Please let me know if this is a server issue. Also, is it unusual for a WS not to appear at all in the "Server Status" list? Thanks for your help.
[19:50:06] Completed 7000000 out of 7000000 steps (100%)
[19:50:06] DynamicWrapper: Finished Work Unit: sleep=10000
[19:50:16]
[19:50:16] Finished Work Unit:
[19:50:16] - Reading up to 1818648 from "work/wudata_09.trr": Read 1818648
[19:50:16] trr file hash check passed.
[19:50:16] - Reading up to 168608 from "work/wudata_09.xtc": Read 168608
[19:50:16] xtc file hash check passed.
[19:50:16] edr file hash check passed.
[19:50:16] logfile size: 37747
[19:50:16] Leaving Run
[19:50:20] - Writing 2034615 bytes of core data to disk...
[19:50:21] Done: 2034103 -> 1893752 (compressed to 93.1 percent)
[19:50:21] ... Done.
[19:50:23] - Shutting down core
[19:50:23]
[19:50:23] Folding@home Core Shutdown: FINISHED_UNIT
[19:50:26] CoreStatus = 64 (100)
[19:50:26] Unit 9 finished with 80 percent of time to deadline remaining.
[19:50:26] Updated performance fraction: 0.840637
[19:50:26] Sending work to server
[19:50:26] Project: 10721 (Run 0, Clone 10498, Gen 4)
[19:50:26] + Attempting to send results [November 27 19:50:26 UTC]
[19:50:26] - Reading file work/wuresults_09.dat from core
[19:50:26] (Read 1894264 bytes from disk)
[19:50:26] Connecting to http://171.67.108.42:8080/
[19:50:27] - Couldn't send HTTP request to server
[19:50:27] + Could not connect to Work Server (results)
[19:50:27] (171.67.108.42:8080)
[19:50:27] + Retrying using alternative port
[19:50:27] Connecting to http://171.67.108.42:80/
[19:50:29] - Couldn't send HTTP request to server
[19:50:29] + Could not connect to Work Server (results)
[19:50:29] (171.67.108.42:80)
[19:50:29] - Error: Could not transmit unit 09 (completed November 27) to work server.
[19:50:29] - 1 failed uploads of this unit.
[19:50:29] Keeping unit 09 in queue.
[19:50:29] Trying to send all finished work units
[19:50:29] Project: 10721 (Run 0, Clone 10498, Gen 4)
[19:50:29] + Attempting to send results [November 27 19:50:29 UTC]
[19:50:29] - Reading file work/wuresults_09.dat from core
[19:50:29] (Read 1894264 bytes from disk)
[19:50:29] Connecting to http://171.67.108.42:8080/
[19:50:30] - Couldn't send HTTP request to server
[19:50:30] + Could not connect to Work Server (results)
[19:50:30] (171.67.108.42:8080)
[19:50:30] + Retrying using alternative port
[19:50:30] Connecting to http://171.67.108.42:80/
[19:50:32] - Couldn't send HTTP request to server
[19:50:32] + Could not connect to Work Server (results)
[19:50:32] (171.67.108.42:80)
[19:50:32] - Error: Could not transmit unit 09 (completed November 27) to work server.
[19:50:32] - 2 failed uploads of this unit.
[19:50:32] + Attempting to send results [November 27 19:50:32 UTC]
[19:50:32] - Reading file work/wuresults_09.dat from core
[19:50:32] (Read 1894264 bytes from disk)
[19:50:32] Connecting to http://171.67.108.26:8080/
[19:50:33] - Couldn't send HTTP request to server
[19:50:33] + Could not connect to Work Server (results)
[19:50:33] (171.67.108.26:8080)
[19:50:33] + Retrying using alternative port
[19:50:33] Connecting to http://171.67.108.26:80/
[19:50:35] - Couldn't send HTTP request to server
[19:50:35] + Could not connect to Work Server (results)
[19:50:35] (171.67.108.26:80)
[19:50:35] Could not transmit unit 09 to Collection server; keeping in queue.
[19:50:35] + Sent 0 of 1 completed units to the server
[19:50:35] - Preparing to get new work unit...
[19:50:35] + Attempting to get work packet
[19:50:35] - Will indicate memory of 3999 MB
[19:50:35] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 6
[19:50:35] - Connecting to assignment server
[19:50:35] Connecting to http://assign.stanford.edu:8080/
[19:50:36] Posted data.
[19:50:36] Initial: 4A81; - Successful: assigned to (129.74.85.15).
[19:50:36] + News From Folding@Home: Welcome to Folding@Home
[19:50:36] Loaded queue successfully.
[19:50:36] Connecting to http://129.74.85.15:8080/
[19:50:36] Initial: 0000; - Receiving payload (expected size: 51666)
[19:50:37] - Downloaded at ~50 kB/s
[19:50:37] - Averaged speed for that direction ~196 kB/s
[19:50:37] + Received work.
[19:50:37] Trying to send all finished work units
[19:50:37] Project: 10721 (Run 0, Clone 10498, Gen 4)
[19:50:37] + Attempting to send results [November 27 19:50:37 UTC]
[19:50:37] - Reading file work/wuresults_09.dat from core
[19:50:37] (Read 1894264 bytes from disk)
[19:50:37] Connecting to http://171.67.108.42:8080/
[19:50:38] - Couldn't send HTTP request to server
[19:50:38] + Could not connect to Work Server (results)
[19:50:38] (171.67.108.42:8080)
[19:50:38] + Retrying using alternative port
[19:50:38] Connecting to http://171.67.108.42:80/
[19:50:40] - Couldn't send HTTP request to server
[19:50:40] + Could not connect to Work Server (results)
[19:50:40] (171.67.108.42:80)
[19:50:40] - Error: Could not transmit unit 09 (completed November 27) to work server.
[19:50:40] - 3 failed uploads of this unit.
[19:50:40] + Attempting to send results [November 27 19:50:40 UTC]
[19:50:40] - Reading file work/wuresults_09.dat from core
[19:50:40] (Read 1894264 bytes from disk)
[19:50:40] Connecting to http://171.67.108.26:8080/
[19:50:41] - Couldn't send HTTP request to server
[19:50:41] + Could not connect to Work Server (results)
[19:50:41] (171.67.108.26:8080)
[19:50:41] + Retrying using alternative port
[19:50:41] Connecting to http://171.67.108.26:80/
[19:50:43] - Couldn't send HTTP request to server
[19:50:43] + Could not connect to Work Server (results)
[19:50:43] (171.67.108.26:80)
[19:50:43] Could not transmit unit 09 to Collection server; keeping in queue.
[19:50:43] + Sent 0 of 1 completed units to the server
[19:50:43] + Closed connections
[20:10:57] - Autosending finished units... [November 27 20:10:57 UTC]
[20:10:57] Trying to send all finished work units
[20:10:57] Project: 10721 (Run 0, Clone 10498, Gen 4)
[20:10:57] + Attempting to send results [November 27 20:10:57 UTC]
[20:10:57] - Reading file work/wuresults_09.dat from core
[20:10:57] (Read 1894264 bytes from disk)
[20:10:57] Connecting to http://171.67.108.42:8080/
[20:10:57] Working on queue slot 00 [November 27 20:10:57 UTC]
[20:10:57] + Working ...
[20:10:57] - Calling '.\FahCore_a4.exe -dir work/ -suffix 00 -priority 96 -nocpulock -checkpoint 30 -verbose -lifeline 4172 -version 623'
[20:10:57]
[20:10:57] *------------------------------*
[20:10:57] Folding@Home Gromacs GB Core
[20:10:57] Version 2.27 (Dec. 15, 2010)
[20:10:57]
[20:10:57] Preparing to commence simulation
[20:10:57] - Looking at optimizations...
[20:10:57] - Files status OK
[20:10:57] - Expanded 51154 -> 201448 (decompressed 393.8 percent)
[20:10:57] Called DecompressByteArray: compressed_data_size=51154 data_size=201448, decompressed_data_size=201448 diff=0
[20:10:57] - Digital signature verified
[20:10:57]
[20:10:57] Project: 10085 (Run 2, Clone 607, Gen 0)
[20:10:57]
[20:10:57] Assembly optimizations on if available.
[20:10:57] Entering M.D.
[20:11:00] - Couldn't send HTTP request to server
[20:11:00] + Could not connect to Work Server (results)
[20:11:00] (171.67.108.42:8080)
[20:11:00] + Retrying using alternative port
[20:11:00] Connecting to http://171.67.108.42:80/
[20:11:02] - Couldn't send HTTP request to server
[20:11:02] + Could not connect to Work Server (results)
[20:11:02] (171.67.108.42:80)
[20:11:02] - Error: Could not transmit unit 09 (completed November 27) to work server.
[20:11:02] - 4 failed uploads of this unit.
[20:11:02] + Attempting to send results [November 27 20:11:02 UTC]
[20:11:02] - Reading file work/wuresults_09.dat from core
[20:11:02] (Read 1894264 bytes from disk)
[20:11:02] Connecting to http://171.67.108.26:8080/
[20:11:03] Mapping NT from 1 to 1
[20:11:03] Completed 0 out of 10000000 steps (0%)
[20:11:05] - Couldn't send HTTP request to server
[20:11:05] + Could not connect to Work Server (results)
[20:11:05] (171.67.108.26:8080)
[20:11:05] + Retrying using alternative port
[20:11:05] Connecting to http://171.67.108.26:80/
[20:11:08] - Couldn't send HTTP request to server
[20:11:08] + Could not connect to Work Server (results)
[20:11:08] (171.67.108.26:80)
[20:11:08] Could not transmit unit 09 to Collection server; keeping in queue.
[20:11:08] + Sent 0 of 1 completed units to the server
[20:11:08] - Autosend completed
[20:12:38] ***** Got a SIGTERM signal (2)
[20:12:38] Killing all core threads
Folding@Home Client Shutdown.
[19:50:43]
