundException()
   at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
   at FAHWatch7.clsClientInfo.FAHClientInfo.get_Version()
   at FAHWatch7.clsParser.AsyncParser.OldParser(FAHClientInfo ClientInfo)
   at FAHWatch7.clsParser.AsyncParser.ParseLogs(LogStartObject lStart)
[1/19/2012] * 5:12:49 PM - DEBUG: sqliteconnection 0 commited a transaction - True
[1/19/2012] * 5:12:49 PM - DEBUG: createtransaction:0
[1/19/2012] * 5:12:49 PM - DEBUG: endtransaction:0
[1/19/2012] * 5:12:49 PM - DEBUG: Starting Hardware statistics generation
[1/19/2012] * 5:12:49 PM - CRITICAL: Object reference not set to an instance of an object.
[1/19/2012] * 5:12:49 PM - CRITICAL:  - Err.source: FAHWatch7_preview Line: 0 - Err.number : 91
[1/19/2012] * 5:12:49 PM - CRITICAL:  - Err.description: Object reference not set to an instance of an object.
[1/19/2012] * 5:12:49 PM - CRITICAL:  - stacktrace:    at FAHWatch7.Data.PerformanceStatistics(DateTime startDate, Boolean Limit)
[1/19/2012] * 5:12:49 PM - DEBUG: Generating project statistics
[1/19/2012] * 5:12:49 PM - DEBUG: Generating individual project statistics
[1/19/2012] * 5:12:49 PM - DEBUG: -Generation took 0 Days, 0 hours, 0 minutes,0 seconds and 0 milliseconds
[1/19/2012] * 5:12:49 PM - DEBUG: -generation took 0 Days, 0 hours, 0 minutes,0 seconds and 0 milliseconds
[1/19/2012] * 5:12:49 PM - DEBUG: Generated hardware statistics
[1/19/2012] * 5:12:49 PM - Logparser took 0 Days, 0 hours, 0 minutes,0 seconds and 171 milliseconds
[1/19/2012] * 5:12:49 PM - Logparser done, took 0 Days, 0 hours, 0 minutes,0 seconds and 187 milliseconds
[1/19/2012] * 5:12:49 PM - DEBUG: Initialized database for ExtremeOverclocking updates
[1/19/2012] * 5:12:49 PM - DEBUG: Initialized ExtremeOverclocking updates handler
[1/19/2012] * 5:12:49 PM - DEBUG: sqliteconnection 0 performed Insert Filters row 1
[1/19/2012] * 5:12:49 PM - DEBUG: sqliteconnection 0 performed Insert Filters row 2
[1/19/2012] * 5:12:49 PM - DEBUG: sqliteconnection 0 performed Insert Filters row 3
[1/19/2012] * 5:12:49 PM - DEBUG: sqliteconnection 0 performed Insert Filters row 4
[1/19/2012] * 5:12:49 PM - Initialized sql filters
[1/19/2012] * 5:12:49 PM - Generating performance statistics: True
[1/19/2012] * 5:12:49 PM - CRITICAL:  - stacktrace:    at FAHWatch7.clsSettings.InitializeFilters()
[1/19/2012] * 5:12:49 PM - WARNING: Failed to get prepare notification filters.
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 commited a transaction - True
[1/19/2012] * 5:13:03 PM - DEBUG: createtransaction:0
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 1
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 2
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 3
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 4
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 5
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 6
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 7
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 8
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 9
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 10
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 11
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 12
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 13
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 14
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 15
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 16
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 17
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 18
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 19
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 20
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 21
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 22
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 23
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 24
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 25
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 26
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 27
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 28
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 29
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 30
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 31
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 32
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 33
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 34
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 35
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 36
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 37
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 38
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 39
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 40
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 41
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 42
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 43
[1/19/2012] * 5:13:03 PM - DEBUG: sqliteconnection 0 performed Insert Settings row 44
[1/19/2012] * 5:13:03 PM - DEBUG: endtransaction:0
[1/19/2012] * 5:13:03 PM - Initialized EOC xml updates
[1/19/2012] * 5:13:03 PM - DEBUG: History detail splitter moved, value: 462
[1/19/2012] * 5:13:03 PM - CRITICAL: The given key was not present in the dictionary.
[1/19/2012] * 5:13:03 PM - CRITICAL:  - Err.source: mscorlib Line: 0 - Err.number : 5
[1/19/2012] * 5:13:03 PM - CRITICAL:  - Err.description: The given key was not present in the dictionary.
[1/19/2012] * 5:13:03 PM - CRITICAL:  - stacktrace:    at System.ThrowHelper.ThrowKeyNotFoundException()
   at FAHWatch7.Data.get_ProjectRanges_Count()
[1/19/2012] * 5:13:03 PM - DEBUG: Reading work units from database, query:  skipdetails: True
[1/19/2012] * 5:13:03 PM - DEBUG: -process took 0 Days, 0 hours, 0 minutes,0 seconds and 0 milliseconds
[1/19/2012] * 5:13:03 PM - DEBUG: History main splitter moved, value: 400
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
MtM
Re: FAHWatch7
Post by MtM »
Can you mail me ( or post the top section of )
\logs\log_20120114_014604.txt
That should make it easier to fix this ( it's the same error as has been occurring with that system I think? ) The error there cascades, I need to fix it :(
There is something in your client info part of the log file which shouldn't be there ( duplicate key means I already added it, and I don't see how this could happen ), so I need to see it to fix it. I should perhaps edit the error handling so it prints the actual string being processed, but so far I left that out as it could contain information people would like to keep private ( configuration options like passkey are always blanked but still ).
There will be a bug fix release tomorrow, noticed some things which slipped through.
Grandpa_01
Re: FAHWatch7
Sorry I uninstalled it. I can reinstall it and get the file if you need it. And where will the file be located.
Edit I found it.
*********************** Log Started 2012-01-14T01:45:17 ************************
01:45:17:************************* Folding@home Client *************************
01:45:17:      Website: http://folding.stanford.edu/
01:45:17:    Copyright: (c) 2009-2011 Stanford University
01:45:17:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:45:17:         Args: --lifeline 4420 --command-port=36330
01:45:17:       Config: C:/Users/Barbie/AppData/Roaming/FAHClient/config.xml
01:45:17:         Args: --lifeline 4488 --command-port=36330
01:45:17:******************************** Build ********************************
01:45:17:      Version: 7.1.38
01:45:17:         Date: Oct 6 2011
01:45:17:         Time: 19:57:04
01:45:17:      SVN Rev: 3080
01:45:17:       Branch: fah/trunk/client
01:45:17:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:45:17:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:45:17:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
01:45:17:     Platform: win32 XP
01:45:17:         Bits: 32
01:45:17:         Mode: Release
01:45:17:         Bits: 32
01:45:17:******************************* System ********************************
01:45:17:          CPU: Intel(R) Core(TM) i7 CPU 970 @ 3.20GHz
01:45:17:       CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
01:45:17:         CPUs: 12
01:45:17:       Memory: 11.99GiB
01:45:17:         CPUs: 12
01:45:17:  Free Memory: 10.33GiB
01:45:17:      Threads: WINDOWS_THREADS
01:45:17:   On Battery: false
01:45:17:   UTC offset: -8
01:45:17:          PID: 4592
01:45:17:          PID: 4560
01:45:17:          CWD: C:/Users/Barbie/AppData/Roaming/FAHClient
01:45:17:           OS: Windows 7 Home Premium
01:45:17:      OS Arch: AMD64
01:45:17:         GPUs: 1
01:45:17:         GPUs: 1
01:45:17:        GPU 0: ATI:2 RV670PRO [Radeon HD 3850]
01:45:17:         CUDA: Not detected
01:45:17:Win32 Service: false
01:45:17:***********************************************************************
01:45:17:<config>
01:45:17:  <!-- Network -->
01:45:17:<config>
01:45:17:  <proxy v=':8080'/>
01:45:17:
01:45:17:
01:45:17:  <!-- User Information -->
01:45:17:  <passkey v='********************************'/>
01:45:17:  <team v='183368'/>
01:45:17:  <user v='Grandpa'/>
01:45:17:
01:45:17:
01:45:17:  <!-- Folding Slots -->
01:45:17:  <slot id='0' type='SMP'>
01:45:17:    <client-type v='beta'/>
01:45:17:  </slot>
01:45:17:</config>
01:45:17:  </slot>
01:45:17:</config>
01:45:17:Trying to access database...
01:45:17:Successfully acquired database lock
01:45:17:Enabled folding slot 00: READY smp:12
01:45:17:Downloading project 7001 description
01:45:17:Connecting to fah-web.stanford.edu:80
01:45:17:Starting Unit 00
01:45:17:Running core: C:/Users/Barbie/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -lifeline 4560 -version 701 -checkpoint 15 -np 12
01:45:17:Running core: C:/Users/Barbie/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -lifeline 4592 -version 701 -checkpoint 15 -np 12
01:45:17:Started core on PID 4856
01:45:17:Started core on PID 4852
01:45:17:FahCore 0xa4 started
01:45:18:Unit 00:01:45:18:Unit 00:
01:45:18:Unit 00:*------------------------------*01:45:18:Unit 00:*------------------------------*
01:45:18:Unit 00:Folding@Home Gromacs GB Core01:45:18:Unit 00:Folding@Home Gromacs GB Core
01:45:18:Unit 00:Version 2.27 (Dec. 15, 2010)
01:45:18:Unit 00:Preparing to commence simulation
01:45:18:Unit 00:- Ensuring status. Please wait.
01:45:21:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
01:45:23:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
01:45:27:Unit 00:- Looking at optimizations...01:45:27:Unit 00:- Looking at optimizations...
01:45:27:Unit 00:- Working with standard loops on this execution.01:45:27:Unit 00:- Working with standard loops on this execution.
01:45:27:Unit 00:- Previous termination of core was improper.
01:45:27:Unit 00:- Going to use sta- Expanded 626571 -> 1492924 (decompressed 238.2 percent)
01:45:27:Unit 00:Called DecompressByteArray: compressed_data_size=626571 data_size=1492924, decompressed_data_size=1492924 diff=001:45:27:Unit 00:Called DecompressByteArray: compressed_data_size=626571 data_size=1492924, decompressed_data_size=1492924 diff=0
01:45:27:Unit 00:- Digital signature verified01:45:27:Unit 00:- Digital signature verified
01:45:27:Unit 00:01:45:27:Unit 00:
01:45:27:Unit 00:Project: 8011 (Run 0, Clone 4, Gen 18)01:45:27:Unit 00:Project: 8011 (Run 0, Clone 4, Gen 18)
01:45:27:Unit 00:Entering M.D.01:45:27:Unit 00:Entering M.D.
01:45:27:Unit 00:lone 4, Gen 18)01:45:27:Unit 00:lone 4, Gen 18)
01:45:27:Unit 00:
01:45:31:Server connection id=3 on 0.0.0.0:36330 from 127.0.0.1
01:45:33:Server connection id=4 on 0.0.0.0:36330 from 127.0.0.1
01:45:33:Unit 00:eted 0 out of 250000 steps  (0%)
01:45:34:Unit 00:ed 0 out of 250000 steps  (0%)01:45:34:Unit 00:ed 0 out of 250000 steps  (0%)
01:45:41:Server connection id=5 on 0.0.0.0:36330 from 127.0.0.1
01:45:44:Server connection id=6 on 0.0.0.0:36330 from 127.0.0.1
01:45:50:ERROR: Exception: Failed to advance statement result: The database file is locked
01:45:50:Lost lifeline PID 4488, exiting
01:45:50:Downloading project 7003 description
01:45:50:Connecting to fah-web.stanford.edu:80
01:45:51:Downloading project 7013 description
01:45:51:Connecting to fah-web.stanford.edu:80
01:45:51:Downloading project 8004 description
01:45:51:Slot 00: shutting core down
01:45:51:WARNING: FahCore is known to not shutdown cleanly, killing
01:45:52:WARNING: Killing Unit 00
01:45:52:Clean exit
01:45:52:Lost lifeline PID 4420, exiting
01:45:52:Downloading project 7003 description
01:45:52:Connecting to fah-web.stanford.edu:80
01:45:52:Server connection id=1 ended
01:45:52:Server connection id=2 ended
01:45:52:Server connection id=3 ended
01:45:52:Server connection id=4 ended
01:45:52:Server connection id=5 ended
01:45:52:Server connection id=6 ended
01:45:53:Downloading project 7013 description
01:45:53:Connecting to fah-web.stanford.edu:80
01:45:53:Downloading project 8004 description
01:45:54:Slot 00: shutting core down
01:45:54:WARNING: FahCore is known to not shutdown cleanly, killing
01:45:54:WARNING: Killing Unit 00
01:45:54:Clean exit
MtM
Re: FAHWatch7
Post by MtM »
Well I think it's clear what went wrong, I'll edit it so it won't try to add a key which is already known. I heard about this log somewhere, double entries for messages, but I don't remember actually seeing it.
Thanks for the posting of the file!
darkbasic
Re: FAHWatch7
Post by darkbasic »
It doesn't work, I get tons of
and it shows no results.
MtM
Re: FAHWatch7
Post by MtM »
There is a log file, pm it to me. It might be the same problem as posted above.
Btw, it does work, it does not work for you. Big difference ;)
darkbasic
Re: FAHWatch7
Post by darkbasic »
MtM wrote:There is a log file, pm it to me. It might be the same problem as posted above.
Done.
MtM wrote:Btw, it does work, it does not work for you. Big difference ;)
That's obvious, I speak for myself.
MtM
Re: FAHWatch7
Post by MtM »
As I said, I thought that error was fixed as it's due to the difference between pre 1.7.48 logs and the current format. The log showed I an error in selecting the relevant part of the 'FINAL CREDIT ESTIMATE' string. It shouldn't be hard to fix.
Thanks for the report.
I have to add, that if the version I uploaded has the error causing your problem, it is universal ( eg it won't work for anyone making my above comment wrong ). Maybe I uploaded the wrong setup file, or I didn't compile the latest changes to the source.
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Re: FAHWatch7
Post by GreyWhiskers »
re: v43. Thanks for your evolving product. Good job.
Running on a WinXp computer. Viewing two v7 instances, one running v43, the other v38
Log messages. I had to snip out a number of the lines to make it fit in the forum post.
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 3
[1/20/2012] * 8:26:01 AM - ****** FAHWatch7_preview 0.1.0.0 logging started ******
[1/20/2012] * 8:26:01 AM - DEBUG: Application init started, splash: True
[1/20/2012] * 8:26:01 AM - Found FAHClient folders!
[1/20/2012] * 8:26:02 AM - DEBUG: Start slot parse
[1/20/2012] * 8:26:02 AM - DEBUG: Parsed 0:UNIPROCESSOR
[1/20/2012] * 8:26:02 AM - DEBUG: Slot added
[1/20/2012] * 8:26:02 AM - DEBUG: Parsed 1:GPU
[1/20/2012] * 8:26:02 AM - DEBUG: Parsed 1:GPU, parsing
    <gpu-index v="0" />
[1/20/2012] * 8:26:02 AM - Client config obtained
[1/20/2012] * 8:26:04 AM - Client info obtained
[1/20/2012] * 8:26:04 AM - Initializing database access
[1/20/2012] * 8:26:05 AM - DEBUG: tryopencon 0 called, dtNow=2000-01-01T00:00:00 TimeOut=00:00:05 tsWait=00:00:00
[1/20/2012] * 8:26:07 AM - DEBUG: sqliteconnection 0 state changed from Closed to Open
[1/20/2012] * 8:26:07 AM - Created sqlitecommand for instance 0
[1/20/2012] * 8:26:07 AM - Starting hardware detection
[1/20/2012] * 8:26:14 AM - Getting environment information:
[1/20/2012] * 8:26:15 AM - Administrator rights detected.
[1/20/2012] * 8:26:15 AM - Platform: WindowsXPsp3
[1/20/2012] * 8:26:15 AM - DEBUG: Diagnostics being saved to C:\Documents and Settings\Owner\Application Data\FAHClient
[1/20/2012] * 8:26:15 AM - Initializing parser for BUD-S-HPA475C
[1/20/2012] * 8:26:15 AM - Checking for remote clients configuration..True
[1/20/2012] * 8:26:15 AM - Remote clients initialized!
[1/20/2012] * 8:26:15 AM - Initializing project info
[1/20/2012] * 8:26:15 AM - Parsing logs started at 1/20/2012 8:26:15 AM
[1/20/2012] * 8:26:15 AM - Started logparser
[1/20/2012] * 8:26:15 AM - DEBUG: Started parselog thread for BUD-S-HPA475C on threadid: 5
[1/20/2012] * 8:26:15 AM - DEBUG: Parsing client BUD-S-HPA475C
[1/20/2012] * 8:26:15 AM - DEBUG: Processing log_20120112_165031
[1/20/2012] * 8:26:16 AM - DEBUG: Stripping log of chrw(10)
[1/20/2012] * 8:26:16 AM - DEBUG: Start slot parse
[1/20/2012] * 8:26:16 AM - DEBUG: Parsed 0:UNIPROCESSOR
[1/20/2012] * 8:26:16 AM - DEBUG: Slot added
[1/20/2012] * 8:26:16 AM - DEBUG: Parsed 1:GPU
[1/20/2012] * 8:26:16 AM - DEBUG: Parsed 1:GPU, parsing
    <gpu-index v="0" />
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-15T18:41:22
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-15T18:41:22
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 96.88KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Hardware for work unit detected: RV730 Pro AGP [Radeon HD 4600 Series]
[1/20/2012] * 8:26:16 AM - DEBUG: -(2)set work server to: 171.64.65.102
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-16T05:23:47
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-16T05:23:47
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 96.90KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-16T16:12:54
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-16T16:12:54
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 94.95KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-17T02:57:15
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-17T02:57:15
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 96.99KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-17T13:56:37
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-17T13:56:37
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 96.76KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-18T00:48:32
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-18T00:48:32
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-18T11:36:30
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-18T11:36:30
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 97.02KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-18T23:00:57
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-18T23:00:57
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 94.87KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-19T10:17:41
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-19T10:17:41
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 94.97KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-19T21:59:36
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-19T21:59:36
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 96.93KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-20T08:41:58
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-20T08:41:58
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-20T19:21:00
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-20T19:21:00
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-21T05:58:06
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-21T05:58:06
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 94.96KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-21T16:43:04
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-21T16:43:04
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 94.98KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-21T23:27:58
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-21T23:27:58
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 51.81KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -(2)Hardware for work unit detected: uniprocessor
[1/20/2012] * 8:26:16 AM - DEBUG: -(2)set work server to: 129.74.85.15
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-22T03:27:02
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-22T03:27:02
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-22T14:12:31
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-22T14:12:31
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 96.82KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-23T02:46:07
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-23T02:46:07
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 94.94KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-23T13:18:01
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-23T13:18:01
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-24T00:15:12
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-24T00:15:12
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 95.04KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-24T10:43:58
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-24T10:43:58
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 95.13KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-24T21:38:05
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-24T21:38:05
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 95.01KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-25T01:29:52
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-25T01:29:51
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 51.71KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-25T08:46:43
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-25T08:46:43
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 97.00KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-25T19:40:51
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-25T19:40:51
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 95.02KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-26T06:22:53
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-26T06:22:53
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 96.95KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-26T17:27:06
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-26T17:27:02
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 94.85KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-27T04:14:56
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-27T04:14:56
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-27T14:55:57
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-27T14:55:57
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-27T20:51:14
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-27T20:51:13
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 51.59KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-28T01:56:43
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-28T01:56:43
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 94.89KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-28T12:46:15
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-28T12:46:15
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 96.94KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-28T23:23:32
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-28T23:23:32
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 95.00KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-29T10:06:33
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-29T10:06:33
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-29T20:40:49
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-29T20:40:49
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-30T08:17:35
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-30T08:17:35
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-30T19:38:12
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-30T19:38:12
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 94.90KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -Downloaded: 2011-12-31T02:02:16
[1/20/2012] * 8:26:16 AM - DEBUG: -StartDownload: 2011-12-31T02:02:16
[1/20/2012] * 8:26:16 AM - DEBUG: -DownloadSize: 223.08KiB
[1/20/2012] * 8:26:16 AM - DEBUG: -(2)set work server to: 171.67.108.42
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2011-12-31T06:29:27
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2011-12-31T06:29:27
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 94.91KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Hardware for work unit detected: RV730 Pro AGP [Radeon HD 4600 Series]
[1/20/2012] * 8:26:17 AM - DEBUG: -(2)set work server to: 171.64.65.102
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2011-12-31T17:11:17
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2011-12-31T17:11:17
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 96.91KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-01T03:52:31
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-01T03:52:31
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 94.98KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-01T14:37:18
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-01T14:37:18
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-02T01:30:49
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-02T01:30:49
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 95.00KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-02T12:20:21
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-02T12:20:21
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-02T23:21:31
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-02T23:21:31
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 94.94KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-03T10:06:27
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-03T10:06:27
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 94.95KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-03T20:53:14
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-03T20:53:14
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 96.89KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-04T07:47:52
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-04T07:47:52
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 96.96KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-04T18:33:21
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-04T18:33:21
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 94.97KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-05T05:21:15
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-05T05:21:15
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 97.05KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-05T16:09:52
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-05T16:09:52
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-06T02:49:47
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-06T02:49:47
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 95.07KiB
[1/20/2012] * 8:26:17 AM - DEBUG: Start slot parse
[1/20/2012] * 8:26:17 AM - DEBUG: Parsed 0:UNIPROCESSOR
[1/20/2012] * 8:26:17 AM - DEBUG: Slot added
[1/20/2012] * 8:26:17 AM - DEBUG: Parsed 1:GPU
[1/20/2012] * 8:26:17 AM - DEBUG: Parsed 1:GPU, parsing     <gpu-index v="0" />
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-06T13:41:53
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-06T13:41:53
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 96.98KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-07T02:11:05
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-07T02:11:05
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 96.83KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-07T13:00:50
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-07T13:00:50
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-07T23:53:24
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-07T23:53:24
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-08T10:38:51
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-08T10:38:51
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 96.95KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-08T21:16:27
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-08T21:16:27
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 96.87KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-09T07:52:06
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-09T07:52:06
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 94.93KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-09T18:50:01
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-09T18:50:01
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 97.04KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-10T05:29:20
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-10T05:29:20
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 96.94KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-10T16:21:04
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-10T16:21:04
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 94.89KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-11T03:10:23
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-11T03:10:23
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 94.88KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-11T14:07:58
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-11T14:07:58
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-12T00:54:40
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-12T00:54:40
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 96.76KiB
[1/20/2012] * 8:26:17 AM - DEBUG: Processing log
[1/20/2012] * 8:26:17 AM - DEBUG: Stripping log of chrw(10)
    <gpu-index v="0" />
[1/20/2012] * 8:26:17 AM - Initialized slot 00 for BUD-S-HPA475C
[1/20/2012] * 8:26:17 AM - Initialized slot 01 for BUD-S-HPA475C
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-13T08:46:59
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-13T08:46:59
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 94.86KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-13T19:40:34
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-13T19:40:34
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 94.99KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-13T22:58:45
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-13T22:58:45
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 97.01KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-14T11:39:45
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-14T11:39:45
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 94.92KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-14T22:46:22
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-14T22:46:22
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 96.86KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-14T09:36:22
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-14T09:36:21
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-14T20:30:46
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-14T20:30:46
[1/20/2012] * 8:26:17 AM - DEBUG: -DownloadSize: 96.90KiB
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-15T07:13:58
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-15T07:13:58
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-15T17:58:34
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-15T17:58:34
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-16T04:50:54
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-16T04:50:54
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-16T15:37:36
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-16T15:37:36
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-17T02:25:36
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-17T02:25:36
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-17T13:10:46
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-17T13:10:46
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-18T00:32:30
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-18T00:32:30
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-18T12:53:20
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-18T12:53:20
[1/20/2012] * 8:26:17 AM - DEBUG: -Downloaded: 2012-01-19T01:07:28
[1/20/2012] * 8:26:17 AM - DEBUG: -StartDownload: 2012-01-19T01:07:28
[1/20/2012] * 8:26:18 AM - DEBUG: -Downloaded: 2012-01-19T12:54:30
[1/20/2012] * 8:26:18 AM - DEBUG: -StartDownload: 2012-01-19T12:54:30
[1/20/2012] * 8:26:18 AM - DEBUG: -DownloadSize: 94.94KiB
[1/20/2012] * 8:26:18 AM - DEBUG: -Hardware for work unit detected: RV730 Pro AGP [Radeon HD 4600 Series]
[1/20/2012] * 8:26:18 AM - DEBUG: -(2)set work server to: 171.64.65.102
[1/20/2012] * 8:26:18 AM - DEBUG: Processing log_20120112_165031
[1/20/2012] * 8:26:18 AM - DEBUG: --Starting to parse project:10722 run:0 clone:3382 gen:0 - Slot:00 ID:01 - 0x000000056652edba4db896dcb957bd4e
[1/20/2012] * 8:26:18 AM - DEBUG: Setting dtStarted:2011-12-31T02:02:40
[1/20/2012] * 8:26:18 AM - DEBUG: Setting new core version:2.27 (Dec. 15, 2010)
[1/20/2012] * 8:26:18 AM - DEBUG: Setting new log start date:2012-01-12T23:50:07
[1/20/2012] * 8:26:18 AM - DEBUG: Parsing logs for BUD-S-HPA475C
Found 3 work unit indexes
- 0 finalized work units
- 1 active work units
[1/20/2012] * 8:26:18 AM - DEBUG: --Starting to parse project:5738 run:3 clone:636 gen:1135 - Slot:01 ID:02 - 0x623ecbf44f18be3e046f027c0003166a
[1/20/2012] * 8:26:18 AM - DEBUG: Setting dtStarted:2012-01-19T01:07:28
[1/20/2012] * 8:26:18 AM - DEBUG: Setting new board type:AMD
[1/20/2012] * 8:26:18 AM - DEBUG: FahCore returned value: FINISHED_UNIT (100 = 0x64)
[1/20/2012] * 8:26:18 AM - DEBUG: Dump exited due to last frame found
[1/20/2012] * 8:26:18 AM - DEBUG: Detected upload, upload size:258.61KiB CS:171.64.65.102
[1/20/2012] * 8:26:18 AM - DEBUG: Found upload completed event at 2012-01-19T12:54:46
[1/20/2012] * 8:26:18 AM - DEBUG: Response found:WORK_ACK (400)
[1/20/2012] * 8:26:18 AM - DEBUG: Cleaning up detected - Accrediting 0x623ecbf44f18be3e046f027c0003166a
[1/20/2012] * 8:26:18 AM - DEBUG: Starting wu credit check for project:5738 run:3 clone:636 gen:1135 - 0x623ecbf44f18be3e046f027c0003166a
[1/20/2012] * 8:26:18 AM - DEBUG: Cores snippet assigned, storing work unit
[1/20/2012] * 8:26:18 AM - DEBUG: Finished with unit: 0x623ecbf44f18be3e046f027c0003166a
[1/20/2012] * 8:26:18 AM - DEBUG: --Starting to parse project:5738 run:3 clone:598 gen:975 - Slot:01 ID:00 - 0x188b4bfc4f1963f303cf02560003166a
[1/20/2012] * 8:26:18 AM - DEBUG: Setting dtStarted:2012-01-19T12:54:30
- 1 finalized work units
- 2 active work units
[1/20/2012] * 8:26:18 AM - DEBUG: Finished after 0 Days, 0 hours, 0 minutes,2 seconds and 546 milliseconds
[1/20/2012] * 8:26:18 AM - DEBUG: Started parselog thread for Carols05toshiba on threadid: 5
[1/20/2012] * 8:26:18 AM - DEBUG: Parsing client Carols05toshiba
[1/20/2012] * 8:26:20 AM - DEBUG: Stripping log of chrw(10)
[1/20/2012] * 8:26:20 AM - DEBUG: Start slot parse
[1/20/2012] * 8:26:20 AM - DEBUG: Parsed 0:UNIPROCESSOR
[1/20/2012] * 8:26:20 AM - DEBUG: Parsed 0:UNIPROCESSOR, parsing
    <client-type v="advanced" />
[1/20/2012] * 8:26:20 AM - DEBUG: Slot added
[1/20/2012] * 8:26:20 AM - Initialized slot 00 for Carols05toshiba
[1/20/2012] * 8:26:20 AM - DEBUG: -Downloaded: 2012-01-12T18:26:06
[1/20/2012] * 8:26:20 AM - DEBUG: -StartDownload: 2012-01-12T18:26:05
[1/20/2012] * 8:26:20 AM - DEBUG: -DownloadSize: 647.19KiB
[1/20/2012] * 8:26:20 AM - DEBUG: -(2)Hardware for work unit detected: uniprocessor
[1/20/2012] * 8:26:20 AM - DEBUG: -(2)set work server to: 171.67.108.53
[1/20/2012] * 8:26:20 AM - DEBUG: -Downloaded: 2012-01-13T19:37:56
[1/20/2012] * 8:26:20 AM - DEBUG: -StartDownload: 2012-01-13T19:37:56
[1/20/2012] * 8:26:20 AM - DEBUG: -DownloadSize: 646.58KiB
[1/20/2012] * 8:26:20 AM - DEBUG: -Downloaded: 2012-01-14T20:50:09
[1/20/2012] * 8:26:20 AM - DEBUG: -StartDownload: 2012-01-14T20:50:09
[1/20/2012] * 8:26:20 AM - DEBUG: -DownloadSize: 647.01KiB
[1/20/2012] * 8:26:20 AM - DEBUG: -Downloaded: 2012-01-15T21:59:36
[1/20/2012] * 8:26:20 AM - DEBUG: -StartDownload: 2012-01-15T21:59:36
[1/20/2012] * 8:26:20 AM - DEBUG: -DownloadSize: 648.04KiB
[1/20/2012] * 8:26:20 AM - DEBUG: -Downloaded: 2012-01-16T23:32:00
[1/20/2012] * 8:26:20 AM - DEBUG: -StartDownload: 2012-01-16T23:32:00
[1/20/2012] * 8:26:20 AM - DEBUG: -DownloadSize: 648.37KiB
[1/20/2012] * 8:26:20 AM - DEBUG: -Downloaded: 2012-01-18T16:21:15
[1/20/2012] * 8:26:20 AM - DEBUG: -StartDownload: 2012-01-18T16:21:14
[1/20/2012] * 8:26:20 AM - DEBUG: -DownloadSize: 648.10KiB
[1/20/2012] * 8:26:20 AM - DEBUG: -Downloaded: 2012-01-19T17:12:58
[1/20/2012] * 8:26:20 AM - DEBUG: -StartDownload: 2012-01-19T17:12:58
[1/20/2012] * 8:26:20 AM - DEBUG: -DownloadSize: 647.28KiB
[1/20/2012] * 8:26:20 AM - DEBUG: Processing log
[1/20/2012] * 8:26:20 AM - DEBUG: --Starting to parse project:6892 run:293 clone:5 gen:52 - Slot:00 ID:00 - 0x000000386652edc54e25cce0e574f9f5
[1/20/2012] * 8:26:20 AM - DEBUG: Setting dtStarted:2012-01-19T17:29:03
[1/20/2012] * 8:26:20 AM - DEBUG: Setting new core version:1.90 (March 8, 2006)
[1/20/2012] * 8:26:21 AM - DEBUG: Parsing logs for Carols05toshiba
Found 1 work unit indexes
[1/20/2012] * 8:26:21 AM - DEBUG: Finished after 0 Days, 0 hours, 0 minutes,2 seconds and 234 milliseconds
[1/20/2012] * 8:26:21 AM - DEBUG: createtransaction:0
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert WorkUnits row 577
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 1
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 2
SNIP
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 46
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 47
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 48
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 49
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 50
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 51
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 52
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 53
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 54
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 55
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 56
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 57
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 58
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 59
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 60
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 61
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 62
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 63
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 64
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 65
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 66
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 67
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 68
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 69
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 70
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 71
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 72
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 73
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 74
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 75
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 76
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 77
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 78
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 79
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 80
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 81
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 82
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 83
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 84
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 85
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 86
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 87
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 88
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 89
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 90
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 91
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 92
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 93
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 94
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 95
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 96
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 97
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 98
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 99
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert FrameInfo_BUD_S_HPA475C_01_0x623ecbf44f18be3e046f027c0003166a row 100
[1/20/2012] * 8:26:21 AM - DEBUG: endtransaction:0
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 commited a transaction - True
[1/20/2012] * 8:26:21 AM - DEBUG: Saving fahclient config for BUD-S-HPA475C - 2011-12-15T12:45:12
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert ClientConfig row 62
[1/20/2012] * 8:26:21 AM - DEBUG: Saving fahclient config for BUD-S-HPA475C - 2012-01-12T23:50:07
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert ClientConfig row 63
[1/20/2012] * 8:26:21 AM - DEBUG: Saving fahclient config for Carols05toshiba - 2012-01-12T17:33:00
[1/20/2012] * 8:26:21 AM - DEBUG: sqliteconnection 0 performed Insert ClientConfig row 64
[1/20/2012] * 8:26:21 AM - DEBUG: Starting Hardware statistics generation
[1/20/2012] * 8:26:21 AM - DEBUG: -generation took 0 Days, 0 hours, 0 minutes,0 seconds and 234 milliseconds
[1/20/2012] * 8:26:21 AM - DEBUG: Generating project statistics
[1/20/2012] * 8:26:22 AM - DEBUG: Generating individual project statistics
[1/20/2012] * 8:26:22 AM - DEBUG: Reading work units from database, query:  WHERE Project='2977' skipdetails: True
[1/20/2012] * 8:26:22 AM - DEBUG: -process took 0 Days, 0 hours, 0 minutes,0 seconds and 0 milliseconds
[1/20/2012] * 8:26:22 AM - DEBUG: Reading work units from database, query:  WHERE Project='5732' skipdetails: True
[1/20/2012] * 8:26:22 AM - DEBUG: -process took 0 Days, 0 hours, 0 minutes,0 seconds and 62 milliseconds
[1/20/2012] * 8:26:22 AM - DEBUG: Reading work units from database, query:  WHERE Project='5733' skipdetails: True
[1/20/2012] * 8:26:22 AM - DEBUG: Reading work units from database, query:  WHERE Project='5734' skipdetails: True
[1/20/2012] * 8:26:22 AM - DEBUG: -process took 0 Days, 0 hours, 0 minutes,0 seconds and 93 milliseconds
[1/20/2012] * 8:26:23 AM - CRITICAL: Input string was not in a correct format.
[1/20/2012] * 8:26:23 AM - CRITICAL:  - Err.source: mscorlib Line: 0 - Err.number : 13
[1/20/2012] * 8:26:23 AM - CRITICAL:  - Err.description: Input string was not in a correct format.
[1/20/2012] * 8:26:23 AM - CRITICAL:  - stacktrace:    at System.TimeSpan.StringParser.Parse(String s)
   at FAHWatch7.Data.get_ProjectStatistics(String ProjectNumber, String HW)
[1/20/2012] * 8:26:23 AM - DEBUG: -generation took 0 Days, 0 hours, 0 minutes,1 seconds and 640 milliseconds
[1/20/2012] * 8:26:23 AM - DEBUG: Starting Hardware statistics generation
[1/20/2012] * 8:26:23 AM - DEBUG: Reading work units from database, query: where HW ='uniprocessor'  skipdetails: True
[1/20/2012] * 8:26:24 AM - DEBUG: -process took 0 Days, 0 hours, 0 minutes,0 seconds and 218 milliseconds
[1/20/2012] * 8:26:24 AM - DEBUG: Reading work units from database, query: where HW ='RV730 Pro AGP [Radeon HD 4600 Series]'  skipdetails: True
[1/20/2012] * 8:26:24 AM - DEBUG: -process took 0 Days, 0 hours, 0 minutes,0 seconds and 531 milliseconds
[1/20/2012] * 8:26:24 AM - DEBUG: -Generation took 0 Days, 0 hours, 0 minutes,0 seconds and 921 milliseconds
[1/20/2012] * 8:26:24 AM - DEBUG: Generated hardware statistics
[1/20/2012] * 8:26:24 AM - Logparser took 0 Days, 0 hours, 0 minutes,9 seconds and 343 milliseconds
[1/20/2012] * 8:26:24 AM - Logparser done, took 0 Days, 0 hours, 0 minutes,9 seconds and 468 milliseconds
[1/20/2012] * 8:26:25 AM - DEBUG: Initialized database for ExtremeOverclocking updates
[1/20/2012] * 8:26:25 AM - DEBUG: sqliteconnection 0 commited a transaction - True
[1/20/2012] * 8:26:25 AM - DEBUG: createtransaction:0
[1/20/2012] * 8:26:25 AM - DEBUG: sqliteconnection 0 performed Insert eoc_accounts row 1
[1/20/2012] * 8:26:25 AM - DEBUG: sqliteconnection 0 performed Insert eoc_accounts row 2
[1/20/2012] * 8:26:25 AM - DEBUG: endtransaction:0
[1/20/2012] * 8:26:25 AM - DEBUG: Initialized ExtremeOverclocking updates handler
[1/20/2012] * 8:26:25 AM - Initialized sql filters
[1/20/2012] * 8:26:25 AM - Initialized notification filters
[1/20/2012] * 8:26:26 AM - DEBUG: Last eoc update is not current and last attempt was more then 15m ago, shouldrefresh=true
[1/20/2012] * 8:26:27 AM - DEBUG: Retrieving stored EOC update for GreyWhiskers(0) - 2012-01-20T07:00:00
[1/20/2012] * 8:26:27 AM - DEBUG: sqliteconnection 0 performed Insert eocupdates row 1
[1/20/2012] * 8:26:27 AM - DEBUG: sqliteconnection 0 commited a transaction - True
[1/20/2012] * 8:26:27 AM - Stored EOC update 2012-01-20T07:00:00 - GreyWhiskers(Default)
[1/20/2012] * 8:26:27 AM - Saved EOC XML data to database
[1/20/2012] * 8:26:27 AM - DEBUG: sqliteconnection 0 performed Insert signatureimage row 1
[1/20/2012] * 8:26:27 AM - DEBUG: sqliteconnection 0 performed Insert signatureimage row 2
[1/20/2012] * 8:26:27 AM - DEBUG: Last eoc update is not current but last attempt was less then 15m ago, shouldrefresh=false
[1/20/2012] * 8:26:27 AM - Initialized EOC xml updates
[1/20/2012] * 8:26:28 AM - DEBUG: Reading work units from database, query:  skipdetails: True
[1/20/2012] * 8:26:28 AM - DEBUG: -process took 0 Days, 0 hours, 0 minutes,0 seconds and 734 milliseconds
[1/20/2012] * 8:26:30 AM - DEBUG: Loading data for selected wu
[1/20/2012] * 8:26:30 AM - DEBUG: Reading work unit from database, client: Carols05toshiba slot: 00 unit: 0x0000002f6652edc54e25d69e13743f92
[1/20/2012] * 8:26:30 AM - DEBUG: -process took 0 Days, 0 hours, 0 minutes,0 seconds and 125 milliseconds
[1/20/2012] * 8:26:30 AM - DEBUG: 0 Days, 0 hours, 0 minutes,0 seconds and 140 milliseconds
[1/20/2012] * 8:26:30 AM - DEBUG: Start slot parse
[1/20/2012] * 8:26:30 AM - DEBUG: Parsed 0:UNIPROCESSOR
[1/20/2012] * 8:26:30 AM - DEBUG: Parsed 0:UNIPROCESSOR, parsing
[1/20/2012] * 8:26:30 AM - DEBUG: Slot added
[1/20/2012] * 8:26:30 AM - DEBUG: History main splitter moved, value: 399
[1/20/2012] * 8:26:30 AM - DEBUG: History detail splitter moved, value: 281
[1/20/2012] * 8:28:39 AM - DEBUG: Diagnostic property accessed
[1/20/2012] * 8:28:39 AM - DEBUG: Starting diagnostics
[1/20/2012] * 8:28:39 AM - DEBUG: Start slot parse
[1/20/2012] * 8:28:39 AM - DEBUG: Parsed 0:UNIPROCESSOR
[1/20/2012] * 8:28:39 AM - DEBUG: Slot added
[1/20/2012] * 8:28:39 AM - DEBUG: Parsed 1:GPU
[1/20/2012] * 8:28:39 AM - DEBUG: Parsed 1:GPU, parsing
    <gpu-index v="0" />
[1/20/2012] * 8:28:41 AM - DEBUG: Diagnosts finished
[1/20/2012] * 8:31:27 AM - DEBUG: Last eoc update is less then 3 hours and 15 minutes old, shouldrefresh=false
[1/20/2012] * 8:31:28 AM - DEBUG: Last eoc update is not current and last attempt was more then 15m ago, shouldrefresh=true
[1/20/2012] * 8:31:28 AM - Attempting to refresh eoc for GreyWhiskers()
[1/20/2012] * 8:31:28 AM - DEBUG: Retrieving stored EOC update for GreyWhiskers() - 2012-01-20T07:00:00
[1/20/2012] * 8:31:28 AM - DEBUG: sqliteconnection 0 performed Insert eocupdates row 2
[1/20/2012] * 8:31:28 AM - DEBUG: sqliteconnection 0 commited a transaction - True
[1/20/2012] * 8:31:28 AM - Stored EOC update 2012-01-20T07:00:00 - GreyWhiskers(Default)
[1/20/2012] * 8:31:28 AM - Saved EOC XML data to database
[1/20/2012] * 8:31:28 AM - DEBUG: sqliteconnection 0 performed Insert signatureimage row 3
[1/20/2012] * 8:31:28 AM - DEBUG: sqliteconnection 0 performed Insert signatureimage row 4
[1/20/2012] * 8:33:48 AM - DEBUG: Clearing data
[1/20/2012] * 8:33:48 AM - DEBUG: Loading data for selected wu
[1/20/2012] * 8:33:48 AM - DEBUG: Reading work unit from database, client: Carols05toshiba slot: 00 unit: 0x0000003d6652edc54e25cb8db6b5664f
[1/20/2012] * 8:33:49 AM - DEBUG: -process took 0 Days, 0 hours, 0 minutes,0 seconds and 125 milliseconds
[1/20/2012] * 8:33:49 AM - DEBUG: 0 Days, 0 hours, 0 minutes,0 seconds and 125 milliseconds
[1/20/2012] * 8:33:49 AM - DEBUG: Start slot parse
[1/20/2012] * 8:33:49 AM - DEBUG: Parsed 0:UNIPROCESSOR
[1/20/2012] * 8:33:49 AM - DEBUG: Parsed 0:UNIPROCESSOR, parsing
[1/20/2012] * 8:33:49 AM - DEBUG: Slot added
[1/20/2012] * 8:36:27 AM - DEBUG: Last eoc update is less then 3 hours and 15 minutes old, shouldrefresh=false
[1/20/2012] * 8:36:28 AM - DEBUG: Last eoc update is less then 3 hours and 15 minutes old, shouldrefresh=false
[1/20/2012] * 8:41:27 AM - DEBUG: Last eoc update is less then 3 hours and 15 minutes old, shouldrefresh=false
[1/20/2012] * 8:41:28 AM - DEBUG: Last eoc update is less then 3 hours and 15 minutes old, shouldrefresh=false
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Re: FAHWatch7
Post by MtM »
Yeah I didn't fix that before uploading, or uploaded from the wrong directory, sorry. I'll upload the fixed source and new installer later today. My apologies.
Grandpa_01
Re: FAHWatch7
Post by Grandpa_01 »
MtM wrote:Yeah I didn't fix that before uploading, or uploaded from the wrong directory, sorry. I'll upload the fixed source and new installer later today. My apologies.
MtM you amaze me, There is no need for you to apologies for making a mistake on something you are providing at a great deal of personal time for the folding communities. Thank you for your time my friend, this is a beta and I myself expect problems as I am sure others do also. Keep up the good work MtM and Thank You.
Grandpa_01
