Failed to connect to 171.64.65.106
Ripper36
Post by Ripper36 »
Is it just a question of waiting again?
01:28:42:Unit 02:Completed 100%
01:28:45:Unit 02:Successful run
01:28:45:Unit 02:DynamicWrapper: Finished Work Unit: sleep=10000
01:28:54:Unit 02:Reserved 149488 bytes for xtc file; Cosm status=0
01:28:54:Unit 02:Allocated 149488 bytes for xtc file
01:28:54:Unit 02:- Reading up to 149488 from "02/wudata_01.xtc": Read 149488
01:28:54:Unit 02:Read 149488 bytes from xtc file; available packet space=786280976
01:28:54:Unit 02:xtc file hash check passed.
01:28:54:Unit 02:Reserved 22536 22536 786280976 bytes for arc file=<02/wudata_01.trr> Cosm status=0
01:28:54:Unit 02:Allocated 22536 bytes for arc file
01:28:54:Unit 02:- Reading up to 22536 from "02/wudata_01.trr": Read 22536
01:28:54:Unit 02:Read 22536 bytes from arc file; available packet space=786258440
01:28:54:Unit 02:trr file hash check passed.
01:28:54:Unit 02:Allocated 560 bytes for edr file
01:28:54:Unit 02:Read bedfile
01:28:54:Unit 02:edr file hash check passed.
01:28:54:Unit 02:Allocated 25280 bytes for logfile
01:28:54:Unit 02:Read logfile
01:28:54:Unit 02:GuardedRun: success in DynamicWrapper
01:28:54:Unit 02:GuardedRun: done
01:28:54:Unit 02:Run: GuardedRun completed.
01:28:56:Unit 02:+ Opened results file
01:28:56:Unit 02:- Writing 198376 bytes of core data to disk...
01:28:56:Unit 02:Done: 197864 -> 178941 (compressed to 90.4 percent)
01:28:56:Unit 02:  ... Done.
01:28:56:Unit 02:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
01:28:57:FahCore, running Unit 02, returned: FINISHED_UNIT (100 = 0x64)
01:28:57:Sending unit results: id:02 state:SEND project:5796 run:8 clone:150 gen:3 core:0x11 unit:0x1625c1784ed6534000030096000816a4
01:28:57:Unit 02: Uploading 175.25KiB to 171.64.65.106
01:28:57:Connecting to 171.64.65.106:8080
01:28:57:Starting Unit 00
01:28:57:Running core: C:/Users/John/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -lifeline 3984 -version 701 -checkpoint 15 -gpu 0
01:28:59:Started core on PID 3728
01:28:59:FahCore 0x11 started
01:28:59:Started thread 14 on PID 3984
01:28:59:WARNING: Exception: Failed to send results to work server: Upload failed
01:28:59:Trying to send results to collection server
01:28:59:Unit 02: Uploading 175.25KiB to 171.67.108.25
01:28:59:Connecting to 171.67.108.25:8080
01:28:59:Unit 00:
01:28:59:Unit 00:*------------------------------*
01:28:59:Unit 00:Folding@Home GPU Core
01:28:59:Unit 00:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
01:28:59:Unit 00:
01:28:59:Unit 00:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
01:28:59:Unit 00:Build host: amoeba
01:28:59:Unit 00:Board Type: Nvidia
01:28:59:Unit 00:Core      :
01:28:59:Unit 00:Preparing to commence simulation
01:28:59:Unit 00:- Looking at optimizations...
01:28:59:Unit 00:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
01:28:59:Unit 00:- Created dyn
01:28:59:Unit 00:- Files status OK
01:28:59:Unit 00:- Expanded 45443 -> 251112 (decompressed 552.5 percent)
01:28:59:Unit 00:Called DecompressByteArray: compressed_data_size=45443 data_size=251112, decompressed_data_size=251112 diff=0
01:28:59:Unit 00:- Digital signature verified
01:28:59:Unit 00:
01:28:59:Unit 00:Project: 5769 (Run 1, Clone 29, Gen 204)
01:28:59:Unit 00:
01:28:59:Unit 00:Assembly optimizations on if available.
01:28:59:Unit 00:Entering M.D.
01:29:01:WARNING: WorkServer connection failed on port 8080 trying 80
01:29:01:Connecting to 171.67.108.25:80
01:29:05:Unit 00:Tpr hash 00/wudata_01.tpr:  3289601426 3690484254 2227271905 1992293246 2293447962
01:29:05:Unit 00:
01:29:05:Unit 00:Calling fah_main args: 14 usage=90
01:29:05:Unit 00:
01:29:05:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:29:05:Sending unit results: id:02 state:SEND project:5796 run:8 clone:150 gen:3 core:0x11 unit:0x1625c1784ed6534000030096000816a4
01:29:05:Unit 02: Uploading 175.25KiB to 171.64.65.106
01:29:05:Connecting to 171.64.65.106:8080
01:29:06:Unit 00:Working on Protein
01:29:06:Unit 00:Client config unavailable.
01:29:06:Unit 00:Starting GUI Server
01:29:07:WARNING: Exception: Failed to send results to work server: Upload failed
01:29:07:Trying to send results to collection server
01:29:07:Unit 02: Uploading 175.25KiB to 171.67.108.25
01:29:07:Connecting to 171.67.108.25:8080
01:29:11:WARNING: WorkServer connection failed on port 8080 trying 80
01:29:11:Connecting to 171.67.108.25:80
01:29:25:ERROR: Exception: Failed to connect to 171.67.108.25:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:30:06:Sending unit results: id:02 state:SEND project:5796 run:8 clone:150 gen:3 core:0x11 unit:0x1625c1784ed6534000030096000816a4
01:30:06:Unit 02: Uploading 175.25KiB to 171.64.65.106
01:30:06:Connecting to 171.64.65.106:8080
01:30:07:WARNING: Exception: Failed to send results to work server: Upload failed
01:30:07:Trying to send results to collection server
01:30:07:Unit 02: Uploading 175.25KiB to 171.67.108.25
01:30:07:Connecting to 171.67.108.25:8080
01:30:09:WARNING: WorkServer connection failed on port 8080 trying 80
01:30:09:Connecting to 171.67.108.25:80
01:30:16:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:31:18:Unit 00:Completed 1%
01:31:43:Sending unit results: id:02 state:SEND project:5796 run:8 clone:150 gen:3 core:0x11 unit:0x1625c1784ed6534000030096000816a4
01:31:43:Unit 02: Uploading 175.25KiB to 171.64.65.106
01:31:43:Connecting to 171.64.65.106:8080
01:31:50:WARNING: Exception: Failed to send results to work server: Upload failed
01:31:50:Trying to send results to collection server
01:31:50:Unit 02: Uploading 175.25KiB to 171.67.108.25
01:31:50:Connecting to 171.67.108.25:8080
01:31:52:WARNING: WorkServer connection failed on port 8080 trying 80
01:31:52:Connecting to 171.67.108.25:80
01:31:54:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:33:30:Unit 00:Completed 2%
01:34:20:Sending unit results: id:02 state:SEND project:5796 run:8 clone:150 gen:3 core:0x11 unit:0x1625c1784ed6534000030096000816a4
01:34:20:Unit 02: Uploading 175.25KiB to 171.64.65.106
01:34:20:Connecting to 171.64.65.106:8080
01:34:21:WARNING: Exception: Failed to send results to work server: Upload failed
01:34:21:Trying to send results to collection server
01:34:21:Unit 02: Uploading 175.25KiB to 171.67.108.25
01:34:21:Connecting to 171.67.108.25:8080
01:34:23:WARNING: WorkServer connection failed on port 8080 trying 80
01:34:23:Connecting to 171.67.108.25:80
01:34:37:ERROR: Exception: Failed to connect to 171.67.108.25:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:35:43:Unit 00:Completed 3%
01:36:37:Unit 01:Completed 1095000 out of 1500000 steps  (73%)
01:37:55:Unit 00:Completed 4%
01:38:34:Sending unit results: id:02 state:SEND project:5796 run:8 clone:150 gen:3 core:0x11 unit:0x1625c1784ed6534000030096000816a4
01:38:34:Unit 02: Uploading 175.25KiB to 171.64.65.106
01:38:34:Connecting to 171.64.65.106:8080
01:38:35:WARNING: Exception: Failed to send results to work server: Upload failed
01:38:35:Trying to send results to collection server
01:38:35:Unit 02: Uploading 175.25KiB to 171.67.108.25
01:38:35:Connecting to 171.67.108.25:8080
01:38:37:WARNING: WorkServer connection failed on port 8080 trying 80
01:38:37:Connecting to 171.67.108.25:80
01:38:39:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:40:07:Unit 00:Completed 5%
01:42:20:Unit 00:Completed 6%
01:44:32:Unit 00:Completed 7%
01:45:26:Sending unit results: id:02 state:SEND project:5796 run:8 clone:150 gen:3 core:0x11 unit:0x1625c1784ed6534000030096000816a4
01:45:26:Unit 02: Uploading 175.25KiB to 171.64.65.106
01:45:26:Connecting to 171.64.65.106:8080
01:45:27:WARNING: Exception: Failed to send results to work server: Upload failed
01:45:27:Trying to send results to collection server
01:45:27:Unit 02: Uploading 175.25KiB to 171.67.108.25
01:45:27:Connecting to 171.67.108.25:8080
01:45:29:WARNING: WorkServer connection failed on port 8080 trying 80
01:45:29:Connecting to 171.67.108.25:80
01:45:31:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:46:45:Unit 00:Completed 8%
01:48:57:Unit 00:Completed 9%
01:51:10:Unit 00:Completed 10%
01:53:23:Unit 00:Completed 11%
01:55:35:Unit 00:Completed 12%
01:56:31:Sending unit results: id:02 state:SEND project:5796 run:8 clone:150 gen:3 core:0x11 unit:0x1625c1784ed6534000030096000816a4
01:56:31:Unit 02: Uploading 175.25KiB to 171.64.65.106
01:56:31:Connecting to 171.64.65.106:8080
01:56:33:WARNING: Exception: Failed to send results to work server: Upload failed
01:56:33:Trying to send results to collection server
01:56:33:Unit 02: Uploading 175.25KiB to 171.67.108.25
01:56:33:Connecting to 171.67.108.25:8080
01:56:40:WARNING: WorkServer connection failed on port 8080 trying 80
01:56:40:Connecting to 171.67.108.25:80
01:56:42:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:57:48:Unit 00:Completed 13%
02:00:01:Unit 00:Completed 14%
02:02:13:Unit 00:Completed 15%
02:04:26:Unit 00:Completed 16%
02:06:38:Unit 00:Completed 17%
02:07:02:Unit 01:Completed 1110000 out of 1500000 steps  (74%)
02:08:50:Unit 00:Completed 18%
02:11:03:Unit 00:Completed 19%
02:13:16:Unit 00:Completed 20%
02:14:28:Sending unit results: id:02 state:SEND project:5796 run:8 clone:150 gen:3 core:0x11 unit:0x1625c1784ed6534000030096000816a4
02:14:28:Unit 02: Uploading 175.25KiB to 171.64.65.106
02:14:28:Connecting to 171.64.65.106:8080
02:14:37:Unit 02: 2.28%
02:14:38:WARNING: Exception: Failed to send results to work server: Upload failed
02:14:38:Trying to send results to collection server
02:14:38:Unit 02: Uploading 175.25KiB to 171.67.108.25
02:14:38:Connecting to 171.67.108.25:8080
02:14:42:WARNING: WorkServer connection failed on port 8080 trying 80
02:14:42:Connecting to 171.67.108.25:80
02:14:44:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
02:15:28:Unit 00:Completed 21%
02:17:40:Unit 00:Completed 22%
02:19:53:Unit 00:Completed 23%
02:22:05:Unit 00:Completed 24%
02:24:18:Unit 00:Completed 25%
02:26:31:Unit 00:Completed 26%
02:28:44:Unit 00:Completed 27%
02:30:56:Unit 00:Completed 28%
02:33:09:Unit 00:Completed 29%
02:35:21:Unit 00:Completed 30%
02:37:14:Unit 01:Completed 1125000 out of 1500000 steps  (75%)
02:37:33:Unit 00:Completed 31%
02:39:46:Unit 00:Completed 32%
02:41:58:Unit 00:Completed 33%
02:43:30:Sending unit results: id:02 state:SEND project:5796 run:8 clone:150 gen:3 core:0x11 unit:0x1625c1784ed6534000030096000816a4
02:43:30:Unit 02: Uploading 175.25KiB to 171.64.65.106
02:43:30:Connecting to 171.64.65.106:8080
02:43:32:WARNING: Exception: Failed to send results to work server: Upload failed
02:43:32:Trying to send results to collection server
02:43:32:Unit 02: Uploading 175.25KiB to 171.67.108.25
02:43:32:Connecting to 171.67.108.25:8080
02:43:34:WARNING: WorkServer connection failed on port 8080 trying 80
02:43:34:Connecting to 171.67.108.25:80
02:43:36:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
02:44:11:Unit 00:Completed 34%
02:46:23:Unit 00:Completed 35%
02:48:36:Unit 00:Completed 36%
02:50:48:Unit 00:Completed 37%
bollix47
Re: Failed to connect to 171.67.108.25
Post by bollix47 »
Server 171.67.108.25 is a collection server that hasn't worked in a long time.
The real problem is the work server 171.64.65.106 which according to the Server status is extremely busy:
http://fah-web.stanford.edu/pybeta/serverstat.html
I'd advise editing your first post and changing the title to reflect 171.64.65.106 as the problem server so that the person responsible might notice it and investigate why it's so busy.
Re: Failed to connect to 171.64.65.106
Yes, I'm also having trouble to connect to 171.64.65.106 with v6 clients.
Since the server load is at ~130, it's not surprising :?
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
For the first time in a good number of months I'm having trouble as well. Relevant snippets from the v7 log:
14:34:40:Sending unit results: id:00 state:SEND error:OK project:5790 run:22 clone:990 gen:5 core:0x11 unit:0x2f81a5954ed681c0000503de0016169e
14:34:40:Unit 00: Uploading 174.63KiB to 171.64.65.106
14:34:40:Connecting to 171.64.65.106:8080
14:34:42:WARNING: WorkServer connection failed on port 8080 trying 80
14:34:42:Connecting to 171.64.65.106:80
14:34:43:WARNING: Exception: Failed to send results to work server: Failed to connect to 171.64.65.106:80: No connection could be made because the target machine actively refused it.
14:34:43:Trying to send results to collection server
14:34:43:Unit 00: Uploading 174.63KiB to 171.67.108.25
14:34:43:Connecting to 171.67.108.25:8080
14:34:44:WARNING: WorkServer connection failed on port 8080 trying 80
14:34:44:Connecting to 171.67.108.25:80
14:34:45:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
Fortunately, my SMP client is doing fine, so at least the bonus points aren't threatened. :)
Ripper36
Post by Ripper36 »
Server status has changed to "accepting" and my WU has now uploaded.
Thanks
sticks435
Post by sticks435 »
I'm having trouble uploading to this server tonight also. My WU has been trying to upload for about 6 hours now. My computer blue screened for some reason after folding fine for a week, but according to the logs, everything recovered fine and finished without errors. Should I just keep waiting?
*********************** Log Started 2011-12-08T01:15:03 ************************
01:15:03:************************* Folding@home Client *************************
01:15:03:      Website: http://folding.stanford.edu/
01:15:03:    Copyright: (c) 2009-2011 Stanford University
01:15:03:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:15:03:         Args: --lifeline 2120 --command-port=36330
01:15:03:       Config: C:/Users/sticks folding/AppData/Roaming/FAHClient/config.xml
01:15:03:******************************** Build ********************************
01:15:03:      Version: 7.1.38
01:15:03:         Date: Oct 6 2011
01:15:03:         Time: 19:57:04
01:15:03:      SVN Rev: 3080
01:15:03:       Branch: fah/trunk/client
01:15:03:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:15:03:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:15:03:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
01:15:03:     Platform: win32 XP
01:15:03:         Bits: 32
01:15:03:         Mode: Release
01:15:03:******************************* System ********************************
01:15:03:          CPU: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
01:15:03:       CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
01:15:03:         CPUs: 4
01:15:03:       Memory: 4.00GiB
01:15:03:  Free Memory: 3.19GiB
01:15:03:      Threads: WINDOWS_THREADS
01:15:03:   On Battery: false
01:15:03:   UTC offset: -6
01:15:03:          PID: 864
01:15:03:          CWD: C:/Users/sticks folding/AppData/Roaming/FAHClient
01:15:03:           OS: Windows 7 Professional
01:15:03:      OS Arch: AMD64
01:15:03:         GPUs: 1
01:15:03:        GPU 0: NVIDIA:1 GT200 [GeForce GTX 260]
01:15:03:         CUDA: 1.3
01:15:03:  CUDA Driver: 4000
01:15:03:Win32 Service: false
01:15:03:***********************************************************************
01:15:03:<config>
01:15:03:  <!-- Folding Slot Configuration -->
01:15:03:  <gpu v='true'/>
01:15:03:
01:15:03:  <!-- User Information -->
01:15:03:  <passkey v='********************************'/>
01:15:03:  <team v='111065'/>
01:15:03:  <user v='sticks435'/>
01:15:03:
01:15:03:  <!-- Folding Slots -->
01:15:03:</config>
01:15:03:Trying to access database...
01:15:04:Successfully acquired database lock
01:15:04:Enabled folding slot 00: READY gpu:0:"GT200 [GeForce GTX 260]"
01:15:04:Enabled folding slot 01: READY smp:4
01:15:04:Starting Unit 02
01:15:04:Running core: "C:/Users/sticks folding/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 02 -suffix 01 -lifeline 864 -version 701 -checkpoint 15 -np 4
01:15:04:Started core on PID 2132
01:15:04:FahCore 0xa4 started
01:15:04:Starting Unit 01
01:15:04:Running core: "C:/Users/sticks folding/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 01 -suffix 01 -lifeline 864 -version 701 -checkpoint 15 -gpu 0
01:15:04:Started core on PID 2468
01:15:04:FahCore 0x11 started
01:15:04:Unit 02:
01:15:04:Unit 02:*------------------------------*
01:15:04:Unit 02:Folding@Home Gromacs GB Core
01:15:04:Unit 02:Version 2.27 (Dec. 15, 2010)
01:15:04:Unit 02:
01:15:04:Unit 02:Preparing to commence simulation
01:15:04:Unit 02:- Ensuring status. Please wait.
01:15:05:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
01:15:05:Unit 01:
01:15:05:Unit 01:*------------------------------*
01:15:05:Unit 01:Folding@Home GPU Core
01:15:05:Unit 01:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
01:15:05:Unit 01:
01:15:05:Unit 01:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
01:15:05:Unit 01:Build host: amoeba
01:15:05:Unit 01:Board Type: Nvidia
01:15:05:Unit 01:Core      :
01:15:05:Unit 01:Preparing to commence simulation
01:15:05:Unit 01:- Ensuring status. Please wait.
01:15:14:Unit 02:- Looking at optimizations...
01:15:14:Unit 02:- Working with standard loops on this execution.
01:15:14:Unit 02:- Previous termination of core was improper.
01:15:14:Unit 02:- Files status OK
01:15:14:Unit 02:- Expanded 2080097 -> 5386224 (decompressed 258.9 percent)
01:15:14:Unit 02:Called DecompressByteArray: compressed_data_size=2080097 data_size=5386224, decompressed_data_size=5386224 diff=0
01:15:14:Unit 02:- Digital signature verified
01:15:14:Unit 02:
01:15:14:Unit 02:Project: 7809 (Run 2, Clone 373, Gen 21)
01:15:14:Unit 02:
01:15:14:Unit 02:Entering M.D.
01:15:14:Unit 01:- Looking at optimizations...
01:15:14:Unit 01:- Working with standard loops on this execution.
01:15:14:Unit 01:- Previous termination of core was improper.
01:15:14:Unit 01:- Files status OK
01:15:14:Unit 01:- Expanded 67194 -> 348420 (decompressed 518.5 percent)
01:15:14:Unit 01:Called DecompressByteArray: compressed_data_size=67194 data_size=348420, decompressed_data_size=348420 diff=0
01:15:14:Unit 01:- Digital signature verified
01:15:14:Unit 01:
01:15:14:Unit 01:Project: 5797 (Run 6, Clone 237, Gen 4)
01:15:14:Unit 01:
01:15:14:Unit 01:Entering M.D.
01:15:20:Unit 02:Using Gromacs checkpoints
01:15:20:Unit 01:Will resume from checkpoint file
01:15:20:Unit 01:Tpr hash 01/wudata_01.tpr:  1636459281 4226658375 2886790493 2992392799 3969947755
01:15:20:Unit 01:
01:15:20:Unit 01:Calling fah_main args: 14 usage=100
01:15:20:Unit 01:
01:15:21:Unit 02:Mapping NT from 4 to 4
01:15:21:Unit 01:Working on Protein
01:15:22:Unit 01:Client config unavailable.
01:15:22:Unit 01:Starting GUI Server
01:15:22:Unit 01:Resuming from checkpoint
01:15:22:Unit 01:fcCheckPointResume: retreived and current tpr file hash:
01:15:22:Unit 01:   0   1636459281   1636459281
01:15:22:Unit 01:   1   4226658375   4226658375
01:15:22:Unit 01:   2   2886790493   2886790493
01:15:22:Unit 01:   3   2992392799   2992392799
01:15:22:Unit 01:   4   3969947755   3969947755
01:15:22:Unit 01:fcCheckPointResume: file hashes same.
01:15:22:Unit 01:fcCheckPointResume: state restored.
01:15:22:Unit 01:Verified 01/wudata_01.log
01:15:22:Unit 01:Verified 01/wudata_01.edr
01:15:22:Unit 01:Verified 01/wudata_01.xtc
01:15:22:Unit 01:Completed 89%
01:15:23:Unit 02:Resuming from checkpoint
01:15:23:Unit 02:Verified 02/wudata_01.log
01:15:23:Unit 02:Verified 02/wudata_01.trr
01:15:23:Unit 02:Verified 02/wudata_01.xtc
01:15:23:Unit 02:Verified 02/wudata_01.edr
01:15:23:Unit 02:Completed 123060 out of 1500000 steps  (8%)
01:17:04:Unit 01:Completed 90%
01:18:47:Unit 01:Completed 91%
01:20:30:Unit 01:Completed 92%
01:22:13:Unit 01:Completed 93%
01:23:56:Unit 01:Completed 94%
01:25:38:Unit 01:Completed 95%
01:27:19:Unit 01:Completed 96%
01:28:13:Unit 02:Completed 135000 out of 1500000 steps  (9%)
01:28:58:Unit 01:Completed 97%
01:30:37:Unit 01:Completed 98%
01:32:16:Unit 01:Completed 99%
01:32:17:Connecting to assign-GPU.stanford.edu:80
01:32:17:News: Welcome to Folding@Home
01:32:17:Assigned to work server 171.67.108.11
01:32:17:Requesting new work unit for slot 00: RUNNING gpu:0:"GT200 [GeForce GTX 260]" from 171.67.108.11
01:32:17:Connecting to 171.67.108.11:8080
01:32:18:Slot 00: Downloading 46.11KiB
01:32:18:Slot 00: Download complete
01:32:18:Received Unit: id:00 state:DOWNLOAD error:OK project:5766 run:0 clone:434 gen:2339 core:0x11 unit:0x46fef4414ee013ac092301b200001686
01:33:56:Unit 01:Completed 100%
01:33:57:Unit 01:Successful run
01:33:57:Unit 01:DynamicWrapper: Finished Work Unit: sleep=10000
01:34:07:Unit 01:Reserved 147684 bytes for xtc file; Cosm status=0
01:34:07:Unit 01:Allocated 147684 bytes for xtc file
01:34:07:Unit 01:- Reading up to 147684 from "01/wudata_01.xtc": Read 147684
01:34:07:Unit 01:Read 147684 bytes from xtc file; available packet space=786282780
01:34:07:Unit 01:xtc file hash check passed.
01:34:07:Unit 01:Reserved 22536 22536 786282780 bytes for arc file=<01/wudata_01.trr> Cosm status=0
01:34:07:Unit 01:Allocated 22536 bytes for arc file
01:34:07:Unit 01:- Reading up to 22536 from "01/wudata_01.trr": Read 22536
01:34:07:Unit 01:Read 22536 bytes from arc file; available packet space=786260244
01:34:07:Unit 01:trr file hash check passed.
01:34:07:Unit 01:Allocated 560 bytes for edr file
01:34:07:Unit 01:Read bedfile
01:34:07:Unit 01:edr file hash check passed.
01:34:07:Unit 01:Allocated 29393 bytes for logfile
01:34:07:Unit 01:Read logfile
01:34:07:Unit 01:GuardedRun: success in DynamicWrapper
01:34:07:Unit 01:GuardedRun: done
01:34:07:Unit 01:Run: GuardedRun completed.
01:34:10:FahCore, running Unit 01, returned: FINISHED_UNIT (100 = 0x64)
01:34:10:Sending unit results: id:01 state:SEND error:OK project:5797 run:6 clone:237 gen:4 core:0x11 unit:0x634657ee4edfeffc000400ed000616a5
01:34:10:Unit 01: Uploading 173.77KiB to 171.64.65.106
01:34:10:Connecting to 171.64.65.106:8080
01:34:10:Starting Unit 00
01:34:10:Running core: "C:/Users/sticks folding/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 00 -suffix 01 -lifeline 864 -version 701 -checkpoint 15 -gpu 0
01:34:10:Started core on PID 3916
01:34:10:FahCore 0x11 started
01:34:10:WARNING: Exception: Failed to send results to work server: Upload failed
01:34:10:Trying to send results to collection server
01:34:10:Unit 01: Uploading 173.77KiB to 171.67.108.25
01:34:10:Connecting to 171.67.108.25:8080
01:34:10:Unit 00:
01:34:10:Unit 00:*------------------------------*
01:34:10:Unit 00:Folding@Home GPU Core
01:34:10:Unit 00:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
01:34:10:Unit 00:
01:34:10:Unit 00:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
01:34:10:Unit 00:Build host: amoeba
01:34:10:Unit 00:Board Type: Nvidia
01:34:10:Unit 00:Core      :
01:34:10:Unit 00:Preparing to commence simulation
01:34:10:Unit 00:- Looking at optimizations...
01:34:10:Unit 00:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
01:34:10:Unit 00:- Created dyn
01:34:10:Unit 00:- Files status OK
01:34:10:Unit 00:- Expanded 46709 -> 252912 (decompressed 541.4 percent)
01:34:10:Unit 00:Called DecompressByteArray: compressed_data_size=46709 data_size=252912, decompressed_data_size=252912 diff=0
01:34:10:Unit 00:- Digital signature verified
01:34:10:Unit 00:
01:34:10:Unit 00:Project: 5766 (Run 0, Clone 434, Gen 2339)
01:34:10:Unit 00:
01:34:10:Unit 00:Assembly optimizations on if available.
01:34:10:Unit 00:Entering M.D.
01:34:12:WARNING: WorkServer connection failed on port 8080 trying 80
01:34:12:Connecting to 171.67.108.25:80
01:34:13:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:34:13:Sending unit results: id:01 state:SEND error:OK project:5797 run:6 clone:237 gen:4 core:0x11 unit:0x634657ee4edfeffc000400ed000616a5
01:34:13:Unit 01: Uploading 173.77KiB to 171.64.65.106
01:34:13:Connecting to 171.64.65.106:8080
01:34:14:WARNING: Exception: Failed to send results to work server: Upload failed
01:34:14:Trying to send results to collection server
01:34:14:Unit 01: Uploading 173.77KiB to 171.67.108.25
01:34:14:Connecting to 171.67.108.25:8080
01:34:15:WARNING: WorkServer connection failed on port 8080 trying 80
01:34:15:Connecting to 171.67.108.25:80
01:34:16:Unit 00:Tpr hash 00/wudata_01.tpr:  2598203200 3316869389 2350700046 2170810719 866062330
01:34:16:Unit 00:
01:34:16:Unit 00:Calling fah_main args: 14 usage=100
01:34:16:Unit 00:
01:34:16:Unit 00:Working on Protein
01:34:16:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:34:17:Unit 00:Client config unavailable.
01:34:17:Unit 00:Starting GUI Server
01:34:59:Unit 00:Completed 1%
01:35:13:Sending unit results: id:01 state:SEND error:OK project:5797 run:6 clone:237 gen:4 core:0x11 unit:0x634657ee4edfeffc000400ed000616a5
01:35:13:Unit 01: Uploading 173.77KiB to 171.64.65.106
01:35:13:Connecting to 171.64.65.106:8080
01:35:14:WARNING: Exception: Failed to send results to work server: Upload failed
01:35:14:Trying to send results to collection server
01:35:14:Unit 01: Uploading 173.77KiB to 171.67.108.25
01:35:14:Connecting to 171.67.108.25:8080
01:35:15:WARNING: WorkServer connection failed on port 8080 trying 80
01:35:15:Connecting to 171.67.108.25:80
01:35:16:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:35:41:Unit 00:Completed 2%
01:36:23:Unit 00:Completed 3%
01:36:51:Sending unit results: id:01 state:SEND error:OK project:5797 run:6 clone:237 gen:4 core:0x11 unit:0x634657ee4edfeffc000400ed000616a5
01:36:51:Unit 01: Uploading 173.77KiB to 171.64.65.106
01:36:51:Connecting to 171.64.65.106:8080
01:36:51:WARNING: Exception: Failed to send results to work server: Upload failed
01:36:51:Trying to send results to collection server
01:36:51:Unit 01: Uploading 173.77KiB to 171.67.108.25
01:36:51:Connecting to 171.67.108.25:8080
01:36:52:WARNING: WorkServer connection failed on port 8080 trying 80
01:36:52:Connecting to 171.67.108.25:80
01:36:54:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:37:05:Unit 00:Completed 4%
01:37:48:Unit 00:Completed 5%
01:38:30:Unit 00:Completed 6%
01:39:12:Unit 00:Completed 7%
01:39:28:Sending unit results: id:01 state:SEND error:OK project:5797 run:6 clone:237 gen:4 core:0x11 unit:0x634657ee4edfeffc000400ed000616a5
01:39:28:Unit 01: Uploading 173.77KiB to 171.64.65.106
01:39:28:Connecting to 171.64.65.106:8080
01:39:28:WARNING: Exception: Failed to send results to work server: Upload failed
01:39:28:Trying to send results to collection server
01:39:28:Unit 01: Uploading 173.77KiB to 171.67.108.25
01:39:28:Connecting to 171.67.108.25:8080
01:39:30:WARNING: WorkServer connection failed on port 8080 trying 80
01:39:30:Connecting to 171.67.108.25:80
01:39:31:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:39:55:Unit 00:Completed 8%
01:40:37:Unit 00:Completed 9%
01:41:19:Unit 00:Completed 10%
01:42:01:Unit 00:Completed 11%
01:42:44:Unit 00:Completed 12%
01:43:26:Unit 00:Completed 13%
01:43:42:Sending unit results: id:01 state:SEND error:OK project:5797 run:6 clone:237 gen:4 core:0x11 unit:0x634657ee4edfeffc000400ed000616a5
01:43:42:Unit 01: Uploading 173.77KiB to 171.64.65.106
01:43:42:Connecting to 171.64.65.106:8080
01:43:42:WARNING: Exception: Failed to send results to work server: Upload failed
01:43:42:Trying to send results to collection server
01:43:43:Unit 01: Uploading 173.77KiB to 171.67.108.25
01:43:43:Connecting to 171.67.108.25:8080
01:43:44:WARNING: WorkServer connection failed on port 8080 trying 80
01:43:44:Connecting to 171.67.108.25:80
01:43:45:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:44:08:Unit 00:Completed 14%
01:44:40:Unit 02:Completed 150000 out of 1500000 steps  (10%)
01:44:50:Unit 00:Completed 15%
01:45:33:Unit 00:Completed 16%
01:46:15:Unit 00:Completed 17%
01:46:57:Unit 00:Completed 18%
01:47:39:Unit 00:Completed 19%
01:48:22:Unit 00:Completed 20%
01:49:04:Unit 00:Completed 21%
01:49:46:Unit 00:Completed 22%
01:50:28:Unit 00:Completed 23%
01:50:33:Sending unit results: id:01 state:SEND error:OK project:5797 run:6 clone:237 gen:4 core:0x11 unit:0x634657ee4edfeffc000400ed000616a5
01:50:33:Unit 01: Uploading 173.77KiB to 171.64.65.106
01:50:33:Connecting to 171.64.65.106:8080
01:50:34:WARNING: Exception: Failed to send results to work server: Upload failed
01:50:34:Trying to send results to collection server
01:50:34:Unit 01: Uploading 173.77KiB to 171.67.108.25
01:50:34:Connecting to 171.67.108.25:8080
01:50:35:WARNING: WorkServer connection failed on port 8080 trying 80
01:50:35:Connecting to 171.67.108.25:80
01:50:37:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:51:11:Unit 00:Completed 24%
01:51:53:Unit 00:Completed 25%
01:52:35:Unit 00:Completed 26%
01:53:17:Unit 00:Completed 27%
01:54:00:Unit 00:Completed 28%
01:54:42:Unit 00:Completed 29%
01:55:24:Unit 00:Completed 30%
01:56:06:Unit 00:Completed 31%
01:56:49:Unit 00:Completed 32%
01:57:31:Unit 00:Completed 33%
01:58:13:Unit 00:Completed 34%
01:58:55:Unit 00:Completed 35%
01:59:37:Unit 00:Completed 36%
02:00:20:Unit 00:Completed 37%
02:01:02:Unit 00:Completed 38%
02:01:38:Unit 02:Completed 165000 out of 1500000 steps  (11%)
02:01:39:Sending unit results: id:01 state:SEND error:OK project:5797 run:6 clone:237 gen:4 core:0x11 unit:0x634657ee4edfeffc000400ed000616a5
02:01:39:Unit 01: Uploading 173.77KiB to 171.64.65.106
02:01:39:Connecting to 171.64.65.106:8080
02:01:39:WARNING: Exception: Failed to send results to work server: Upload failed
02:01:39:Trying to send results to collection server
02:01:39:Unit 01: Uploading 173.77KiB to 171.67.108.25
02:01:39:Connecting to 171.67.108.25:8080
02:01:41:WARNING: WorkServer connection failed on port 8080 trying 80
02:01:41:Connecting to 171.67.108.25:80
02:01:42:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
02:01:44:Unit 00:Completed 39%
02:02:26:Unit 00:Completed 40%
02:03:08:Unit 00:Completed 41%
02:03:51:Unit 00:Completed 42%
02:04:33:Unit 00:Completed 43%
02:05:15:Unit 00:Completed 44%
02:05:57:Unit 00:Completed 45%
02:06:39:Unit 00:Completed 46%
02:07:22:Unit 00:Completed 47%
02:08:04:Unit 00:Completed 48%
02:08:46:Unit 00:Completed 49%
02:09:28:Unit 00:Completed 50%
02:10:10:Unit 00:Completed 51%
02:10:52:Unit 00:Completed 52%
02:11:35:Unit 00:Completed 53%
02:12:17:Unit 00:Completed 54%
02:12:59:Unit 00:Completed 55%
02:13:41:Unit 00:Completed 56%
02:14:23:Unit 00:Completed 57%
02:15:06:Unit 00:Completed 58%
02:15:49:Unit 00:Completed 59%
02:16:32:Unit 00:Completed 60%
02:17:15:Unit 00:Completed 61%
02:17:58:Unit 00:Completed 62%
02:18:27:Unit 02:Completed 180000 out of 1500000 steps  (12%)
02:18:41:Unit 00:Completed 63%
02:19:24:Unit 00:Completed 64%
02:19:36:Sending unit results: id:01 state:SEND error:OK project:5797 run:6 clone:237 gen:4 core:0x11 unit:0x634657ee4edfeffc000400ed000616a5
02:19:36:Unit 01: Uploading 173.77KiB to 171.64.65.106
02:19:36:Connecting to 171.64.65.106:8080
02:19:36:WARNING: Exception: Failed to send results to work server: Upload failed
02:19:36:Trying to send results to collection server
02:19:36:Unit 01: Uploading 173.77KiB to 171.67.108.25
02:19:36:Connecting to 171.67.108.25:8080
02:19:37:WARNING: WorkServer connection failed on port 8080 trying 80
02:19:37:Connecting to 171.67.108.25:80
02:19:39:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
02:20:07:Unit 00:Completed 65%
02:20:50:Unit 00:Completed 66%
02:21:33:Unit 00:Completed 67%
02:22:16:Unit 00:Completed 68%
02:22:59:Unit 00:Completed 69%
02:23:43:Unit 00:Completed 70%
02:24:26:Unit 00:Completed 71%
02:25:09:Unit 00:Completed 72%
02:25:52:Unit 00:Completed 73%
02:26:35:Unit 00:Completed 74%
02:27:18:Unit 00:Completed 75%
02:28:01:Unit 00:Completed 76%
02:28:44:Unit 00:Completed 77%
02:29:27:Unit 00:Completed 78%
02:30:10:Unit 00:Completed 79%
02:30:53:Unit 00:Completed 80%
02:31:36:Unit 00:Completed 81%
02:32:19:Unit 00:Completed 82%
02:33:02:Unit 00:Completed 83%
02:33:45:Unit 00:Completed 84%
02:34:28:Unit 00:Completed 85%
02:35:11:Unit 00:Completed 86%
02:35:13:Unit 02:Completed 195000 out of 1500000 steps  (13%)
02:35:54:Unit 00:Completed 87%
02:36:37:Unit 00:Completed 88%
02:37:20:Unit 00:Completed 89%
02:38:03:Unit 00:Completed 90%
02:38:46:Unit 00:Completed 91%
02:39:29:Unit 00:Completed 92%
02:40:12:Unit 00:Completed 93%
02:40:56:Unit 00:Completed 94%
02:41:39:Unit 00:Completed 95%
02:42:22:Unit 00:Completed 96%
02:43:05:Unit 00:Completed 97%
02:43:48:Unit 00:Completed 98%
02:44:31:Unit 00:Completed 99%
02:44:31:Connecting to assign-GPU.stanford.edu:80
02:44:31:News: Welcome to Folding@Home
02:44:31:Assigned to work server 171.67.108.21
02:44:31:Requesting new work unit for slot 00: RUNNING gpu:0:"GT200 [GeForce GTX 260]" from 171.67.108.21
02:44:31:Connecting to 171.67.108.21:8080
02:44:31:Slot 00: Downloading 62.06KiB
02:44:32:Slot 00: Download complete
02:44:32:Received Unit: id:03 state:DOWNLOAD error:OK project:10502 run:2 clone:0 gen:335 core:0x11 unit:0x000002b76652eda54b6f38fb00000862
02:45:14:Unit 00:Completed 100%
02:45:14:Unit 00:Successful run
02:45:14:Unit 00:DynamicWrapper: Finished Work Unit: sleep=10000
02:45:24:Unit 00:Reserved 75584 bytes for xtc file; Cosm status=0
02:45:24:Unit 00:Allocated 75584 bytes for xtc file
02:45:24:Unit 00:- Reading up to 75584 from "00/wudata_01.xtc": Read 75584
02:45:24:Unit 00:Read 75584 bytes from xtc file; available packet space=786354880
02:45:24:Unit 00:xtc file hash check passed.
02:45:24:Unit 00:Reserved 15168 15168 786354880 bytes for arc file=<00/wudata_01.trr> Cosm status=0
02:45:24:Unit 00:Allocated 15168 bytes for arc file
02:45:24:Unit 00:- Reading up to 15168 from "00/wudata_01.trr": Read 15168
02:45:24:Unit 00:Read 15168 bytes from arc file; available packet space=786339712
02:45:24:Unit 00:trr file hash check passed.
02:45:24:Unit 00:Allocated 560 bytes for edr file
02:45:24:Unit 00:Read bedfile
02:45:24:Unit 00:edr file hash check passed.
02:45:24:Unit 00:Allocated 17672 bytes for logfile
02:45:24:Unit 00:Read logfile
02:45:24:Unit 00:GuardedRun: success in DynamicWrapper
02:45:24:Unit 00:GuardedRun: done
02:45:24:Unit 00:Run: GuardedRun completed.
02:45:26:Unit 00:+ Opened results file
02:45:26:Unit 00:- Writing 109496 bytes of core data to disk...
02:45:26:Unit 00:Done: 108984 -> 96458 (compressed to 88.5 percent)
02:45:26:Unit 00:  ... Done.
02:45:26:Unit 00:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
02:45:26:Unit 00:Shutting down core
02:45:26:Unit 00:
02:45:26:Unit 00:Folding@home Core Shutdown: FINISHED_UNIT
02:45:26:FahCore, running Unit 00, returned: FINISHED_UNIT (100 = 0x64)
02:45:26:Sending unit results: id:00 state:SEND error:OK project:5766 run:0 clone:434 gen:2339 core:0x11 unit:0x46fef4414ee013ac092301b200001686
02:45:26:Unit 00: Uploading 94.70KiB to 171.67.108.11
02:45:26:Starting Unit 03
02:45:26:Connecting to 171.67.108.11:8080
02:45:26:Running core: "C:/Users/sticks folding/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 03 -suffix 01 -lifeline 864 -version 701 -checkpoint 15 -gpu 0
02:45:26:Started core on PID 2488
02:45:26:FahCore 0x11 started
02:45:27:Unit 03:
02:45:27:Unit 03:*------------------------------*
02:45:27:Unit 03:Folding@Home GPU Core
02:45:27:Unit 03:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
02:45:27:Unit 03:
02:45:27:Unit 03:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
02:45:27:Unit 03:Build host: amoeba
02:45:27:Unit 03:Board Type: Nvidia
02:45:27:Unit 03:Core      :
02:45:27:Unit 03:Preparing to commence simulation
02:45:27:Unit 03:- Looking at optimizations...
02:45:27:Unit 03:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
02:45:27:Unit 03:- Created dyn
02:45:27:Unit 03:- Files status OK
02:45:27:Unit 03:- Expanded 63037 -> 336763 (decompressed 534.2 percent)
02:45:27:Unit 03:Called DecompressByteArray: compressed_data_size=63037 data_size=336763, decompressed_data_size=336763 diff=0
02:45:27:Unit 03:- Digital signature verified
02:45:27:Unit 03:
02:45:27:Unit 03:Project: 10502 (Run 2, Clone 0, Gen 335)
02:45:27:Unit 03:
02:45:27:Unit 03:Assembly optimizations on if available.
02:45:27:Unit 03:Entering M.D.
02:45:29:Unit 00: Upload complete
02:45:29:Server responded WORK_ACK (400)
02:45:29:Cleaning up Unit 00
02:45:33:Unit 03:Tpr hash 03/wudata_01.tpr:  2656493596 1741665033 1300189372 1670923798 4175623837
02:45:33:Unit 03:
02:45:33:Unit 03:Calling fah_main args: 14 usage=100
02:45:33:Unit 03:
02:45:33:Unit 03:Working on Protein
02:45:34:Unit 03:Client config unavailable.
02:45:34:Unit 03:Starting GUI Server
02:46:46:Unit 03:Completed 1%
02:47:59:Unit 03:Completed 2%
02:48:38:Sending unit results: id:01 state:SEND error:OK project:5797 run:6 clone:237 gen:4 core:0x11 unit:0x634657ee4edfeffc000400ed000616a5
02:48:38:Unit 01: Uploading 173.77KiB to 171.64.65.106
02:48:38:Connecting to 171.64.65.106:8080
02:48:38:WARNING: Exception: Failed to send results to work server: Upload failed
02:48:38:Trying to send results to collection server
02:48:38:Unit 01: Uploading 173.77KiB to 171.67.108.25
02:48:38:Connecting to 171.67.108.25:8080
02:48:40:WARNING: WorkServer connection failed on port 8080 trying 80
02:48:40:Connecting to 171.67.108.25:80
02:48:41:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
02:49:12:Unit 03:Completed 3%
02:50:25:Unit 03:Completed 4%
02:51:38:Unit 03:Completed 5%
02:51:44:Unit 02:Completed 210000 out of 1500000 steps  (14%)
02:52:51:Unit 03:Completed 6%
02:54:03:Unit 03:Completed 7%
02:55:16:Unit 03:Completed 8%
02:56:29:Unit 03:Completed 9%
02:57:42:Unit 03:Completed 10%
02:58:55:Unit 03:Completed 11%
03:00:08:Unit 03:Completed 12%
03:01:21:Unit 03:Completed 13%
03:02:34:Unit 03:Completed 14%
03:03:47:Unit 03:Completed 15%
03:05:00:Unit 03:Completed 16%
03:06:13:Unit 03:Completed 17%
03:07:26:Unit 03:Completed 18%
03:07:51:Unit 02:Completed 225000 out of 1500000 steps  (15%)
03:08:39:Unit 03:Completed 19%
03:09:52:Unit 03:Completed 20%
03:11:04:Unit 03:Completed 21%
03:12:17:Unit 03:Completed 22%
03:13:30:Unit 03:Completed 23%
03:14:43:Unit 03:Completed 24%
03:15:56:Unit 03:Completed 25%
03:17:09:Unit 03:Completed 26%
03:18:22:Unit 03:Completed 27%
03:19:35:Unit 03:Completed 28%
03:20:48:Unit 03:Completed 29%
HendricksSA
Post by HendricksSA »
Same here. No luck since 00 GMT. Stat page says it is busy at 64%. We will probably have to wait it out.
noni_boy
- Couldn't send HTTP request to server
Post by noni_boy »
Hi.
(Sorry for my ignorance :oops: )
I want to know why I failed to send the results to the sever? Does that mean my 24-hours work is lost? :( I haven't had these issues before.
--- Opening Log file [December 8 06:09:50 UTC]
# Windows GPU Systray Edition #################################################
                       Folding@Home Client Version 6.41r2
Launch directory: C:\Users\Toni\AppData\Roaming\Folding@home-gpu
[06:09:50] - Ask before connecting: No
[06:09:50] - User name: noni_boy (Team 213342)
[06:09:50] - User ID: 426FEA782E86F110
[06:09:50] - Machine ID: 2
[06:09:50]
[06:09:50] Gpu type=2 species=11.
[06:09:50] Loaded queue successfully.
[06:09:50] Initialization complete
[06:09:50]
[06:09:50] + Processing work unit
[06:09:50] Core required: FahCore_11.exe
[06:09:50] Core found.
[06:09:50] Working on queue slot 08 [December 8 06:09:50 UTC]
[06:09:50] + Working ...
[06:09:55]
[06:09:55] *------------------------------*
[06:09:55] Folding@Home GPU Core
[06:09:55] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[06:09:55]
[06:09:55] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:09:55] Build host: amoeba
[06:09:55] Board Type: Nvidia
[06:09:55] Core      :
[06:09:55] Preparing to commence simulation
[06:09:55] - Looking at optimizations...
[06:09:55] - Files status OK
[06:09:56] - Expanded 67265 -> 350744 (decompressed 521.4 percent)
[06:09:56] Called DecompressByteArray: compressed_data_size=67265 data_size=350744, decompressed_data_size=350744 diff=0
[06:09:56] - Digital signature verified
[06:09:56]
[06:09:56] Project: 5789 (Run 18, Clone 144, Gen 8)
[06:09:56]
[06:09:56] Assembly optimizations on if available.
[06:09:56] Entering M.D.
[06:10:03] Will resume from checkpoint file
[06:10:03] Tpr hash work/wudata_08.tpr:  630296122 3208331879 3513788190 2514775117 426441038
[06:10:03]
[06:10:03] Calling fah_main args: 14 usage=100
[06:10:03]
[06:10:04] Working on Protein
[06:10:07] Client config found, loading data.
[06:10:08] Resuming from checkpoint
[06:10:08] fcCheckPointResume: retreived and current tpr file hash:
[06:10:08]    0    630296122    630296122
[06:10:08]    1   3208331879   3208331879
[06:10:08]    2   3513788190   3513788190
[06:10:08]    3   2514775117   2514775117
[06:10:08]    4    426441038    426441038
[06:10:08] fcCheckPointResume: file hashes same.
[06:10:08] fcCheckPointResume: state restored.
[06:10:08] Verified work/wudata_08.log
[06:10:08] Starting GUI Server
[06:10:08] Verified work/wudata_08.edr
[06:10:08] Verified work/wudata_08.xtc
[06:10:08] Completed 93%
[06:17:53] Completed 94%
[06:25:41] Completed 95%
[06:33:29] Completed 96%
[06:41:17] Completed 97%
[06:49:05] Completed 98%
[06:57:00] Completed 99%
[07:04:48] Completed 100%
[07:04:53] Successful run
[07:04:53] DynamicWrapper: Finished Work Unit: sleep=10000
[07:05:04] Reserved 148980 bytes for xtc file; Cosm status=0
[07:05:04] Allocated 148980 bytes for xtc file
[07:05:04] - Reading up to 148980 from "work/wudata_08.xtc": Read 148980
[07:05:04] Read 148980 bytes from xtc file; available packet space=786281484
[07:05:04] xtc file hash check passed.
[07:05:04] Reserved 22704 22704 786281484 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[07:05:04] Allocated 22704 bytes for arc file
[07:05:04] - Reading up to 22704 from "work/wudata_08.trr": Read 22704
[07:05:04] Read 22704 bytes from arc file; available packet space=786258780
[07:05:04] trr file hash check passed.
[07:05:04] Allocated 560 bytes for edr file
[07:05:04] Read bedfile
[07:05:04] edr file hash check passed.
[07:05:04] Allocated 30212 bytes for logfile
[07:05:04] Read logfile
[07:05:04] GuardedRun: success in DynamicWrapper
[07:05:04] GuardedRun: done
[07:05:04] Run: GuardedRun completed.
[07:05:08] + Opened results file
[07:05:08] - Writing 202968 bytes of core data to disk...
[07:05:08] Done: 202456 -> 178874 (compressed to 88.3 percent)
[07:05:08]   ... Done.
[07:05:09] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[07:05:11] Shutting down core
[07:05:11]
[07:05:11] Folding@home Core Shutdown: FINISHED_UNIT
[07:05:14] CoreStatus = 64 (100)
[07:05:14] Sending work to server
[07:05:14] Project: 5789 (Run 18, Clone 144, Gen 8)
[07:05:14] + Attempting to send results [December 8 07:05:14 UTC]
[07:05:14] Gpu type=2 species=11.
[07:05:15] - Couldn't send HTTP request to server
[07:05:15]   (Got status 503)
[07:05:15] + Could not connect to Work Server (results)
[07:05:15]     (171.64.65.106:8080)
[07:05:15] + Retrying using alternative port
[07:05:15]     (171.64.65.106:80)
[07:05:15] - Error: Could not transmit unit 08 (completed December 8) to work server.
[07:05:15]   Keeping unit 08 in queue.
[07:05:15] Project: 5789 (Run 18, Clone 144, Gen 8)
[07:05:15] + Attempting to send results [December 8 07:05:15 UTC]
[07:05:15] Gpu type=2 species=11.
[07:05:16] - Couldn't send HTTP request to server
[07:05:16]   (Got status 503)
[07:05:16] + Could not connect to Work Server (results)
[07:05:16]     (171.64.65.106:8080)
[07:05:16] + Retrying using alternative port
[07:05:16]     (171.64.65.106:80)
[07:05:16] - Error: Could not transmit unit 08 (completed December 8) to work server.
[07:05:16] + Attempting to send results [December 8 07:05:16 UTC]
[07:05:16] Gpu type=2 species=11.
[07:05:18] - Couldn't send HTTP request to server
[07:05:18] + Could not connect to Work Server (results)
[07:05:18]     (171.67.108.25:8080)
[07:05:18] + Retrying using alternative port
[07:05:20] - Couldn't send HTTP request to server
[07:05:20] + Could not connect to Work Server (results)
[07:05:20]     (171.67.108.25:80)
[07:05:20]   Could not transmit unit 08 to Collection server; keeping in queue.
[07:05:20] - Preparing to get new work unit...
[07:05:20] Cleaning up work directory
[07:05:20] + Attempting to get work packet
[07:05:20] Passkey found
[07:05:20] Gpu type=2 species=11.
[07:05:20] - Connecting to assignment server
[07:05:21] - Successful: assigned to (171.67.108.11).
[07:05:21] + News From Folding@Home: Welcome to Folding@Home
[07:05:22] Loaded queue successfully.
[07:05:22] Gpu type=2 species=11.
[07:05:24] Project: 5789 (Run 18, Clone 144, Gen 8)
[07:05:24] + Attempting to send results [December 8 07:05:24 UTC]
[07:05:24] Gpu type=2 species=11.
[07:05:24] - Couldn't send HTTP request to server
[07:05:24]   (Got status 503)
[07:05:24] + Could not connect to Work Server (results)
[07:05:24]     (171.64.65.106:8080)
[07:05:24] + Retrying using alternative port
[07:05:25] - Couldn't send HTTP request to server
[07:05:25]   (Got status 503)
[07:05:25] + Could not connect to Work Server (results)
[07:05:25]     (171.64.65.106:80)
[07:05:25] - Error: Could not transmit unit 08 (completed December 8) to work server.
[07:05:25] + Attempting to send results [December 8 07:05:25 UTC]
[07:05:25] Gpu type=2 species=11.
[07:05:27] - Couldn't send HTTP request to server
[07:05:27] + Could not connect to Work Server (results)
[07:05:27]     (171.67.108.25:8080)
[07:05:27] + Retrying using alternative port
[07:05:28] - Couldn't send HTTP request to server
[07:05:28] + Could not connect to Work Server (results)
[07:05:28]     (171.67.108.25:80)
[07:05:28]   Could not transmit unit 08 to Collection server; keeping in queue.
[07:05:28] + Closed connections
[07:05:28]
[07:05:28] + Processing work unit
[07:05:28] Core required: FahCore_11.exe
[07:05:28] Core found.
[07:05:28] Working on queue slot 09 [December 8 07:05:28 UTC]
[07:05:28] + Working ...
[07:05:29]
[07:05:29] *------------------------------*
[07:05:29] Folding@Home GPU Core
[07:05:29] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[07:05:29]
[07:05:29] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:05:29] Build host: amoeba
[07:05:29] Board Type: Nvidia
[07:05:29] Core      :
[07:05:29] Preparing to commence simulation
[07:05:29] - Looking at optimizations...
[07:05:29] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[07:05:29] - Created dyn
[07:05:29] - Files status OK
[07:05:29] - Expanded 45307 -> 251112 (decompressed 554.2 percent)
[07:05:29] Called DecompressByteArray: compressed_data_size=45307 data_size=251112, decompressed_data_size=251112 diff=0
[07:05:29] - Digital signature verified
[07:05:29]
[07:05:29] Project: 5772 (Run 14, Clone 107, Gen 2258)
[07:05:29]
[07:05:29] Assembly optimizations on if available.
[07:05:29] Entering M.D.
[07:05:35] Tpr hash work/wudata_09.tpr:  3350492603 3897208705 1027202632 770442888 1826697637
[07:05:35]
[07:05:35] Calling fah_main args: 14 usage=100
[07:05:35]
[07:05:35] Working on Protein
[07:05:37] Client config found, loading data.
[07:05:37] Starting GUI Server
[07:08:31] Completed 1%
[07:11:28] Completed 2%
[07:14:25] Completed 3%
[07:17:22] Completed 4%
[07:20:19] Completed 5%
[07:23:16] Completed 6%
[07:26:13] Completed 7%
[07:29:10] Completed 8%
[07:32:07] Completed 9%
[07:35:03] Completed 10%
[07:38:00] Completed 11%
[07:40:57] Completed 12%
[07:43:54] Completed 13%
[07:46:51] Completed 14%
[07:49:47] Completed 15%
[07:52:47] Completed 16%
[07:55:46] Completed 17%
[07:58:45] Completed 18%
[08:01:47] Completed 19%
[08:04:48] Completed 20%
[08:07:47] Completed 21%
[08:10:51] Completed 22%
Thank you !
cpqrst3
Re: - Couldn't send HTTP request to server
Post by cpqrst3 »
It seems the collection server is down (hence the 503 answers) but your work seems save:
The client tries to sent pending WU results every 6 hours if I read my logs correctly.
Intel D201GLY Debian Squeeze
Q2D E6750 & 8800GTS G80 WinXP
noni_boy
Post by noni_boy »
Thank you cpqrst3.
There are half a dozen server IP's now up to load averages over 100. Based on other evidence, they are on 2 or 3 servers. Hopefully since it is now morning out there, someone will be looking into this soon.
See this topic in the server problem forum, viewtopic.php?f=18&t=20137. That work server is overloaded at the moment, hopefully fixed later today.
Edit by Mod: Topics merged.
Stephenish
WU upload failed
Post by Stephenish »
18:18:07:Sending unit results: id:03 state:SEND error:OK project:5793 run:1 clone:255 gen:4 core:0x11 unit:0x635966584edfeb59000400ff000116a1
18:18:07:Unit 03: Uploading 173.76KiB to 171.64.65.106
18:18:07:Connecting to 171.64.65.106:8080
18:18:07:WARNING: Exception: Failed to send results to work server: Upload failed
18:18:07:Trying to send results to collection server
18:18:07:Unit 03: Uploading 173.76KiB to 171.67.108.25
18:18:07:Connecting to 171.67.108.25:8080
18:18:09:WARNING: WorkServer connection failed on port 8080 trying 80
18:18:09:Connecting to 171.67.108.25:80
18:18:11:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
HendricksSA
CPU load now 165. Looks like Stanford has some server problems. WUs continue to queue up. Best wishes for a quick resolution.
mflanaga
cant upload all day..
Post by mflanaga »
Can get wu's, just can't send the results back.
--- Opening Log file [December 8 22:14:19 UTC]
Launch directory: C:\Users\Mike\Desktop\FAH_GPU_Tracker_V2\FAH GPU Tracker V2\GPU0
Executable: C:\Users\Mike\Desktop\FAH_GPU_Tracker_V2\FAH GPU Tracker V2\FAH_GPU2.exe
Arguments: -oneunit -forcegpu nvidia_g80 -advmethods -gpu 0
[22:14:19] - Ask before connecting: No
[22:14:19] - User name: mflanaga (Team 111065)
[22:14:19] - User ID:  xxxxxxxxxxxxxxx
[22:14:19] - Machine ID: 3
[22:14:19]
[22:14:19] Loaded queue successfully.
[22:14:19] - Preparing to get new work unit...
[22:14:19] Project: 5796 (Run 20, Clone 330, Gen 3)
[22:14:19] + Attempting to get work packet
[22:14:19] - Read packet limit of 540015616... [22:14:19] - Connecting to assignment server
Set to 524286976.
[22:14:19] + Attempting to send results [December 8 22:14:19 UTC]
[22:14:20] - Couldn't send HTTP request to server
[22:14:20] + Could not connect to Work Server (results)
[22:14:20]     (171.64.65.106:8080)
[22:14:20] + Retrying using alternative port
[22:14:20] - Successful: assigned to (171.67.108.11).
[22:14:20] + News From Folding@Home: Welcome to Folding@Home
[22:14:20] Loaded queue successfully.
[22:14:21] + Closed connections
[22:14:21]
[22:14:21] + Processing work unit
[22:14:21] Core required: FahCore_11.exe
[22:14:21] Core found.
[22:14:21] Working on queue slot 04 [December 8 22:14:21 UTC]
[22:14:21] + Working ...
[22:14:22]
[22:14:22] *------------------------------*
[22:14:22] Folding@Home GPU Core
[22:14:22] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[22:14:22]
[22:14:22] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[22:14:22] Build host: amoeba
[22:14:22] Board Type: Nvidia
[22:14:22] Core      :
[22:14:22] Preparing to commence simulation
[22:14:22] - Looking at optimizations...
[22:14:22] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[22:14:22] - Created dyn
[22:14:22] - Files status OK
[22:14:22] - Expanded 45426 -> 251112 (decompressed 552.7 percent)
[22:14:22] Called DecompressByteArray: compressed_data_size=45426 data_size=251112, decompressed_data_size=251112 diff=0
[22:14:22] - Digital signature verified
[22:14:22]
[22:14:22] Project: 5770 (Run 1, Clone 376, Gen 433)
[22:14:22]
[22:14:22] Assembly optimizations on if available.
[22:14:22] Entering M.D.
[22:14:28] Tpr hash work/wudata_04.tpr:  1963414956 2755621927 4111774342 1233137644 3569095544
[22:14:28]
[22:14:28] Calling fah_main args: 14 usage=100
[22:14:28]
[22:14:28] Working on Protein
[22:14:29] Client config found, loading data.
[22:14:29] Starting GUI Server
[22:14:41] - Couldn't send HTTP request to server
[22:14:41] + Could not connect to Work Server (results)
[22:14:41]     (171.64.65.106:80)
[22:14:41] - Error: Could not transmit unit 01 (completed December 7) to work server.
[22:14:41] - Read packet limit of 540015616... Set to 524286976.
[22:14:41] + Attempting to send results [December 8 22:14:41 UTC]
[22:14:44] - Couldn't send HTTP request to server
[22:14:44] + Could not connect to Work Server (results)
[22:14:44]     (171.67.108.25:8080)
[22:14:44] + Retrying using alternative port
[22:14:46] - Couldn't send HTTP request to server
[22:14:46] + Could not connect to Work Server (results)
[22:14:46]     (171.67.108.25:80)
[22:14:46]   Could not transmit unit 01 to Collection server; keeping in queue.
[22:15:06] Completed 1%
[22:15:42] Completed 2%
[22:16:19] Completed 3%
