Project:6099 run:3 clone:4 gen:0 - Core needs updating
Late yesterday evening my Mac downloaded this unit, I noticed this morning it was not running. Checked the log, it was continually trying to update the A3 core.
01:38:26:Unit 01:Completed 495000 out of 500000 steps  (99%)
01:38:27:Connecting to assign3.stanford.edu:8080
01:38:28:News: Welcome to Folding@Home
01:38:28:Assigned to work server 171.64.65.53
01:38:28:Requesting new work unit for slot 00: RUNNING smp:8 from 171.64.65.53
01:38:28:Connecting to 171.64.65.53:8080
01:38:29:Slot 00: Downloading 2.86MiB
01:38:35:Slot 00: 46.35%
01:38:38:Slot 00: Download complete
01:38:38:Received Unit: id:00 state:DOWNLOAD project:6099 run:3 clone:4 gen:0 core:0xa3 unit:0x000000000a3b1e594e889fb408a58a73
01:43:17:Unit 01:Completed 500000 out of 500000 steps  (100%)
01:43:17:Unit 01:DynamicWrapper: Finished Work Unit: sleep=10000
01:43:27:Unit 01:
01:43:27:Unit 01:Finished Work Unit:
01:43:27:Unit 01:- Reading up to 3694848 from "01/wudata_01.trr": Read 3694848
01:43:27:Unit 01:trr file hash check passed.
01:43:27:Unit 01:edr file hash check passed.
01:43:27:Unit 01:logfile size: 55808
01:43:27:Unit 01:Leaving Run
01:43:27:Unit 01:- Writing 3786208 bytes of core data to disk...
01:43:27:Unit 01:  ... Done.
01:43:28:Unit 01:- Shutting down core
01:43:28:Unit 01:
01:43:28:Unit 01:Folding@home Core Shutdown: FINISHED_UNIT
01:43:29:FahCore, running Unit 01, returned: FINISHED_UNIT (100)
01:43:29:Sending unit results: id:01 state:SEND project:6072 run:0 clone:122 gen:450 core:0xa3 unit:0x30836f264e932ca201c2007a000017b8
01:43:29:Unit 01: Uploading 3.61MiB
01:43:29:Connecting to 171.64.65.54:8080
01:43:29:Starting Unit 00
01:43:29:Running core: "/Users/********/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah/FahCore_a3" -dir 00 -suffix 01 -lifeline 263 -version 701 -checkpoint 15 -np 8
01:43:29:Started core on PID 3892
01:43:29:FahCore 0xa3 started
01:43:29:FahCore, running Unit 00, returned: CORE_OUTDATED (110)
01:43:29:Downloading core from http://www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah
01:43:29:Connecting to www.stanford.edu:80
[93m01:43:30:WARNING: FahCore type in core package seems to be in wrong byte order.[0m
01:43:30:FahCore a3: Downloading 1.19MiB
01:43:35:Unit 01: 15.79%
01:43:36:FahCore a3: 11.42%
01:43:41:Unit 01: 29.97%
01:43:42:FahCore a3: 22.28%
01:43:47:Unit 01: 44.03%
01:43:48:FahCore a3: 32.44%
01:43:53:Unit 01: 58.09%
01:43:54:FahCore a3: 42.60%
01:43:59:Unit 01: 72.27%
01:44:00:FahCore a3: 52.76%
01:44:05:Unit 01: 86.44%
01:44:06:FahCore a3: 62.91%
01:44:12:FahCore a3: 73.05%
01:44:13:Unit 01: Upload complete
01:44:13:Server responded WORK_ACK (400)
01:44:13:Cleaning up Unit 01
01:44:13:FahCore a3: Download complete
01:44:13:Valid core signature
[93m01:44:13:WARNING: FahCore has not changed since last download, aborting core update[0m
01:44:13:Starting Unit 00
01:44:13:Running core: "/Users/********/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah/FahCore_a3" -dir 00 -suffix 01 -lifeline 263 -version 701 -checkpoint 15 -np 8
01:44:13:Started core on PID 3894
01:44:13:FahCore 0xa3 started
01:44:13:FahCore, running Unit 00, returned: CORE_OUTDATED (110)
01:44:29:Downloading core from http://www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah
01:44:29:Connecting to www.stanford.edu:80
[93m01:44:30:WARNING: FahCore type in core package seems to be in wrong byte order.[0m
01:44:30:FahCore a3: Downloading 1.19MiB
01:44:35:FahCore a3: Download complete
01:44:35:Valid core signature
[93m01:44:35:WARNING: FahCore has not changed since last download, aborting core update[0m
01:45:13:Starting Unit 00
01:45:13:Running core: "/Users/********/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah/FahCore_a3" -dir 00 -suffix 01 -lifeline 263 -version 701 -checkpoint 15 -np 8
01:45:13:Started core on PID 3898
01:45:13:FahCore 0xa3 started
01:45:14:FahCore, running Unit 00, returned: CORE_OUTDATED (110)
Restarted after manually deleting the core to make sure it was downloaded fresh, same results.
15:35:16:  <command-deny-no-pass v='0.0.0.0/0'/>
15:35:16:  <command-port v='36330'/>
15:35:16:
15:35:16:  <!-- Slot Control -->
15:35:16:  <max-shutdown-wait v='60'/>
15:35:16:  <pause-on-battery v='false'/>
15:35:16:  <pause-on-start v='false'/>
15:35:16:
15:35:16:  <!-- User Information -->
15:35:16:  <machine-id v='0'/>
15:35:16:  <passkey v='********************************'/>
15:35:16:  <team v='38910'/>
15:35:16:  <user v='Joe_H'/>
15:35:16:
15:35:16:  <!-- Work Unit Control -->
15:35:16:  <dump-after-deadline v='true'/>
15:35:16:  <max-queue v='16'/>
15:35:16:  <max-units v='0'/>
15:35:16:  <next-unit-percentage v='99'/>
15:35:16:
15:35:16:  <!-- Folding Slots -->
15:35:16:  <slot id='0' type='SMP'>
15:35:16:    <client-type v='advanced'/>
15:35:16:    <pause-on-start v='true'/>
15:35:16:  </slot>
15:35:16:</config>
15:35:16:Trying to access database...
15:35:16:Database locked
15:35:16:Enabled folding slot 00: PAUSED smp:8
15:35:21:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
15:35:42:Slot 00 unpaused
15:35:42:Downloading core from http://www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah
15:35:42:Connecting to www.stanford.edu:80
15:35:43:WARNING: FahCore type in core package seems to be in wrong byte order.
15:35:43:FahCore a3: Downloading 1.19MiB
15:35:49:FahCore a3: 95.68%
15:35:49:FahCore a3: Download complete
15:35:49:Valid core signature
15:35:49:Unpacked 3.39MiB to cores/www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah/FahCore_a3
15:35:49:Starting Unit 00
15:35:49:Running core: "/Users/********/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah/FahCore_a3" -dir 00 -suffix 01 -lifeline 4578 -version 701 -checkpoint 15 -np 8
15:35:49:Started core on PID 4580
15:35:49:FahCore 0xa3 started
15:35:49:FahCore, running Unit 00, returned: CORE_OUTDATED (110)
15:36:42:Downloading core from http://www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah
15:36:42:Connecting to www.stanford.edu:80
15:36:43:WARNING: FahCore type in core package seems to be in wrong byte order.
15:36:43:FahCore a3: Downloading 1.19MiB
15:36:48:FahCore a3: Download complete
15:36:48:Valid core signature
15:36:48:WARNING: FahCore has not changed since last download, aborting core update
15:36:48:Starting Unit 00
15:36:48:Running core: "/Users/********/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah/FahCore_a3" -dir 00 -suffix 01 -lifeline 4578 -version 701 -checkpoint 15 -np 8
15:36:48:Started core on PID 4584
15:36:48:FahCore 0xa3 started
15:36:48:FahCore, running Unit 00, returned: CORE_OUTDATED (110)
15:38:20:Downloading core from http://www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah
15:38:20:Connecting to www.stanford.edu:80
15:38:20:WARNING: FahCore type in core package seems to be in wrong byte order.
15:38:20:FahCore a3: Downloading 1.19MiB
15:38:25:FahCore a3: Download complete
15:38:25:Valid core signature
15:38:25:WARNING: FahCore has not changed since last download, aborting core update
15:38:25:Starting Unit 00
15:38:25:Running core: "/Users/********/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a3.fah/FahCore_a3" -dir 00 -suffix 01 -lifeline 4578 -version 701 -checkpoint 15 -np 8
15:38:25:Started core on PID 4594
15:38:25:FahCore 0xa3 started
15:38:25:FahCore, running Unit 00, returned: CORE_OUTDATED (110)
15:38:44:Slot 00 paused
Running the the 7.1.24 beta, will dump this WU so I can get going again. Hopefully the core on the server to download gets updated quickly if this project needs a new version of A3.
P.S. Used the pause in folding to also go to the latest public beta, 7.1.38.
kasson
Pande Group Member
Re: Project:6099 run:3 clone:4 gen:0 - Core needs updating
Post by kasson »
Our apologies; the current A3 core is not available for OS/X. We have turned off OS/X assigns for this project. Thanks for alerting us.
No problem, if I didn't care for an occasional glitch, I wouldn't run with -adv or use the beta client. Hopefully the updated A3 core for OS X becomes available soon, it has been a while since I got anything but the other project 60nn A3 WU's. The few A4 units I got were a nice change in PPD too, but none have come in for a while.
kevfruitbat
Post by kevfruitbat »
Hey Joe_H,
Thanks for posting this issue. I'm having exactly the same problem with my Mac Pro. It was nice to find your post, it gave me a quick answer and solution :)
+1 person hopeful the A3 core is updated soon.
