Project: 7808 (Run:6 Clone:59 Gen:22)
Hisuichan
Hardware configuration: @UK: Win7 Ultimate x64, Intel i5-2500K @ 4.2 GHz, Asus P8P67, 8 GB DDR3-1600, MSI R6870 Hawk, Crucial M4 128GB SSD, Samsung 1.5TB HDD.
@LUX: Win7 Professional x64, Intel Core 2 Duo E6600, Asus P5W DH Deluxe, 3 GB DDR2-800, Leadtek WinFast PX8800GT, over 9000 HDDs.
Post by Hisuichan »
My first faulty WU, although since it returned a FAULTY_MACHINE (Edit: Yeah right. It's actually UNSTABLE_MACHINE, but I hate waking up early in the morning.) I suspect it's on my end.
Specs: Win7 Ultimate x64, Intel i5-2500K @ 4.2 GHz, Asus P8P67, 8 GB DDR-1600, MSI R6870 Hawk, Crucial M4 128GB SSD, Samsung 1.5TB HDD
Running 7.1.38, SMP: 3 threads and GPU: Radeon HD 6800 Series.
04:07:15:Unit 01:Completed 645000 out of 1500000 steps  (43%)
04:19:38:Unit 01:Completed 660000 out of 1500000 steps  (44%)
04:31:59:Unit 01:Completed 675000 out of 1500000 steps  (45%)
04:44:22:Unit 01:Completed 690000 out of 1500000 steps  (46%)
04:56:46:Unit 01:Completed 705000 out of 1500000 steps  (47%)
05:09:12:Unit 01:Completed 720000 out of 1500000 steps  (48%)
05:21:52:Unit 01:Completed 735000 out of 1500000 steps  (49%)
05:34:14:Unit 01:Completed 750000 out of 1500000 steps  (50%)
05:46:37:Unit 01:Completed 765000 out of 1500000 steps  (51%)
05:58:59:Unit 01:Completed 780000 out of 1500000 steps  (52%)
06:11:22:Unit 01:Completed 795000 out of 1500000 steps  (53%)
06:23:44:Unit 01:Completed 810000 out of 1500000 steps  (54%)
06:36:06:Unit 01:Completed 825000 out of 1500000 steps  (55%)
06:48:28:Unit 01:Completed 840000 out of 1500000 steps  (56%)
07:00:49:Unit 01:Completed 855000 out of 1500000 steps  (57%)
07:13:14:Unit 01:Completed 870000 out of 1500000 steps  (58%)
07:25:39:Unit 01:Completed 885000 out of 1500000 steps  (59%)
07:38:01:Unit 01:Completed 900000 out of 1500000 steps  (60%)
07:50:33:Unit 01:Completed 915000 out of 1500000 steps  (61%)
08:03:38:Unit 01:Completed 930000 out of 1500000 steps  (62%)
08:16:13:Unit 01:Completed 945000 out of 1500000 steps  (63%)
08:28:39:Unit 01:Completed 960000 out of 1500000 steps  (64%)
08:33:09:Unit 01:Gromacs cannot continue further.
08:33:09:Unit 01:Going to send back what have done -- stepsTotalG=1500000
08:33:09:Unit 01:Work fraction=0.6436 steps=1500000.
08:33:13:Unit 01:logfile size=16345 infoLength=16345 edr=0 trr=23
08:33:13:Unit 01:logfile size: 16345 info=16345 bed=0 hdr=23
08:33:13:Unit 01:- Writing 16881 bytes of core data to disk...
08:33:13:FahCore, running Unit 01, returned: UNSTABLE_MACHINE (122 = 0x7a)
08:33:13:Sending unit results: id:01 state:SEND error:FAULTY project:7808 run:6 clone:59 gen:22 core:0xa4 unit:0x000000180a3b1e874e30fc24d85173a7
08:33:13:Unit 01: Uploading 5.44KiB to 171.64.65.99
08:33:13:Connecting to 171.64.65.99:8080
08:33:14:Connecting to assign3.stanford.edu:8080
08:33:14:Unit 01: Upload complete
08:33:14:Server responded WORK_ACK (400)
08:33:14:Cleaning up Unit 01
I haven't restarted my computer in a while, and yesterday night I put the process priority of FahCore_a4 to High just to see if it works more efficiently overnight. After I started using the pc one hour ago, the WU faulted half an hour ago as I went to make breakfast. Will run Core Damage and Memtest later today as soon as I come back from Uni, but last week everything passed with flying flags.
Steam profile | Perfection consists not in doing extraordinary things, but in doing ordinary things extraordinarily well. -Angelique Arnauld
Re: Project: 7808 (Run:6 Clone:59 Gen:22)
Only your results so far:
Hi Hisuichan (team 70335),
Your WU (P7808 R6 C59 G22) was added to the stats database on 2011-12-07 01:08:06 for 0 points of credit.
I have marked it for a follow up
codysluder
Post by codysluder »
Setting process priority has no effect when there's only one thing running. 100% at idle priority is the same as 100% at high priority.
When you're actively using your computer and taking perhaps 2%, then you can choose to let F@h use the remaining 98% at idle priority or you can choose to make your system very, very sluggish because F@h will take 100% and you won't be able to get the 2% that you want when you want it.
Hisuichan
Post by Hisuichan »
Yeah, I knew as much, but since I usually have some background apps requesting come cpu time overnight (as little as it might be), I wanted to see whether that setting made any difference at all. I haven't yet checked my logs whether it did or not though, I think I did some 7808's in the past, but of course I'm not expecting anything over 1% improvement. Bored? Yeah, maybe.
Not a bad WU as it was completed by another Donor:
Your WU (P7808 R6 C59 G22) was added to the stats database on 2011-12-07 19:09:30 for 10949.3 points of credit.
