128.143.199.97/ Reject Status [Some WUs MIA]
shunter
Post by shunter »
The above server is in Reject status and I have had 2 units trying to access this server. Both were eventually accepted by 130.237.165.141 but cannot see this server on server listing and no points credited so far,
Any ideas what the position / problem is; do you need logs attaching.
Thanks
Shunter
Edit GMT1.45pm Another 2 units have failed to upload to 128.143.199.97 and are now hanging after an hour trying to upload to 130.237.165.141. What's going on please
ThunderRd
Re: 128.143.199.97:8080/ Reject Status
Post by ThunderRd »
My log showing same problem as the OP, client 6.34 on Gentoo. At this time the server does not show reject status, it claims to be accepting, but the client neither uploads nor downloads. After waiting about 3 hours, I restarted the client. It appeared to be successful in connecting to .97, but failed to transfer any data after thinking about it for a while. The collection server 130.237.165.141 is also not functioning for me, although it claims to be accepting as well:
[10:13:54] Completed 435000 out of 500000 steps  (87%)
[10:19:19] Completed 440000 out of 500000 steps  (88%)
[10:24:44] Completed 445000 out of 500000 steps  (89%)
[10:30:08] Completed 450000 out of 500000 steps  (90%)
[10:35:32] Completed 455000 out of 500000 steps  (91%)
[10:40:57] Completed 460000 out of 500000 steps  (92%)
[10:46:22] Completed 465000 out of 500000 steps  (93%)
[10:51:47] Completed 470000 out of 500000 steps  (94%)
[10:57:12] Completed 475000 out of 500000 steps  (95%)
[11:02:36] Completed 480000 out of 500000 steps  (96%)
[11:08:01] Completed 485000 out of 500000 steps  (97%)
[11:13:26] Completed 490000 out of 500000 steps  (98%)
[11:18:51] Completed 495000 out of 500000 steps  (99%)
[11:24:16] Completed 500000 out of 500000 steps  (100%)
[11:24:17] DynamicWrapper: Finished Work Unit: sleep=10000
[11:24:27]
[11:24:27] Finished Work Unit:
[11:24:27] - Reading up to 5030784 from "work/wudata_05.trr": Read 5030784
[11:24:27] trr file hash check passed.
[11:24:27] - Reading up to 5372104 from "work/wudata_05.xtc": Read 5372104
[11:24:27] xtc file hash check passed.
[11:24:27] edr file hash check passed.
[11:24:27] logfile size: 323927
[11:24:27] Leaving Run
[11:24:30] - Writing 10759219 bytes of core data to disk...
[11:24:31] Done: 10758707 -> 10186022 (compressed to 94.6 percent)
[11:24:31]   ... Done.
[11:27:28] - Shutting down core
[11:27:28]
[11:27:28] Folding@home Core Shutdown: FINISHED_UNIT
[11:27:44] CoreStatus = 64 (100)
[11:27:44] Unit 5 finished with 93 percent of time to deadline remaining.
[11:27:44] Updated performance fraction: 0.923450
[11:27:44] Sending work to server
[11:27:44] Project: 7504 (Run 4, Clone 76, Gen 20)
[11:27:44] + Attempting to send results [November 16 11:27:44 UTC]
[11:27:44] - Reading file work/wuresults_05.dat from core
[11:27:44]   (Read 10186534 bytes from disk)
[11:27:44] Connecting to http://128.143.199.97:8080/
[11:32:18] - Couldn't send HTTP request to server
[11:32:18] + Could not connect to Work Server (results)
[11:32:18]     (128.143.199.97:8080)
[11:32:18] + Retrying using alternative port
[11:32:18] Connecting to http://128.143.199.97:80/
[11:36:41] - Couldn't send HTTP request to server
[11:36:41] + Could not connect to Work Server (results)
[11:36:41]     (128.143.199.97:80)
[11:36:41] - Error: Could not transmit unit 05 (completed November 16) to work server.
[11:36:41] - 1 failed uploads of this unit.
[11:36:41]   Keeping unit 05 in queue.
[11:36:41] Trying to send all finished work units
[11:36:41] Project: 7504 (Run 4, Clone 76, Gen 20)
[11:36:41] + Attempting to send results [November 16 11:36:41 UTC]
[11:36:41] - Reading file work/wuresults_05.dat from core
[11:36:41]   (Read 10186534 bytes from disk)
[11:36:41] Connecting to http://128.143.199.97:8080/
[11:39:50] - Couldn't send HTTP request to server
[11:39:50] + Could not connect to Work Server (results)
[11:39:50]     (128.143.199.97:8080)
[11:39:50] + Retrying using alternative port
[11:39:50] Connecting to http://128.143.199.97:80/
[11:42:59] - Couldn't send HTTP request to server
[11:42:59] + Could not connect to Work Server (results)
[11:42:59]     (128.143.199.97:80)
[11:42:59] - Error: Could not transmit unit 05 (completed November 16) to work server.
[11:42:59] - 2 failed uploads of this unit.
[11:42:59] + Attempting to send results [November 16 11:42:59 UTC]
[11:42:59] - Reading file work/wuresults_05.dat from core
[11:42:59]   (Read 10186534 bytes from disk)
[11:42:59] Connecting to http://130.237.165.141:8080/
[14:26:01] ***** Got an Activate signal (2)
[14:26:02] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [November 16 14:26:11 UTC]
# Linux SMP Console Edition ###################################################
                       Folding@Home Client Version 6.34
                          http://folding.stanford.edu
Launch directory: /home/thunderrd/FAH6
Executable: ./fah6
Arguments: -smp -verbosity 9 -advmethods
[14:26:11] - Ask before connecting: No
[14:26:11] - User name: ThunderRd (Team 45)
[14:26:11] - User ID: 10A4394F32057960
[14:26:11] - Machine ID: 1
[14:26:11]
[14:26:12] Loaded queue successfully.
[14:26:12] - Preparing to get new work unit...
[14:26:12] - Autosending finished units... [14:26:12]
[14:26:12] Cleaning up work directory
[14:26:12] Trying to send all finished work units
[14:26:12] Project: 7504 (Run 4, Clone 76, Gen 20)
[14:26:12] + Attempting to send results [November 16 14:26:12 UTC]
[14:26:12] - Reading file work/wuresults_05.dat from core
[14:26:12]   (Read 10186534 bytes from disk)
[14:26:12] Connecting to http://128.143.199.97:8080/
[14:27:30] + Attempting to get work packet
[14:27:30] Passkey found
[14:27:30] - Will indicate memory of 3964 MB
[14:27:30] - Connecting to assignment server
[14:27:30] Connecting to http://assign.stanford.edu:8080/
[14:27:31] Posted data.
[14:27:31] Initial: 8F80; - Successful: assigned to (128.143.199.97).
[14:27:31] + News From Folding@Home: Welcome to Folding@Home
[14:27:32] Loaded queue successfully.
[14:27:32] Sent data
[14:27:32] Connecting to http://128.143.199.97:8080/
[14:29:21] - Couldn't send HTTP request to server
[14:29:21] + Could not connect to Work Server (results)
[14:29:21]     (128.143.199.97:8080)
[14:29:21] + Retrying using alternative port
[14:29:21] Connecting to http://128.143.199.97:80/
[14:30:41] - Couldn't send HTTP request to server
[14:30:41] + Could not connect to Work Server
[14:30:41] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[14:30:47] + Attempting to get work packet
[14:30:47] Passkey found
[14:30:47] - Will indicate memory of 3964 MB
[14:30:47] - Connecting to assignment server
[14:30:47] Connecting to http://assign.stanford.edu:8080/
[14:30:48] Posted data.
[14:30:48] Initial: 8F80; - Successful: assigned to (128.143.199.97).
[14:30:48] + News From Folding@Home: Welcome to Folding@Home
[14:30:48] Loaded queue successfully.
[14:30:48] Sent data
[14:30:48] Connecting to http://128.143.199.97:8080/
[14:33:55] - Couldn't send HTTP request to server
[14:33:55] + Could not connect to Work Server (results)
[14:33:55]     (128.143.199.97:80)
[14:33:55] - Error: Could not transmit unit 05 (completed November 16) to work server.
[14:33:55] - 2 failed uploads of this unit.
[14:33:55] + Attempting to send results [November 16 14:33:55 UTC]
[14:33:55] - Reading file work/wuresults_05.dat from core
[14:33:55]   (Read 10186534 bytes from disk)
[14:33:55] Connecting to http://130.237.165.141:8080/
[14:36:35] - Couldn't send HTTP request to server
[14:36:35] + Could not connect to Work Server
[14:36:35] - Attempt #2  to get work failed, and no other work to do.
[14:36:52] + Attempting to get work packet
[14:36:52] Passkey found
[14:36:52] - Will indicate memory of 3964 MB
[14:36:52] - Connecting to assignment server
[14:36:52] Connecting to http://assign.stanford.edu:8080/
[14:36:52] Posted data.
[14:36:52] Initial: 8F80; - Successful: assigned to (128.143.199.97).
[14:36:52] + News From Folding@Home: Welcome to Folding@Home
[14:36:53] Loaded queue successfully.
[14:36:53] Sent data
[14:36:53] Connecting to http://128.143.199.97:8080/
[14:38:04] - Couldn't send HTTP request to server
[14:38:04] + Could not connect to Work Server (results)
[14:38:04]     (130.237.165.141:8080)
[14:38:04] + Retrying using alternative port
[14:38:04] Connecting to http://130.237.165.141:80/
sco01
Hardware configuration: Core i7 3930K(C2)@4,2 (1.30v)
Swiftech Apogee Drive II + MCR-H220 Radiator
Asus P9X79
4*4Gb SEC 1600@1866 1.5v
GeForce GTX780ti ref (nztx G10+zalman lq315)
Creative X-Fi Titanium Fatal1ty
Lite-On iHAS124-34
HDD- WD3000GLFS + 2*Hitaсhi HDS723030BLE640 + 2*HDT721010SLA360
case-Corsair Obsidian 700D
PSU - Seasonic Platinum 860W (SS-860XP2)
2) Xeon E5645@4Ghz (1,34v)
ASUS P6T
Thermalright Silver Arrow
Corsair TR3X6G1600C7 (3x2048Mb, 7-7-7-20 1,62v)
GeForce GTX780 ref (nztx G10+corsair H75)
Zotac GTX980 AMP! Edition (ZT-90204-10P)
Hitachi 320Gb HTS543232A7A384
case - Chieftec LBX-03B Dremel edition :-)
PSU - Zalman ZM-850HP+ (Enhance silver)
APC SUA1500RMI2U
APC SUA1500RMI2U
Post by sco01 »
[11:48:30] Completed 500000 out of 500000 steps  (100%)
[11:48:32] DynamicWrapper: Finished Work Unit: sleep=10000
[11:48:42]
[11:48:42] Finished Work Unit:
[11:48:42] - Reading up to 6296832 from "work/wudata_09.trr": Read 6296832
[11:48:42] trr file hash check passed.
[11:48:42] - Reading up to 6757016 from "work/wudata_09.xtc": Read 6757016
[11:48:42] xtc file hash check passed.
[11:48:42] edr file hash check passed.
[11:48:42] logfile size: 324009
[11:48:42] Leaving Run
[11:48:44] - Writing 13410261 bytes of core data to disk...
[11:48:46] Done: 13409749 -> 12785543 (compressed to 95.3 percent)
[11:48:46]   ... Done.
[11:48:47] - Shutting down core
[11:48:47]
[11:48:47] Folding@home Core Shutdown: FINISHED_UNIT
[11:48:51] CoreStatus = 64 (100)
[11:48:51] Unit 9 finished with 94 percent of time to deadline remaining.
[11:48:51] Updated performance fraction: 0.894832
[11:48:51] Sending work to server
[11:48:51] Project: 7511 (Run 0, Clone 90, Gen 35)
[11:48:51] + Attempting to send results [November 16 11:48:51 UTC]
[11:48:51] - Reading file work/wuresults_09.dat from core
[11:48:51]   (Read 12786055 bytes from disk)
[11:48:51] Connecting to http://128.143.199.97:8080/
[11:49:21] - Couldn't send HTTP request to server
[11:49:21] + Could not connect to Work Server (results)
[11:49:21]     (128.143.199.97:8080)
[11:49:21] + Retrying using alternative port
[11:49:21] Connecting to http://128.143.199.97:80/
[11:49:48] - Couldn't send HTTP request to server
[11:49:48] + Could not connect to Work Server (results)
[11:49:48]     (128.143.199.97:80)
[11:49:48] - Error: Could not transmit unit 09 (completed November 16) to work server.
[11:49:48] - 1 failed uploads of this unit.
[11:49:48]   Keeping unit 09 in queue.
[11:49:48] Trying to send all finished work units
[11:49:48] Project: 7511 (Run 0, Clone 90, Gen 35)
[11:49:48] + Attempting to send results [November 16 11:49:48 UTC]
[11:49:48] - Reading file work/wuresults_09.dat from core
[11:49:48]   (Read 12786055 bytes from disk)
[11:49:48] Connecting to http://128.143.199.97:8080/
[11:52:30] - Couldn't send HTTP request to server
[11:52:30] + Could not connect to Work Server (results)
[11:52:30]     (128.143.199.97:8080)
[11:52:30] + Retrying using alternative port
[11:52:30] Connecting to http://128.143.199.97:80/
[11:55:12] - Couldn't send HTTP request to server
[11:55:12] + Could not connect to Work Server (results)
[11:55:12]     (128.143.199.97:80)
[11:55:12] - Error: Could not transmit unit 09 (completed November 16) to work server.
[11:55:12] - 2 failed uploads of this unit.
[11:55:12] + Attempting to send results [November 16 11:55:12 UTC]
[11:55:12] - Reading file work/wuresults_09.dat from core
[11:55:12]   (Read 12786055 bytes from disk)
[11:55:12] Connecting to http://130.237.165.141:8080/
[15:40:10] - Autosending finished units... [November 16 15:40:10 UTC]
[15:40:10] Trying to send all finished work units
[15:40:10] - Already sending work
[15:40:10] + Sent 0 of 1 completed units to the server
[15:40:10] - Autosend completed
[15:55:15] Killing all core threads
[15:55:15] Could not get process id information.  Please kill core process manually
hinebaud
Post by hinebaud »
Same Problem
[14:34:23] Completed 495000 out of 500000 steps  (99%)
[14:40:02] Completed 500000 out of 500000 steps  (100%)
[14:40:02] DynamicWrapper: Finished Work Unit: sleep=10000
[14:40:12]
[14:40:12] Finished Work Unit:
[14:40:12] - Reading up to 6108408 from "work/wudata_01.trr": Read 6108408
[14:40:12] trr file hash check passed.
[14:40:12] - Reading up to 6551240 from "work/wudata_01.xtc": Read 6551240
[14:40:12] xtc file hash check passed.
[14:40:12] edr file hash check passed.
[14:40:12] logfile size: 350092
[14:40:12] Leaving Run
[14:40:15] - Writing 13042780 bytes of core data to disk...
[14:40:17] Done: 13042268 -> 12388994 (compressed to 94.9 percent)
[14:40:17]   ... Done.
[14:40:20] - Shutting down core
[14:40:20]
[14:40:20] Folding@home Core Shutdown: FINISHED_UNIT
[14:40:24] CoreStatus = 64 (100)
[14:40:24] Sending work to server
[14:40:24] Project: 7508 (Run 0, Clone 153, Gen 21)
[14:40:24] + Attempting to send results [November 16 14:40:24 UTC]
[14:40:45] - Couldn't send HTTP request to server
[14:40:45] + Could not connect to Work Server (results)
[14:40:45]     (128.143.199.97:8080)
[14:40:45] + Retrying using alternative port
[14:41:06] - Couldn't send HTTP request to server
[14:41:06] + Could not connect to Work Server (results)
[14:41:06]     (128.143.199.97:80)
[14:41:06] - Error: Could not transmit unit 01 (completed November 16) to work server.
[14:41:06]   Keeping unit 01 in queue.
[14:41:06] Project: 7508 (Run 0, Clone 153, Gen 21)
[14:41:06] + Attempting to send results [November 16 14:41:06 UTC]
[14:41:27] - Couldn't send HTTP request to server
[14:41:27] + Could not connect to Work Server (results)
[14:41:27]     (128.143.199.97:8080)
[14:41:27] + Retrying using alternative port
[14:41:48] - Couldn't send HTTP request to server
[14:41:48] + Could not connect to Work Server (results)
[14:41:48]     (128.143.199.97:80)
[14:41:48] - Error: Could not transmit unit 01 (completed November 16) to work server.
[14:41:48] + Attempting to send results [November 16 14:41:48 UTC]
[14:44:48] - Couldn't send HTTP request to server
[14:44:48] + Could not connect to Work Server (results)
[14:44:48]     (130.237.165.141:8080)
[14:44:48] + Retrying using alternative port
[14:45:17] - Couldn't send HTTP request to server
[14:45:17] + Could not connect to Work Server (results)
[14:45:17]     (130.237.165.141:80)
[14:45:17]   Could not transmit unit 01 to Collection server; keeping in queue.
[14:45:47] Project: 7508 (Run 0, Clone 153, Gen 21)
[14:45:47] + Attempting to send results [November 16 14:45:47 UTC]
[14:46:08] - Couldn't send HTTP request to server
[14:46:08] + Could not connect to Work Server (results)
[14:46:08]     (128.143.199.97:8080)
[14:46:08] + Retrying using alternative port
[14:46:29] - Couldn't send HTTP request to server
[14:46:29] + Could not connect to Work Server (results)
[14:46:29]     (128.143.199.97:80)
[14:46:29] - Error: Could not transmit unit 01 (completed November 16) to work server.
[14:46:29] + Attempting to send results [November 16 14:46:29 UTC]
[14:47:01] - Couldn't send HTTP request to server
[14:47:01] + Could not connect to Work Server (results)
[14:47:01]     (130.237.165.141:8080)
[14:47:01] + Retrying using alternative port
[14:47:29] - Couldn't send HTTP request to server
[14:47:29] + Could not connect to Work Server (results)
[14:47:29]     (130.237.165.141:80)
[14:47:29]   Could not transmit unit 01 to Collection server; keeping in queue.
[14:47:59] Project: 7508 (Run 0, Clone 153, Gen 21)
[14:47:59] + Attempting to send results [November 16 14:47:59 UTC]
[14:48:20] - Couldn't send HTTP request to server
[14:48:20] + Could not connect to Work Server (results)
[14:48:20]     (128.143.199.97:8080)
[14:48:20] + Retrying using alternative port
[14:48:41] - Couldn't send HTTP request to server
[14:48:41] + Could not connect to Work Server (results)
[14:48:41]     (128.143.199.97:80)
[14:48:41] - Error: Could not transmit unit 01 (completed November 16) to work server.
[14:48:41] + Attempting to send results [November 16 14:48:41 UTC]
[14:49:16] - Couldn't send HTTP request to server
[14:49:16] + Could not connect to Work Server (results)
[14:49:16]     (130.237.165.141:8080)
[14:49:16] + Retrying using alternative port
[14:49:37] - Couldn't send HTTP request to server
[14:49:37] + Could not connect to Work Server (results)
[14:49:37]     (130.237.165.141:80)
[14:49:37]   Could not transmit unit 01 to Collection server; keeping in queue.
[14:50:07] Project: 7508 (Run 0, Clone 153, Gen 21)
[14:50:07] + Attempting to send results [November 16 14:50:07 UTC]
[14:50:28] - Couldn't send HTTP request to server
[14:50:28] + Could not connect to Work Server (results)
[14:50:28]     (128.143.199.97:8080)
[14:50:28] + Retrying using alternative port
[14:50:49] - Couldn't send HTTP request to server
[14:50:49] + Could not connect to Work Server (results)
[14:50:49]     (128.143.199.97:80)
[14:50:49] - Error: Could not transmit unit 01 (completed November 16) to work server.
[14:50:49] + Attempting to send results [November 16 14:50:49 UTC]
[14:51:19] - Couldn't send HTTP request to server
[14:51:19] + Could not connect to Work Server (results)
[14:51:19]     (130.237.165.141:8080)
[14:51:19] + Retrying using alternative port
[14:53:55] - Couldn't send HTTP request to server
[14:53:55] + Could not connect to Work Server (results)
[14:53:55]     (130.237.165.141:80)
[14:53:55]   Could not transmit unit 01 to Collection server; keeping in queue.
[14:54:25] Project: 7508 (Run 0, Clone 153, Gen 21)
[14:54:25] + Attempting to send results [November 16 14:54:25 UTC]
[14:57:25] - Couldn't send HTTP request to server
[14:57:25] + Could not connect to Work Server (results)
[14:57:25]     (128.143.199.97:8080)
[14:57:25] + Retrying using alternative port
[15:00:07] - Couldn't send HTTP request to server
[15:00:07] + Could not connect to Work Server (results)
[15:00:07]     (128.143.199.97:80)
[15:00:07] - Error: Could not transmit unit 01 (completed November 16) to work server.
[15:00:07] + Attempting to send results [November 16 15:00:07 UTC]
[15:00:37] - Couldn't send HTTP request to server
[15:00:37] + Could not connect to Work Server (results)
[15:00:37]     (130.237.165.141:8080)
[15:00:37] + Retrying using alternative port
[15:00:58] - Couldn't send HTTP request to server
[15:00:58] + Could not connect to Work Server (results)
[15:00:58]     (130.237.165.141:80)
[15:00:58]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:01:28] Project: 7508 (Run 0, Clone 153, Gen 21)
[15:01:28] + Attempting to send results [November 16 15:01:28 UTC]
[15:01:49] - Couldn't send HTTP request to server
[15:01:49] + Could not connect to Work Server (results)
[15:01:49]     (128.143.199.97:8080)
[15:01:49] + Retrying using alternative port
[15:02:10] - Couldn't send HTTP request to server
[15:02:10] + Could not connect to Work Server (results)
[15:02:10]     (128.143.199.97:80)
[15:02:10] - Error: Could not transmit unit 01 (completed November 16) to work server.
[15:02:10] + Attempting to send results [November 16 15:02:10 UTC]
[15:02:31] - Couldn't send HTTP request to server
[15:02:31] + Could not connect to Work Server (results)
[15:02:31]     (130.237.165.141:8080)
[15:02:31] + Retrying using alternative port
[15:02:52] - Couldn't send HTTP request to server
[15:02:52] + Could not connect to Work Server (results)
[15:02:52]     (130.237.165.141:80)
[15:02:52]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:03:22] Project: 7508 (Run 0, Clone 153, Gen 21)
[15:03:22] + Attempting to send results [November 16 15:03:22 UTC]
[15:03:43] - Couldn't send HTTP request to server
[15:03:43] + Could not connect to Work Server (results)
[15:03:43]     (128.143.199.97:8080)
[15:03:43] + Retrying using alternative port
[15:06:43] - Couldn't send HTTP request to server
[15:06:43] + Could not connect to Work Server (results)
[15:06:43]     (128.143.199.97:80)
[15:06:43] - Error: Could not transmit unit 01 (completed November 16) to work server.
[15:06:43] + Attempting to send results [November 16 15:06:43 UTC]
[15:09:43] - Couldn't send HTTP request to server
[15:09:43] + Could not connect to Work Server (results)
[15:09:43]     (130.237.165.141:8080)
[15:09:43] + Retrying using alternative port
[15:12:19] - Couldn't send HTTP request to server
[15:12:19] + Could not connect to Work Server (results)
[15:12:19]     (130.237.165.141:80)
[15:12:19]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:12:49] Project: 7508 (Run 0, Clone 153, Gen 21)
[15:12:49] + Attempting to send results [November 16 15:12:49 UTC]
[15:13:10] - Couldn't send HTTP request to server
[15:13:10] + Could not connect to Work Server (results)
[15:13:10]     (128.143.199.97:8080)
[15:13:10] + Retrying using alternative port
[15:13:31] - Couldn't send HTTP request to server
[15:13:31] + Could not connect to Work Server (results)
[15:13:31]     (128.143.199.97:80)
[15:13:31] - Error: Could not transmit unit 01 (completed November 16) to work server.
[15:13:31] + Attempting to send results [November 16 15:13:31 UTC]
[15:13:52] - Couldn't send HTTP request to server
[15:13:52] + Could not connect to Work Server (results)
[15:13:52]     (130.237.165.141:8080)
[15:13:52] + Retrying using alternative port
[15:14:22] - Couldn't send HTTP request to server
[15:14:22] + Could not connect to Work Server (results)
[15:14:22]     (130.237.165.141:80)
[15:14:22]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:14:52] Project: 7508 (Run 0, Clone 153, Gen 21)
[15:14:52] + Attempting to send results [November 16 15:14:52 UTC]
[15:17:58] - Couldn't send HTTP request to server
[15:17:58] + Could not connect to Work Server (results)
[15:17:58]     (128.143.199.97:8080)
[15:17:58] + Retrying using alternative port
[15:18:19] - Couldn't send HTTP request to server
[15:18:19] + Could not connect to Work Server (results)
[15:18:19]     (128.143.199.97:80)
[15:18:19] - Error: Could not transmit unit 01 (completed November 16) to work server.
[15:18:19] + Attempting to send results [November 16 15:18:19 UTC]
[15:21:19] - Couldn't send HTTP request to server
[15:21:19] + Could not connect to Work Server (results)
[15:21:19]     (130.237.165.141:8080)
[15:21:19] + Retrying using alternative port
[15:23:56] - Couldn't send HTTP request to server
[15:23:56] + Could not connect to Work Server (results)
[15:23:56]     (130.237.165.141:80)
[15:23:56]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:24:26] Project: 7508 (Run 0, Clone 153, Gen 21)
[15:24:26] + Attempting to send results [November 16 15:24:26 UTC]
[15:24:47] - Couldn't send HTTP request to server
[15:24:47] + Could not connect to Work Server (results)
[15:24:47]     (128.143.199.97:8080)
[15:24:47] + Retrying using alternative port
[15:25:08] - Couldn't send HTTP request to server
[15:25:08] + Could not connect to Work Server (results)
[15:25:08]     (128.143.199.97:80)
[15:25:08] - Error: Could not transmit unit 01 (completed November 16) to work server.
[15:25:08] + Attempting to send results [November 16 15:25:08 UTC]
[15:25:29] - Couldn't send HTTP request to server
[15:25:29] + Could not connect to Work Server (results)
[15:25:29]     (130.237.165.141:8080)
[15:25:29] + Retrying using alternative port
[15:28:29] - Couldn't send HTTP request to server
[15:28:29] + Could not connect to Work Server (results)
[15:28:29]     (130.237.165.141:80)
[15:28:29]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:28:59] Project: 7508 (Run 0, Clone 153, Gen 21)
[15:28:59] + Attempting to send results [November 16 15:28:59 UTC]
[15:29:20] - Couldn't send HTTP request to server
[15:29:20] + Could not connect to Work Server (results)
[15:29:20]     (128.143.199.97:8080)
[15:29:20] + Retrying using alternative port
[15:29:41] - Couldn't send HTTP request to server
[15:29:41] + Could not connect to Work Server (results)
[15:29:41]     (128.143.199.97:80)
[15:29:41] - Error: Could not transmit unit 01 (completed November 16) to work server.
[15:29:41] + Attempting to send results [November 16 15:29:41 UTC]
[15:32:47] - Couldn't send HTTP request to server
[15:32:47] + Could not connect to Work Server (results)
[15:32:47]     (130.237.165.141:8080)
[15:32:47] + Retrying using alternative port
[15:35:29] - Couldn't send HTTP request to server
[15:35:29] + Could not connect to Work Server (results)
[15:35:29]     (130.237.165.141:80)
[15:35:29]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:35:59] Project: 7508 (Run 0, Clone 153, Gen 21)
[15:35:59] + Attempting to send results [November 16 15:35:59 UTC]
[15:38:59] - Couldn't send HTTP request to server
[15:38:59] + Could not connect to Work Server (results)
[15:38:59]     (128.143.199.97:8080)
[15:38:59] + Retrying using alternative port
[15:41:35] - Couldn't send HTTP request to server
[15:41:35] + Could not connect to Work Server (results)
[15:41:35]     (128.143.199.97:80)
[15:41:35] - Error: Could not transmit unit 01 (completed November 16) to work server.
[15:41:35] + Attempting to send results [November 16 15:41:35 UTC]
[15:41:56] - Couldn't send HTTP request to server
[15:41:56] + Could not connect to Work Server (results)
[15:41:56]     (130.237.165.141:8080)
[15:41:56] + Retrying using alternative port
[15:42:17] - Couldn't send HTTP request to server
[15:42:17] + Could not connect to Work Server (results)
[15:42:17]     (130.237.165.141:80)
[15:42:17]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:42:47] Project: 7508 (Run 0, Clone 153, Gen 21)
[15:42:47] + Attempting to send results [November 16 15:42:47 UTC]
[15:43:08] - Couldn't send HTTP request to server
[15:43:08] + Could not connect to Work Server (results)
[15:43:08]     (128.143.199.97:8080)
[15:43:08] + Retrying using alternative port
[15:43:29] - Couldn't send HTTP request to server
[15:43:29] + Could not connect to Work Server (results)
[15:43:29]     (128.143.199.97:80)
[15:43:29] - Error: Could not transmit unit 01 (completed November 16) to work server.
[15:43:29] + Attempting to send results [November 16 15:43:29 UTC]
[15:46:29] - Couldn't send HTTP request to server
[15:46:29] + Could not connect to Work Server (results)
[15:46:29]     (130.237.165.141:8080)
[15:46:29] + Retrying using alternative port
[15:46:50] - Couldn't send HTTP request to server
[15:46:50] + Could not connect to Work Server (results)
[15:46:50]     (130.237.165.141:80)
[15:46:50]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:47:20] Project: 7508 (Run 0, Clone 153, Gen 21)
[15:47:20] + Attempting to send results [November 16 15:47:20 UTC]
[15:50:20] - Couldn't send HTTP request to server
[15:50:20] + Could not connect to Work Server (results)
[15:50:20]     (128.143.199.97:8080)
[15:50:20] + Retrying using alternative port
[15:52:57] - Couldn't send HTTP request to server
[15:52:57] + Could not connect to Work Server (results)
[15:52:57]     (128.143.199.97:80)
[15:52:57] - Error: Could not transmit unit 01 (completed November 16) to work server.
[15:52:57] + Attempting to send results [November 16 15:52:57 UTC]
[15:53:18] - Couldn't send HTTP request to server
[15:53:18] + Could not connect to Work Server (results)
[15:53:18]     (130.237.165.141:8080)
[15:53:18] + Retrying using alternative port
[15:53:39] - Couldn't send HTTP request to server
[15:53:39] + Could not connect to Work Server (results)
[15:53:39]     (130.237.165.141:80)
[15:53:39]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:54:09] Project: 7508 (Run 0, Clone 153, Gen 21)
[15:54:09] + Attempting to send results [November 16 15:54:09 UTC]
[15:54:30] - Couldn't send HTTP request to server
[15:54:30] + Could not connect to Work Server (results)
[15:54:30]     (128.143.199.97:8080)
[15:54:30] + Retrying using alternative port
[15:54:51] - Couldn't send HTTP request to server
[15:54:51] + Could not connect to Work Server (results)
[15:54:51]     (128.143.199.97:80)
[15:54:51] - Error: Could not transmit unit 01 (completed November 16) to work server.
[15:54:51] + Attempting to send results [November 16 15:54:51 UTC]
[15:55:12] - Couldn't send HTTP request to server
[15:55:12] + Could not connect to Work Server (results)
[15:55:12]     (130.237.165.141:8080)
[15:55:12] + Retrying using alternative port
[15:58:18] - Couldn't send HTTP request to server
[15:58:18] + Could not connect to Work Server (results)
[15:58:18]     (130.237.165.141:80)
[15:58:18]   Could not transmit unit 01 to Collection server; keeping in queue.
[15:58:48] Project: 7508 (Run 0, Clone 153, Gen 21)
[15:58:48] + Attempting to send results [November 16 15:58:48 UTC]
[15:59:09] - Couldn't send HTTP request to server
[15:59:09] + Could not connect to Work Server (results)
[15:59:09]     (128.143.199.97:8080)
[15:59:09] + Retrying using alternative port
[16:02:09] - Couldn't send HTTP request to server
[16:02:09] + Could not connect to Work Server (results)
[16:02:09]     (128.143.199.97:80)
[16:02:09] - Error: Could not transmit unit 01 (completed November 16) to work server.
[16:02:09] + Attempting to send results [November 16 16:02:09 UTC]
[16:02:30] - Couldn't send HTTP request to server
[16:02:30] + Could not connect to Work Server (results)
[16:02:30]     (130.237.165.141:8080)
[16:02:30] + Retrying using alternative port
[16:02:51] - Couldn't send HTTP request to server
[16:02:51] + Could not connect to Work Server (results)
[16:02:51]     (130.237.165.141:80)
[16:02:51]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:03:21] Project: 7508 (Run 0, Clone 153, Gen 21)
[16:03:21] + Attempting to send results [November 16 16:03:21 UTC]
[16:03:42] - Couldn't send HTTP request to server
[16:03:42] + Could not connect to Work Server (results)
[16:03:42]     (128.143.199.97:8080)
[16:03:42] + Retrying using alternative port
[16:04:03] - Couldn't send HTTP request to server
[16:04:03] + Could not connect to Work Server (results)
[16:04:03]     (128.143.199.97:80)
[16:04:03] - Error: Could not transmit unit 01 (completed November 16) to work server.
[16:04:03] + Attempting to send results [November 16 16:04:03 UTC]
[16:04:24] - Couldn't send HTTP request to server
[16:04:24] + Could not connect to Work Server (results)
[16:04:24]     (130.237.165.141:8080)
[16:04:24] + Retrying using alternative port
[16:04:45] - Couldn't send HTTP request to server
[16:04:45] + Could not connect to Work Server (results)
[16:04:45]     (130.237.165.141:80)
[16:04:45]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:05:15] Project: 7508 (Run 0, Clone 153, Gen 21)
[16:05:15] + Attempting to send results [November 16 16:05:15 UTC]
[16:05:36] - Couldn't send HTTP request to server
[16:05:36] + Could not connect to Work Server (results)
[16:05:36]     (128.143.199.97:8080)
[16:05:36] + Retrying using alternative port
[16:05:57] - Couldn't send HTTP request to server
[16:05:57] + Could not connect to Work Server (results)
[16:05:57]     (128.143.199.97:80)
[16:05:57] - Error: Could not transmit unit 01 (completed November 16) to work server.
[16:05:57] + Attempting to send results [November 16 16:05:57 UTC]
[16:08:57] - Couldn't send HTTP request to server
[16:08:57] + Could not connect to Work Server (results)
[16:08:57]     (130.237.165.141:8080)
[16:08:57] + Retrying using alternative port
[16:09:18] - Couldn't send HTTP request to server
[16:09:18] + Could not connect to Work Server (results)
[16:09:18]     (130.237.165.141:80)
[16:09:18]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:09:48] Project: 7508 (Run 0, Clone 153, Gen 21)
[16:09:48] + Attempting to send results [November 16 16:09:48 UTC]
[16:10:09] - Couldn't send HTTP request to server
[16:10:09] + Could not connect to Work Server (results)
[16:10:09]     (128.143.199.97:8080)
[16:10:09] + Retrying using alternative port
[16:10:30] - Couldn't send HTTP request to server
[16:10:30] + Could not connect to Work Server (results)
[16:10:30]     (128.143.199.97:80)
[16:10:30] - Error: Could not transmit unit 01 (completed November 16) to work server.
[16:10:30] + Attempting to send results [November 16 16:10:30 UTC]
[16:13:30] - Couldn't send HTTP request to server
[16:13:30] + Could not connect to Work Server (results)
[16:13:30]     (130.237.165.141:8080)
[16:13:30] + Retrying using alternative port
[16:16:13] - Couldn't send HTTP request to server
[16:16:13] + Could not connect to Work Server (results)
[16:16:13]     (130.237.165.141:80)
[16:16:13]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:16:43] Project: 7508 (Run 0, Clone 153, Gen 21)
[16:16:43] + Attempting to send results [November 16 16:16:43 UTC]
[16:19:43] - Couldn't send HTTP request to server
[16:19:43] + Could not connect to Work Server (results)
[16:19:43]     (128.143.199.97:8080)
[16:19:43] + Retrying using alternative port
[16:20:04] - Couldn't send HTTP request to server
[16:20:04] + Could not connect to Work Server (results)
[16:20:04]     (128.143.199.97:80)
[16:20:04] - Error: Could not transmit unit 01 (completed November 16) to work server.
[16:20:04] + Attempting to send results [November 16 16:20:04 UTC]
[16:20:34] - Couldn't send HTTP request to server
[16:20:34] + Could not connect to Work Server (results)
[16:20:34]     (130.237.165.141:8080)
[16:20:34] + Retrying using alternative port
[16:20:55] - Couldn't send HTTP request to server
[16:20:55] + Could not connect to Work Server (results)
[16:20:55]     (130.237.165.141:80)
[16:20:55]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:21:25] Project: 7508 (Run 0, Clone 153, Gen 21)
[16:21:25] + Attempting to send results [November 16 16:21:25 UTC]
[16:21:46] - Couldn't send HTTP request to server
[16:21:46] + Could not connect to Work Server (results)
[16:21:46]     (128.143.199.97:8080)
[16:21:46] + Retrying using alternative port
[16:22:07] - Couldn't send HTTP request to server
[16:22:07] + Could not connect to Work Server (results)
[16:22:07]     (128.143.199.97:80)
[16:22:07] - Error: Could not transmit unit 01 (completed November 16) to work server.
[16:22:07] + Attempting to send results [November 16 16:22:07 UTC]
[16:22:39] - Couldn't send HTTP request to server
[16:22:39] + Could not connect to Work Server (results)
[16:22:39]     (130.237.165.141:8080)
[16:22:39] + Retrying using alternative port
[16:25:21] - Couldn't send HTTP request to server
[16:25:21] + Could not connect to Work Server (results)
[16:25:21]     (130.237.165.141:80)
[16:25:21]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:25:51] Project: 7508 (Run 0, Clone 153, Gen 21)
[16:25:51] + Attempting to send results [November 16 16:25:51 UTC]
[16:26:12] - Couldn't send HTTP request to server
[16:26:12] + Could not connect to Work Server (results)
[16:26:12]     (128.143.199.97:8080)
[16:26:12] + Retrying using alternative port
[16:29:12] - Couldn't send HTTP request to server
[16:29:12] + Could not connect to Work Server (results)
[16:29:12]     (128.143.199.97:80)
[16:29:12] - Error: Could not transmit unit 01 (completed November 16) to work server.
[16:29:12] + Attempting to send results [November 16 16:29:12 UTC]
Folding@Home Client Shutdown at user request.
--- Opening Log file [November 16 16:29:36 UTC]
Launch directory: D:\Users\David\Folding\FAH_GPU_Tracker_V2\FAH GPU Tracker V2\SMP
Executable: D:\Users\David\Folding\FAH_GPU_Tracker_V2\FAH GPU Tracker V2\FAH.exe
Arguments: -oneunit -forceasm -smp 6 -advmethods
[16:29:36] - Ask before connecting: No
[16:29:36] - User name: hinebaud (Team 111065)
[16:29:36] - User ID: 2EC0D0B06EF30825
[16:29:36] - Machine ID: 2
[16:29:36]
[16:29:36] Loaded queue successfully.
[16:29:36] - Preparing to get new work unit...
[16:29:36] Project: 7508 (Run 0, Clone 153, Gen 21)
[16:29:36] Cleaning up work directory
[16:29:36] + Attempting to get work packet
[16:29:36] + Attempting to send results [November 16 16:29:36 UTC]
[16:29:36] Passkey found
[16:29:36] - Connecting to assignment server
[16:29:37] - Successful: assigned to (128.143.199.97).
[16:29:37] + News From Folding@Home: Welcome to Folding@Home
[16:29:37] Loaded queue successfully.
[16:29:57] - Couldn't send HTTP request to server
[16:29:57] + Could not connect to Work Server (results)
[16:29:57]     (128.143.199.97:8080)
[16:29:57] + Retrying using alternative port
[16:30:18] - Couldn't send HTTP request to server
[16:30:18] + Could not connect to Work Server (results)
[16:30:18]     (128.143.199.97:80)
[16:30:18] - Error: Could not transmit unit 01 (completed November 16) to work server.
[16:30:18] + Attempting to send results [November 16 16:30:18 UTC]
[16:30:39] - Couldn't send HTTP request to server
[16:30:39] + Could not connect to Work Server (results)
[16:30:39]     (130.237.165.141:8080)
[16:30:39] + Retrying using alternative port
[16:31:12] - Couldn't send HTTP request to server
[16:31:12] + Could not connect to Work Server (results)
[16:31:12]     (130.237.165.141:80)
[16:31:12]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:32:43] + Could not connect to Work Server
[16:32:43] - Attempt #1  to get work failed, and no other work to do.
[16:32:55] + Attempting to get work packet
[16:32:55] Passkey found
[16:32:55] - Connecting to assignment server
[16:32:56] - Successful: assigned to (128.143.199.97).
[16:32:56] + News From Folding@Home: Welcome to Folding@Home
[16:32:56] Loaded queue successfully.
[16:33:17] - Couldn't send HTTP request to server
[16:33:17] + Could not connect to Work Server
[16:33:17] - Attempt #2  to get work failed, and no other work to do.
[16:33:31] + Attempting to get work packet
[16:33:31] Passkey found
[16:33:31] - Connecting to assignment server
[16:33:32] - Successful: assigned to (128.143.199.97).
[16:33:32] + News From Folding@Home: Welcome to Folding@Home
[16:33:32] Loaded queue successfully.
[16:33:53] - Couldn't send HTTP request to server
[16:33:53] + Could not connect to Work Server
[16:33:53] - Attempt #3  to get work failed, and no other work to do.
[16:34:15] + Attempting to get work packet
[16:34:15] Passkey found
[16:34:15] - Connecting to assignment server
[16:34:16] - Successful: assigned to (128.143.199.97).
[16:34:16] + News From Folding@Home: Welcome to Folding@Home
[16:34:16] Loaded queue successfully.
[16:34:37] - Couldn't send HTTP request to server
[16:34:37] + Could not connect to Work Server
[16:34:37] - Attempt #4  to get work failed, and no other work to do.
[16:35:19] + Attempting to get work packet
[16:35:19] Passkey found
[16:35:19] - Connecting to assignment server
[16:35:19] - Successful: assigned to (128.143.199.97).
[16:35:19] + News From Folding@Home: Welcome to Folding@Home
[16:35:19] Loaded queue successfully.
[16:38:25] + Could not connect to Work Server
[16:38:25] - Attempt #5  to get work failed, and no other work to do.
[16:39:51] + Attempting to get work packet
[16:39:51] Passkey found
[16:39:51] - Connecting to assignment server
[16:39:52] - Successful: assigned to (128.143.199.96).
[16:39:52] + News From Folding@Home: Welcome to Folding@Home
[16:39:52] Loaded queue successfully.
[16:39:53] + Closed connections
[16:39:53]
[16:39:53] + Processing work unit
[16:39:53] Core required: FahCore_a3.exe
[16:39:53] Core found.
[16:39:53] Working on queue slot 02 [November 16 16:39:53 UTC]
[16:39:53] + Working ...
[16:39:54]
[16:39:54] *------------------------------*
[16:39:54] Folding@Home Gromacs SMP Core
[16:39:54] Version 2.27 (Dec. 15, 2010)
[16:39:54]
[16:39:54] Preparing to commence simulation
[16:39:54] - Assembly optimizations manually forced on.
[16:39:54] - Not checking prior termination.
[16:39:54] - Expanded 1774464 -> 1972036 (decompressed 111.1 percent)
[16:39:54] Called DecompressByteArray: compressed_data_size=1774464 data_size=1972036, decompressed_data_size=1972036 diff=0
[16:39:54] - Digital signature verified
[16:39:54]
[16:39:54] Project: 7148 (Run 0, Clone 61, Gen 269)
[16:39:54]
[16:39:54] Assembly optimizations on if available.
[16:39:54] Entering M.D.
[16:40:00] Mapping NT from 6 to 6
[16:40:00] Completed 0 out of 500000 steps  (0%)
ikerekes
Hardware configuration: q6600 @ 3.3Ghz windows xp-sp3 one SMP2 (2.15 core) + 1 9800GT native GPU2
Athlon x2 6000+ @ 3.0Ghz ubuntu 8.04 smp + asus 9600GSO gpu2 in wine wrapper
5600X2 @ 3.19Ghz ubuntu 8.04 smp + asus 9600GSO gpu2 in wine wrapper
E5200 @ 3.7Ghz ubuntu 8.04 smp2 + asus 9600GT silent gpu2 in wine wrapper
E5200 @ 3.65Ghz ubuntu 8.04 smp2 + asus 9600GSO gpu2 in wine wrapper
E6550 vmware ubuntu 8.4.1
q8400 @ 3.3Ghz windows xp-sp3 one SMP2 (2.15 core) + 1 9800GT native GPU2
Athlon II 620 @ 2.6 Ghz windows xp-sp3 one SMP2 (2.15 core) + 1 9800GT native GPU2
Post by ikerekes »
It is doing it again :(
[17:51:50] Completed 1000000 out of 1000000 steps  (100%)
[17:51:50] DynamicWrapper: Finished Work Unit: sleep=10000
[17:52:00]
[17:52:00] Finished Work Unit:
[17:52:00] - Reading up to 6652008 from "work/wudata_06.trr": Read 6652008
[17:52:00] trr file hash check passed.
[17:52:00] - Reading up to 998912 from "work/wudata_06.xtc": Read 998912
[17:52:00] xtc file hash check passed.
[17:52:00] edr file hash check passed.
[17:52:00] logfile size: 28024
[17:52:00] Leaving Run
[17:52:01] - Writing 7686308 bytes of core data to disk...
[17:52:03] Done: 7685796 -> 7349350 (compressed to 95.6 percent)
[17:52:03]   ... Done.
[17:52:04] - Shutting down core
[17:52:04]
[17:52:04] Folding@home Core Shutdown: FINISHED_UNIT
[17:52:07] CoreStatus = 64 (100)
[17:52:07] Unit 6 finished with 97 percent of time to deadline remaining.
[17:52:07] Updated performance fraction: 0.898964
[17:52:07] Sending work to server
[17:52:07] Project: 11020 (Run 0, Clone 1287, Gen 41)
[17:52:07] + Attempting to send results [November 16 17:52:07 UTC]
[17:52:07] - Reading file work/wuresults_06.dat from core
[17:52:07]   (Read 7349862 bytes from disk)
[17:52:07] Connecting to http://171.64.65.55:8080/
[17:54:14] Posted data.
[17:54:14] Initial: 0000; - Uploaded at ~56 kB/s
[17:54:14] - Averaged speed for that direction ~55 kB/s
[17:54:14] + Results successfully sent
[17:54:14] Thank you for your contribution to Folding@Home.
[17:54:14] + Number of Units Completed: 279
[17:54:18] Trying to send all finished work units
[17:54:18] + No unsent completed units remaining.
[17:54:18] - Preparing to get new work unit...
[17:54:18] Cleaning up work directory
[17:54:18] + Attempting to get work packet
[17:54:18] Passkey found
[17:54:18] - Will indicate memory of 2031 MB
[17:54:18] - Connecting to assignment server
[17:54:18] Connecting to http://assign.stanford.edu:8080/
[17:54:18] Posted data.
[17:54:18] Initial: 40AB; - Successful: assigned to (171.64.65.53).
[17:54:18] + News From Folding@Home: Welcome to Folding@Home
[17:54:19] Loaded queue successfully.
[17:54:19] Sent data
[17:54:19] Connecting to http://171.64.65.53:8080/
[17:54:19] Posted data.
[17:54:19] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[17:54:19] - Attempt #1  to get work failed, and no other work to do.
[17:54:28] + Attempting to get work packet
[17:54:28] Passkey found
[17:54:28] - Will indicate memory of 2031 MB
[17:54:28] - Connecting to assignment server
[17:54:28] Connecting to http://assign.stanford.edu:8080/
[17:54:29] Posted data.
[17:54:29] Initial: 40AB; - Successful: assigned to (171.64.65.53).
[17:54:29] + News From Folding@Home: Welcome to Folding@Home
[17:54:29] Loaded queue successfully.
[17:54:29] Sent data
[17:54:29] Connecting to http://171.64.65.53:8080/
[17:54:29] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[17:54:29] - Attempt #2  to get work failed, and no other work to do.
[17:54:54] + Attempting to get work packet
[17:54:54] Passkey found
[17:54:54] - Will indicate memory of 2031 MB
[17:54:54] - Connecting to assignment server
[17:54:54] Connecting to http://assign.stanford.edu:8080/
[17:54:54] Posted data.
[17:54:54] Initial: 40AB; - Successful: assigned to (171.64.65.53).
[17:54:54] + News From Folding@Home: Welcome to Folding@Home
[17:54:54] Loaded queue successfully.
[17:54:54] Sent data
[17:54:54] Connecting to http://171.64.65.53:8080/
[17:54:54] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[17:54:54] - Attempt #3  to get work failed, and no other work to do.
[17:55:27] + Attempting to get work packet
[17:55:27] Passkey found
[17:55:27] - Will indicate memory of 2031 MB
[17:55:27] - Connecting to assignment server
[17:55:27] Connecting to http://assign.stanford.edu:8080/
[17:55:28] Posted data.
[17:55:28] Initial: 40AB; - Successful: assigned to (171.64.65.53).
[17:55:28] + News From Folding@Home: Welcome to Folding@Home
[17:55:28] Loaded queue successfully.
[17:55:28] Sent data
[17:55:28] Connecting to http://171.64.65.53:8080/
[17:55:28] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[17:55:28] - Attempt #4  to get work failed, and no other work to do.
[17:56:15] + Attempting to get work packet
[17:56:15] Passkey found
[17:56:15] - Will indicate memory of 2031 MB
[17:56:15] - Connecting to assignment server
[17:56:15] Connecting to http://assign.stanford.edu:8080/
[17:56:16] Posted data.
[17:56:16] Initial: 40AB; - Successful: assigned to (171.64.65.53).
[17:56:16] + News From Folding@Home: Welcome to Folding@Home
[17:56:16] Loaded queue successfully.
[17:56:16] Sent data
[17:56:16] Connecting to http://171.64.65.53:8080/
[17:56:16] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[17:56:16] - Attempt #5  to get work failed, and no other work to do.
[17:57:48] + Attempting to get work packet
[17:57:48] Passkey found
[17:57:48] - Will indicate memory of 2031 MB
[17:57:48] - Connecting to assignment server
[17:57:48] Connecting to http://assign.stanford.edu:8080/
[17:57:48] Posted data.
[17:57:48] Initial: 8F80; - Successful: assigned to (128.143.199.97).
[17:57:48] + News From Folding@Home: Welcome to Folding@Home
[17:57:49] Loaded queue successfully.
[17:57:49] Sent data
[17:57:49] Connecting to http://128.143.199.97:8080/
[17:59:52] Posted data.
[18:02:58] Initial: 00DA; + Could not connect to Work Server
[18:02:58] - Attempt #6  to get work failed, and no other work to do.
[18:05:50] + Attempting to get work packet
[18:05:50] Passkey found
[18:05:50] - Will indicate memory of 2031 MB
[18:05:50] - Connecting to assignment server
[18:05:50] Connecting to http://assign.stanford.edu:8080/
[18:05:50] Posted data.
[18:05:50] Initial: 8F80; - Successful: assigned to (128.143.199.97).
[18:05:50] + News From Folding@Home: Welcome to Folding@Home
[18:05:50] Loaded queue successfully.
[18:05:50] Sent data
[18:05:50] Connecting to http://128.143.199.97:8080/
[18:06:10] - Couldn't send HTTP request to server
[18:06:10] + Could not connect to Work Server
[18:06:10] - Attempt #7  to get work failed, and no other work to do.
[18:11:38] + Attempting to get work packet
[18:11:38] Passkey found
[18:11:38] - Will indicate memory of 2031 MB
[18:11:38] - Connecting to assignment server
[18:11:38] Connecting to http://assign.stanford.edu:8080/
[18:11:39] Posted data.
[18:11:39] Initial: 8F80; - Successful: assigned to (128.143.199.97).
[18:11:39] + News From Folding@Home: Welcome to Folding@Home
[18:11:39] Loaded queue successfully.
[18:11:39] Sent data
[18:11:39] Connecting to http://128.143.199.97:8080/
[18:11:58] - Couldn't send HTTP request to server
[18:11:58] + Could not connect to Work Server
[18:11:58] - Attempt #8  to get work failed, and no other work to do.
[18:22:50] + Attempting to get work packet
[18:22:50] Passkey found
[18:22:50] - Will indicate memory of 2031 MB
[18:22:50] - Connecting to assignment server
[18:22:50] Connecting to http://assign.stanford.edu:8080/
[18:22:51] Posted data.
[18:22:51] Initial: 8F80; - Successful: assigned to (128.143.199.97).
[18:22:51] + News From Folding@Home: Welcome to Folding@Home
[18:22:51] Loaded queue successfully.
[18:22:51] Sent data
[18:22:51] Connecting to http://128.143.199.97:8080/
[18:23:10] - Couldn't send HTTP request to server
[18:23:10] + Could not connect to Work Server
[18:23:10] - Attempt #9  to get work failed, and no other work to do.
[18:44:45] + Attempting to get work packet
[18:44:45] Passkey found
[18:44:45] - Will indicate memory of 2031 MB
[18:44:45] - Connecting to assignment server
[18:44:45] Connecting to http://assign.stanford.edu:8080/
[18:44:45] Posted data.
[18:44:45] Initial: 8F80; - Successful: assigned to (128.143.199.97).
[18:44:45] + News From Folding@Home: Welcome to Folding@Home
[18:44:45] Loaded queue successfully.
[18:44:45] Sent data
[18:44:45] Connecting to http://128.143.199.97:8080/
[18:45:04] - Couldn't send HTTP request to server
[18:45:04] + Could not connect to Work Server
[18:45:04] - Attempt #10  to get work failed, and no other work to do.
parkut
Post by parkut »
I have 18 different machines with completed 75xx work units unable to upload. All show collection server CS: 130.237.165.141 and server: 128.143.199.97
Project: 7504 (Run 2, Clone 106, Gen 18)
Project: 7510 (Run 0, Clone 67, Gen 87)
Project: 7504 (Run 6, Clone 60, Gen 16)
Project: 7504 (Run 18, Clone 73, Gen 19)
Project: 7500 (Run 0, Clone 357, Gen 42)
Project: 7504 (Run 10, Clone 37, Gen 10)
Project: 7504 (Run 11, Clone 140, Gen 16)
Project: 7506 (Run 0, Clone 156, Gen 21)
Project: 7501 (Run 0, Clone 59, Gen 234)
Project: 7500 (Run 0, Clone 21, Gen 366)
Project: 7504 (Run 2, Clone 223, Gen 12)
Project: 7504 (Run 1, Clone 158, Gen 6)
Project: 7504 (Run 0, Clone 151, Gen 11)
Project: 7504 (Run 18, Clone 78, Gen 13)
Project: 7504 (Run 8, Clone 7, Gen 62)
Project: 7508 (Run 0, Clone 70, Gen 86)
Project: 7504 (Run 19, Clone 87, Gen 16)
Project: 7504 (Run 15, Clone 125, Gen 16)
Additional details below
q23
 Index 4: ready for upload 644.00 pts (52.213 pt/hr, 1249.14 ppd) 10.1 X min speed
  server: 128.143.199.97:8080; project: 7504
  CS: 130.237.165.141; upload failures: 3; P limit: 524286976
q20
 Index 5: ready for upload 700.00 pts (55.221 pt/hr, 1321.16 ppd) 10.6 X min speed
  server: 128.143.199.97:8080; project: 7510
q17
 Index 7: ready for upload 644.00 pts (52.884 pt/hr, 1265.13 ppd) 10.2 X min speed
q16
 Index 0: ready for upload 644.00 pts (56.979 pt/hr, 1362.73 ppd) 11 X min speed
  CS: 130.237.165.141; upload failures: 5; P limit: 524286976
q15
 Index 3: ready for upload 529.00 pts (58.487 pt/hr, 1397.68 ppd) 10.6 X min speed
  server: 128.143.199.97:8080; project: 7500
q13
 Index 6: ready for upload 644.00 pts (51.723 pt/hr, 1237.41 ppd) 10 X min speed
  CS: 130.237.165.141; upload failures: 4; P limit: 524286976
q11
 Index 2: ready for upload 644.00 pts (53.048 pt/hr, 1269.02 ppd) 10.3 X min speed
q10
 Index 7: ready for upload 706.00 pts (53.017 pt/hr, 1268.66 ppd) 10.3 X min speed
  server: 128.143.199.97:8080; project: 7506
  CS: 130.237.165.141; upload failures: 2; P limit: 524286976
q09
 Index 2: ready for upload 494.00 pts (57.481 pt/hr, 1373.24 ppd) 10.1 X min speed
  server: 128.143.199.97:8080; project: 7501
q05
 Index 7: ready for upload 529.00 pts (58.778 pt/hr, 1404.51 ppd) 10.7 X min speed
  CS: 130.237.165.141; upload failures: 1; P limit: 524286976
q04
 Index 9: ready for upload 644.00 pts (45.800 pt/hr, 1096.15 ppd) 8.88 X min speed
q01
 Index 1: ready for upload 644.00 pts (53.109 pt/hr, 1270.44 ppd) 10.3 X min speed
c07
 Index 4: ready for upload 644.00 pts (60.655 pt/hr, 1450.32 ppd) 11.8 X min speed
c06
 Index 2: ready for upload 644.00 pts (60.231 pt/hr, 1440.19 ppd) 11.7 X min speed
c01
 Index 8: ready for upload 644.00 pts (53.718 pt/hr, 1285.00 ppd) 10.4 X min speed
i901
 Index 6: ready for upload 770.00 pts (85.211 pt/hr, 2036.11 ppd) 16.5 X min speed
  server: 128.143.199.97:8080; project: 7508
f3b6
 Index 3: ready for upload 644.00 pts (50.945 pt/hr, 1218.87 ppd) 9.87 X min speed
f3b5
 Index 9: ready for upload 644.00 pts (52.809 pt/hr, 1263.29 ppd) 10.2 X min speed
sortofageek
Post by sortofageek »
viewtopic.php?f=18&t=20044
Server Status shows it accepting for the past 2-3 hours. It may take awhile to catch up even if it is now operating as it should.
kasson
Pande Group Member
Post by kasson »
Has this improved? The server ran into a problem; we restarted it and are keeping an eye on it.
ThunderRd
Post by ThunderRd »
kasson wrote:Has this improved? The server ran into a problem; we restarted it and are keeping an eye on it.
Looks OK now. I got work long before the client uploaded, though. It took another 7 hours to upload the finished work.
Thanks for checking it out.
parkut
Post by parkut »
Looks good from here. Sorry if my note was premature. Sounds like Dr. Kasson was on it already!!!!
shunter
Re: 128.143.199.97:8080/ Reject Status [resolved]
Post by shunter »
Seems to have been some catching up but as of now I have lost 3 units completly and others scaled back. In total some 12k points are lost
sortofageek
I checked the database for all parkut listed. All but one seem to have credited at this point. I will check for the other posters as well if their posts contain the relevant info about the WUs in question (Project, Run, Clone, Gen) as parkut's post did.
Hi parkut (team 4),
Your WU (P7504 R2 C106 G18) was added to the stats database on 2011-11-16 19:06:48 for 2208.28 points of credit.
Hi parkut (team 4),
Your WU (P7510 R0 C67 G87) was added to the stats database on 2011-11-16 18:07:05 for 3169.6 points of credit.
Hi parkut (team 4),
Your WU (P7504 R6 C60 G16) was added to the stats database on 2011-11-16 17:07:47 for 2462.66 points of credit.
Hi parkut (team 4),
Your WU (P7504 R18 C73 G19) was added to the stats database on 2011-11-16 16:07:05 for 2622.37 points of credit.
Hi parkut (team 4),
Your WU (P7500 R0 C357 G42) was added to the stats database on 2011-11-16 19:06:48 for 1722.42 points of credit.
Hi parkut (team 4),
Your WU (P7504 R10 C37 G10) was added to the stats database on 2011-11-16 18:07:05 for 2465.23 points of credit.
Hi parkut (team 4),
Your WU (P7504 R11 C140 G16) was added to the stats database on 2011-11-16 14:07:13 for 2838.11 points of credit.
Hi parkut (team 4),
Your WU (P7506 R0 C156 G21) was added to the stats database on 2011-11-16 18:07:05 for 3196.06 points of credit.
Hi parkut (team 4),
Your WU (P7501 R0 C59 G234) was added to the stats database on 2011-11-16 17:07:47 for 1706.28 points of credit.
No data back from query
Results received. See this post.
Hi parkut (team 4),
Your WU (P7504 R2 C223 G12) was added to the stats database on 2011-11-16 19:06:48 for 2373.78 points of credit.
Hi parkut (team 4),
Your WU (P7504 R1 C158 G6) was added to the stats database on 2011-11-16 16:07:05 for 2870.95 points of credit.
Hi parkut (team 4),
Your WU (P7504 R0 C151 G11) was added to the stats database on 2011-11-16 16:07:05 for 2680.97 points of credit.
Hi parkut (team 4),
Your WU (P7504 R18 C78 G13) was added to the stats database on 2011-11-16 16:07:05 for 2979.79 points of credit.
Project: 7504 (Run 8, Clone 7, Gen 62)Hi parkut (team 4),
Your WU (P7504 R8 C7 G62) was added to the stats database on 2011-11-16 17:07:47 for 2551.53 points of credit.
Hi parkut (team 4),
Your WU (P7508 R0 C70 G86) was added to the stats database on 2011-11-16 18:07:05 for 3407.25 points of credit.
Hi TH_Foldinator (team 4),
Your WU (P7504 R19 C87 G16) was added to the stats database on 2011-11-17 06:06:32 for 2027.96 points of credit.
Your WU (P7504 R15 C125 G16) was added to the stats database on 2011-11-16 17:07:47 for 2854.85 points of credit.
sortofageek
Hi ThunderRd (team 45),
Your WU (P7504 R4 C76 G20) was added to the stats database on 2011-11-16 16:07:05 for 2715.1 points of credit.
shunter
Re: 128.143.199.97:8080/ Reject Status [resolving]
Post by shunter »
My lost ones are ( as best I can tell)
7504 8 175 17 (shunter)
7504 10 32 22 (alias ravey)
7500 0 310 50 (alias frostushenon)
Partial scores are
7501 0 235 94 (alias frostushenon) approx 1727 points
7508 0 112 65 (alias ravey) approx3158 points
Many thanks
shunter
sortofageek
I checked the database.
Project: 7504 (Run 8, Clone 175,Gen 17) (shunter)
Project: 7504 (Run 10, Clone 32, Gen 22) (alias ravey)
Project: 7500 (Run 0, Clone 310, Gen 50) (alias frostushenon)
Partial scores are
Project: 7501 (Run 0, Clone 235, Gen 94) (alias frostushenon) approx 1727 points
Days taken to complete WU: 0.93
Hi frostushenon (team 46590),
Your WU (P7501 R0 C235 G94) was added to the stats database on 2011-11-16 14:07:13 for 1728.01 points of credit.
Project: 7508 (Run 0, Clone 112, Gen 65) (alias ravey) approx3158 points
Days taken to complete WU: 1.12
Hi ravey (team 46590),
Your WU (P7508 R0 C112 G65) was added to the stats database on 2011-11-16 13:07:30 for 3157.77 points of credit.
I will mark the ones with no results for followup, but please post the logs for each one still in question.
