Project: 6903 (Run 6, Clone 20, Gen 6)
Ishinomori
Hey guys,
Just curious as to why i only received basepoints for this WU?
To my knowledge i have not failed this WU previously, and i completed + uploaded within the deadline.
Downloaded successfully @ (December 3 13:09:01 UTC)
Uploaded successfully @ (19:27:22 07/12/2011 UTC)
Cheers,
Ishinomori
Cheers,
Ishinomori
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: Project: 6903 (Run 6, Clone 20, Gen 6)
To get bonus points you need to use a passkey, complete 10 SMP WUs, and then maintain an 80% successful return rate before the deadline. Are you doing all of those? If not, please paste the log in between Code tags and we'll see if we can help you further.
Ishinomori
yes, i am doing all of the above, i returned a 6904 not 7 days before hand for 300k+ points
Jesse_V
CPU: i7-6700k
That is quite impressive and I wish my system could do that! The log is very beneficial for understanding setups and what happened in the client. Can you post it in between Code tags? Those are available under the Full Editor. I'm not sure what's going on, but the mods have access to more information than I do.Ishinomori wrote:yes, i am doing all of the above, i returned a 6904 not 7 days before hand for 300k+ points
Ishinomori
Its fun at times, but it takes 5 days to complete a 6904! O.O lol
In the WU Database:
The reason for the base points is because you took longer than the Preferred Deadline (which is 5 days) to complete the WU.Days taken to complete WU: 6.2
Hi Ishinomori (team 37726),
Your WU (P6903 R6 C20 G6) was added to the stats database on 2011-12-07 11:08:17 for 22706 points of credit.
Ishinomori
Thank you for the reply.
That doesn't seem right, as according to my times it only took 4d 6hrs to complete, which is the average time frame for a 6903 on my system.
Rather confused to be honest. :-S
Others have reported a similar issue occasionally. According to the server records, that WU was assigned to you at: 2011-12-01 06:15:19 PST. What probably happened was that for some reason, the WU failed and was later reassigned. If it was downloaded more than once, the oldest data-time is used.
If you can locate an older log showing the events surrounding 2011-12-01 15:15:19 UTC, please post it so we know what happened.
Ishinomori
Sure, I'll post up the log of around that time.
I've searched through my FAHlog's and did not come across another 6903 with that run number, and I know that I had not failed a WU for weeks now.
Is received a 6901 and was working on that for 2 days prior to my 6903, do you think it's possible that I was assigned 2 WU at the same time?
I'm not sure how this happens, which is why I want to see the log. If I can gather enough data to identify what actually causes this sort of issue, I can probably get somebody to fix it, but it's not common enough for anybody to have categorized what might have happened.
Ishinomori
[15:44:57] - Error: Could not get length of results file work/wuresults_07.dat
[15:44:57] - Error: Could not read unit 07 file. Removing from queue.
[15:44:57] + Closed connections
[15:44:57]
[15:44:57] + Processing work unit
[15:44:57] Core required: FahCore_a5.exe
[15:44:57] Core found.
[15:44:57] Working on queue slot 08 [December 1 15:44:57 UTC]
[15:44:57] + Working ...
[15:44:57]
[15:44:57] *------------------------------*
[15:44:57] Folding@Home Gromacs SMP Core
[15:44:57] Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
[15:44:57]
[15:44:57] Preparing to commence simulation
[15:44:57] - Looking at optimizations...
[15:44:57] - Created dyn
[15:44:57] - Files status OK
[15:44:59] - Expanded 24863721 -> 30796292 (decompressed 123.8 percent)
[15:44:59] Called DecompressByteArray: compressed_data_size=24863721 data_size=30796292, decompressed_data_size=30796292 diff=0
[15:44:59] - Digital signature verified
[15:44:59]
[15:44:59] Project: 6900 (Run 16, Clone 18, Gen 85)
[15:44:59]
[15:44:59] Assembly optimizations on if available.
[15:44:59] Entering M.D.
[15:45:05] Mapping NT from 4 to 4
[15:45:07] Completed 0 out of 250000 steps (0%)
[16:11:54] Completed 2500 out of 250000 steps (1%)
[16:38:42] Completed 5000 out of 250000 steps (2%)
[17:05:27] Completed 7500 out of 250000 steps (3%)
[17:32:13] Completed 10000 out of 250000 steps (4%)
[17:58:56] Completed 12500 out of 250000 steps (5%)
[18:25:38] Completed 15000 out of 250000 steps (6%)
[18:52:21] Completed 17500 out of 250000 steps (7%)
[19:19:03] Completed 20000 out of 250000 steps (8%)
[19:45:42] Completed 22500 out of 250000 steps (9%)
[20:12:22] Completed 25000 out of 250000 steps (10%)
[20:39:00] Completed 27500 out of 250000 steps (11%)
[21:05:38] Completed 30000 out of 250000 steps (12%)
[21:32:15] Completed 32500 out of 250000 steps (13%)
[21:58:51] Completed 35000 out of 250000 steps (14%)
[22:25:27] Completed 37500 out of 250000 steps (15%)
[22:52:03] Completed 40000 out of 250000 steps (16%)
[23:18:40] Completed 42500 out of 250000 steps (17%)
[23:45:16] Completed 45000 out of 250000 steps (18%)
[00:11:53] Completed 47500 out of 250000 steps (19%)
[00:38:30] Completed 50000 out of 250000 steps (20%)
[01:05:09] Completed 52500 out of 250000 steps (21%)
[01:31:46] Completed 55000 out of 250000 steps (22%)
[01:58:24] Completed 57500 out of 250000 steps (23%)
[02:25:03] Completed 60000 out of 250000 steps (24%)
[02:51:39] Completed 62500 out of 250000 steps (25%)
[03:18:14] Completed 65000 out of 250000 steps (26%)
[03:44:48] Completed 67500 out of 250000 steps (27%)
[04:11:24] Completed 70000 out of 250000 steps (28%)
[04:38:01] Completed 72500 out of 250000 steps (29%)
[05:04:40] Completed 75000 out of 250000 steps (30%)
[05:31:19] Completed 77500 out of 250000 steps (31%)
[05:57:57] Completed 80000 out of 250000 steps (32%)
[06:24:35] Completed 82500 out of 250000 steps (33%)
[06:51:13] Completed 85000 out of 250000 steps (34%)
[07:17:52] Completed 87500 out of 250000 steps (35%)
[07:44:31] Completed 90000 out of 250000 steps (36%)
[08:11:10] Completed 92500 out of 250000 steps (37%)
[08:37:49] Completed 95000 out of 250000 steps (38%)
[09:04:29] Completed 97500 out of 250000 steps (39%)
[09:31:09] Completed 100000 out of 250000 steps (40%)
[09:57:48] Completed 102500 out of 250000 steps (41%)
[10:24:30] Completed 105000 out of 250000 steps (42%)
[10:51:10] Completed 107500 out of 250000 steps (43%)
[11:17:50] Completed 110000 out of 250000 steps (44%)
[11:44:30] Completed 112500 out of 250000 steps (45%)
[12:11:10] Completed 115000 out of 250000 steps (46%)
[12:37:53] Completed 117500 out of 250000 steps (47%)
[13:04:35] Completed 120000 out of 250000 steps (48%)
[13:31:16] Completed 122500 out of 250000 steps (49%)
[13:57:57] Completed 125000 out of 250000 steps (50%)
[14:24:38] Completed 127500 out of 250000 steps (51%)
[14:51:22] Completed 130000 out of 250000 steps (52%)
[15:18:02] Completed 132500 out of 250000 steps (53%)
[15:44:43] Completed 135000 out of 250000 steps (54%)
[16:11:24] Completed 137500 out of 250000 steps (55%)
[16:38:07] Completed 140000 out of 250000 steps (56%)
[17:04:49] Completed 142500 out of 250000 steps (57%)
[17:31:31] Completed 145000 out of 250000 steps (58%)
[17:58:13] Completed 147500 out of 250000 steps (59%)
[18:24:57] Completed 150000 out of 250000 steps (60%)
[18:51:39] Completed 152500 out of 250000 steps (61%)
[19:18:23] Completed 155000 out of 250000 steps (62%)
[19:45:05] Completed 157500 out of 250000 steps (63%)
[20:11:45] Completed 160000 out of 250000 steps (64%)
[20:38:28] Completed 162500 out of 250000 steps (65%)
[21:05:10] Completed 165000 out of 250000 steps (66%)
[21:31:52] Completed 167500 out of 250000 steps (67%)
[21:58:35] Completed 170000 out of 250000 steps (68%)
[22:25:17] Completed 172500 out of 250000 steps (69%)
[22:52:00] Completed 175000 out of 250000 steps (70%)
[23:18:41] Completed 177500 out of 250000 steps (71%)
[23:45:23] Completed 180000 out of 250000 steps (72%)
[00:12:03] Completed 182500 out of 250000 steps (73%)
[00:38:44] Completed 185000 out of 250000 steps (74%)
[01:05:25] Completed 187500 out of 250000 steps (75%)
[01:32:06] Completed 190000 out of 250000 steps (76%)
[01:58:46] Completed 192500 out of 250000 steps (77%)
[02:25:26] Completed 195000 out of 250000 steps (78%)
[02:52:04] Completed 197500 out of 250000 steps (79%)
[03:18:41] Completed 200000 out of 250000 steps (80%)
[03:45:18] Completed 202500 out of 250000 steps (81%)
[04:11:56] Completed 205000 out of 250000 steps (82%)
[04:38:35] Completed 207500 out of 250000 steps (83%)
[05:05:12] Completed 210000 out of 250000 steps (84%)
[05:31:48] Completed 212500 out of 250000 steps (85%)
[05:58:25] Completed 215000 out of 250000 steps (86%)
[06:25:01] Completed 217500 out of 250000 steps (87%)
[06:51:38] Completed 220000 out of 250000 steps (88%)
[07:18:15] Completed 222500 out of 250000 steps (89%)
[07:44:51] Completed 225000 out of 250000 steps (90%)
[08:11:28] Completed 227500 out of 250000 steps (91%)
[08:38:04] Completed 230000 out of 250000 steps (92%)
[09:04:41] Completed 232500 out of 250000 steps (93%)
[09:31:19] Completed 235000 out of 250000 steps (94%)
[09:57:57] Completed 237500 out of 250000 steps (95%)
[10:24:35] Completed 240000 out of 250000 steps (96%)
[10:51:13] Completed 242500 out of 250000 steps (97%)
[11:17:50] Completed 245000 out of 250000 steps (98%)
[11:44:30] Completed 247500 out of 250000 steps (99%)
[12:11:06] Completed 250000 out of 250000 steps (100%)
[12:11:10] DynamicWrapper: Finished Work Unit: sleep=10000
[12:11:21]
[12:11:21] Finished Work Unit:
[12:11:21] - Reading up to 52713120 from "work/wudata_08.trr": Read 52713120
[12:11:21] trr file hash check passed.
[12:11:21] - Reading up to 47030896 from "work/wudata_08.xtc": Read 47030896
[12:11:21] xtc file hash check passed.
[12:11:21] edr file hash check passed.
[12:11:21] logfile size: 245404
[12:11:21] Leaving Run
[12:11:25] - Writing 100159368 bytes of core data to disk...
[12:11:26] ... Done.
[12:11:34] - Shutting down core
[12:11:34]
[12:11:34] Folding@home Core Shutdown: FINISHED_UNIT
[12:11:35] CoreStatus = 64 (100)
[12:11:35] Sending work to server
[12:11:35] Project: 6900 (Run 16, Clone 18, Gen 85)
[12:11:35] + Attempting to send results [December 3 12:11:35 UTC]
[12:11:35] - Couldn't send HTTP request to server
[12:11:35] + Could not connect to Work Server (results)
[12:11:35] (130.237.232.141:80)
[12:11:35] + Retrying using alternative port
[12:11:35] (130.237.232.141:8080)
[12:11:35] - Error: Could not transmit unit 08 (completed December 3) to work server.
[12:11:35] Keeping unit 08 in queue.
[12:11:35] - Error: Could not transmit unit 08 (completed December 3) to work server.Note: I use Langouste decoupler to upload, as i have really slow upload speeds and helps to up my ppd
Ishinomori
The 6903:
[13:09:01] - Error: Could not read unit 08 file. Removing from queue.
[13:09:01] + Closed connections
[13:09:01]
[13:09:01] + Processing work unit
[13:09:01] Core required: FahCore_a5.exe
[13:09:01] Core found.
[13:09:01] Working on queue slot 09 [December 3 13:09:01 UTC]
[13:09:01] + Working ...
[13:09:01]
[13:09:01] *------------------------------*
[13:09:01] Folding@Home Gromacs SMP Core
[13:09:01] Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
[13:09:01]
[13:09:01] Preparing to commence simulation
[13:09:01] - Looking at optimizations...
[13:09:01] - Created dyn
[13:09:01] - Files status OK
[13:09:04] - Expanded 57246096 -> 71846524 (decompressed 50.4 percent)
[13:09:04] Called DecompressByteArray: compressed_data_size=57246096 data_size=71846524, decompressed_data_size=71846524 diff=0
[13:09:05] - Digital signature verified
[13:09:05]
[13:09:05] Project: 6903 (Run 6, Clone 20, Gen 6)
[13:09:05]
[13:09:05] Assembly optimizations on if available.
[13:09:05] Entering M.D.
[13:09:11] Mapping NT from 4 to 4
[13:09:15] Completed 0 out of 250000 steps (0%)
[14:09:08] Completed 2500 out of 250000 steps (1%)
[15:09:01] Completed 5000 out of 250000 steps (2%)
[16:08:54] Completed 7500 out of 250000 steps (3%)
[17:08:47] Completed 10000 out of 250000 steps (4%)
[18:08:40] Completed 12500 out of 250000 steps (5%)
[19:08:32] Completed 15000 out of 250000 steps (6%)
[20:08:26] Completed 17500 out of 250000 steps (7%)
[21:08:20] Completed 20000 out of 250000 steps (8%)
[22:08:14] Completed 22500 out of 250000 steps (9%)
[23:08:08] Completed 25000 out of 250000 steps (10%)
[00:08:05] Completed 27500 out of 250000 steps (11%)
[01:07:58] Completed 30000 out of 250000 steps (12%)
[02:07:51] Completed 32500 out of 250000 steps (13%)
[03:07:44] Completed 35000 out of 250000 steps (14%)
[04:07:37] Completed 37500 out of 250000 steps (15%)
[05:07:31] Completed 40000 out of 250000 steps (16%)
[06:07:23] Completed 42500 out of 250000 steps (17%)
[07:07:18] Completed 45000 out of 250000 steps (18%)
[08:07:12] Completed 47500 out of 250000 steps (19%)
[09:07:05] Completed 50000 out of 250000 steps (20%)
[10:06:58] Completed 52500 out of 250000 steps (21%)Re: Project: 6903 (Run 6, Clone 20, Gen 6)
The log you posted only start from 15:44:57. You have to post the log surrounding 15:15:19-UTC as stated by Bruce.bruce wrote:...If you can locate an older log showing the events surrounding 2011-12-01 15:15:19 UTC, please post it so we know what happened.
Your log starting with the message [15:44:57] - Error: Could not get length of results file work/wuresults_07.dat does not show what happened during the preceding hour ... around [15:15:19] ... so that's not helpful. It does look like there was probably a WU there that failed.
This type of problem seems to happen more frequently to people who use Langouste. We've never been able to determine whether that's an important factor or not, but it is possible. As I said earlier, we don't have any conclusive evidence other than the server's record that it did issue the WU to you.
You'll be happy to know that V7 manages the downloads and uploads in much the same way as Langouste so your slow internet connection will be less of a problem than it is when you use V6 without Langouste.
Ishinomori
Ok, thank's for your help guys, i think i'll just give langouste the boot, and close/re-open FAH client so it searches for a new WU.
Cheers,
Ishi
Cheers,
Ishi
