Post issues with Project 7620 or 7621 points here [Resolved]
Xavier Zepherious
Post by Xavier Zepherious »
Im not the only one this morning
since there is two of us at about the same time I suspect an issue here
mine was 8:57am
5187 pointers not appearing to be credited
http://www.evga.com/forums/fb.ashx?m=1293951
http://www.evga.com/forums/fb.ashx?m=1294016
Macaholic
Re: posted wu and no credit
Post by Macaholic »
Could you please post a snippet from the log file (FAHlog.txt) you suspect contains the missing unit(s). Be sure it contains the project number along with the run, clone, and generation numbers. Server address would be nice too. That will help us with troubleshooting and determining if the units have been properly credited. Thanks.
Fold! It does a body good!™
Xavier Zepherious
I wish I had a sample
not a failed WU... (which I have logs of every one) - have't had a failed WU since AUG
(I just selected to save Complete units Logs because of this)
I uploaded the unit at 8:57:28 MST
I didn't keep completed Units
I don't know if the other person did either
I can give you current WU and server
[14:57:29] Initial: 40AB; - Successful: assigned to (171.64.65.105).
[14:57:29] + News From Folding@Home: Welcome to Folding@Home
[14:57:29] Loaded queue successfully.
[14:57:29] Gpu type=3 species=30.
[14:57:29] Sent data
[14:57:29] Connecting to http://171.64.65.105:8080/
[14:57:29] Posted data.
[14:57:29] Initial: 0000; - Receiving payload (expected size: 125097)
[14:57:29] Conversation time very short, giving reduced weight in bandwidth avg
[14:57:29] - Downloaded at ~244 kB/s
[14:57:29] - Averaged speed for that direction ~244 kB/s
[14:57:29] + Received work.
[14:57:29] + Closed connections
[14:57:29]
[14:57:29] + Processing work unit
[14:57:29] Core required: FahCore_15.exe
[14:57:29] Core found.
[14:57:29] Working on queue slot 01 [October 27 14:57:29 UTC]
[14:57:29] + Working ...
[14:57:29] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 16884 -version 630'
[14:57:29]
[14:57:29] *------------------------------*
[14:57:29] Folding@Home GPU Core
[14:57:29] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[14:57:29] Build host             SimbiosNvdWin7
[14:57:29] Board Type             NVIDIA/CUDA
[14:57:29] Core                   15
[14:57:29]
[14:57:29] Window's signal control handler registered.
[14:57:29] Preparing to commence simulation
[14:57:29] - Looking at optimizations...
[14:57:29] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[14:57:29] - Created dyn
[14:57:29] - Files status OK
[14:57:29] sizeof(CORE_PACKET_HDR) = 512 file=<>
[14:57:30] - Expanded 124585 -> 501826 (decompressed 402.7 percent)
[14:57:30] Called DecompressByteArray: compressed_data_size=124585 data_size=501826, decompressed_data_size=501826 diff=0
[14:57:30] - Digital signature verified
[14:57:30]
[14:57:30] Project: 7620 (Run 387, Clone 0, Gen 46)
Next time I'll have the completed log if it happens
The reason I posted was so you could check servers
not that Im trying to get lost points...if I lost them it's fine
Mod edit - added code tags
Zagen30
Post by Zagen30 »
You sure you don't still have the log? If you completed it today, and you haven't been restarting the client a lot, the log should still be there. v6 keeps the current one (FAHlog.txt) going as long as you don't close the client, and it then gets renamed as FAHlog-Prev.txt and retained until the more current one is large enough to be archived and the client gets closed again. v7 keeps several day's worth of logs around.
I'm afraid there's not a whole lot the mods can do without the PRCG numbers. They can check your most recently completed WU, but if you've returned something else since the ones that seem to have gone uncredited they can't see beyond the latest one.
Xavier Zepherious
I don't ...use FAH gpu tracker V2
however the other user does
he used the same server - didn't get points
WILLYRAY ------------------- his stuff below
Signed up for an account and tried posting it twice ... so you may see some newbie tracks of mine over at that forum
Just so you all can get the information, here's a snippet from the log file:
[13:38:19] Project: 7620 (Run 797, Clone 0, Gen 70)
[13:38:19] - Read packet limit of 540015616... Set to 524286976.
[13:38:19] + Attempting to send results [October 27 13:38:19 UTC]
[13:38:19] - Reading file work/wuresults_01.dat from core
[13:38:19] (Read 819540 bytes from disk)
[13:38:19] Gpu type=3 species=30.
[13:38:19] Connecting to http://171.64.65.105:8080/
[13:38:25] Posted data.
[13:38:25] Initial: 0000; - Uploaded at ~133 kB/s
[13:38:25] - Averaged speed for that direction ~133 kB/s
[13:38:25] + Results successfully sent
[13:38:25] Thank you for your contribution to [link=mailto:Folding@Home]Folding@Home[/link].
Xavier Zepherious
PS: I haven't seen points for the next one either
finished at 5:11
I just checked the stats page it's not there yet 1 hr later
I have the log for that. no errors
Xavier Zepherious
Heres the log file of the one at 5:11MST
it's now 7:11 MST and no points
[14:57:28] Could not open work queue, generating new queue...
[14:57:28] - Preparing to get new work unit...
[14:57:28] - Autosending finished units... [October 27 14:57:28 UTC]
[14:57:28] Cleaning up work directory
[14:57:28] Trying to send all finished work units
[14:57:28] + No unsent completed units remaining.
[14:57:28] - Autosend completed
[14:57:28] + Attempting to get work packet
[14:57:28] Passkey found
[14:57:28] - Will indicate memory of 4094 MB
[14:57:28] Gpu type=3 species=30.
[14:57:28] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[14:57:28] - Connecting to assignment server
[14:57:28] Connecting to http://assign-GPU.stanford.edu:8080/
[14:57:29]
[14:57:29]
[14:57:29] Core                   15
[14:57:29]
[14:57:30]
[14:57:30]
[14:57:30] Assembly optimizations on if available.
[14:57:30] Entering M.D.
[14:57:32] Tpr hash work/wudata_01.tpr:  3026582797 146979024 2350487081 1724542826 51681914
[14:57:32] calling fah_main gpuDeviceId=0
[14:57:32] Working on Protein
[14:57:32] Client config found, loading data.
[14:57:32] Starting GUI Server
[14:58:35] Setting checkpoint frequency: 400000
[14:58:35] Completed         3 out of 40000000 steps (0%).
[15:03:29] Completed    400000 out of 40000000 steps (1%).
[15:08:23] Completed    800000 out of 40000000 steps (2%).
[15:13:18] Completed   1200000 out of 40000000 steps (3%).
[15:18:12] Completed   1600000 out of 40000000 steps (4%).
[15:23:06] Completed   2000000 out of 40000000 steps (5%).
[15:28:00] Completed   2400000 out of 40000000 steps (6%).
[15:32:55] Completed   2800000 out of 40000000 steps (7%).
[15:37:50] Completed   3200000 out of 40000000 steps (8%).
[15:42:46] Completed   3600000 out of 40000000 steps (9%).
[15:47:45] Completed   4000000 out of 40000000 steps (10%).
[15:52:45] Completed   4400000 out of 40000000 steps (11%).
[15:57:41] Completed   4800000 out of 40000000 steps (12%).
[16:02:43] Completed   5200000 out of 40000000 steps (13%).
[16:07:43] Completed   5600000 out of 40000000 steps (14%).
[16:12:42] Completed   6000000 out of 40000000 steps (15%).
[16:17:42] Completed   6400000 out of 40000000 steps (16%).
[16:22:43] Completed   6800000 out of 40000000 steps (17%).
[16:27:44] Completed   7200000 out of 40000000 steps (18%).
[16:32:44] Completed   7600000 out of 40000000 steps (19%).
[16:37:41] Completed   8000000 out of 40000000 steps (20%).
[16:42:41] Completed   8400000 out of 40000000 steps (21%).
[16:47:44] Completed   8800000 out of 40000000 steps (22%).
[16:52:39] Completed   9200000 out of 40000000 steps (23%).
[16:57:33] Completed   9600000 out of 40000000 steps (24%).
[17:02:27] Completed  10000000 out of 40000000 steps (25%).
[17:07:24] Completed  10400000 out of 40000000 steps (26%).
[17:12:18] Completed  10800000 out of 40000000 steps (27%).
[17:17:12] Completed  11200000 out of 40000000 steps (28%).
[17:22:06] Completed  11600000 out of 40000000 steps (29%).
[17:26:59] Completed  12000000 out of 40000000 steps (30%).
[17:31:53] Completed  12400000 out of 40000000 steps (31%).
[17:36:47] Completed  12800000 out of 40000000 steps (32%).
[17:41:41] Completed  13200000 out of 40000000 steps (33%).
[17:46:34] Completed  13600000 out of 40000000 steps (34%).
[17:51:28] Completed  14000000 out of 40000000 steps (35%).
[17:56:22] Completed  14400000 out of 40000000 steps (36%).
[18:01:15] Completed  14800000 out of 40000000 steps (37%).
[18:06:09] Completed  15200000 out of 40000000 steps (38%).
[18:11:02] Completed  15600000 out of 40000000 steps (39%).
[18:15:56] Completed  16000000 out of 40000000 steps (40%).
[18:20:51] Completed  16400000 out of 40000000 steps (41%).
[18:25:45] Completed  16800000 out of 40000000 steps (42%).
[18:30:39] Completed  17200000 out of 40000000 steps (43%).
[18:35:33] Completed  17600000 out of 40000000 steps (44%).
[18:40:31] Completed  18000000 out of 40000000 steps (45%).
[18:45:26] Completed  18400000 out of 40000000 steps (46%).
[18:50:20] Completed  18800000 out of 40000000 steps (47%).
[18:55:15] Completed  19200000 out of 40000000 steps (48%).
[19:00:11] Completed  19600000 out of 40000000 steps (49%).
[19:05:06] Completed  20000000 out of 40000000 steps (50%).
[19:10:01] Completed  20400000 out of 40000000 steps (51%).
[19:14:57] Completed  20800000 out of 40000000 steps (52%).
[19:19:51] Completed  21200000 out of 40000000 steps (53%).
[19:24:47] Completed  21600000 out of 40000000 steps (54%).
[19:29:41] Completed  22000000 out of 40000000 steps (55%).
[19:34:37] Completed  22400000 out of 40000000 steps (56%).
[19:39:32] Completed  22800000 out of 40000000 steps (57%).
[19:44:27] Completed  23200000 out of 40000000 steps (58%).
[19:49:21] Completed  23600000 out of 40000000 steps (59%).
[19:54:16] Completed  24000000 out of 40000000 steps (60%).
[19:59:10] Completed  24400000 out of 40000000 steps (61%).
[20:04:04] Completed  24800000 out of 40000000 steps (62%).
[20:09:00] Completed  25200000 out of 40000000 steps (63%).
[20:13:55] Completed  25600000 out of 40000000 steps (64%).
[20:18:50] Completed  26000000 out of 40000000 steps (65%).
[20:23:44] Completed  26400000 out of 40000000 steps (66%).
[20:28:38] Completed  26800000 out of 40000000 steps (67%).
[20:33:33] Completed  27200000 out of 40000000 steps (68%).
[20:38:28] Completed  27600000 out of 40000000 steps (69%).
[20:43:22] Completed  28000000 out of 40000000 steps (70%).
[20:48:16] Completed  28400000 out of 40000000 steps (71%).
[20:53:09] Completed  28800000 out of 40000000 steps (72%).
[20:57:28] - Autosending finished units... [October 27 20:57:28 UTC]
[20:57:28] Trying to send all finished work units
[20:57:28] + No unsent completed units remaining.
[20:57:28] - Autosend completed
[20:58:03] Completed  29200000 out of 40000000 steps (73%).
[21:02:59] Completed  29600000 out of 40000000 steps (74%).
[21:07:53] Completed  30000000 out of 40000000 steps (75%).
[21:12:47] Completed  30400000 out of 40000000 steps (76%).
[21:17:41] Completed  30800000 out of 40000000 steps (77%).
[21:22:36] Completed  31200000 out of 40000000 steps (78%).
[21:27:30] Completed  31600000 out of 40000000 steps (79%).
[21:32:25] Completed  32000000 out of 40000000 steps (80%).
[21:37:20] Completed  32400000 out of 40000000 steps (81%).
[21:42:15] Completed  32800000 out of 40000000 steps (82%).
[21:47:10] Completed  33200000 out of 40000000 steps (83%).
[21:52:06] Completed  33600000 out of 40000000 steps (84%).
[21:57:00] Completed  34000000 out of 40000000 steps (85%).
[22:01:55] Completed  34400000 out of 40000000 steps (86%).
[22:06:50] Completed  34800000 out of 40000000 steps (87%).
[22:11:47] Completed  35200000 out of 40000000 steps (88%).
[22:16:41] Completed  35600000 out of 40000000 steps (89%).
[22:21:34] Completed  36000000 out of 40000000 steps (90%).
[22:26:28] Completed  36400000 out of 40000000 steps (91%).
[22:31:23] Completed  36800000 out of 40000000 steps (92%).
[22:36:16] Completed  37200000 out of 40000000 steps (93%).
[22:41:10] Completed  37600000 out of 40000000 steps (94%).
[22:46:04] Completed  38000000 out of 40000000 steps (95%).
[22:50:58] Completed  38400000 out of 40000000 steps (96%).
[22:55:52] Completed  38800000 out of 40000000 steps (97%).
[23:00:45] Completed  39200000 out of 40000000 steps (98%).
[23:05:40] Completed  39600000 out of 40000000 steps (99%).
[23:10:35] Completed  40000000 out of 40000000 steps (100%).
[23:10:37] Finished fah_main status=0
[23:10:37] Successful run
[23:10:37] DynamicWrapper: Finished Work Unit: sleep=10000
[23:10:47] Reserved 760000 bytes for xtc file; Cosm status=0
[23:10:47] Allocated 760000 bytes for xtc file
[23:10:47] - Reading up to 760000 from "work/wudata_01.xtc": Read 760000
[23:10:47] Read 760000 bytes from xtc file; available packet space=785670464
[23:10:47] xtc file hash check passed.
[23:10:47] Reserved 47688 47688 785670464 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[23:10:47] Allocated 47688 bytes for arc file
[23:10:47] - Reading up to 47688 from "work/wudata_01.trr": Read 47688
[23:10:47] Read 47688 bytes from arc file; available packet space=785622776
[23:10:47] trr file hash check passed.
[23:10:47] Allocated 544 bytes for edr file
[23:10:47] Read bedfile
[23:10:47] edr file hash check passed.
[23:10:47] Allocated 36677 bytes for logfile
[23:10:47] Read logfile
[23:10:47] GuardedRun: success in DynamicWrapper
[23:10:47] GuardedRun: done
[23:10:47] Run: GuardedRun completed.
[23:10:49] + Opened results file
[23:10:49] - Writing 845421 bytes of core data to disk...
[23:10:50] Done: 844909 -> 816559 (compressed to 96.6 percent)
[23:10:50]   ... Done.
[23:10:50] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[23:10:50] Shutting down core
[23:10:50]
[23:10:50] Folding@home Core Shutdown: FINISHED_UNIT
[23:10:53] CoreStatus = 64 (100)
[23:10:53] Unit 1 finished with 98 percent of time to deadline remaining.
[23:10:53] Updated performance fraction: 0.980858
[23:10:53] Sending work to server
[23:10:53] Project: 7620 (Run 387, Clone 0, Gen 46)
[23:10:53] - Read packet limit of 540015616... Set to 524286976.
[23:10:53] + Attempting to send results [October 27 23:10:53 UTC]
[23:10:53] - Reading file work/wuresults_01.dat from core
[23:10:53]   (Read 817071 bytes from disk)
[23:10:53] Gpu type=3 species=30.
[23:10:53] Connecting to http://171.64.65.105:8080/
[23:11:07] Posted data.
[23:11:07] Initial: 0000; - Uploaded at ~57 kB/s
[23:11:07] - Averaged speed for that direction ~57 kB/s
[23:11:07] - Server has already received unit.
[23:11:07] Trying to send all finished work units
[23:11:07] + No unsent completed units remaining.
[23:11:07] + -oneunit flag given and have now finished a unit. Exiting.***** Got a SIGTERM signal (2)
[23:11:07] Killing all core threads
Folding@Home Client Shutdown.
Macaholic
Post by Macaholic »
Project leader has been notified. Thank you. :)
tjlane
Pande Group Member
Post by tjlane »
Hi Xavier,
Two questions:
(1) How many WUs have not been credited? If you can list them that would be helpful.
(2) Are you running with -advmethods?
Thanks. Sorry about this... I'll try to track down the bug as fast as possible. I have a suspect (!) but need more data to verify.
TJ
Xavier Zepherious
2 WU from myself -
last one credited was last night at 1:am MST
two WU's after.... no points
7620 or 7621 projects -5187 point WU's
the one I posted a completed log for... is a 7620
the only one I have a record for is above - since I did not save completed units til after the first completed WU I didn't get credit for
Im running advmethods
the other person above has the same issue
if you need his info I'll get him to post it to me or post it himself
willyray
Post by willyray »
My third attempt to post ... here's the complete log (less my ID #) from a 7620 that was uploaded, but, never showed up at Stanford or EOC stats:
--- Opening Log file [October 27 00:35:33 UTC]
                       Folding@Home Client Version 6.30r1
                          http://folding.stanford.edu
Launch directory: C:\Program Files (x86)\FAH_GPU_Tracker_V2\FAH GPU Tracker V2\GPU0
Executable: C:\Program Files (x86)\FAH_GPU_Tracker_V2\FAH GPU Tracker V2\FAH_GPU3.exe
Arguments: -oneunit -forcegpu nvidia_fermi -advmethods -verbosity 9 -gpu 0
[00:35:33] - Ask before connecting: No
[00:35:33] - User name: willyray (Team 111065)
[00:35:33] - User ID: XXXXXXXXXXXXXXXX
[00:35:33] - Machine ID: 3
[00:35:33]
[00:35:33] Gpu type=3 species=30.
[00:35:33] Work directory not found. Creating...
[00:35:33] Could not open work queue, generating new queue...
[00:35:33] - Preparing to get new work unit...
[00:35:33] Cleaning up work directory
[00:35:33] - Autosending finished units... [October 27 00:35:33 UTC]
[00:35:33] Trying to send all finished work units
[00:35:33] + No unsent completed units remaining.
[00:35:33] - Autosend completed
[00:35:33] + Attempting to get work packet
[00:35:33] Passkey found
[00:35:33] - Will indicate memory of 4094 MB
[00:35:33] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[00:35:33] - Connecting to assignment server
[00:35:33] Connecting to http://assign-GPU.stanford.edu:8080/
[00:35:33] Posted data.
[00:35:33] Initial: 40AB; - Successful: assigned to (171.64.65.105).
[00:35:33] + News From Folding@Home: Welcome to Folding@Home
[00:35:33] Loaded queue successfully.
[00:35:33] Sent data
[00:35:33] Connecting to http://171.64.65.105:8080/
[00:35:34] Posted data.
[00:35:34] Initial: 0000; - Receiving payload (expected size: 125352)
[00:35:35] - Downloaded at ~122 kB/s
[00:35:35] - Averaged speed for that direction ~122 kB/s
[00:35:35] + Received work.
[00:35:35] + Closed connections
[00:35:35]
[00:35:35] + Processing work unit
[00:35:35] Core required: FahCore_15.exe
[00:35:35] Core found.
[00:35:35] Working on queue slot 01 [October 27 00:35:35 UTC]
[00:35:35] + Working ...
[00:35:35] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 2424 -version 630'
[00:35:35]
[00:35:35] *------------------------------*
[00:35:35] Folding@Home GPU Core
[00:35:35] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[00:35:35] Build host             SimbiosNvdWin7
[00:35:35] Board Type             NVIDIA/CUDA
[00:35:35] Core                   15
[00:35:35]
[00:35:35] Window's signal control handler registered.
[00:35:35] Preparing to commence simulation
[00:35:35] - Looking at optimizations...
[00:35:35] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[00:35:35] - Created dyn
[00:35:35] - Files status OK
[00:35:35] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:35:35] - Expanded 124840 -> 501826 (decompressed 401.9 percent)
[00:35:35] Called DecompressByteArray: compressed_data_size=124840 data_size=501826, decompressed_data_size=501826 diff=0
[00:35:35] - Digital signature verified
[00:35:35]
[00:35:35] Project: 7620 (Run 797, Clone 0, Gen 70)
[00:35:35]
[00:35:35] Assembly optimizations on if available.
[00:35:35] Entering M.D.
[00:35:37] Tpr hash work/wudata_01.tpr:  868991297 3210814348 2181615393 3323288864 3358889042
[00:35:37] calling fah_main gpuDeviceId=0
[00:35:37] Working on Protein
[00:35:37] Client config found, loading data.
[00:35:37] Starting GUI Server
[00:35:38] ***** Got a SIGTERM signal (2)
[00:35:38] Killing all core threads
--- Opening Log file [October 27 00:35:38 UTC]
[00:35:38] - Ask before connecting: No
[00:35:38] - User name: willyray (Team 111065)
[00:35:38] - User ID: 1733CA8113AE2479
[00:35:38] - Machine ID: 3
[00:35:38]
[00:35:38] Gpu type=3 species=30.
[00:35:38] Loaded queue successfully.
[00:35:38]
[00:35:38] - Autosending finished units... [October 27 00:35:38 UTC]
[00:35:38] + Processing work unit
[00:35:38] Trying to send all finished work units
[00:35:38] Core required: FahCore_15.exe
[00:35:38] + No unsent completed units remaining.
[00:35:38] - Autosend completed
[00:35:38] Core found.
[00:35:38] Working on queue slot 01 [October 27 00:35:38 UTC]
[00:35:38] + Working ...
[00:35:38] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 1040 -version 630'
[00:35:38]
[00:35:38] *------------------------------*
[00:35:38] Folding@Home GPU Core
[00:35:38] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[00:35:38] Build host             SimbiosNvdWin7
[00:35:38] Board Type             NVIDIA/CUDA
[00:35:38] Core                   15
[00:35:38]
[00:35:38] Window's signal control handler registered.
[00:35:38] Preparing to commence simulation
[00:35:38] - Looking at optimizations...
[00:35:38] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[00:35:38] - Created dyn
[00:35:38] - Files status OK
[00:35:38] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:35:38] - Expanded 124840 -> 501826 (decompressed 401.9 percent)
[00:35:38] Called DecompressByteArray: compressed_data_size=124840 data_size=501826, decompressed_data_size=501826 diff=0
[00:35:38] - Digital signature verified
[00:35:38]
[00:35:38] Project: 7620 (Run 797, Clone 0, Gen 70)
[00:35:38]
[00:35:38] Assembly optimizations on if available.
[00:35:38] Entering M.D.
[00:35:38] Tpr hash work/wudata_01.tpr:  868991297 3210814348 2181615393 3323288864 3358889042
[00:35:38] calling fah_main gpuDeviceId=0
[00:35:38] Working on Protein
[00:35:38] Client config found, loading data.
[00:35:38] Starting GUI Server
[00:35:45] Client no longer detected. Shutting down core
[00:35:45]
[00:35:45] Folding@home Core Shutdown: CLIENT_DIED
[00:52:27] Completed    800000 out of 40000000 steps (2%).
[01:00:16] Completed   1200000 out of 40000000 steps (3%).
[01:08:04] Completed   1600000 out of 40000000 steps (4%).
[01:15:53] Completed   2000000 out of 40000000 steps (5%).
[01:23:41] Completed   2400000 out of 40000000 steps (6%).
[01:31:30] Completed   2800000 out of 40000000 steps (7%).
[01:39:19] Completed   3200000 out of 40000000 steps (8%).
[01:47:07] Completed   3600000 out of 40000000 steps (9%).
[01:54:56] Completed   4000000 out of 40000000 steps (10%).
[02:02:44] Completed   4400000 out of 40000000 steps (11%).
[02:10:33] Completed   4800000 out of 40000000 steps (12%).
[02:18:21] Completed   5200000 out of 40000000 steps (13%).
[02:26:10] Completed   5600000 out of 40000000 steps (14%).
[02:33:59] Completed   6000000 out of 40000000 steps (15%).
[02:41:47] Completed   6400000 out of 40000000 steps (16%).
[02:49:36] Completed   6800000 out of 40000000 steps (17%).
[02:57:24] Completed   7200000 out of 40000000 steps (18%).
[03:05:13] Completed   7600000 out of 40000000 steps (19%).
[03:13:02] Completed   8000000 out of 40000000 steps (20%).
[03:20:50] Completed   8400000 out of 40000000 steps (21%).
[03:28:40] Completed   8800000 out of 40000000 steps (22%).
[03:36:29] Completed   9200000 out of 40000000 steps (23%).
[03:44:18] Completed   9600000 out of 40000000 steps (24%).
[03:52:08] Completed  10000000 out of 40000000 steps (25%).
[04:00:00] Completed  10400000 out of 40000000 steps (26%).
[04:07:52] Completed  10800000 out of 40000000 steps (27%).
[04:15:42] Completed  11200000 out of 40000000 steps (28%).
[04:23:33] Completed  11600000 out of 40000000 steps (29%).
[04:31:22] Completed  12000000 out of 40000000 steps (30%).
[04:39:11] Completed  12400000 out of 40000000 steps (31%).
[04:47:02] Completed  12800000 out of 40000000 steps (32%).
[04:54:51] Completed  13200000 out of 40000000 steps (33%).
[05:02:41] Completed  13600000 out of 40000000 steps (34%).
[05:10:29] Completed  14000000 out of 40000000 steps (35%).
[05:18:17] Completed  14400000 out of 40000000 steps (36%).
[05:26:06] Completed  14800000 out of 40000000 steps (37%).
[05:33:54] Completed  15200000 out of 40000000 steps (38%).
[05:41:43] Completed  15600000 out of 40000000 steps (39%).
[05:49:31] Completed  16000000 out of 40000000 steps (40%).
[05:57:20] Completed  16400000 out of 40000000 steps (41%).
[06:05:09] Completed  16800000 out of 40000000 steps (42%).
[06:12:57] Completed  17200000 out of 40000000 steps (43%).
[06:20:46] Completed  17600000 out of 40000000 steps (44%).
[06:28:35] Completed  18000000 out of 40000000 steps (45%).
[06:35:38] - Autosending finished units... [October 27 06:35:38 UTC]
[06:35:38] Trying to send all finished work units
[06:35:38] + No unsent completed units remaining.
[06:35:38] - Autosend completed
[06:36:23] Completed  18400000 out of 40000000 steps (46%).
[06:44:11] Completed  18800000 out of 40000000 steps (47%).
[06:52:00] Completed  19200000 out of 40000000 steps (48%).
[06:59:48] Completed  19600000 out of 40000000 steps (49%).
[07:07:37] Completed  20000000 out of 40000000 steps (50%).
[07:15:25] Completed  20400000 out of 40000000 steps (51%).
[07:23:14] Completed  20800000 out of 40000000 steps (52%).
[07:31:02] Completed  21200000 out of 40000000 steps (53%).
[07:38:51] Completed  21600000 out of 40000000 steps (54%).
[07:46:40] Completed  22000000 out of 40000000 steps (55%).
[07:54:28] Completed  22400000 out of 40000000 steps (56%).
[08:02:16] Completed  22800000 out of 40000000 steps (57%).
[08:10:05] Completed  23200000 out of 40000000 steps (58%).
[08:17:53] Completed  23600000 out of 40000000 steps (59%).
[08:25:42] Completed  24000000 out of 40000000 steps (60%).
[08:33:30] Completed  24400000 out of 40000000 steps (61%).
[08:41:19] Completed  24800000 out of 40000000 steps (62%).
[08:49:07] Completed  25200000 out of 40000000 steps (63%).
[08:56:56] Completed  25600000 out of 40000000 steps (64%).
[09:04:44] Completed  26000000 out of 40000000 steps (65%).
[09:12:33] Completed  26400000 out of 40000000 steps (66%).
[09:20:21] Completed  26800000 out of 40000000 steps (67%).
[09:28:10] Completed  27200000 out of 40000000 steps (68%).
[09:35:59] Completed  27600000 out of 40000000 steps (69%).
[09:43:47] Completed  28000000 out of 40000000 steps (70%).
[09:51:36] Completed  28400000 out of 40000000 steps (71%).
[09:59:25] Completed  28800000 out of 40000000 steps (72%).
[10:07:13] Completed  29200000 out of 40000000 steps (73%).
[10:15:02] Completed  29600000 out of 40000000 steps (74%).
[10:22:51] Completed  30000000 out of 40000000 steps (75%).
[10:30:39] Completed  30400000 out of 40000000 steps (76%).
[10:38:28] Completed  30800000 out of 40000000 steps (77%).
[10:46:16] Completed  31200000 out of 40000000 steps (78%).
[10:54:05] Completed  31600000 out of 40000000 steps (79%).
[11:01:53] Completed  32000000 out of 40000000 steps (80%).
[11:09:42] Completed  32400000 out of 40000000 steps (81%).
[11:17:31] Completed  32800000 out of 40000000 steps (82%).
[11:25:19] Completed  33200000 out of 40000000 steps (83%).
[11:33:07] Completed  33600000 out of 40000000 steps (84%).
[11:40:56] Completed  34000000 out of 40000000 steps (85%).
[11:48:45] Completed  34400000 out of 40000000 steps (86%).
[11:56:33] Completed  34800000 out of 40000000 steps (87%).
[12:04:22] Completed  35200000 out of 40000000 steps (88%).
[12:12:10] Completed  35600000 out of 40000000 steps (89%).
[12:19:59] Completed  36000000 out of 40000000 steps (90%).
[12:27:47] Completed  36400000 out of 40000000 steps (91%).
[12:35:36] Completed  36800000 out of 40000000 steps (92%).
[12:35:38] - Autosending finished units... [October 27 12:35:38 UTC]
[12:35:38] Trying to send all finished work units
[12:35:38] + No unsent completed units remaining.
[12:35:38] - Autosend completed
[12:43:24] Completed  37200000 out of 40000000 steps (93%).
[12:51:13] Completed  37600000 out of 40000000 steps (94%).
[12:59:01] Completed  38000000 out of 40000000 steps (95%).
[13:06:50] Completed  38400000 out of 40000000 steps (96%).
[13:14:39] Completed  38800000 out of 40000000 steps (97%).
[13:22:27] Completed  39200000 out of 40000000 steps (98%).
[13:30:16] Completed  39600000 out of 40000000 steps (99%).
[13:38:04] Completed  40000000 out of 40000000 steps (100%).
[13:38:05] Finished fah_main status=0
[13:38:05] Successful run
[13:38:05] DynamicWrapper: Finished Work Unit: sleep=10000
[13:38:15] Reserved 762164 bytes for xtc file; Cosm status=0
[13:38:15] Allocated 762164 bytes for xtc file
[13:38:15] - Reading up to 762164 from "work/wudata_01.xtc": Read 762164
[13:38:15] Read 762164 bytes from xtc file; available packet space=785668300
[13:38:15] xtc file hash check passed.
[13:38:15] Reserved 47688 47688 785668300 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[13:38:15] Allocated 47688 bytes for arc file
[13:38:15] - Reading up to 47688 from "work/wudata_01.trr": Read 47688
[13:38:15] Read 47688 bytes from arc file; available packet space=785620612
[13:38:15] trr file hash check passed.
[13:38:15] Allocated 544 bytes for edr file
[13:38:15] Read bedfile
[13:38:15] edr file hash check passed.
[13:38:15] Allocated 36678 bytes for logfile
[13:38:15] Read logfile
[13:38:15] GuardedRun: success in DynamicWrapper
[13:38:15] GuardedRun: done
[13:38:15] Run: GuardedRun completed.
[13:38:17] + Opened results file
[13:38:17] - Writing 847586 bytes of core data to disk...
[13:38:17] Done: 847074 -> 819028 (compressed to 96.6 percent)
[13:38:17]   ... Done.
[13:38:17] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[13:38:17] Shutting down core
[13:38:17]
[13:38:17] Folding@home Core Shutdown: FINISHED_UNIT
[13:38:19] CoreStatus = 64 (100)
[13:38:19] Unit 1 finished with 97 percent of time to deadline remaining.
[13:38:19] Updated performance fraction: 0.969633
[13:38:19] Sending work to server
[13:38:25] Thank you for your contribution to Folding@Home.
[13:38:25] + Number of Units Completed: 45
[13:38:29] Trying to send all finished work units
[13:38:29] + No unsent completed units remaining.
[13:38:29] + -oneunit flag given and have now finished a unit. Exiting.***** Got a SIGTERM signal (2)
[13:38:29] Killing all core threads
kawika57
Post by kawika57 »
I also seem to have lost Project: 7620 (Run 711, Clone 0, Gen 106). Upload with no errors 9:25 am CST.
[19:46:15] Gpu type=3 species=30.
[19:46:15] Work directory not found. Creating...
[19:46:15] Could not open work queue, generating new queue...
[19:46:15] - Preparing to get new work unit...
[19:46:15] Cleaning up work directory
[19:46:15] - Autosending finished units... [October 26 19:46:15 UTC]
[19:46:15] Trying to send all finished work units
[19:46:15] + No unsent completed units remaining.
[19:46:15] + Attempting to get work packet
[19:46:15] - Autosend completed
[19:46:15] Passkey found
[19:46:15] - Will indicate memory of 6134 MB
[19:46:15] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 5
[19:46:15] - Connecting to assignment server
[19:46:15] Connecting to http://assign-GPU.stanford.edu:8080/
[19:46:16] Posted data.
[19:46:16] Initial: 40AB; - Successful: assigned to (171.64.65.105).
[19:46:16] + News From Folding@Home: Welcome to Folding@Home
[19:46:16] Loaded queue successfully.
[19:46:16] Gpu type=3 species=30.
[19:46:16] Sent data
[19:46:16] Connecting to http://171.64.65.105:8080/
[19:46:16] Initial: 0000; - Receiving payload (expected size: 125309)
[19:46:17] - Downloaded at ~122 kB/s
[19:46:17] - Averaged speed for that direction ~122 kB/s
[19:46:17] + Received work.
[19:46:17] + Closed connections
[19:46:17]
[19:46:17] + Processing work unit
[19:46:17] Core required: FahCore_15.exe
[19:46:17] Core found.
[19:46:17] Working on queue slot 01 [October 26 19:46:17 UTC]
[19:46:17] + Working ...
[19:46:17] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 3116 -version 630'
[19:46:17]
[19:46:17] *------------------------------*
[19:46:17] Folding@Home GPU Core
[19:46:17] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[19:46:17] Build host             SimbiosNvdWin7
[19:46:17] Board Type             NVIDIA/CUDA
[19:46:17] Core                   15
[19:46:17]
[19:46:17] Window's signal control handler registered.
[19:46:17] Preparing to commence simulation
[19:46:17] - Looking at optimizations...
[19:46:17] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[19:46:17] - Created dyn
[19:46:17] - Files status OK
[19:46:17] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:46:17] - Expanded 124797 -> 501826 (decompressed 402.1 percent)
[19:46:17] Called DecompressByteArray: compressed_data_size=124797 data_size=501826, decompressed_data_size=501826 diff=0
[19:46:17] - Digital signature verified
[19:46:17]
[19:46:17] Project: 7620 (Run 711, Clone 0, Gen 106)
[19:46:17]
[19:46:17] Assembly optimizations on if available.
[19:46:17] Entering M.D.
[19:46:19] Tpr hash work/wudata_01.tpr:  1961592501 1902935580 1627091491 471109522 642014790
[19:46:19] calling fah_main gpuDeviceId=0
[19:46:20] Working on Protein
[19:46:20] Client config found, loading data.
[19:46:20] Starting GUI Server
[19:47:21] Setting checkpoint frequency: 400000
[19:47:21] Completed         3 out of 40000000 steps (0%).
[19:53:02] Completed    400000 out of 40000000 steps (1%).
[19:58:43] Completed    800000 out of 40000000 steps (2%).
[20:04:24] Completed   1200000 out of 40000000 steps (3%).
[20:10:05] Completed   1600000 out of 40000000 steps (4%).
[20:15:46] Completed   2000000 out of 40000000 steps (5%).
[20:21:28] Completed   2400000 out of 40000000 steps (6%).
[20:27:10] Completed   2800000 out of 40000000 steps (7%).
[20:32:52] Completed   3200000 out of 40000000 steps (8%).
[20:38:33] Completed   3600000 out of 40000000 steps (9%).
[20:44:15] Completed   4000000 out of 40000000 steps (10%).
[20:49:56] Completed   4400000 out of 40000000 steps (11%).
[20:55:38] Completed   4800000 out of 40000000 steps (12%).
[21:01:19] Completed   5200000 out of 40000000 steps (13%).
[21:07:00] Completed   5600000 out of 40000000 steps (14%).
[21:12:41] Completed   6000000 out of 40000000 steps (15%).
[21:18:22] Completed   6400000 out of 40000000 steps (16%).
[21:24:04] Completed   6800000 out of 40000000 steps (17%).
[21:29:47] Completed   7200000 out of 40000000 steps (18%).
[21:35:29] Completed   7600000 out of 40000000 steps (19%).
[21:41:11] Completed   8000000 out of 40000000 steps (20%).
[21:46:54] Completed   8400000 out of 40000000 steps (21%).
[21:50:34] ***** Got a SIGTERM signal (2)
[21:50:34] Killing all core threads
--- Opening Log file [October 27 07:10:31 UTC]
Launch directory: C:\Program Files (x86)\Tracker V2\FAH GPU Tracker V2\GPU0
Executable: C:\Program Files (x86)\Tracker V2\FAH GPU Tracker V2\FAH_GPU3.exe
[07:10:31] - Ask before connecting: No
[07:10:31] - User name: kawika57 (Team 111065)
[07:10:31] - User ID: xxxxxxxxxxxxx
[07:10:31] - Machine ID: 3
[07:10:31]
[07:10:31] Gpu type=3 species=30.
[07:10:31] Loaded queue successfully.
[07:10:31]
[07:10:31] + Processing work unit
[07:10:31] - Autosending finished units... [October 27 07:10:31 UTC]
[07:10:31] Core required: FahCore_15.exe
[07:10:31] Trying to send all finished work units
[07:10:31] + No unsent completed units remaining.
[07:10:31] - Autosend completed
[07:10:31] Core found.
[07:10:31] Working on queue slot 01 [October 27 07:10:31 UTC]
[07:10:31] + Working ...
[07:10:31] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 4700 -version 630'
[07:10:31]
[07:10:31] *------------------------------*
[07:10:31] Folding@Home GPU Core
[07:10:31] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[07:10:31] Build host             SimbiosNvdWin7
[07:10:31] Board Type             NVIDIA/CUDA
[07:10:31] Core                   15
[07:10:31]
[07:10:31] Window's signal control handler registered.
[07:10:31] Preparing to commence simulation
[07:10:31] - Looking at optimizations...
[07:10:31] - Files status OK
[07:10:31] sizeof(CORE_PACKET_HDR) = 512 file=<>
[07:10:31] - Expanded 124797 -> 501826 (decompressed 402.1 percent)
[07:10:31] Called DecompressByteArray: compressed_data_size=124797 data_size=501826, decompressed_data_size=501826 diff=0
[07:10:31] - Digital signature verified
[07:10:31]
[07:10:31] Project: 7620 (Run 711, Clone 0, Gen 106)
[07:10:31]
[07:10:31] Assembly optimizations on if available.
[07:10:31] Entering M.D.
[07:10:33] Will resume from checkpoint file work/wudata_01.ckp
[07:10:33] Tpr hash work/wudata_01.tpr:  1961592501 1902935580 1627091491 471109522 642014790
[07:10:33] calling fah_main gpuDeviceId=0
[07:10:34] Working on Protein
[07:10:34] Client config found, loading data.
[07:10:34] Starting GUI Server
[07:11:36] Resuming from checkpoint
[07:11:36] fcCheckPointResume: retreived and current tpr file hash:
[07:11:36]    0   1961592501   1961592501
[07:11:36]    1   1902935580   1902935580
[07:11:36]    2   1627091491   1627091491
[07:11:36]    3    471109522    471109522
[07:11:36]    4    642014790    642014790
[07:11:36] fcCheckPointResume: file hashes same.
[07:11:36] fcCheckPointResume: state restored.
[07:11:36] fcCheckPointResume: name work/wudata_01.log Verified work/wudata_01.log
[07:11:36] fcCheckPointResume: name work/wudata_01.trr Verified work/wudata_01.trr
[07:11:36] fcCheckPointResume: name work/wudata_01.xtc Verified work/wudata_01.xtc
[07:11:36] fcCheckPointResume: name work/wudata_01.edr Verified work/wudata_01.edr
[07:11:36] fcCheckPointResume: state restored 2
[07:11:36] Resumed from checkpoint
[07:11:36] Setting checkpoint frequency: 400000
[07:11:36] Completed   8400001 out of 40000000 steps (21%).
[07:16:21] Completed   8800000 out of 40000000 steps (22%).
[07:21:07] Completed   9200000 out of 40000000 steps (23%).
[07:25:53] Completed   9600000 out of 40000000 steps (24%).
[07:30:38] Completed  10000000 out of 40000000 steps (25%).
[07:35:24] Completed  10400000 out of 40000000 steps (26%).
[07:40:10] Completed  10800000 out of 40000000 steps (27%).
[07:44:55] Completed  11200000 out of 40000000 steps (28%).
[07:49:41] Completed  11600000 out of 40000000 steps (29%).
[07:54:26] Completed  12000000 out of 40000000 steps (30%).
[07:59:12] Completed  12400000 out of 40000000 steps (31%).
[08:03:58] Completed  12800000 out of 40000000 steps (32%).
[08:08:44] Completed  13200000 out of 40000000 steps (33%).
[08:13:29] Completed  13600000 out of 40000000 steps (34%).
[08:18:15] Completed  14000000 out of 40000000 steps (35%).
[08:23:00] Completed  14400000 out of 40000000 steps (36%).
[08:27:46] Completed  14800000 out of 40000000 steps (37%).
[08:32:32] Completed  15200000 out of 40000000 steps (38%).
[08:37:38] Completed  15600000 out of 40000000 steps (39%).
[08:43:20] Completed  16000000 out of 40000000 steps (40%).
[08:49:02] Completed  16400000 out of 40000000 steps (41%).
[08:54:44] Completed  16800000 out of 40000000 steps (42%).
[09:00:26] Completed  17200000 out of 40000000 steps (43%).
[09:06:08] Completed  17600000 out of 40000000 steps (44%).
[09:11:50] Completed  18000000 out of 40000000 steps (45%).
[09:17:32] Completed  18400000 out of 40000000 steps (46%).
[09:23:13] Completed  18800000 out of 40000000 steps (47%).
[09:28:55] Completed  19200000 out of 40000000 steps (48%).
[09:34:36] Completed  19600000 out of 40000000 steps (49%).
[09:40:17] Completed  20000000 out of 40000000 steps (50%).
[09:45:58] Completed  20400000 out of 40000000 steps (51%).
[09:51:39] Completed  20800000 out of 40000000 steps (52%).
[09:57:20] Completed  21200000 out of 40000000 steps (53%).
[10:03:01] Completed  21600000 out of 40000000 steps (54%).
[10:08:42] Completed  22000000 out of 40000000 steps (55%).
[10:14:24] Completed  22400000 out of 40000000 steps (56%).
[10:20:05] Completed  22800000 out of 40000000 steps (57%).
[10:25:46] Completed  23200000 out of 40000000 steps (58%).
[10:31:27] Completed  23600000 out of 40000000 steps (59%).
[10:37:08] Completed  24000000 out of 40000000 steps (60%).
[10:42:49] Completed  24400000 out of 40000000 steps (61%).
[10:48:30] Completed  24800000 out of 40000000 steps (62%).
[10:54:11] Completed  25200000 out of 40000000 steps (63%).
[10:59:52] Completed  25600000 out of 40000000 steps (64%).
[11:05:33] Completed  26000000 out of 40000000 steps (65%).
[11:11:15] Completed  26400000 out of 40000000 steps (66%).
[11:16:56] Completed  26800000 out of 40000000 steps (67%).
[11:22:37] Completed  27200000 out of 40000000 steps (68%).
[11:28:18] Completed  27600000 out of 40000000 steps (69%).
[11:33:59] Completed  28000000 out of 40000000 steps (70%).
[11:39:40] Completed  28400000 out of 40000000 steps (71%).
[11:45:21] Completed  28800000 out of 40000000 steps (72%).
[11:51:02] Completed  29200000 out of 40000000 steps (73%).
[11:56:43] Completed  29600000 out of 40000000 steps (74%).
[12:02:24] Completed  30000000 out of 40000000 steps (75%).
[12:08:05] Completed  30400000 out of 40000000 steps (76%).
[12:13:47] Completed  30800000 out of 40000000 steps (77%).
[12:19:28] Completed  31200000 out of 40000000 steps (78%).
[12:25:09] Completed  31600000 out of 40000000 steps (79%).
[12:30:50] Completed  32000000 out of 40000000 steps (80%).
[12:36:31] Completed  32400000 out of 40000000 steps (81%).
[12:42:12] Completed  32800000 out of 40000000 steps (82%).
[12:47:53] Completed  33200000 out of 40000000 steps (83%).
[12:53:34] Completed  33600000 out of 40000000 steps (84%).
[12:59:16] Completed  34000000 out of 40000000 steps (85%).
[13:04:57] Completed  34400000 out of 40000000 steps (86%).
[13:10:31] - Autosending finished units... [October 27 13:10:31 UTC]
[13:10:31] Trying to send all finished work units
[13:10:31] + No unsent completed units remaining.
[13:10:31] - Autosend completed
[13:10:38] Completed  34800000 out of 40000000 steps (87%).
[13:16:19] Completed  35200000 out of 40000000 steps (88%).
[13:22:00] Completed  35600000 out of 40000000 steps (89%).
[13:27:41] Completed  36000000 out of 40000000 steps (90%).
[13:33:22] Completed  36400000 out of 40000000 steps (91%).
[13:39:03] Completed  36800000 out of 40000000 steps (92%).
[13:44:44] Completed  37200000 out of 40000000 steps (93%).
[13:50:26] Completed  37600000 out of 40000000 steps (94%).
[13:56:07] Completed  38000000 out of 40000000 steps (95%).
[14:01:48] Completed  38400000 out of 40000000 steps (96%).
[14:07:29] Completed  38800000 out of 40000000 steps (97%).
[14:13:10] Completed  39200000 out of 40000000 steps (98%).
[14:18:51] Completed  39600000 out of 40000000 steps (99%).
[14:24:32] Completed  40000000 out of 40000000 steps (100%).
[14:24:33] Finished fah_main status=0
[14:24:33] Successful run
[14:24:33] DynamicWrapper: Finished Work Unit: sleep=10000
[14:24:43] Reserved 759532 bytes for xtc file; Cosm status=0
[14:24:43] Allocated 759532 bytes for xtc file
[14:24:43] - Reading up to 759532 from "work/wudata_01.xtc": Read 759532
[14:24:43] Read 759532 bytes from xtc file; available packet space=785670932
[14:24:43] xtc file hash check passed.
[14:24:43] Reserved 47688 47688 785670932 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[14:24:43] Allocated 47688 bytes for arc file
[14:24:43] - Reading up to 47688 from "work/wudata_01.trr": Read 47688
[14:24:43] Read 47688 bytes from arc file; available packet space=785623244
[14:24:43] trr file hash check passed.
[14:24:43] Allocated 544 bytes for edr file
[14:24:43] Read bedfile
[14:24:43] edr file hash check passed.
[14:24:43] Allocated 36879 bytes for logfile
[14:24:43] Read logfile
[14:24:43] GuardedRun: success in DynamicWrapper
[14:24:43] GuardedRun: done
[14:24:43] Run: GuardedRun completed.
[14:24:43] + Opened results file
[14:24:43] - Writing 845155 bytes of core data to disk...
[14:24:43] Done: 844643 -> 816409 (compressed to 96.6 percent)
[14:24:43]   ... Done.
[14:24:43] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[14:24:43] Shutting down core
[14:24:43]
[14:24:43] Folding@home Core Shutdown: FINISHED_UNIT
[14:24:47] CoreStatus = 64 (100)
[14:24:47] Unit 1 finished with 96 percent of time to deadline remaining.
[14:24:47] Updated performance fraction: 0.956607
[14:24:47] Sending work to server
[14:24:47] Project: 7620 (Run 711, Clone 0, Gen 106)
[14:24:47] - Read packet limit of 540015616... Set to 524286976.
[14:24:47] + Attempting to send results [October 27 14:24:47 UTC]
[14:24:47] - Reading file work/wuresults_01.dat from core
[14:24:47]   (Read 816921 bytes from disk)
[14:24:47] Gpu type=3 species=30.
[14:24:47] Connecting to http://171.64.65.105:8080/
[14:24:57] Posted data.
[14:24:57] Initial: 0000; - Uploaded at ~79 kB/s
[14:24:57] - Averaged speed for that direction ~79 kB/s
[14:24:57] + Results successfully sent
[14:24:57] Thank you for your contribution to Folding@Home.
[14:24:57] + Number of Units Completed: 14
[14:25:01] Trying to send all finished work units
[14:25:01] + No unsent completed units remaining.
[14:25:01] + -oneunit flag given and have now finished a unit. Exiting.***** Got a SIGTERM signal (2)
[14:25:01] Killing all core threads
tjlane
Pande Group Member
Post by tjlane »
Hmmm, no conclusions yet. I will continue to search in the morning.
If you're reading this and are having issues with p7620 or p7621 points, please post here.
Also, if you've successfully received credit for these units since the OP, a post would be great so we know if this is limited or wide-spread
Sorry to any who are losing credit... I will do my best to remedy the situation over here at Stanford.
kawika57
Post by kawika57 »
I have successfully completed a 76xx unit after having the unit in question go missing. These units were processed on a different machine. Sequence went like this Rig 1 completed and credited. Rig 2 completed not credited. Rig 1 completed and credited.
VijayPande
Pande Group Member
Re: Post issues with Project 7620 or 7621 points here
Post by VijayPande »
Thanks for your posts. There was one stats update which doesn't have a record on the stats server, but is on the WS. We've run a manual recredit for it. All the WUs above were in that update.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
