Can't upload to 171.67.108.11/171.67.108.25[resolved]
ThunderRd
Post by ThunderRd »
I awoke today to find 2 gpu clients not able to upload. Log of one of the clients follows. I have tried the normal solutions, restarting the clients, etc. Attempting to connect in my browser also fails, although the server stats page indicates the servers are accepting. Is anyone else having the same difficulty today?
Note: Please read the license agreement (Folding@home-Win32-GPU.exe -license). F
urther
use of this software requires that you have read and accepted this agreement.
[01:40:12] Gpu type=2 species=11.
--- Opening Log file [December 16 01:40:12 UTC]
                       Folding@Home Client Version 6.41r2
                          http://folding.stanford.edu
Launch directory: C:\Program Files\fah33GPU
Executable: C:\Program Files\fah33GPU\Folding@home-Win32-GPU.exe
Arguments: -verbosity 9
[01:40:12] - Ask before connecting: No
[01:40:12] - User name: ThunderRd (Team 45)
[01:40:12] - User ID: 27956FFF3B56F31E
[01:40:12] - Machine ID: 2
[01:40:12]
[01:40:12] Loaded queue successfully.
[01:40:12]
[01:40:12] + Processing work unit
[01:40:12] Core required: FahCore_11.exe
[01:40:12] - Autosending finished units... [December 16 01:40:12 UTC]
[01:40:12] Trying to send all finished work units
[01:40:12] Core found.
[01:40:12] Project: 5769 (Run 12, Clone 285, Gen 1035)
[01:40:12] - Read packet limit of 540015616... Set to 524286976.
[01:40:12] + Attempting to send results [December 16 01:40:12 UTC]
[01:40:12] - Reading file work/wuresults_04.dat from core
[01:40:12] Working on queue slot 07 [December 16 01:40:12 UTC]
[01:40:12] + Working ...
[01:40:12]   (Read 99654 bytes from disk)
[01:40:12] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -checkpoin
t 15 -verbose -lifeline 2976 -version 641'
[01:40:12] Connecting to http://171.67.108.11:8080/
[01:40:13]
[01:40:13] *------------------------------*
[01:40:13] Folding@Home GPU Core
[01:40:13] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[01:40:13]
[01:40:13] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14
.00.50727.762 for 80x86
[01:40:13] Build host: amoeba
[01:40:13] Board Type: Nvidia
[01:40:13] Core      :
[01:40:13] Preparing to commence simulation
[01:40:13] - Looking at optimizations...
[01:40:13] - Files status OK
[01:40:13] - Expanded 46730 -> 252912 (decompressed 541.2 percent)
[01:40:13] Called DecompressByteArray: compressed_data_size=46730 data_size=2529
12, decompressed_data_size=252912 diff=0
[01:40:13] - Digital signature verified
[01:40:13]
[01:40:13] Project: 5765 (Run 5, Clone 444, Gen 763)
[01:40:13]
[01:40:13] Assembly optimizations on if available.
[01:40:13] Entering M.D.
[01:40:19] Will resume from checkpoint file
[01:40:19] Tpr hash work/wudata_07.tpr:  2258399368 1967562896 3301884078 356981
5794 3991448474
[01:40:19]
[01:40:19] Calling fah_main args: 14 usage=100
[01:40:19]
[01:40:19] Working on Protein
[01:40:20] Client config found, loading data.
[01:40:21] Starting GUI Server
[01:40:21] Resuming from checkpoint
[01:40:21] fcCheckPointResume: retreived and current tpr file hash:
[01:40:21]    0   2258399368   2258399368
[01:40:21]    1   1967562896   1967562896
[01:40:21]    2   3301884078   3301884078
[01:40:21]    3   3569815794   3569815794
[01:40:21]    4   3991448474   3991448474
[01:40:21] fcCheckPointResume: file hashes same.
[01:40:21] fcCheckPointResume: state restored.
[01:40:21] Verified work/wudata_07.log
[01:40:21] Verified work/wudata_07.edr
[01:40:21] Verified work/wudata_07.xtc
[01:40:21] Completed 68%
[01:41:13] - Couldn't send HTTP request to server
[01:41:13] + Could not connect to Work Server (results)
[01:41:13]     (171.67.108.11:8080)
[01:41:13] + Retrying using alternative port
[01:41:13] Connecting to http://171.67.108.11:80/
[01:41:40] Completed 69%
[01:42:17] - Couldn't send HTTP request to server
[01:42:17] + Could not connect to Work Server (results)
[01:42:17]     (171.67.108.11:80)
[01:42:17] - Error: Could not transmit unit 04 (completed December 15) to work s
erver.
[01:42:17] - 8 failed uploads of this unit.
[01:42:17] - Read packet limit of 540015616... Set to 524286976.
[01:42:17] + Attempting to send results [December 16 01:42:17 UTC]
[01:42:17] - Reading file work/wuresults_04.dat from core
[01:42:17]   (Read 99654 bytes from disk)
[01:42:17] Gpu type=2 species=11.
[01:42:17] Connecting to http://171.67.108.25:8080/
[01:42:33] - Couldn't send HTTP request to server
[01:42:33] + Could not connect to Work Server (results)
[01:42:33]     (171.67.108.25:8080)
[01:42:33] + Retrying using alternative port
[01:42:33] Connecting to http://171.67.108.25:80/
[01:42:34] - Couldn't send HTTP request to server
[01:42:34] + Could not connect to Work Server (results)
[01:42:34]     (171.67.108.25:80)
[01:42:34]   Could not transmit unit 04 to Collection server; keeping in queue.
[01:42:34] Project: 5770 (Run 11, Clone 171, Gen 1570)
[01:42:34] - Read packet limit of 540015616... Set to 524286976.
[01:42:34] + Attempting to send results [December 16 01:42:34 UTC]
[01:42:34] - Reading file work/wuresults_05.dat from core
[01:42:34]   (Read 99822 bytes from disk)
[01:42:34] Gpu type=2 species=11.
[01:42:34] Connecting to http://171.67.108.11:8080/
[01:42:58] Completed 70%
[01:44:17] Completed 71%
[01:44:29] - Couldn't send HTTP request to server
[01:44:29] + Could not connect to Work Server (results)
[01:44:29]     (171.67.108.11:8080)
[01:44:29] + Retrying using alternative port
[01:44:29] Connecting to http://171.67.108.11:80/
[01:44:38] - Couldn't send HTTP request to server
[01:44:38] + Could not connect to Work Server (results)
[01:44:38]     (171.67.108.11:80)
[01:44:38] - Error: Could not transmit unit 05 (completed December 15) to work s
erver.
[01:44:38] - 6 failed uploads of this unit.
[01:44:38] - Read packet limit of 540015616... Set to 524286976.
[01:44:38] + Attempting to send results [December 16 01:44:38 UTC]
[01:44:38] - Reading file work/wuresults_05.dat from core
[01:44:38]   (Read 99822 bytes from disk)
[01:44:38] Gpu type=2 species=11.
[01:44:38] Connecting to http://171.67.108.25:8080/
[01:45:00] - Couldn't send HTTP request to server
[01:45:00] + Could not connect to Work Server (results)
[01:45:00]     (171.67.108.25:8080)
[01:45:00] + Retrying using alternative port
[01:45:00] Connecting to http://171.67.108.25:80/
[01:45:02] - Couldn't send HTTP request to server
[01:45:02] + Could not connect to Work Server (results)
[01:45:02]     (171.67.108.25:80)
[01:45:02]   Could not transmit unit 05 to Collection server; keeping in queue.
[01:45:02] Project: 5767 (Run 14, Clone 10, Gen 726)
[01:45:02] - Read packet limit of 540015616... Set to 524286976.
[01:45:02] + Attempting to send results [December 16 01:45:02 UTC]
[01:45:02] - Reading file work/wuresults_06.dat from core
[01:45:02]   (Read 99748 bytes from disk)
[01:45:02] Gpu type=2 species=11.
[01:45:02] Connecting to http://171.67.108.11:8080/
[01:45:23] - Couldn't send HTTP request to server
[01:45:23] + Could not connect to Work Server (results)
[01:45:23]     (171.67.108.11:8080)
[01:45:23] + Retrying using alternative port
[01:45:23] Connecting to http://171.67.108.11:80/
[01:45:28] - Couldn't send HTTP request to server
[01:45:28] + Could not connect to Work Server (results)
[01:45:28]     (171.67.108.11:80)
[01:45:28] - Error: Could not transmit unit 06 (completed December 15) to work s
erver.
[01:45:28] - 4 failed uploads of this unit.
[01:45:28] - Read packet limit of 540015616... Set to 524286976.
[01:45:28] + Attempting to send results [December 16 01:45:28 UTC]
[01:45:28] - Reading file work/wuresults_06.dat from core
[01:45:28]   (Read 99748 bytes from disk)
[01:45:28] Gpu type=2 species=11.
[01:45:28] Connecting to http://171.67.108.25:8080/
[01:45:36] Completed 72%
[01:45:42] - Couldn't send HTTP request to server
[01:45:42] + Could not connect to Work Server (results)
[01:45:42]     (171.67.108.25:8080)
[01:45:42] + Retrying using alternative port
[01:45:42] Connecting to http://171.67.108.25:80/
[01:45:43] - Couldn't send HTTP request to server
[01:45:43] + Could not connect to Work Server (results)
[01:45:43]     (171.67.108.25:80)
[01:45:43]   Could not transmit unit 06 to Collection server; keeping in queue.
[01:45:43] + Sent 0 of 3 completed units to the server
[01:45:43] - Autosend completed
[01:47:01] Completed 73%
[01:48:29] Completed 74%
[01:49:54] Completed 75%
ThunderRd
Re: Can't upload to 171.67.108.11/171.67.108.25 [resolved]
Post by ThunderRd »
The issue seems to have resolved itself, all 4 waiting WUs have uploaded. Thanks.
