Is this a known problem?
This WU has taken an age to complete anyway, and I don't want to lose the results.
19:26:18:Unit 03:Completed 2500000 out of 2500000 steps (100%)
19:26:19:Unit 03:DynamicWrapper: Finished Work Unit: sleep=10000
19:26:29:Unit 03:
19:26:29:Unit 03:Finished Work Unit:
19:26:29:Unit 03:- Reading up to 35910936 from "03/wudata_01.trr": Read 35910936
19:26:30:Unit 03:trr file hash check passed.
19:26:30:Unit 03:edr file hash check passed.
19:26:30:Unit 03:logfile size: 87126
19:26:30:Unit 03:Leaving Run
19:26:33:Unit 00:Completed 63%
19:26:34:Unit 03:- Writing 36027978 bytes of core data to disk...
19:26:46:Unit 03:Done: 36027466 -> 30225610 (compressed to 83.8 percent)
19:26:47:Unit 03: ... Done.
19:26:49:Unit 03:- Shutting down core
19:26:49:Unit 03:
19:26:49:Unit 03:Folding@home Core Shutdown: FINISHED_UNIT
19:26:49:FahCore, running Unit 03, returned: FINISHED_UNIT (100 = 0x64)
19:26:50:Sending unit results: id:03 state:SEND project:7903 run:128 clone:0 gen:17 core:0xa4 unit:0x0000001500ac9c214e4d2c4c4f8b4862
19:26:50:Unit 03: Uploading 28.83MiB to 128.113.12.161
19:26:50:Starting Unit 01
19:26:50:Connecting to 128.113.12.161:8080
19:26:50:Running core: C:/Users/John/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -lifeline 2912 -version 701 -checkpoint 15 -np 4
19:26:52:Started core on PID 1880
19:26:52:FahCore 0xa4 started
19:26:52:Unit 01:
19:26:52:Unit 01:*------------------------------*
19:26:52:Unit 01:Folding@Home Gromacs GB Core
19:26:52:Unit 01:Version 2.27 (Dec. 15, 2010)
19:26:52:Unit 01:
19:26:52:Unit 01:Preparing to commence simulation
19:26:52:Unit 01:- Looking at optimizations...
19:26:52:Unit 01:- Created dyn
19:26:52:Unit 01:- Files status OK
19:26:52:Unit 01:- Expanded 1277427 -> 1751180 (decompressed 137.0 percent)
19:26:52:Unit 01:Called DecompressByteArray: compressed_data_size=1277427 data_size=1751180, decompressed_data_size=1751180 diff=0
19:26:52:Unit 01:- Digital signature verified
19:26:53:Unit 01:
19:26:53:Unit 01:Project: 7904 (Run 80, Clone 7, Gen 3)
19:26:53:Unit 01:
19:26:53:Unit 01:Assembly optimizations on if available.
19:26:53:Unit 01:Entering M.D.
19:26:58:Unit 01:Mapping NT from 4 to 4
19:26:59:Unit 01:Completed 0 out of 1000000 steps (0%)
19:27:11:WARNING: WorkServer connection failed on port 8080 trying 80
19:27:11:Connecting to 128.113.12.161:80
19:27:33:WARNING: Exception: Failed to send results to work server: Failed to connect to 128.113.12.161:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:27:33:Trying to send results to collection server
19:27:33:Unit 03: Uploading 28.83MiB to 129.74.85.16
19:27:33:Connecting to 129.74.85.16:8080
19:27:54:WARNING: WorkServer connection failed on port 8080 trying 80
19:27:54:Connecting to 129.74.85.16:80
19:28:15:ERROR: Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:28:15:Sending unit results: id:03 state:SEND project:7903 run:128 clone:0 gen:17 core:0xa4 unit:0x0000001500ac9c214e4d2c4c4f8b4862
19:28:16:Unit 03: Uploading 28.83MiB to 128.113.12.161
19:28:16:Connecting to 128.113.12.161:8080
19:28:37:WARNING: WorkServer connection failed on port 8080 trying 80
19:28:37:Connecting to 128.113.12.161:80
19:28:46:Unit 00:Completed 64%
19:28:58:WARNING: Exception: Failed to send results to work server: Failed to connect to 128.113.12.161:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:28:58:Trying to send results to collection server
19:28:58:Unit 03: Uploading 28.83MiB to 129.74.85.16
19:28:58:Connecting to 129.74.85.16:8080
19:29:19:WARNING: WorkServer connection failed on port 8080 trying 80
19:29:19:Connecting to 129.74.85.16:80
19:29:40:ERROR: Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:29:40:Sending unit results: id:03 state:SEND project:7903 run:128 clone:0 gen:17 core:0xa4 unit:0x0000001500ac9c214e4d2c4c4f8b4862
19:29:40:Unit 03: Uploading 28.83MiB to 128.113.12.161
19:29:40:Connecting to 128.113.12.161:8080
19:30:01:WARNING: WorkServer connection failed on port 8080 trying 80
19:30:01:Connecting to 128.113.12.161:80
19:30:22:WARNING: Exception: Failed to send results to work server: Failed to connect to 128.113.12.161:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:30:22:Trying to send results to collection server
19:30:22:Unit 03: Uploading 28.83MiB to 129.74.85.16
19:30:23:Connecting to 129.74.85.16:8080
19:30:44:WARNING: WorkServer connection failed on port 8080 trying 80
19:30:44:Connecting to 129.74.85.16:80
19:31:00:Unit 00:Completed 65%
19:31:05:ERROR: Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:31:17:Sending unit results: id:03 state:SEND project:7903 run:128 clone:0 gen:17 core:0xa4 unit:0x0000001500ac9c214e4d2c4c4f8b4862
19:31:17:Unit 03: Uploading 28.83MiB to 128.113.12.161
19:31:17:Connecting to 128.113.12.161:8080
19:31:38:WARNING: WorkServer connection failed on port 8080 trying 80
19:31:38:Connecting to 128.113.12.161:80
19:32:00:WARNING: Exception: Failed to send results to work server: Failed to connect to 128.113.12.161:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:32:00:Trying to send results to collection server
19:32:00:Unit 03: Uploading 28.83MiB to 129.74.85.16
19:32:00:Connecting to 129.74.85.16:8080
19:32:21:WARNING: WorkServer connection failed on port 8080 trying 80
19:32:21:Connecting to 129.74.85.16:80
19:32:42:ERROR: Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:33:14:Unit 00:Completed 66%
19:33:55:Sending unit results: id:03 state:SEND project:7903 run:128 clone:0 gen:17 core:0xa4 unit:0x0000001500ac9c214e4d2c4c4f8b4862
19:33:55:Unit 03: Uploading 28.83MiB to 128.113.12.161
19:33:55:Connecting to 128.113.12.161:8080
19:34:16:WARNING: WorkServer connection failed on port 8080 trying 80
19:34:16:Connecting to 128.113.12.161:80
19:34:37:WARNING: Exception: Failed to send results to work server: Failed to connect to 128.113.12.161:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:34:37:Trying to send results to collection server
19:34:37:Unit 03: Uploading 28.83MiB to 129.74.85.16
19:34:37:Connecting to 129.74.85.16:8080
19:34:58:WARNING: WorkServer connection failed on port 8080 trying 80
19:34:58:Connecting to 129.74.85.16:80
19:35:19:ERROR: Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:35:27:Unit 00:Completed 67%
19:37:41:Unit 00:Completed 68%
19:38:06:Unit 01:Completed 10000 out of 1000000 steps (1%)
19:38:09:Sending unit results: id:03 state:SEND project:7903 run:128 clone:0 gen:17 core:0xa4 unit:0x0000001500ac9c214e4d2c4c4f8b4862
19:38:09:Unit 03: Uploading 28.83MiB to 128.113.12.161
19:38:09:Connecting to 128.113.12.161:8080
19:38:30:WARNING: WorkServer connection failed on port 8080 trying 80
19:38:30:Connecting to 128.113.12.161:80
19:38:51:WARNING: Exception: Failed to send results to work server: Failed to connect to 128.113.12.161:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:38:51:Trying to send results to collection server
19:38:51:Unit 03: Uploading 28.83MiB to 129.74.85.16
19:38:51:Connecting to 129.74.85.16:8080
19:39:12:WARNING: WorkServer connection failed on port 8080 trying 80
19:39:12:Connecting to 129.74.85.16:80
19:39:33:ERROR: Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:39:55:Unit 00:Completed 69%
19:42:09:Unit 00:Completed 70%
19:44:22:Unit 00:Completed 71%
19:45:00:Sending unit results: id:03 state:SEND project:7903 run:128 clone:0 gen:17 core:0xa4 unit:0x0000001500ac9c214e4d2c4c4f8b4862
19:45:00:Unit 03: Uploading 28.83MiB to 128.113.12.161
19:45:00:Connecting to 128.113.12.161:8080
19:45:21:WARNING: WorkServer connection failed on port 8080 trying 80
19:45:21:Connecting to 128.113.12.161:80
19:45:43:WARNING: Exception: Failed to send results to work server: Failed to connect to 128.113.12.161:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:45:43:Trying to send results to collection server
19:45:43:Unit 03: Uploading 28.83MiB to 129.74.85.16
19:45:43:Connecting to 129.74.85.16:8080
19:46:04:WARNING: WorkServer connection failed on port 8080 trying 80
19:46:04:Connecting to 129.74.85.16:80
19:46:25:ERROR: Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:46:36:Unit 00:Completed 72%
19:48:49:Unit 00:Completed 73%
19:49:13:Unit 01:Completed 20000 out of 1000000 steps (2%)
19:51:03:Unit 00:Completed 74%
19:53:17:Unit 00:Completed 75%
19:55:31:Unit 00:Completed 76%
19:56:06:Sending unit results: id:03 state:SEND project:7903 run:128 clone:0 gen:17 core:0xa4 unit:0x0000001500ac9c214e4d2c4c4f8b4862
19:56:06:Unit 03: Uploading 28.83MiB to 128.113.12.161
19:56:06:Connecting to 128.113.12.161:8080
19:56:27:WARNING: WorkServer connection failed on port 8080 trying 80
19:56:27:Connecting to 128.113.12.161:80
19:56:48:WARNING: Exception: Failed to send results to work server: Failed to connect to 128.113.12.161:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:56:48:Trying to send results to collection server
19:56:48:Unit 03: Uploading 28.83MiB to 129.74.85.16
19:56:48:Connecting to 129.74.85.16:8080
19:57:09:WARNING: WorkServer connection failed on port 8080 trying 80
19:57:09:Connecting to 129.74.85.16:80
19:57:31:ERROR: Exception: Failed to connect to 129.74.85.16:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:57:44:Unit 00:Completed 77%
19:59:58:Unit 00:Completed 78%
20:00:24:Unit 01:Completed 30000 out of 1000000 steps (3%)
20:02:12:Unit 00:Completed 79%
20:04:25:Unit 00:Completed 80%
20:06:39:Unit 00:Completed 81%
20:08:53:Unit 00:Completed 82%
20:11:06:Unit 00:Completed 83%
20:11:33:Unit 01:Completed 40000 out of 1000000 steps (4%)
20:13:20:Unit 00:Completed 84%
20:14:02:Sending unit results: id:03 state:SEND project:7903 run:128 clone:0 gen:17 core:0xa4 unit:0x0000001500ac9c214e4d2c4c4f8b4862
20:14:03:Unit 03: Uploading 28.83MiB to 128.113.12.161
20:14:03:Connecting to 128.113.12.161:8080
20:14:09:Unit 03: 0.18%
20:14:15:Unit 03: 0.31%
20:14:21:Unit 03: 0.53%
20:14:27:Unit 03: 0.84%
20:14:33:Unit 03: 1.12%
20:14:39:Unit 03: 1.36%
20:14:46:Unit 03: 1.63%
20:14:52:Unit 03: 1.82%
20:14:58:Unit 03: 2.07%
20:15:04:Unit 03: 2.30%
20:15:10:Unit 03: 2.63%
20:15:17:Unit 03: 2.78%
20:15:23:Unit 03: 3.05%
20:15:29:Unit 03: 3.31%
20:15:34:Unit 00:Completed 85%
20:15:35:Unit 03: 3.54%
20:15:41:Unit 03: 3.79%
20:15:47:Unit 03: 3.88%
20:15:54:Unit 03: 4.01%
20:16:00:Unit 03: 4.23%
20:16:06:Unit 03: 4.39%
20:16:12:Unit 03: 4.68%
20:16:19:Unit 03: 4.81%
20:16:25:Unit 03: 5.01%
20:16:31:Unit 03: 5.23%
20:16:37:Unit 03: 5.49%
20:16:43:Unit 03: 5.77%
20:16:49:Unit 03: 5.91%
20:16:55:Unit 03: 6.13%
20:17:01:Unit 03: 6.41%
20:17:07:Unit 03: 6.68%
20:17:13:Unit 03: 6.95%
20:17:19:Unit 03: 7.05%
20:17:27:Unit 03: 7.07%
20:17:35:Unit 03: 7.18%
20:17:41:Unit 03: 7.40%
20:17:48:Unit 00:Completed 86%
20:17:48:Unit 03: 7.60%
20:17:54:Unit 03: 7.79%
20:18:00:Unit 03: 8.06%
20:18:06:Unit 03: 8.31%
20:18:12:Unit 03: 8.59%
20:18:19:Unit 03: 8.79%
20:18:25:Unit 03: 8.89%
20:18:31:Unit 03: 9.19%
20:18:37:Unit 03: 9.40%
20:18:43:Unit 03: 9.70%
20:18:49:Unit 03: 9.91%
20:18:55:Unit 03: 10.15%
20:19:01:Unit 03: 10.39%
20:19:07:Unit 03: 10.57%
20:19:13:Unit 03: 10.75%
20:19:19:Unit 03: 11.00%
20:19:25:Unit 03: 11.06%
20:19:31:Unit 03: 11.30%
20:19:37:Unit 03: 11.49%
20:19:43:Unit 03: 11.74%
20:19:49:Unit 03: 11.95%
20:19:55:Unit 03: 12.03%
20:20:01:Unit 03: 12.20%
20:20:01:Unit 00:Completed 87%
20:20:07:Unit 03: 12.47%
20:20:13:Unit 03: 12.70%
20:20:19:Unit 03: 12.90%
20:20:27:Unit 03: 13.13%
20:20:35:Unit 03: 13.33%
20:20:41:Unit 03: 13.48%
20:20:47:Unit 03: 13.58%
20:20:53:Unit 03: 13.77%
20:20:59:Unit 03: 13.93%
20:21:05:Unit 03: 14.12%
20:21:11:Unit 03: 14.20%
20:21:17:Unit 03: 14.43%
20:21:23:Unit 03: 14.64%
20:21:29:Unit 03: 14.85%
20:21:36:Unit 03: 14.97%
20:21:42:Unit 03: 15.06%
20:21:48:Unit 03: 15.23%
20:21:54:Unit 03: 15.34%
20:22:00:Unit 03: 15.48%
20:22:07:Unit 03: 15.60%
20:22:13:Unit 03: 15.65%
20:22:15:Unit 00:Completed 88%
20:22:19:Unit 03: 15.87%
20:22:25:Unit 03: 16.10%
20:22:31:Unit 03: 16.23%
20:22:37:Unit 03: 16.36%
20:22:43:Unit 01:Completed 50000 out of 1000000 steps (5%)
20:22:43:Unit 03: 16.49%
20:22:49:Unit 03: 16.75%
20:22:55:Unit 03: 16.93%
20:23:01:Unit 03: 17.13%
20:23:07:Unit 03: 17.35%
20:23:13:Unit 03: 17.49%
20:23:19:Unit 03: 17.68%
20:23:26:Unit 03: 17.83%
20:23:32:Unit 03: 17.97%
20:23:38:Unit 03: 18.09%
20:23:44:Unit 03: 18.16%
20:23:50:Unit 03: 18.32%
20:23:56:Unit 03: 18.62%
20:24:02:Unit 03: 18.84%
20:24:08:Unit 03: 19.08%
20:24:14:Unit 03: 19.32%
20:24:20:Unit 03: 19.62%
20:24:26:Unit 03: 19.83%
20:24:28:Unit 00:Completed 89%
20:24:32:Unit 03: 19.89%
20:24:38:Unit 03: 20.04%
20:24:44:Unit 03: 20.26%
20:24:50:Unit 03: 20.41%
20:24:56:Unit 03: 20.60%
20:25:02:Unit 03: 20.88%
20:25:08:Unit 03: 21.07%
20:25:14:Unit 03: 21.29%
20:25:20:Unit 03: 21.53%
20:25:26:Unit 03: 21.76%
20:25:32:Unit 03: 21.84%
20:25:38:Unit 03: 22.06%
20:25:46:Unit 03: 22.21%
20:25:52:Unit 03: 22.43%
20:25:59:Unit 03: 22.60%
20:26:05:Unit 03: 22.68%
20:26:11:Unit 03: 22.85%
20:26:17:Unit 03: 22.98%
20:26:23:Unit 03: 23.17%
20:26:29:Unit 03: 23.25%
20:26:35:Unit 03: 23.42%
20:26:41:Unit 03: 23.57%
20:26:42:Unit 00:Completed 90%
20:26:47:Unit 03: 23.65%
20:26:53:Unit 03: 23.92%
20:26:59:Unit 03: 24.03%
20:27:05:Unit 03: 24.19%
20:27:11:Unit 03: 24.26%
20:27:18:Unit 03: 24.49%
20:27:25:Unit 03: 24.62%
20:27:31:Unit 03: 24.84%
20:27:37:Unit 03: 24.99%
20:27:43:Unit 03: 25.31%
20:27:49:Unit 03: 25.48%
20:27:55:Unit 03: 25.60%
20:28:01:Unit 03: 25.75%
20:28:07:Unit 03: 25.86%
20:28:13:Unit 03: 25.99%
20:28:19:Unit 03: 26.10%
20:28:26:Unit 03: 26.26%
20:28:32:Unit 03: 26.47%
20:28:38:Unit 03: 26.67%
20:28:44:Unit 03: 26.91%
20:28:50:Unit 03: 27.21%
20:28:56:Unit 03: 27.44%
20:28:56:Unit 00:Completed 91%
20:29:02:Unit 03: 27.69%
20:29:08:Unit 03: 27.79%
20:29:14:Unit 03: 28.04%
20:29:20:Unit 03: 28.34%
20:29:26:Unit 03: 28.62%
20:29:32:Unit 03: 28.97%
20:29:38:Unit 03: 29.23%
20:29:44:Unit 03: 29.49%
20:29:50:Unit 03: 29.70%
20:29:56:Unit 03: 29.96%
20:30:02:Unit 03: 30.10%
20:30:15:Unit 03: 30.18%
20:30:39:Unit 03: 30.19%
20:30:45:Unit 03: 30.30%
20:30:51:Unit 03: 30.42%
20:30:57:Unit 03: 30.67%
20:31:03:Unit 03: 30.79%
20:31:09:Unit 03: 30.99%
20:31:10:Unit 00:Completed 92%
20:31:15:Unit 03: 31.21%
20:31:21:Unit 03: 31.32%
20:31:27:Unit 03: 31.49%
20:31:38:Unit 03: 31.68%
20:31:44:Unit 03: 31.95%
20:32:06:Unit 03: 32.01%
20:32:36:WARNING: Exception: Failed to send results to work server: Upload failed
20:32:36:Trying to send results to collection server
20:32:36:Unit 03: Uploading 28.83MiB to 129.74.85.16
20:32:36:Connecting to 129.74.85.16:8080
20:32:42:Unit 03: 0.14%
20:32:48:Unit 03: 0.37%
20:32:54:Unit 03: 0.54%
20:33:00:Unit 03: 0.79%
20:33:06:Unit 03: 0.98%
20:33:12:Unit 03: 1.12%
20:33:18:Unit 03: 1.29%
20:33:23:Unit 00:Completed 93%
20:33:24:Unit 03: 1.56%
20:33:30:Unit 03: 1.79%
20:33:36:Unit 03: 2.01%
20:33:43:Unit 03: 2.22%
20:33:49:Unit 03: 2.41%
20:33:50:Unit 01:Completed 60000 out of 1000000 steps (6%)
20:33:55:Unit 03: 2.68%
20:34:01:Unit 03: 2.81%
20:34:07:Unit 03: 3.02%
20:34:13:Unit 03: 3.17%
20:34:19:Unit 03: 3.33%
20:34:26:Unit 03: 3.59%
20:34:33:Unit 03: 3.79%
20:34:39:Unit 03: 4.08%
20:34:45:Unit 03: 4.30%
20:34:51:Unit 03: 4.54%
20:34:57:Unit 03: 4.62%
20:35:03:Unit 03: 4.73%
20:35:10:Unit 03: 4.95%
20:35:18:Unit 03: 5.05%
20:35:25:Unit 03: 5.11%
20:35:31:Unit 03: 5.33%
20:35:37:Unit 00:Completed 94%
20:35:37:Unit 03: 5.54%
20:35:43:Unit 03: 5.68%
20:35:49:Unit 03: 5.85%
20:35:55:Unit 03: 5.98%
20:36:01:Unit 03: 6.08%
20:36:07:Unit 03: 6.21%
20:36:13:Unit 03: 6.44%
20:36:21:Unit 03: 6.64%
20:36:27:Unit 03: 6.80%
20:36:34:Unit 03: 6.90%
20:36:41:Unit 03: 7.11%
20:36:47:Unit 03: 7.28%
20:36:53:Unit 03: 7.47%
20:36:59:Unit 03: 7.53%
20:37:05:Unit 03: 7.63%
20:37:12:Unit 03: 7.71%
20:37:18:Unit 03: 7.87%
20:37:25:Unit 03: 8.08%
20:37:31:Unit 03: 8.18%
20:37:37:Unit 03: 8.46%
20:37:43:Unit 03: 8.70%
20:37:50:Unit 03: 8.90%
20:37:50:Unit 00:Completed 95%
20:37:56:Unit 03: 8.98%
20:38:02:Unit 03: 9.16%
20:38:08:Unit 03: 9.40%
20:38:14:Unit 03: 9.55%
20:38:20:Unit 03: 9.72%
20:38:26:Unit 03: 9.97%
20:38:33:Unit 03: 10.05%
20:38:40:Unit 03: 10.07%
20:38:46:Unit 03: 10.29%
20:38:52:Unit 03: 10.48%
20:38:59:Unit 03: 10.62%
20:39:07:Unit 03: 10.81%
20:39:15:Unit 03: 11.06%
20:39:21:Unit 03: 11.30%
20:39:27:Unit 03: 11.50%
20:39:33:Unit 03: 11.76%
20:39:40:Unit 03: 11.98%
20:39:46:Unit 03: 12.13%
20:39:52:Unit 03: 12.33%
20:39:58:Unit 03: 12.53%
20:40:04:Unit 03: 12.66%
20:40:04:Unit 00:Completed 96%
20:40:10:Unit 03: 12.91%
20:40:16:Unit 03: 13.12%
20:40:22:Unit 03: 13.27%
20:40:28:Unit 03: 13.35%
20:40:34:Unit 03: 13.48%
20:40:40:Unit 03: 13.71%
20:40:46:Unit 03: 13.94%
20:40:52:Unit 03: 14.22%
20:40:58:Unit 03: 14.40%
20:41:04:Unit 03: 14.58%
20:41:10:Unit 03: 14.80%
20:41:16:Unit 03: 14.95%
20:41:22:Unit 03: 15.08%
20:41:28:Unit 03: 15.26%
20:41:34:Unit 03: 15.48%
20:41:40:Unit 03: 15.69%
20:41:46:Unit 03: 15.85%
20:41:53:Unit 03: 16.04%
20:41:59:Unit 03: 16.29%
20:42:05:Unit 03: 16.53%
20:42:11:Unit 03: 16.67%
20:42:17:Unit 03: 16.90%
20:42:18:Unit 00:Completed 97%
20:42:23:Unit 03: 17.16%
20:42:29:Unit 03: 17.28%
20:42:35:Unit 03: 17.36%
20:42:41:Unit 03: 17.58%
20:42:47:Unit 03: 17.72%
20:42:55:Unit 03: 17.90%
20:43:01:Unit 03: 18.00%
20:43:08:Unit 03: 18.20%
20:43:14:Unit 03: 18.47%
20:43:20:Unit 03: 18.75%
20:43:26:Unit 03: 18.86%
20:43:32:Unit 03: 19.12%
20:43:38:Unit 03: 19.39%
20:43:46:Unit 03: 19.49%
20:43:52:Unit 03: 19.58%
20:43:58:Unit 03: 19.83%
20:44:04:Unit 03: 19.97%
20:44:10:Unit 03: 20.22%
20:44:16:Unit 03: 20.49%
20:44:22:Unit 03: 20.77%
20:44:29:Unit 03: 20.98%
20:44:33:Unit 00:Completed 98%
20:44:35:Unit 03: 21.14%
20:44:41:Unit 03: 21.41%
20:45:12:Unit 03: 21.44%
20:45:14:Unit 01:Completed 70000 out of 1000000 steps (7%)
20:45:42:ERROR: Exception: Upload failed
20:45:42:Sending unit results: id:03 state:SEND project:7903 run:128 clone:0 gen:17 core:0xa4 unit:0x0000001500ac9c214e4d2c4c4f8b4862
20:45:42:Unit 03: Uploading 28.83MiB to 128.113.12.161
20:45:42:Connecting to 128.113.12.161:8080
20:45:48:Unit 03: 0.20%
20:45:54:Unit 03: 0.38%
20:46:00:Unit 03: 0.57%
20:46:06:Unit 03: 0.72%
20:46:12:Unit 03: 0.96%
20:46:18:Unit 03: 1.15%
20:46:25:Unit 03: 1.44%
20:46:31:Unit 03: 1.64%
20:46:37:Unit 03: 1.95%
20:46:43:Unit 03: 2.28%
20:46:47:Unit 00:Completed 99%
20:46:48:Connecting to assign-GPU.stanford.edu:80
20:46:49:Unit 03: 2.36%
20:46:50:News: Welcome to Folding@Home
20:46:50:Assigned to work server 171.67.108.11
20:46:50:Requesting new work unit for slot 00: RUNNING gpu:0:"GT216 [GeForce GT 220]" from 171.67.108.11
20:46:50:Connecting to 171.67.108.11:8080
20:46:51:Slot 00: Downloading 46.11KiB
20:46:52:Slot 00: Download complete
20:46:52:Received Unit: id:02 state:DOWNLOAD project:5766 run:2 clone:9 gen:278 core:0x11 unit:0x67aec5b74ec6c4e30116000900021686
20:46:55:Unit 03: 2.56%
20:47:02:Unit 03: 2.68%
20:47:08:Unit 03: 2.94%
20:47:15:Unit 03: 3.29%
20:47:22:Unit 03: 3.41%
20:47:28:Unit 03: 3.65%
20:47:34:Unit 03: 3.88%
20:47:40:Unit 03: 4.05%
20:47:46:Unit 03: 4.21%
20:47:58:Unit 03: 4.27%
20:48:04:Unit 03: 4.46%
20:48:10:Unit 03: 4.73%
20:48:17:Unit 03: 4.89%
20:48:24:Unit 03: 5.07%
20:48:30:Unit 03: 5.20%
20:48:37:Unit 03: 5.28%
20:48:45:Unit 03: 5.39%
20:49:02:Unit 00:Completed 100%
20:49:04:Unit 00:Successful run
20:49:04:Unit 00:DynamicWrapper: Finished Work Unit: sleep=10000
20:49:09:Unit 03: 5.42%
20:49:14:Unit 00:Reserved 75876 bytes for xtc file; Cosm status=0
20:49:14:Unit 00:Allocated 75876 bytes for xtc file
20:49:14:Unit 00:- Reading up to 75876 from "00/wudata_01.xtc": Read 75876
20:49:14:Unit 00:Read 75876 bytes from xtc file; available packet space=786354588
20:49:14:Unit 00:xtc file hash check passed.
20:49:14:Unit 00:Reserved 15168 15168 786354588 bytes for arc file=<00/wudata_01.trr> Cosm status=0
20:49:14:Unit 00:Allocated 15168 bytes for arc file
20:49:14:Unit 00:- Reading up to 15168 from "00/wudata_01.trr": Read 15168
20:49:14:Unit 00:Read 15168 bytes from arc file; available packet space=786339420
20:49:14:Unit 00:trr file hash check passed.
20:49:14:Unit 00:Allocated 560 bytes for edr file
20:49:14:Unit 00:Read bedfile
20:49:14:Unit 00:edr file hash check passed.
20:49:14:Unit 00:Allocated 0 bytes for logfile
20:49:14:Unit 00:Could not open/read logfile=<00/wudata_01.log>; Cosm status=-1
20:49:14:Unit 00:GuardedRun: success in DynamicWrapper
20:49:14:Unit 00:GuardedRun: done
20:49:14:Unit 00:Run: GuardedRun completed.
20:49:15:Unit 03: 5.73%
20:49:17:Unit 00:+ Opened results file
20:49:17:Unit 00:- Writing 92116 bytes of core data to disk...
20:49:17:Unit 00:Done: 91604 -> 90289 (compressed to 98.5 percent)
20:49:17:Unit 00: ... Done.
20:49:17:Unit 00:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
20:49:17:FahCore, running Unit 00, returned: FINISHED_UNIT (100 = 0x64)
20:49:17:Sending unit results: id:00 state:SEND project:5766 run:9 clone:295 gen:718 core:0x11 unit:0x2fb843d84ec6912202ce012700091686
20:49:17:Unit 00: Uploading 88.67KiB to 171.67.108.11
20:49:17:Starting Unit 02
20:49:17:Connecting to 171.67.108.11:8080
20:49:17:Running core: C:/Users/John/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 02 -suffix 01 -lifeline 2912 -version 701 -checkpoint 15 -gpu 0
20:49:17:Started core on PID 1916
20:49:17:FahCore 0x11 started
20:49:18:Unit 02:
20:49:18:Unit 02:*------------------------------*
20:49:18:Unit 02:Folding@Home GPU Core
20:49:18:Unit 02:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
20:49:18:Unit 02:
20:49:18:Unit 02:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
20:49:18:Unit 02:Build host: amoeba
20:49:18:Unit 02:Board Type: Nvidia
20:49:18:Unit 02:Core :
20:49:18:Unit 02:Preparing to commence simulation
20:49:18:Unit 02:- Looking at optimizations...
20:49:18:Unit 02:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
20:49:18:Unit 02:- Created dyn
20:49:18:Unit 02:- Files status OK
20:49:18:Unit 02:- Expanded 46703 -> 252912 (decompressed 541.5 percent)
20:49:18:Unit 02:Called DecompressByteArray: compressed_data_size=46703 data_size=252912, decompressed_data_size=252912 diff=0
20:49:18:Unit 02:- Digital signature verified
20:49:18:Unit 02:
20:49:18:Unit 02:Project: 5766 (Run 2, Clone 9, Gen 278)
20:49:18:Unit 02:
20:49:18:Unit 02:Assembly optimizations on if available.
20:49:18:Unit 02:Entering M.D.
20:49:21:Unit 03: 6.04%
20:49:23:Unit 00: 27.07%
20:49:23:Unit 02:Tpr hash 02/wudata_01.tpr: 3454289913 2955289124 1898217962 2924529371 3142398503
20:49:23:Unit 02:
20:49:23:Unit 02:Calling fah_main args: 14 usage=100
20:49:23:Unit 02:
20:49:24:Unit 02:Working on Protein
20:49:25:Unit 02:Client config unavailable.
20:49:25:Unit 02:Starting GUI Server
20:49:27:Unit 03: 6.19%
20:49:29:Unit 00: 72.18%
20:49:31:Unit 00: Upload complete
20:49:31:Server responded WORK_ACK (400)
20:49:31:Cleaning up Unit 00
20:49:33:Unit 03: 6.44%
20:49:39:Unit 03: 6.75%
20:49:45:Unit 03: 7.02%
20:49:51:Unit 03: 7.26%
20:49:57:Unit 03: 7.45%
20:50:03:Unit 03: 7.66%
20:50:09:Unit 03: 7.87%
20:50:15:Unit 03: 8.08%
20:50:21:Unit 03: 8.24%
20:50:27:Unit 03: 8.48%
20:50:33:Unit 03: 8.66%
20:50:39:Unit 03: 8.92%
20:50:45:Unit 03: 9.19%
20:50:51:Unit 03: 9.42%
20:50:57:Unit 03: 9.62%
20:51:05:Unit 03: 9.76%
20:51:11:Unit 03: 9.97%
20:51:17:Unit 03: 10.29%
20:51:24:Unit 03: 10.61%
20:51:30:Unit 03: 10.88%
20:51:36:Unit 03: 11.22%
20:51:37:Unit 02:Completed 1%
20:51:42:Unit 03: 11.33%
20:51:48:Unit 03: 11.57%
20:51:55:Unit 03: 11.84%
20:52:01:Unit 03: 11.94%
20:52:07:Unit 03: 12.06%
20:52:13:Unit 03: 12.35%
20:52:22:Unit 03: 12.62%
20:52:28:Unit 03: 12.64%
20:52:34:Unit 03: 12.86%
20:52:41:Unit 03: 13.04%
20:52:47:Unit 03: 13.31%
20:52:53:Unit 03: 13.42%
20:52:59:Unit 03: 13.70%
20:53:05:Unit 03: 13.81%
20:53:11:Unit 03: 14.08%
20:53:17:Unit 03: 14.30%
20:53:23:Unit 03: 14.54%
20:53:30:Unit 03: 14.68%
20:53:37:Unit 03: 14.84%
20:53:46:Unit 03: 15.01%
20:53:51:Unit 02:Completed 2%
20:54:13:Unit 03: 15.03%
20:54:43:WARNING: Exception: Failed to send results to work server: Upload failed
20:54:43:Trying to send results to collection server
20:54:43:Unit 03: Uploading 28.83MiB to 129.74.85.16
20:54:43:Connecting to 129.74.85.16:8080
20:54:49:Unit 03: 0.05%
20:54:55:Unit 03: 0.15%
20:55:01:Unit 03: 0.31%
20:55:07:Unit 03: 0.41%
20:55:13:Unit 03: 0.60%
20:55:19:Unit 03: 0.75%
20:55:25:Unit 03: 0.99%
20:55:31:Unit 03: 1.26%
20:55:38:Unit 03: 1.41%
20:55:44:Unit 03: 1.48%
20:55:50:Unit 03: 1.67%
20:55:56:Unit 03: 1.96%
20:56:03:Unit 03: 2.14%
20:56:06:Unit 02:Completed 3%
20:56:09:Unit 03: 2.39%
20:56:15:Unit 03: 2.56%
20:56:21:Unit 03: 2.86%
20:56:27:Unit 03: 3.05%
20:56:33:Unit 03: 3.23%
20:56:39:Unit 03: 3.52%
20:56:45:Unit 03: 3.81%
20:56:46:Unit 01:Completed 80000 out of 1000000 steps (8%)
20:56:51:Unit 03: 3.97%
20:56:58:Unit 03: 4.12%
20:57:04:Unit 03: 4.24%
20:57:10:Unit 03: 4.50%
20:57:16:Unit 03: 4.70%
20:57:22:Unit 03: 4.85%
20:57:28:Unit 03: 5.00%
20:57:34:Unit 03: 5.20%
20:57:40:Unit 03: 5.24%
20:57:46:Unit 03: 5.42%
20:57:52:Unit 03: 5.61%
20:57:58:Unit 03: 5.92%
20:58:04:Unit 03: 6.18%
20:58:10:Unit 03: 6.45%
20:58:16:Unit 03: 6.61%
20:58:20:Unit 02:Completed 4%
20:58:22:Unit 03: 6.83%
20:58:28:Unit 03: 7.06%
20:58:34:Unit 03: 7.24%
20:58:40:Unit 03: 7.44%
20:58:46:Unit 03: 7.71%
20:58:52:Unit 03: 7.90%
20:58:59:Unit 03: 8.13%
20:59:05:Unit 03: 8.32%
20:59:11:Unit 03: 8.46%
20:59:17:Unit 03: 8.62%
20:59:23:Unit 03: 8.85%
20:59:29:Unit 03: 9.05%
20:59:35:Unit 03: 9.30%
20:59:41:Unit 03: 9.54%
20:59:51:Unit 03: 9.59%
20:59:57:Unit 03: 9.89%
21:00:03:Unit 03: 10.12%
21:00:09:Unit 03: 10.41%
21:00:15:Unit 03: 10.62%
21:00:22:Unit 03: 10.92%
21:00:29:Unit 03: 11.08%
21:00:34:Unit 02:Completed 5%
21:00:35:Unit 03: 11.26%
21:00:43:Unit 03: 11.32%
21:00:56:Unit 03: 11.33%
21:01:02:Unit 03: 11.53%
21:01:10:Unit 03: 11.65%
21:01:16:Unit 03: 11.84%
21:01:25:Unit 03: 11.99%
21:01:31:Unit 03: 12.16%
21:01:37:Unit 03: 12.44%
21:01:43:Unit 03: 12.64%
21:01:51:Unit 03: 12.77%
21:01:57:Unit 03: 12.90%
21:02:03:Unit 03: 13.12%
21:02:09:Unit 03: 13.33%
21:02:15:Unit 03: 13.58%
21:02:21:Unit 03: 13.82%
21:02:27:Unit 03: 14.09%
21:02:34:Unit 03: 14.34%
21:02:40:Unit 03: 14.64%
21:02:46:Unit 03: 14.93%
21:02:48:Unit 02:Completed 6%
21:02:52:Unit 03: 15.18%
21:02:58:Unit 03: 15.42%
21:03:07:Unit 03: 15.52%
21:03:24:Unit 03: 15.71%
21:03:30:Unit 03: 15.81%
21:03:36:Unit 03: 16.00%
21:03:42:Unit 03: 16.15%
21:03:48:Unit 03: 16.48%
21:03:54:Unit 03: 16.61%
21:04:01:Unit 03: 16.74%
21:04:07:Unit 03: 16.94%
21:04:13:Unit 03: 17.14%
21:04:20:Unit 03: 17.33%
21:04:26:Unit 03: 17.48%
21:04:32:Unit 03: 17.60%
21:04:38:Unit 03: 17.81%
21:04:44:Unit 03: 17.97%
21:04:50:Unit 03: 18.16%
21:04:57:Unit 03: 18.28%
21:05:02:Unit 02:Completed 7%
21:05:03:Unit 03: 18.39%
21:05:09:Unit 03: 18.59%
21:05:15:Unit 03: 18.73%
21:05:22:Unit 03: 18.92%
21:05:28:Unit 03: 19.11%
21:05:34:Unit 03: 19.34%
21:05:40:Unit 03: 19.50%
21:05:46:Unit 03: 19.60%
21:05:52:Unit 03: 19.80%
21:05:58:Unit 03: 19.99%
21:06:04:Unit 03: 20.16%
21:06:10:Unit 03: 20.34%
21:06:16:Unit 03: 20.50%
21:06:22:Unit 03: 20.73%
21:06:28:Unit 03: 20.88%
21:06:34:Unit 03: 21.07%
21:06:40:Unit 03: 21.29%
21:06:46:Unit 03: 21.45%
21:06:52:Unit 03: 21.70%
21:06:58:Unit 03: 21.86%
21:07:04:Unit 03: 22.02%
21:07:10:Unit 03: 22.17%
21:07:16:Unit 02:Completed 8%
21:07:16:Unit 03: 22.32%
21:07:22:Unit 03: 22.51%
21:07:29:Unit 03: 22.64%
21:07:35:Unit 03: 22.83%
21:07:41:Unit 03: 23.02%
21:07:47:Unit 03: 23.20%
21:07:53:Unit 03: 23.39%
21:07:59:Unit 03: 23.57%
21:08:05:Unit 03: 23.69%
21:08:10:Unit 01:Completed 90000 out of 1000000 steps (9%)
21:08:11:Unit 03: 23.82%
21:08:17:Unit 03: 23.97%
21:08:23:Unit 03: 24.07%
21:08:29:Unit 03: 24.24%
21:08:35:Unit 03: 24.37%
21:08:41:Unit 03: 24.53%
21:08:47:Unit 03: 24.69%
21:08:53:Unit 03: 24.91%
21:08:59:Unit 03: 25.08%
21:09:05:Unit 03: 25.29%
21:09:12:Unit 03: 25.49%
21:09:18:Unit 03: 25.67%
21:09:24:Unit 03: 25.83%
21:09:30:Unit 03: 26.00%
21:09:31:Unit 02:Completed 9%
21:09:37:Unit 03: 26.22%
21:09:43:Unit 03: 26.33%
21:09:48:ERROR: Exception: Upload failed
21:11:45:Unit 02:Completed 10%
21:14:00:Unit 02:Completed 11%
21:16:15:Unit 02:Completed 12%
21:18:30:Unit 02:Completed 13%
