Time Per Frame
nate
Time Per Frame
Post by nate »
My FAH is running at about 2 minutes and 30 seconds per frame. The total number of frames in the WU is 1500. I was just wondering if this time is good, or if I should be doing something else to make it go faster. Thanks!
Nate
zanth
Re: Time Per Frame
Post by zanth »
Well, I think people are going to want to know the stats on your system, what OS, which client and what project your client is currently folding. :)
Re: Time Per Frame
You also need to provide the project number if you want to compare your machine with others ;)
alancabler
Re: Time Per Frame
Post by alancabler »
Howdy Nate,
nate wrote:My FAH is running at about 2 minutes and 30 seconds per frame. The total number of frames in the WU is 1500. I was just wondering if this time is good, or if I should be doing something else to make it go faster. Thanks!
Nate
Adding to the great advice above, you can compare your scores to other machines in the points database.
Feel free to add your own scores!
Facts are not truth. Facts are merely facets of the shining diamond of truth.
