Does the A3 core scale past 8 cores/threads
Simba123
Post by Simba123 »
As title says,
Does the A3 core scale past 8cores/threads? The recent big-adv shortage has lead to
a fair number of 990x users running -SMP. Something that has come up is that is
seems that the PPD from 8cores to 12cores/threads results in barely an increase +5%
in PPD?
I understand A3 is an ancient core that was developed way before 6 core and above
was manufactured, but can someone/anyone confirm that this (non)scaling is expected?
It's been a bit frustrating for our members with these high-end machines not to be able to
churn & burn through the A3 -smp units because they don't scale up.
cheers
Re: Does the A3 core scale past 8 cores/threads
The question has more than one answer depending on what you mean my "scale"
Any SMP software scales with the number of processors within certain constraints. If you have twice as many processors, the actual processing speed can never exceed twice the speed and it will generally be less than that due to a number of factors. There's always some delay required to synchronize the various threads but in most FAH cases this is quite small. An obviously exaggerated case would be a protein with 12 atoms and 12 CPUs. The overhead of distributing one atom to each processor and collecting the results to complete the step would take A LOT more time than processing a single atom.
The points system does not scale linearly, so if you're evaluating your observations based on points rather than elapsed time, the answer will be: No points do not scale.
Processors may not scale linearly either. The i5 and the x6 (etc.) have independent cores and come very close to scaling linearly but there are still shared resources (cache/RAM/disk/etc) for which they may very well compete for. The processors in Bulldozer and the i7 (etc.) do not have fully outfitted independent cores and pairs of ALU "cores" compete with each other for access to a shared FPU. This latter phenomenon is particularly important to FAH.
I suggest you answer the question yourself. Assuming you have N independent cores running SMP in an otherwise idle machine, measure the average frame time. Restart FAH with N/2 smp threads (on the same WU). Is the new frame time twice as long and the original measurement? I think you'll find the answer is "pretty close" but we'd appreciate hearing your results, no matter whether my guess is correct or it isn't. Be sure to describe the hardware and the WU that you used for your test.
Simba123
Post by Simba123 »
thanks for the quick reply bruce. the query is for one of our members, not me.
He's had a rough time lately and is taking this -bigadv shortage a bit personally I think.
It's been very frustrating for him, combined with the P7504 problem.
At the moment he's running a 990x and on smp-12 is getting the same tpf as a 2600k @ 4.5
when running a p7504. I'm not sure what speed/client he's running. I'll direct him to this thread so he can fill you in on his
specific hardware.
cheers.
Grandpa_01
Post by Grandpa_01 »
The PPD on a -smp vs a bigadv has nothing to do with scaling it has to do with the QRB and frame times and the QRB does not scale literally between the 2 types of projects. Remember the kfactor on a bigadv is between 26 and 38 depending on the WU and the QRB on a smp it is between .59 and 3.35 or somewhere in that neighbourhood. So if your 990X has a return time of 3min per frame faster with a kfactor of 38 it PPD is going to be quit a bit more than the slower rig but if you are folding a smp the kfactor is only going to be 3.35 at best so if you are 3 min faster on a smp the PPD difference is going to be quit a bit less.
I hope I made sense here without typing out the formulas it is not that easy to explain. And I am not good with formulas and equations. :?
Just curious but what is the 990X clocked at I get frame times of 1:38 on a 7504 on a 980X
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Simba123
Post by Simba123 »
Thanks Grandpa.
I think he is more concerned about the tpf not scaling with the increase in threads/cores.
Can someone expect that a 990x running smp -12 core A3 would be faster than
a 2600k running smp8 core A3 given the same workunit, and clockspeed?
At the moment the data suggests that they actually come in about the same tpf wise.
I understand the k-factor bonus point thing; It's just that you would expect that a all things
being equal a 990x should be able to churn through a SMP unit faster than a 2600k
Additionally, as I am reasonably new at this, my understanding is that the A4 core is newer and
does use threads/cores above 8 more effectively???
It's possible, but we're not a benchmark site. He can tell us what he's seeing and nobody will argue with it. Then ask Intel to confirm your findings.
Apparently you're comparing a 990x with 6 cores @3.46 to a 2600k with 4 cores @4.5 and they're running the same WU. Both are running two threads per core. Right?
From the theoretical perspective of pure GFLOPS, the 990X is maybe 15% faster, but theoretical GFLOPS do not equate to actual GFLOPS until you also consider what Intel calls "uncore" speeds, including factors like cache size, cache organization, FSB speeds, etc. Moreover, the non-scalability of HyperThreading is well known It also depends greatly on the specific software you're running (and in the case of FAH, the particular project you're running).
Does the extra overhead of breaking down a problem into 12 threads compared to 8 threads make up a measurable part of that 15% difference? Who can say without actually trying it.
Grandpa_01
I should be able to answer that question in a couple of weeks I am putting together a i7 2700k rig to do some testing with that is interesting, do you know what his timings are both cpu speed and memory spped and timings on both rigs. Memory speed and timings play a pretty big role when it comes to folding on the 970, 980 and 990's
Nathan_P
Not currently folding
Post by Nathan_P »
I can run some tests on a lower end hex core as well but it may well take a week or so as I am awaiting parts, can run tests on win 7x64 and linux.
Just out of curiosity which OS is he running?
Mstenholm
Hardware configuration: 4 x GTX 970. Win 7.
Post by Mstenholm »
Grandpa_01 wrote: Just curious but what is the 990X clocked at I get frame times of 1:38 on a 7504 on a 980X
Really? I wonder what I do wrong since I get around 2:27 on a i970 @ 4.1 GHz on the same WU.
WIN7....maybe.
Punchy
Post by Punchy »
Given the information in the thread that prompted this post, my conclusion was that A3 core doesn't scale well on Windows XP on Project 7504 with 2 GPUs running. I don't think that can be extrapolated to simply say that the A3 core doesn't scale. His frame times went from 3:03 at 8 threads to 2:57 at 10 threads and though it improved at 11 that was not a viable solution since some SMP work fails at smp 11. Frame time at 12 threads was 3:22 but that's understandable given he has 2 GPU clients running.
I did a quick test on Windows 7 and saw excellent scaling from 8 to 10 and 12 threads. However, I'm not running XP, I didn't have p7504, and I don't have any GPUs running simultaneously.
Grandpa_01
WIN7....maybe.
That sounds about right, I think my 970 at 4.3Ghz is around 2:00 per frame.
orion
Hardware configuration: 4p/4 MC ES @ 3.0GHz/32GB
4p/4x6128 @ 2.47GHz/32GB
2p/2 IL ES @ 2.7GHz/16GB
1p/8150/8GB
1p/1090T/4GB
Post by orion »
WIN7....maybe.
My x6 @ 3.9 running a 7504 has a TPF of around 2:54 in LINUX.
iustus quia...
ChasR
Post by ChasR »
Numbers from a 2600K running Win7/VMware/Ubuntu 10.10 @ 4.8 GHz.
Project ID: 7504
 Core: GRO-A3
 Credit: 644
 Frames: 100
 Path: \\HTPC-UBUNTU\fah\
 Number of Frames Observed: 72
 Cur. Time / Frame : 00:02:23 - 34,710 PPD
 R3F. Time / Frame : 00:02:23 - 34,710 PPD
Comparing my 2600K frame times to Grandpa's frame times of 1:38 on a 7504 on a 980X, it would appear the a3 WUs scale properly above 8 threads in Linux.
codysluder
Post by codysluder »
I think Punchy made the proper point. A3 scales properly on a clean machine but the time that GPUs steal from SMP means you're not measuring a system with all of the cores dedicated to SMP.
2 things. The concerned user should post here directly, so there is no loss in translation. Second, I'm with cody, turn off the GPUs if you want to get some REAL 12 core folding frame times. Otherwise there is no way to tell what is affecting frame times. Could be just as likely the GPUs as the A3 fahcore. Can't assume anything when the water is that muddy.
P.S. The a3 core is older but not ancient. bigadv was an offshoot of the a3 fahcore.
