My User Stats and Team Stats arent being updated
Fozzy5000
- Hardware configuration: PS3, HP AMD Phenom IIX6 1045T Processor 2.70 8.00 GB Ram 64-Bit operating system
I have the Folding home software installed on my pc and my ps3, I used the same username which is Brian_Coleman_Chwaszczewski and my team number is 160131. My stats are only updated from my ps3, My pc is downloading for days and my clients downloaded has not gone up from 7 even though it has downloaded quite a bit.
sortofageek
Re: My User Stats and Team Stats arent being updated
Hello Fozzy5000 and welcome to the Folding@Home Support site.
Please locate the FAHlog.txt file in the FAH folder on your PC and paste it in a message here (enclosed in code tags). That might help someone discover the problem.
Zagen30
Let me give you a quick rundown on how F@h works since you seem to have gotten some of the terminology mixed up.
The client is the software that runs the whole process. The client downloads a core, which is the scientific software that does the actual calculations. When it has the right core, it then proceeds to download a Work Unit, which is the folding simulation that will be run. The WU gets crunched for some amount of time; this varies based on hardware, client type, etc. When the WU is finished, it's uploaded, credited to your account, and another WU is downloaded. The download and upload don't take very much time, and the client does not actively download anything when the WU is being processed. The stats are not updated with respect to a specific WU until it is returned.
I took a look at your stats page and you now have 8 WUs completed. I assume before you only had 7. The PS3 client usually finishes WUs in 6-8 hours of continuous folding, while CPU WUs can take multiple days depending on the hardware involved. What CPU do you have? It should be noted that if you installed client version 6.23 you're working on what are termed uniprocessor WUs; these only use one core of your CPU regardless of how many cores it has, and as a result they are rarely completed all that quickly.
To support the information mentioned above, your most recent WU from a PC client for Brian_Coleman_Chwaszczewski (team 160131) is WU (P7808 R9 C213 G3) and it was added to the stats database on 2011-10-25 09:47:23 for 1698.09 points of credit.
It took 6.44 days to complete this WU so it's simply not possible that your client has been downloading more WUs during that 6.44 days unless somehow you're running multiple PC clients. When you post the log, that will be apparent.
What kind of CPU does your PC have?
sortofageek
Thanks for posting that, Bruce. The WU from the PC wasn't there when I checked earlier this morning, but it may be Brian has only actually completed one WU on the PC so far.
Fozzy5000
My Computer is a Hewlett- Packard HPE-500y, my processor is an AMD Phenom II X6 1045T Processor 2.70 GHz, with 8.00 Gigs of ram.
--- Opening Log file [October 19 06:09:14 UTC]
# Windows CPU Systray Edition #################################################
http://folding.stanford.edu
Launch directory: C:\Users\Fozzy5000\AppData\Roaming\Folding@home-x86
[06:10:20] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=160131...
[06:10:45] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Brian_Coleman_Chwaszczewski...
[06:11:02] - Ask before connecting: No
[06:11:02] - User name: Brian_Coleman_Chwaszczewski (Team 160131)
[06:11:02] - User ID not found locally
[06:11:02] + Requesting User ID from server
[06:11:03] - Machine ID: 1
[06:11:03]
[06:11:03] Work directory not found. Creating...
[06:11:03] Could not open work queue, generating new queue...
[06:11:03] Initialization complete
[06:11:03] - Preparing to get new work unit...
[06:11:03] + Attempting to get work packet
[06:11:03] - Connecting to assignment server
[06:11:04] - Successful: assigned to (171.64.65.99).
[06:11:04] + News From Folding@Home: Welcome to Folding@Home
[06:11:04] Loaded queue successfully.
[06:11:10] + Closed connections
[06:11:10]
[06:11:10] + Processing work unit
[06:11:10] Core required: FahCore_a4.exe
[06:11:10] Core not found.
[06:11:10] - Core is not present or corrupted.
[06:11:10] - Attempting to download new core...
[06:11:10] + Downloading new core: FahCore_a4.exe
[06:11:10] + 10240 bytes downloaded
[06:11:10] + 20480 bytes downloaded
[06:11:10] + 30720 bytes downloaded
[06:11:10] + 40960 bytes downloaded
[06:11:10] + 51200 bytes downloaded
[06:11:10] + 61440 bytes downloaded
[06:11:10] + 71680 bytes downloaded
[06:11:10] + 81920 bytes downloaded
[06:11:10] + 92160 bytes downloaded
[06:11:10] + 102400 bytes downloaded
[06:11:10] + 112640 bytes downloaded
[06:11:10] + 122880 bytes downloaded
[06:11:10] + 133120 bytes downloaded
[06:11:10] + 143360 bytes downloaded
[06:11:10] + 153600 bytes downloaded
[06:11:10] + 163840 bytes downloaded
[06:11:10] + 174080 bytes downloaded
[06:11:10] + 184320 bytes downloaded
[06:11:10] + 194560 bytes downloaded
[06:11:10] + 204800 bytes downloaded
[06:11:10] + 215040 bytes downloaded
[06:11:10] + 225280 bytes downloaded
[06:11:10] + 235520 bytes downloaded
[06:11:10] + 245760 bytes downloaded
[06:11:10] + 256000 bytes downloaded
[06:11:10] + 266240 bytes downloaded
[06:11:10] + 276480 bytes downloaded
[06:11:10] + 286720 bytes downloaded
[06:11:11] + 296960 bytes downloaded
[06:11:11] + 307200 bytes downloaded
[06:11:11] + 317440 bytes downloaded
[06:11:11] + 327680 bytes downloaded
[06:11:11] + 337920 bytes downloaded
[06:11:11] + 348160 bytes downloaded
[06:11:11] + 358400 bytes downloaded
[06:11:11] + 368640 bytes downloaded
[06:11:11] + 378880 bytes downloaded
[06:11:11] + 389120 bytes downloaded
[06:11:11] + 399360 bytes downloaded
[06:11:11] + 409600 bytes downloaded
[06:11:11] + 419840 bytes downloaded
[06:11:11] + 430080 bytes downloaded
[06:11:11] + 440320 bytes downloaded
[06:11:11] + 450560 bytes downloaded
[06:11:11] + 460800 bytes downloaded
[06:11:11] + 471040 bytes downloaded
[06:11:11] + 481280 bytes downloaded
[06:11:11] + 491520 bytes downloaded
[06:11:11] + 501760 bytes downloaded
[06:11:11] + 512000 bytes downloaded
[06:11:11] + 522240 bytes downloaded
[06:11:11] + 532480 bytes downloaded
[06:11:11] + 542720 bytes downloaded
[06:11:11] + 552960 bytes downloaded
[06:11:11] + 563200 bytes downloaded
[06:11:11] + 573440 bytes downloaded
[06:11:11] + 583680 bytes downloaded
[06:11:11] + 593920 bytes downloaded
[06:11:11] + 604160 bytes downloaded
[06:11:11] + 614400 bytes downloaded
[06:11:11] + 624640 bytes downloaded
[06:11:11] + 634880 bytes downloaded
[06:11:11] + 645120 bytes downloaded
[06:11:11] + 655360 bytes downloaded
[06:11:11] + 665600 bytes downloaded
[06:11:11] + 675840 bytes downloaded
[06:11:11] + 686080 bytes downloaded
[06:11:12] + 696320 bytes downloaded
[06:11:12] + 706560 bytes downloaded
[06:11:12] + 716800 bytes downloaded
[06:11:12] + 727040 bytes downloaded
[06:11:12] + 737280 bytes downloaded
[06:11:12] + 747520 bytes downloaded
[06:11:12] + 757760 bytes downloaded
[06:11:12] + 768000 bytes downloaded
[06:11:12] + 778240 bytes downloaded
[06:11:12] + 788480 bytes downloaded
[06:11:12] + 798720 bytes downloaded
[06:11:12] + 808960 bytes downloaded
[06:11:12] + 819200 bytes downloaded
[06:11:12] + 829440 bytes downloaded
[06:11:12] + 839680 bytes downloaded
[06:11:12] + 849920 bytes downloaded
[06:11:12] + 860160 bytes downloaded
[06:11:12] + 870400 bytes downloaded
[06:11:12] + 880640 bytes downloaded
[06:11:12] + 890880 bytes downloaded
[06:11:12] + 901120 bytes downloaded
[06:11:12] + 911360 bytes downloaded
[06:11:12] + 921600 bytes downloaded
[06:11:12] + 931840 bytes downloaded
[06:11:12] + 942080 bytes downloaded
[06:11:12] + 952320 bytes downloaded
[06:11:12] + 962560 bytes downloaded
[06:11:12] + 972800 bytes downloaded
[06:11:12] + 983040 bytes downloaded
[06:11:12] + 993280 bytes downloaded
[06:11:12] + 1003520 bytes downloaded
[06:11:12] + 1013760 bytes downloaded
[06:11:12] + 1024000 bytes downloaded
[06:11:12] + 1034240 bytes downloaded
[06:11:12] + 1044480 bytes downloaded
[06:11:12] + 1054720 bytes downloaded
[06:11:12] + 1064960 bytes downloaded
[06:11:12] + 1075200 bytes downloaded
[06:11:12] + 1085440 bytes downloaded
[06:11:12] + 1095680 bytes downloaded
[06:11:13] + 1105920 bytes downloaded
[06:11:13] + 1116160 bytes downloaded
[06:11:13] + 1126400 bytes downloaded
[06:11:13] + 1136640 bytes downloaded
[06:11:13] + 1146880 bytes downloaded
[06:11:13] + 1157120 bytes downloaded
[06:11:13] + 1167360 bytes downloaded
[06:11:13] + 1177600 bytes downloaded
[06:11:13] + 1187840 bytes downloaded
[06:11:13] + 1198080 bytes downloaded
[06:11:13] + 1208320 bytes downloaded
[06:11:13] + 1218560 bytes downloaded
[06:11:13] + 1228800 bytes downloaded
[06:11:13] + 1239040 bytes downloaded
[06:11:13] + 1249280 bytes downloaded
[06:11:13] + 1259520 bytes downloaded
[06:11:13] + 1269760 bytes downloaded
[06:11:13] + 1280000 bytes downloaded
[06:11:13] + 1290240 bytes downloaded
[06:11:13] + 1300480 bytes downloaded
[06:11:13] + 1310720 bytes downloaded
[06:11:13] + 1320960 bytes downloaded
[06:11:13] + 1331200 bytes downloaded
[06:11:13] + 1341440 bytes downloaded
[06:11:13] + 1351680 bytes downloaded
[06:11:13] + 1361920 bytes downloaded
[06:11:13] + 1372160 bytes downloaded
[06:11:13] + 1382400 bytes downloaded
[06:11:13] + 1392640 bytes downloaded
[06:11:13] + 1402880 bytes downloaded
[06:11:13] + 1413120 bytes downloaded
[06:11:13] + 1423360 bytes downloaded
[06:11:13] + 1433600 bytes downloaded
[06:11:13] + 1443840 bytes downloaded
[06:11:13] + 1454080 bytes downloaded
[06:11:13] + 1464320 bytes downloaded
[06:11:14] + 1474560 bytes downloaded
[06:11:14] + 1484800 bytes downloaded
[06:11:14] + 1495040 bytes downloaded
[06:11:14] + 1505280 bytes downloaded
[06:11:14] + 1515520 bytes downloaded
[06:11:14] + 1525760 bytes downloaded
[06:11:14] + 1536000 bytes downloaded
[06:11:14] + 1546240 bytes downloaded
[06:11:14] + 1556480 bytes downloaded
[06:11:14] + 1566720 bytes downloaded
[06:11:14] + 1576960 bytes downloaded
[06:11:14] + 1587200 bytes downloaded
[06:11:14] + 1597440 bytes downloaded
[06:11:14] + 1607680 bytes downloaded
[06:11:14] + 1617920 bytes downloaded
[06:11:14] + 1628160 bytes downloaded
[06:11:14] + 1638400 bytes downloaded
[06:11:14] + 1648640 bytes downloaded
[06:11:14] + 1658880 bytes downloaded
[06:11:14] + 1669120 bytes downloaded
[06:11:14] + 1679360 bytes downloaded
[06:11:14] + 1689600 bytes downloaded
[06:11:14] + 1699840 bytes downloaded
[06:11:14] + 1710080 bytes downloaded
[06:11:14] + 1720320 bytes downloaded
[06:11:14] + 1730560 bytes downloaded
[06:11:14] + 1740800 bytes downloaded
[06:11:14] + 1751040 bytes downloaded
[06:11:14] + 1761280 bytes downloaded
[06:11:14] + 1771520 bytes downloaded
[06:11:14] + 1781760 bytes downloaded
[06:11:14] + 1792000 bytes downloaded
[06:11:14] + 1802240 bytes downloaded
[06:11:14] + 1812480 bytes downloaded
[06:11:14] + 1822720 bytes downloaded
[06:11:14] + 1832960 bytes downloaded
[06:11:14] + 1843200 bytes downloaded
[06:11:14] + 1853440 bytes downloaded
[06:11:15] + 1863680 bytes downloaded
[06:11:15] + 1873920 bytes downloaded
[06:11:15] + 1884160 bytes downloaded
[06:11:15] + 1894400 bytes downloaded
[06:11:15] + 1904640 bytes downloaded
[06:11:15] + 1914880 bytes downloaded
[06:11:15] + 1925120 bytes downloaded
[06:11:15] + 1935360 bytes downloaded
[06:11:15] + 1945600 bytes downloaded
[06:11:15] + 1955840 bytes downloaded
[06:11:15] + 1966080 bytes downloaded
[06:11:15] + 1976320 bytes downloaded
[06:11:15] + 1986560 bytes downloaded
[06:11:15] + 1996800 bytes downloaded
[06:11:15] + 2007040 bytes downloaded
[06:11:15] + 2017280 bytes downloaded
[06:11:15] + 2027520 bytes downloaded
[06:11:15] + 2037760 bytes downloaded
[06:11:15] + 2048000 bytes downloaded
[06:11:15] + 2058240 bytes downloaded
[06:11:15] + 2068480 bytes downloaded
[06:11:15] + 2078720 bytes downloaded
[06:11:15] + 2088960 bytes downloaded
[06:11:15] + 2099200 bytes downloaded
[06:11:15] + 2109440 bytes downloaded
[06:11:15] + 2119680 bytes downloaded
[06:11:15] + 2129920 bytes downloaded
[06:11:15] + 2140160 bytes downloaded
[06:11:15] + 2150400 bytes downloaded
[06:11:15] + 2160640 bytes downloaded
[06:11:15] + 2170880 bytes downloaded
[06:11:15] + 2181120 bytes downloaded
[06:11:15] + 2191360 bytes downloaded
[06:11:15] + 2201600 bytes downloaded
[06:11:15] + 2211840 bytes downloaded
[06:11:15] + 2222080 bytes downloaded
[06:11:15] + 2232320 bytes downloaded
[06:11:15] + 2242560 bytes downloaded
[06:11:15] + 2252800 bytes downloaded
[06:11:15] + 2263040 bytes downloaded
[06:11:15] + 2273280 bytes downloaded
[06:11:16] + 2283520 bytes downloaded
[06:11:16] + 2293760 bytes downloaded
[06:11:16] + 2304000 bytes downloaded
[06:11:16] + 2314240 bytes downloaded
[06:11:16] + 2324480 bytes downloaded
[06:11:16] + 2334720 bytes downloaded
[06:11:16] + 2344960 bytes downloaded
[06:11:16] + 2355200 bytes downloaded
[06:11:16] + 2365440 bytes downloaded
[06:11:16] + 2375680 bytes downloaded
[06:11:16] + 2385920 bytes downloaded
[06:11:16] + 2396160 bytes downloaded
[06:11:16] + 2406400 bytes downloaded
[06:11:16] + 2416640 bytes downloaded
[06:11:16] + 2426880 bytes downloaded
[06:11:16] + 2437120 bytes downloaded
[06:11:16] + 2447360 bytes downloaded
[06:11:16] + 2457600 bytes downloaded
[06:11:16] + 2467840 bytes downloaded
[06:11:16] + 2478080 bytes downloaded
[06:11:16] + 2488320 bytes downloaded
[06:11:16] + 2498560 bytes downloaded
[06:11:16] + 2508800 bytes downloaded
[06:11:16] + 2519040 bytes downloaded
[06:11:16] + 2529280 bytes downloaded
[06:11:16] + 2539520 bytes downloaded
[06:11:16] + 2549760 bytes downloaded
[06:11:16] + 2560000 bytes downloaded
[06:11:16] + 2570240 bytes downloaded
[06:11:16] + 2580480 bytes downloaded
[06:11:16] + 2590720 bytes downloaded
[06:11:16] + 2600960 bytes downloaded
[06:11:16] + 2611200 bytes downloaded
[06:11:16] + 2621440 bytes downloaded
[06:11:16] + 2631680 bytes downloaded
[06:11:16] + 2641920 bytes downloaded
[06:11:16] + 2652160 bytes downloaded
[06:11:16] + 2662400 bytes downloaded
[06:11:16] + 2672640 bytes downloaded
[06:11:16] + 2682880 bytes downloaded
[06:11:16] + 2693120 bytes downloaded
[06:11:17] + 2703360 bytes downloaded
[06:11:17] + 2713600 bytes downloaded
[06:11:17] + 2723840 bytes downloaded
[06:11:17] + 2734080 bytes downloaded
[06:11:17] + 2744320 bytes downloaded
[06:11:17] + 2754560 bytes downloaded
[06:11:17] + 2764800 bytes downloaded
[06:11:17] + 2775040 bytes downloaded
[06:11:17] + 2785280 bytes downloaded
[06:11:17] + 2795520 bytes downloaded
[06:11:17] + 2805760 bytes downloaded
[06:11:17] + 2816000 bytes downloaded
[06:11:17] + 2826240 bytes downloaded
[06:11:17] + 2836480 bytes downloaded
[06:11:17] + 2846720 bytes downloaded
[06:11:17] + 2856960 bytes downloaded
[06:11:17] + 2867200 bytes downloaded
[06:11:17] + 2877440 bytes downloaded
[06:11:17] + 2887680 bytes downloaded
[06:11:17] + 2897920 bytes downloaded
[06:11:17] + 2908160 bytes downloaded
[06:11:17] + 2918400 bytes downloaded
[06:11:17] + 2928640 bytes downloaded
[06:11:17] + 2938880 bytes downloaded
[06:11:17] + 2949120 bytes downloaded
[06:11:17] + 2959360 bytes downloaded
[06:11:17] + 2969600 bytes downloaded
[06:11:17] + 2979840 bytes downloaded
[06:11:17] + 2990080 bytes downloaded
[06:11:17] + 3000320 bytes downloaded
[06:11:17] + 3010560 bytes downloaded
[06:11:17] + 3020800 bytes downloaded
[06:11:17] + 3028899 bytes downloaded
[06:11:17] Verifying core Core_a4.fah...
[06:11:17] Signature is VALID
[06:11:17]
[06:11:17] Trying to unzip core FahCore_a4.exe
[06:11:19] Decompressed FahCore_a4.exe (10057216 bytes) successfully
[06:11:24] + Core successfully engaged
[06:11:30]
[06:11:30] + Processing work unit
[06:11:30] Core required: FahCore_a4.exe
[06:11:30] Core found.
[06:11:30] Working on queue slot 01 [October 19 06:11:30 UTC]
[06:11:30] + Working ...
[06:11:30]
[06:11:30] *------------------------------*
[06:11:30] Folding@Home Gromacs GB Core
[06:11:30] Version 2.27 (Dec. 15, 2010)
[06:11:30]
[06:11:30] Preparing to commence simulation
[06:11:30] - Looking at optimizations...
[06:11:30] - Created dyn
[06:11:30] - Files status OK
[06:11:31] - Expanded 2053835 -> 5365960 (decompressed 261.2 percent)
[06:11:31] Called DecompressByteArray: compressed_data_size=2053835 data_size=5365960, decompressed_data_size=5365960 diff=0
[06:11:31] - Digital signature verified
[06:11:31]
[06:11:31] Project: 7808 (Run 9, Clone 213, Gen 3)
[06:11:31]
[06:11:31] Assembly optimizations on if available.
[06:11:31] Entering M.D.
[06:11:37] Mapping NT from 1 to 1
[06:11:38] Completed 0 out of 1500000 steps (0%)
--- Opening Log file [October 19 06:15:47 UTC]
[06:15:47] - Ask before connecting: No
[06:15:47] - User name: Brian_Coleman_Chwaszczewski (Team 160131)
[06:15:47] - User ID: 660A645F54FA9D78
[06:15:47] - Machine ID: 1
[06:15:47]
[06:15:47] Loaded queue successfully.
[06:15:47] Initialization complete
[06:15:47]
[06:15:47] + Processing work unit
[06:15:47] Core required: FahCore_a4.exe
[06:15:47] Core found.
[06:15:47] Working on queue slot 01 [October 19 06:15:47 UTC]
[06:15:47] + Working ...
[06:15:47]
[06:15:47] *------------------------------*
[06:15:47] Folding@Home Gromacs GB Core
[06:15:47] Version 2.27 (Dec. 15, 2010)
[06:15:47]
[06:15:47] Preparing to commence simulation
[06:15:47] - Ensuring status. Please wait.
[06:15:57] - Looking at optimizations...
[06:15:57] - Working with standard loops on this execution.
[06:15:57] - Previous termination of core was improper.
[06:15:57] - Files status OK
[06:15:57] - Expanded 2053835 -> 5365960 (decompressed 261.2 percent)
[06:15:57] Called DecompressByteArray: compressed_data_size=2053835 data_size=5365960, decompressed_data_size=5365960 diff=0
[06:15:57] - Digital signature verified
[06:15:57]
[06:15:57] Project: 7808 (Run 9, Clone 213, Gen 3)
[06:15:57]
[06:15:57] Entering M.D.
[06:16:04] Mapping NT from 1 to 1
[06:16:05] Completed 0 out of 1500000 steps (0%)
[06:16:57] Opening C:\Users\Fozzy5000\AppData\Roaming\Folding@home-x86\MyFolding.html...
[07:58:33] Completed 15000 out of 1500000 steps (1%)
[08:33:15] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Brian_Coleman_Chwaszczewski...
[08:45:14] Opening C:\Users\Fozzy5000\AppData\Roaming\Folding@home-x86\MyFolding.html...
[09:13:13] Completed 30000 out of 1500000 steps (2%)
[10:26:34] Completed 45000 out of 1500000 steps (3%)
[11:39:53] Completed 60000 out of 1500000 steps (4%)
[12:15:47] + Working...
[12:53:12] Completed 75000 out of 1500000 steps (5%)
[14:06:33] Completed 90000 out of 1500000 steps (6%)
[15:19:55] Completed 105000 out of 1500000 steps (7%)
[16:33:17] Completed 120000 out of 1500000 steps (8%)
[17:46:39] Completed 135000 out of 1500000 steps (9%)
[18:15:47] + Working...
[18:59:58] Completed 150000 out of 1500000 steps (10%)
[20:13:26] Completed 165000 out of 1500000 steps (11%)
[21:26:54] Completed 180000 out of 1500000 steps (12%)
[22:40:24] Completed 195000 out of 1500000 steps (13%)
[23:53:51] Completed 210000 out of 1500000 steps (14%)
[00:15:47] + Working...
[01:07:19] Completed 225000 out of 1500000 steps (15%)
[02:20:46] Completed 240000 out of 1500000 steps (16%)
[03:34:11] Completed 255000 out of 1500000 steps (17%)
[04:47:35] Completed 270000 out of 1500000 steps (18%)
[05:33:50] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Brian_Coleman_Chwaszczewski...
[06:01:01] Completed 285000 out of 1500000 steps (19%)
--- Opening Log file [October 21 09:03:03 UTC]
[09:03:03] - Ask before connecting: No
[09:03:03] - User name: Brian_Coleman_Chwaszczewski (Team 160131)
[09:03:03] - User ID: 660A645F54FA9D78
[09:03:03] - Machine ID: 1
[09:03:03]
[09:03:03] Loaded queue successfully.
[09:03:03] Initialization complete
[09:03:03]
[09:03:03] + Processing work unit
[09:03:03] Core required: FahCore_a4.exe
[09:03:03] Core found.
[09:03:03] Working on queue slot 01 [October 21 09:03:03 UTC]
[09:03:03] + Working ...
[09:03:03]
[09:03:03] *------------------------------*
[09:03:03] Folding@Home Gromacs GB Core
[09:03:03] Version 2.27 (Dec. 15, 2010)
[09:03:03]
[09:03:03] Preparing to commence simulation
[09:03:03] - Ensuring status. Please wait.
[09:03:13] - Looking at optimizations...
[09:03:13] - Working with standard loops on this execution.
[09:03:13] - Previous termination of core was improper.
[09:03:13] - Going to use standard loops.
[09:03:13] - Files status OK
[09:03:14] - Expanded 2053835 -> 5365960 (decompressed 261.2 percent)
[09:03:14] Called DecompressByteArray: compressed_data_size=2053835 data_size=5365960, decompressed_data_size=5365960 diff=0
[09:03:14] - Digital signature verified
[09:03:14]
[09:03:14] Project: 7808 (Run 9, Clone 213, Gen 3)
[09:03:14]
[09:03:14] Entering M.D.
[09:03:16] Opening C:\Users\Fozzy5000\AppData\Roaming\Folding@home-x86\MyFolding.html...
[09:03:19] Using Gromacs checkpoints
[09:03:20] Mapping NT from 1 to 1
[09:03:21] Resuming from checkpoint
[09:03:21] Verified work/wudata_01.log
[09:03:21] Verified work/wudata_01.trr
[09:03:21] Verified work/wudata_01.xtc
[09:03:21] Verified work/wudata_01.edr
[09:03:21] Completed 285010 out of 1500000 steps (19%)
[09:03:33] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Brian_Coleman_Chwaszczewski...
[10:17:09] Completed 300000 out of 1500000 steps (20%)
[11:30:45] Completed 315000 out of 1500000 steps (21%)
[12:44:17] Completed 330000 out of 1500000 steps (22%)
[13:57:49] Completed 345000 out of 1500000 steps (23%)
[15:03:03] + Working...
[15:11:22] Completed 360000 out of 1500000 steps (24%)
[16:24:53] Completed 375000 out of 1500000 steps (25%)
[17:38:25] Completed 390000 out of 1500000 steps (26%)
[18:51:51] Completed 405000 out of 1500000 steps (27%)
[20:05:12] Completed 420000 out of 1500000 steps (28%)
[21:03:03] + Working...
[21:18:42] Completed 435000 out of 1500000 steps (29%)
[22:32:09] Completed 450000 out of 1500000 steps (30%)
[23:45:41] Completed 465000 out of 1500000 steps (31%)
[00:59:11] Completed 480000 out of 1500000 steps (32%)
[02:12:40] Completed 495000 out of 1500000 steps (33%)
[03:03:03] + Working...
[03:26:10] Completed 510000 out of 1500000 steps (34%)
[04:39:39] Completed 525000 out of 1500000 steps (35%)
[05:53:09] Completed 540000 out of 1500000 steps (36%)
[07:06:37] Completed 555000 out of 1500000 steps (37%)
[08:20:08] Completed 570000 out of 1500000 steps (38%)
[09:03:03] + Working...
[09:33:37] Completed 585000 out of 1500000 steps (39%)
[10:47:07] Completed 600000 out of 1500000 steps (40%)
[12:00:37] Completed 615000 out of 1500000 steps (41%)
[13:14:06] Completed 630000 out of 1500000 steps (42%)
[14:27:20] Completed 645000 out of 1500000 steps (43%)
[15:40:39] Completed 660000 out of 1500000 steps (44%)
[16:54:04] Completed 675000 out of 1500000 steps (45%)
[18:07:55] Completed 690000 out of 1500000 steps (46%)
[18:35:41] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Brian_Coleman_Chwaszczewski...
[18:36:08] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=160131...
[18:37:29] Opening C:\Users\Fozzy5000\AppData\Roaming\Folding@home-x86\MyFolding.html...
--- Opening Log file [October 22 19:10:14 UTC]
[19:10:14] - Ask before connecting: No
[19:10:14] - User name: Brian_Coleman_Chwaszczewski (Team 160131)
[19:10:14] - User ID: 660A645F54FA9D78
[19:10:14] - Machine ID: 1
[19:10:14]
[19:10:14] Loaded queue successfully.
[19:10:14] Initialization complete
[19:10:14]
[19:10:14] + Processing work unit
[19:10:14] Core required: FahCore_a4.exe
[19:10:14] Core found.
[19:10:15] Working on queue slot 01 [October 22 19:10:15 UTC]
[19:10:15] + Working ...
[19:10:15]
[19:10:15] *------------------------------*
[19:10:15] Folding@Home Gromacs GB Core
[19:10:15] Version 2.27 (Dec. 15, 2010)
[19:10:15]
[19:10:15] Preparing to commence simulation
[19:10:15] - Ensuring status. Please wait.
[19:10:24] - Looking at optimizations...
[19:10:24] - Working with standard loops on this execution.
[19:10:24] - Previous termination of core was improper.
[19:10:24] - Going to use standard loops.
[19:10:24] - Files status OK
[19:10:25] - Expanded 2053835 -> 5365960 (decompressed 261.2 percent)
[19:10:25] Called DecompressByteArray: compressed_data_size=2053835 data_size=5365960, decompressed_data_size=5365960 diff=0
[19:10:25] - Digital signature verified
[19:10:25]
[19:10:25] Project: 7808 (Run 9, Clone 213, Gen 3)
[19:10:25]
[19:10:25] Entering M.D.
[19:10:31] Using Gromacs checkpoints
[19:10:31] Mapping NT from 1 to 1
[19:10:32] Resuming from checkpoint
[19:10:32] Verified work/wudata_01.log
[19:10:32] Verified work/wudata_01.trr
[19:10:32] Verified work/wudata_01.xtc
[19:10:32] Verified work/wudata_01.edr
[19:10:33] Completed 695260 out of 1500000 steps (46%)
[19:58:17] Completed 705000 out of 1500000 steps (47%)
[21:11:52] Completed 720000 out of 1500000 steps (48%)
[22:25:26] Completed 735000 out of 1500000 steps (49%)
[23:38:59] Completed 750000 out of 1500000 steps (50%)
[00:52:33] Completed 765000 out of 1500000 steps (51%)
[01:10:14] + Working...
[02:06:01] Completed 780000 out of 1500000 steps (52%)
[03:19:33] Completed 795000 out of 1500000 steps (53%)
[04:33:03] Completed 810000 out of 1500000 steps (54%)
[05:46:35] Completed 825000 out of 1500000 steps (55%)
[06:59:55] Completed 840000 out of 1500000 steps (56%)
[07:10:04] + Working...
[08:13:25] Completed 855000 out of 1500000 steps (57%)
[09:26:53] Completed 870000 out of 1500000 steps (58%)
[10:40:21] Completed 885000 out of 1500000 steps (59%)
[11:53:51] Completed 900000 out of 1500000 steps (60%)
[13:07:22] Completed 915000 out of 1500000 steps (61%)
[13:10:04] + Working...
[14:20:53] Completed 930000 out of 1500000 steps (62%)
[15:34:24] Completed 945000 out of 1500000 steps (63%)
[16:47:53] Completed 960000 out of 1500000 steps (64%)
[18:01:22] Completed 975000 out of 1500000 steps (65%)
[19:10:04] + Working...
[19:14:51] Completed 990000 out of 1500000 steps (66%)
[20:28:17] Completed 1005000 out of 1500000 steps (67%)
[21:41:42] Completed 1020000 out of 1500000 steps (68%)
[22:55:08] Completed 1035000 out of 1500000 steps (69%)
[00:08:32] Completed 1050000 out of 1500000 steps (70%)
[01:10:04] + Working...
[01:21:57] Completed 1065000 out of 1500000 steps (71%)
[02:35:22] Completed 1080000 out of 1500000 steps (72%)
[03:48:49] Completed 1095000 out of 1500000 steps (73%)
[05:02:14] Completed 1110000 out of 1500000 steps (74%)
[06:15:38] Completed 1125000 out of 1500000 steps (75%)
[07:29:03] Completed 1140000 out of 1500000 steps (76%)
[08:42:30] Completed 1155000 out of 1500000 steps (77%)
[09:55:56] Completed 1170000 out of 1500000 steps (78%)
[11:09:23] Completed 1185000 out of 1500000 steps (79%)
[12:22:49] Completed 1200000 out of 1500000 steps (80%)
[13:36:18] Completed 1215000 out of 1500000 steps (81%)
[14:49:50] Completed 1230000 out of 1500000 steps (82%)
[15:14:59] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Brian_Coleman_Chwaszczewski...
[15:15:25] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=160131...
[16:03:22] Completed 1245000 out of 1500000 steps (83%)
[17:21:37] Completed 1260000 out of 1500000 steps (84%)
[18:36:52] Completed 1275000 out of 1500000 steps (85%)
[19:50:33] Completed 1290000 out of 1500000 steps (86%)
[21:03:38] Completed 1305000 out of 1500000 steps (87%)
[22:16:45] Completed 1320000 out of 1500000 steps (88%)
[23:30:08] Completed 1335000 out of 1500000 steps (89%)
[00:43:43] Completed 1350000 out of 1500000 steps (90%)
[01:57:19] Completed 1365000 out of 1500000 steps (91%)
[03:10:54] Completed 1380000 out of 1500000 steps (92%)
[04:24:30] Completed 1395000 out of 1500000 steps (93%)
[05:38:07] Completed 1410000 out of 1500000 steps (94%)
[06:51:38] Completed 1425000 out of 1500000 steps (95%)
[07:58:44] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=160131...
[08:05:14] Completed 1440000 out of 1500000 steps (96%)
[08:14:29] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=160131...
[08:33:49] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=160131...
[08:59:47] + Paused
[08:59:51] mdrun returned 1
[08:59:51] Gromacs was interrupted
[08:59:51] Folding@home Core Shutdown: INTERRUPTED
[08:59:51] CoreStatus = 66 (102)
[08:59:51] + Shutdown requested by user. Exiting.
Folding@Home Client Shutdown.
--- Opening Log file [October 25 09:00:13 UTC]
[09:00:13] - Ask before connecting: No
[09:00:13] - User name: Brian_Coleman_Chwaszczewski (Team 160131)
[09:00:13] - User ID: 660A645F54FA9D78
[09:00:13] - Machine ID: 1
[09:00:13]
[09:00:13] Loaded queue successfully.
[09:00:13] Initialization complete
[09:00:13]
[09:00:13] + Processing work unit
[09:00:13] Core required: FahCore_a4.exe
[09:00:13] Core found.
[09:00:13] Working on queue slot 01 [October 25 09:00:13 UTC]
[09:00:13] + Working ...
[09:00:13]
[09:00:13] *------------------------------*
[09:00:13] Folding@Home Gromacs GB Core
[09:00:13] Version 2.27 (Dec. 15, 2010)
[09:00:13]
[09:00:13] Preparing to commence simulation
[09:00:13] - Looking at optimizations...
[09:00:13] - Files status OK
[09:00:14] - Expanded 2053835 -> 5365960 (decompressed 261.2 percent)
[09:00:14] Called DecompressByteArray: compressed_data_size=2053835 data_size=5365960, decompressed_data_size=5365960 diff=0
[09:00:14] - Digital signature verified
[09:00:14]
[09:00:14] Project: 7808 (Run 9, Clone 213, Gen 3)
[09:00:14]
[09:00:14] Assembly optimizations on if available.
[09:00:14] Entering M.D.
[09:00:20] Using Gromacs checkpoints
[09:00:20] Mapping NT from 1 to 1
[09:00:21] Resuming from checkpoint
[09:00:21] Verified work/wudata_01.log
[09:00:21] Verified work/wudata_01.trr
[09:00:21] Verified work/wudata_01.xtc
[09:00:21] Verified work/wudata_01.edr
[09:00:21] Completed 1451120 out of 1500000 steps (96%)
[09:00:45] Opening C:\Users\Fozzy5000\AppData\Roaming\Folding@home-x86\MyFolding.html...
[09:20:42] Completed 1455000 out of 1500000 steps (97%)
[10:34:47] Completed 1470000 out of 1500000 steps (98%)
[11:48:15] Completed 1485000 out of 1500000 steps (99%)
[13:01:45] Completed 1500000 out of 1500000 steps (100%)
[13:01:46] DynamicWrapper: Finished Work Unit: sleep=10000
[13:01:56]
[13:01:56] Finished Work Unit:
[13:01:56] - Reading up to 2851056 from "work/wudata_01.trr": Read 2851056
[13:01:56] trr file hash check passed.
[13:01:56] - Reading up to 1523992 from "work/wudata_01.xtc": Read 1523992
[13:01:56] xtc file hash check passed.
[13:01:56] edr file hash check passed.
[13:01:56] logfile size: 52208
[13:01:56] Leaving Run
[13:01:59] - Writing 4432268 bytes of core data to disk...
[13:02:01] Done: 4431756 -> 4245450 (compressed to 95.7 percent)
[13:02:01] ... Done.
[13:02:02] - Shutting down core
[13:02:02]
[13:02:02] Folding@home Core Shutdown: FINISHED_UNIT
[13:02:06] CoreStatus = 64 (100)
[13:02:06] Sending work to server
[13:02:06] Project: 7808 (Run 9, Clone 213, Gen 3)
[13:02:06] + Attempting to send results [October 25 13:02:06 UTC]
[13:02:46] + Results successfully sent
[13:02:46] Thank you for your contribution to Folding@Home.
[13:02:46] + Starting local stats count at 1
[13:02:50] - Preparing to get new work unit...
[13:02:50] + Attempting to get work packet
[13:02:50] - Connecting to assignment server
[13:02:51] - Successful: assigned to (143.89.28.72).
[13:02:51] + News From Folding@Home: Welcome to Folding@Home
[13:02:51] Loaded queue successfully.
[13:02:57] + Closed connections
[13:02:57]
[13:02:57] + Processing work unit
[13:02:57] Core required: FahCore_a4.exe
[13:02:57] Core found.
[13:02:57] Working on queue slot 02 [October 25 13:02:57 UTC]
[13:02:57] + Working ...
[13:02:57]
[13:02:57] *------------------------------*
[13:02:57] Folding@Home Gromacs GB Core
[13:02:57] Version 2.27 (Dec. 15, 2010)
[13:02:57]
[13:02:57] Preparing to commence simulation
[13:02:57] - Looking at optimizations...
[13:02:57] - Created dyn
[13:02:57] - Files status OK
[13:02:58] - Expanded 1004533 -> 2267148 (decompressed 225.6 percent)
[13:02:58] Called DecompressByteArray: compressed_data_size=1004533 data_size=2267148, decompressed_data_size=2267148 diff=0
[13:02:58] - Digital signature verified
[13:02:58]
[13:02:58] Project: 7703 (Run 26, Clone 1, Gen 6)
[13:02:58]
[13:02:58] Assembly optimizations on if available.
[13:02:58] Entering M.D.
[13:03:04] Mapping NT from 1 to 1
[13:03:05] Completed 0 out of 1000000 steps (0%)
[13:42:05] Completed 10000 out of 1000000 steps (1%)
[14:21:06] Completed 20000 out of 1000000 steps (2%)
[15:00:06] Completed 30000 out of 1000000 steps (3%)
[15:00:13] + Working...
[15:39:07] Completed 40000 out of 1000000 steps (4%)
[16:18:07] Completed 50000 out of 1000000 steps (5%)
[16:57:05] Completed 60000 out of 1000000 steps (6%)
[17:36:04] Completed 70000 out of 1000000 steps (7%)
[18:15:03] Completed 80000 out of 1000000 steps (8%)
Fozzy5000
Ok I thought it would be around the same speed as a ps3 not 6 days, thank you for letting me know.
Fozzy5000 wrote:Ok I thought it would be around the same speed as a ps3 not 6 days, thank you for letting me know.
The time it takes to run a WU on your cpu depends on a number of factors. The Project running, the options you use when starting the client, cpu speed to name a few.
In your case you are using 1 out of your 6 cores which is akin to running only uniprocessor WUs. If you want to produce faster results you could add -smp to the command line which would run considerably faster than your current setup. It's always a good idea with version 6 of the client to add -verbosity 9 to the command line as well in order to maximize the info that is added to the log.
Your command line would look similar to:
"/path/to/executable/" -smp -verbosity 9Using the additional parameters field: http://fahwiki.net/index.php/How_do_I_r ... options%3F
Running console client: http://fahwiki.net/index.php/How_do_I_a ... _client%3F
Running console as a service: http://fahwiki.net/index.php/How_do_I_a ... ce_mode%3F
Running the GUI client: http://fahwiki.net/index.php/How_do_I_a ... _client%3F
It's a good idea to use a passkey to maximize your points if that's something you want to do:
http://folding.stanford.edu/English/FAQ-passkey
I sounds like you only understand part of what has been said. (I apologize if I'm explaining something that you did, in fact, understand.)Fozzy5000 wrote:Ok I thought it would be around the same speed as a ps3 not 6 days, thank you for letting me know.
First of all, there can be wide variations in processing time, depending on the project. Please see the Project Summary and notice the wide variation in deadlines. There is a relationship (though it's somewhat indirect) between expected processing time and deadlines. One think that can be noted is that all of the current PS3 WUs have a deadlines of 3.0/6.0 days. (The current Server is 171.64.65.83) and since everybody has what is essentially identical processing power, everybody returns WUs in the same amount of time. Neither of those facts apply to projects for the other clients.
Second, because of the missing -smp flag, your current assignment is using only about 19% of the capabilities of your X6. After that has been corrected, your next assignments will be entirely different.
