Not an issue, just never noticed this before.
I've been processing 6904's for a small while now and I just noticed that I've been getting EXACT sequential numbered workunits on one specific machine. I'm not totally sure how many but pretty sure at least my last 4 wu have been sequential.(since I loath pausing clients to do anything like checking with the -queueinfo flag. )
Concidence or just intended?
Username: PrinceCharming
Team #: 143016
6904 (Run1, Clone 33, Gen 6)
6904 (Run1, Clone 33, Gen 7)
6904 (Run1, Clone 33, Gen 8)
6904 (Run1, Clone 33, Gen 9) (Currently processing)
Comments?
Sequential Workunits
Folding Tools:8 X PS3's, 5 x GTX280,1 x 8800GS, 8 x 9800GX2 GPU's
Re: Sequential Workunits
Bit of both. The WU you upload is used to create the next one so it is possible to get WUs in sequence. It's happened to a lot of us. If I look back in my queues I can see numerous instances where this has been the case. Nothing to be concerned about.Concidence or just intended?
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Nothing to worry about if it is v6 client, I might add. By default, v7 downloads a new WU when the current one is at 99%. Even if you set next-unit-percentage to 100%, typically the download will start before the finished WU gets uploaded. AFAIK, Stanford servers can't create gen N+1 WU until gen N is fully uploaded.
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
