Project: 6055 (Run 0, Clone 152, Gen 472) - Bad WU?
daveb
Post by daveb »
I noticed that my computer (2.2 GHz MacBookPro, OSX.6.8) didn't seem to be making any progress on this unit after ~30 minutes. It normally runs this type of unit at ~4 minutes/frame. I also noticed that it reported 236500016 steps instead of the 500000 I usually see for these units.
04:32:00:Unit 00:*------------------------------*
04:32:00:Unit 00:Folding@Home Gromacs SMP Core
04:32:00:Unit 00:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
04:32:00:Unit 00:
04:32:00:Unit 00:Preparing to commence simulation
04:32:00:Unit 00:- Assembly optimizations manually forced on.
04:32:00:Unit 00:- Not checking prior termination.
04:32:00:Unit 00:- Expanded 1389806 -> 2251569 (decompressed 162.0 percent)
04:32:00:Unit 00:Called DecompressByteArray: compressed_data_size=1389806 data_size=2251569, decompressed_data_size=2251569 diff=0
04:32:00:Unit 00:- Digital signature verified
04:32:00:Unit 00:
04:32:00:Unit 00:Project: 6055 (Run 0, Clone 152, Gen 472)
04:32:00:Unit 00:
04:32:00:Unit 00:Assembly optimizations on if available.
04:32:00:Unit 00:Entering M.D.
04:32:06:Unit 01: 18.46%
04:32:06:Unit 00:Mapping NT from 8 to 8
04:32:06:Unit 00:Completed 0 out of 236500016 steps  (0%)
04:32:12:Unit 01: 33.04%
04:32:18:Unit 01: 51.03%
04:32:24:Unit 01: 64.95%
04:32:30:Unit 01: 82.46%
04:32:36:Unit 01: 99.13%
04:32:37:Unit 01: Upload complete
04:32:37:Server responded WORK_ACK (400)
04:32:37:Final credit estimate, 11029.00 points
04:32:37:Cleaning up Unit 01
04:57:21:Downloading project 6040 description
04:57:21:Connecting to fah-web.stanford.edu:80
04:57:22:SocketDevice::read(): End of stream
04:57:22:Downloading project 6078 description
04:57:22:Connecting to fah-web.stanford.edu:80
04:57:23:SocketDevice::read(): End of stream
07:01:43:Slot 00 paused
07:01:43:Slot 00: shutting core down
-Dave
sortofageek
Re: Project: 6055 (Run 0, Clone 152, Gen 472) - Bad WU?
Post by sortofageek »
There is a possibility this one may be bad. It's just too soon to tell. I will mark it for followup.
sortofageek
One other report which looks like an EUE earning no credit, so far.
There is another report of failure in the WU Database so that makes a total of three strikes so I have reported it as a bad WU:
The WU (P6055,R0,C152,G472) has been reported as a bad WU.
Thanks for your report.
