Problem with SMP servers? [Resolved]
artoar_11
- Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
More than 1h computer can not receive a new task. All SMP servers from the browser shows - OK.
Pick2
- Hardware configuration: Linux & CPUs
Re: Problem with SMP servers?
My linux machines also.
Server status not updating and all the Projects I usually get are missing from project summary
artoar_11
6040-6077 are still visible in - Project SummaryPick2 wrote:My linux machines also.
DocJonz
- Hardware configuration: Folding with: 4x RTX 4070Ti, 1x RTX 4080 Super, 1x RTX 5070Ti
I have a Win7 smp and a Linux bigadv sitting waiting for work at the moment.
I wonder if anyone is on-call at Stanford this weekend ... they might have got the short straw on this occasion
Folding Stats (now via v8 webclient)
[Ars] For Caitlin
- Hardware configuration: Two homebuilt rigs. Radeon 6900XT. Nvidia 2060 Super.
I'm also having the same problem. Came in to do BIOS updates related to cooling and was going to run a unit through all my boxen! Somebody wake up the on-call at Stanford.
A couple of servers show that they're out of work but the general statement that there's a problem with (all?) SMP servers isn't something I can deal with. Please post your logs or at least specify which server(s) you are having trouble with.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
I'm having the same issues. I'm at Utah State University, if that helps any. The SMP uploaded results fine, but has been stuck for the last three hours trying to get new work. The message says "Attempting to get work packet", "passkey found", "connecting to assignment server", "no appropriate work server was available, will try again in a bit", and then "couldn't get work instructions" before repeating. I'm running the last v6 version of the SMP client. My log can be found here: http://www.jessevictors.com/jessevictor ... s/SMP.html its updated in real time so if the problem is solved you guys can all see.
This one is on linux 64-bit v6. I can see that 199.96 does not have any WUs available but the assignment server won't switch to another server.
Soon to have a couple of smp clients on win 7 64-bit looking for work also.
[14:07:28] Updated performance fraction: 0.925448
[14:07:28] Sending work to server
[14:07:28] Project: 7128 (Run 0, Clone 34, Gen 258)
[14:07:28] + Attempting to send results [October 8 14:07:28 UTC]
[14:07:28] - Reading file work/wuresults_03.dat from core
[14:07:28] (Read 3528613 bytes from disk)
[14:07:28] Connecting to http://128.143.199.96:8080/
[14:07:59] Posted data.
[14:07:59] Initial: 0000; - Uploaded at ~111 kB/s
[14:07:59] - Averaged speed for that direction ~114 kB/s
[14:07:59] + Results successfully sent
[14:07:59] Thank you for your contribution to Folding@Home.
[14:07:59] + Number of Units Completed: 1996
[14:07:59] Trying to send all finished work units
[14:07:59] + No unsent completed units remaining.
[14:07:59] - Preparing to get new work unit...
[14:07:59] Cleaning up work directory
[14:07:59] + Attempting to get work packet
[14:07:59] Passkey found
[14:07:59] - Will indicate memory of 3954 MB
[14:07:59] - Connecting to assignment server
[14:07:59] Connecting to http://assign.stanford.edu:8080/
[14:07:59] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:07:59] + Couldn't get work instructions.
[14:07:59] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[14:08:07] + Attempting to get work packet
[14:08:07] Passkey found
[14:08:07] - Will indicate memory of 3954 MB
[14:08:07] - Connecting to assignment server
[14:08:07] Connecting to http://assign.stanford.edu:8080/
[14:08:08] Posted data.
[14:08:08] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:08:08] + Couldn't get work instructions.
[14:08:08] - Attempt #2 to get work failed, and no other work to do.
[14:08:18] + Attempting to get work packet
[14:08:18] Passkey found
[14:08:18] - Will indicate memory of 3954 MB
[14:08:18] - Connecting to assignment server
[14:08:18] Connecting to http://assign.stanford.edu:8080/
[14:08:19] Posted data.
[14:08:19] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:08:19] + Couldn't get work instructions.
[14:08:19] - Attempt #3 to get work failed, and no other work to do.
[14:08:45] + Attempting to get work packet
[14:08:45] Passkey found
[14:08:45] - Will indicate memory of 3954 MB
[14:08:45] - Connecting to assignment server
[14:08:45] Connecting to http://assign.stanford.edu:8080/
[14:08:45] Posted data.
[14:08:45] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:08:45] + Couldn't get work instructions.
[14:08:45] - Attempt #4 to get work failed, and no other work to do.
[14:09:36] + Attempting to get work packet
[14:09:36] Passkey found
[14:09:36] - Will indicate memory of 3954 MB
[14:09:36] - Connecting to assignment server
[14:09:36] Connecting to http://assign.stanford.edu:8080/
[14:09:36] Posted data.
[14:09:36] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:09:36] + Couldn't get work instructions.
[14:09:36] - Attempt #5 to get work failed, and no other work to do.
[14:10:59] + Attempting to get work packet
[14:10:59] Passkey found
[14:10:59] - Will indicate memory of 3954 MB
[14:10:59] - Connecting to assignment server
[14:10:59] Connecting to http://assign.stanford.edu:8080/
[14:11:00] Posted data.
[14:11:00] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:11:00] + Couldn't get work instructions.
[14:11:00] - Attempt #6 to get work failed, and no other work to do.
[14:13:46] + Attempting to get work packet
[14:13:46] Passkey found
[14:13:46] - Will indicate memory of 3954 MB
[14:13:46] - Connecting to assignment server
[14:13:46] Connecting to http://assign.stanford.edu:8080/
[14:13:47] Posted data.
[14:13:47] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:13:47] + Couldn't get work instructions.
[14:13:47] - Attempt #7 to get work failed, and no other work to do.
[14:19:13] - Autosending finished units... [October 8 14:19:13 UTC]
[14:19:13] Trying to send all finished work units
[14:19:13] + No unsent completed units remaining.
[14:19:13] - Autosend completed
[14:19:16] + Attempting to get work packet
[14:19:16] Passkey found
[14:19:16] - Will indicate memory of 3954 MB
[14:19:16] - Connecting to assignment server
[14:19:16] Connecting to http://assign.stanford.edu:8080/
[14:19:17] Posted data.
[14:19:17] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:19:17] + Couldn't get work instructions.
[14:19:17] - Attempt #8 to get work failed, and no other work to do.
[14:30:02] + Attempting to get work packet
[14:30:02] Passkey found
[14:30:02] - Will indicate memory of 3954 MB
[14:30:02] - Connecting to assignment server
[14:30:02] Connecting to http://assign.stanford.edu:8080/
[14:30:03] Posted data.
[14:30:03] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:30:03] + Couldn't get work instructions.
[14:30:03] - Attempt #9 to get work failed, and no other work to do.
[14:51:33] + Attempting to get work packet
[14:51:33] Passkey found
[14:51:33] - Will indicate memory of 3954 MB
[14:51:33] - Connecting to assignment server
[14:51:33] Connecting to http://assign.stanford.edu:8080/
[14:51:33] Posted data.
[14:51:33] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:51:33] + Couldn't get work instructions.
[14:51:33] - Attempt #10 to get work failed, and no other work to do.
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Exactly the same here. Last WU uploaded about 90 minutes ago (it's now 0832 PST local / 1532 UTC), and am getting solid string of attempts to get new work. Win64 running SMP v6.Jesse_V wrote:I'm having the same issues. .. The SMP uploaded results fine, but has been stuck for the last three hours trying to get new work. The message says "Attempting to get work packet", "passkey found", "connecting to assignment server", "no appropriate work server was available, will try again in a bit", and then "couldn't get work instructions" before repeating. I'm running the last v6 version of the SMP client. ....
[14:00:07] + Attempting to send results [October 8 14:00:07 UTC]
[14:00:07] - Reading file work/wuresults_00.dat from core
[14:00:07] (Read 100150333 bytes from disk)
[14:00:07] Connecting to http://130.237.232.141:8080/
[14:06:12] Posted data.
[14:06:12] Initial: 0000; - Uploaded at ~267 kB/s
[14:06:12] - Averaged speed for that direction ~275 kB/s
[14:06:12] + Results successfully sent
[14:06:12] Thank you for your contribution to Folding@Home.
[14:06:12] + Number of Units Completed: 103
SNIP
Rebooted here
Folding@Home Client Version 6.34
[15:35:46] + Attempting to get work packet
[15:35:46] Passkey found
[15:35:46] - Will indicate memory of 12268 MB
[15:35:46] - Connecting to assignment server
[15:35:46] Connecting to http://assign.stanford.edu:8080/
[15:35:46] Posted data.
[15:35:46] Initial: 0000; + No appropriate work server was available; will try a
gain in a bit.
[15:35:46] + Couldn't get work instructions.
[15:35:46] - Attempt #8 to get work failed, and no other work to do.
Bobby-Uschi
- Hardware configuration: PC1//C2Q-Q9450,GA-X48-DS5-NinjaMini,GTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit;
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB Western Sata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22" - Location: Deutschland
Winxp 32bit
--- Opening Log file [October 8 14:57:35 UTC]
Folding@Home Client Version 6.29
http://folding.stanford.edu
Launch directory: C:\Programme\Folding@Home Windows SMP Client V1.01
Executable: C:\Programme\Folding@Home Windows SMP Client V1.01\Folding@home-Win32-x86.exe
Arguments: -verbosity 9 -smp
[14:57:35] - Ask before connecting: No
[14:57:35] - User name: Bobby-Uschi (Team 34361)
[14:57:35] - User ID: xxxxxxxxx
[14:57:35] - Machine ID: 1
[14:57:35]
[14:57:35] Loaded queue successfully.
[14:57:35] - Preparing to get new work unit...
[14:57:35] - Autosending finished units... [October 8 14:57:35 UTC]
[14:57:35] Cleaning up work directory
[14:57:35] Trying to send all finished work units
[14:57:35] + No unsent completed units remaining.
[14:57:35] - Autosend completed
[14:57:35] + Attempting to get work packet
[14:57:35] Passkey found
[14:57:35] - Will indicate memory of 2046 MB
[14:57:35] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 7
[14:57:35] - Connecting to assignment server
[14:57:35] Connecting to http://assign.stanford.edu:8080/
[14:57:36] Posted data.
[14:57:36] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:57:36] + Couldn't get work instructions.
[14:57:36] - Attempt #1 to get work failed, and no other work to do.
[14:57:54] + Attempting to get work packet
[14:57:54] Passkey found
[14:57:54] - Will indicate memory of 2046 MB
[14:57:54] - Connecting to assignment server
[14:57:54] Connecting to http://assign.stanford.edu:8080/
[14:57:55] Posted data.
[14:57:55] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:57:55] + Couldn't get work instructions.
[14:57:55] - Attempt #2 to get work failed, and no other work to do.
[14:58:16] + Attempting to get work packet
[14:58:16] Passkey found
[14:58:16] - Will indicate memory of 2046 MB
[14:58:16] - Connecting to assignment server
[14:58:16] Connecting to http://assign.stanford.edu:8080/
[14:58:17] Posted data.
[14:58:17] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:58:17] + Couldn't get work instructions.
[14:58:17] - Attempt #3 to get work failed, and no other work to do.
[14:58:41] + Attempting to get work packet
[14:58:41] Passkey found
[14:58:41] - Will indicate memory of 2046 MB
[14:58:41] - Connecting to assignment server
[14:58:41] Connecting to http://assign.stanford.edu:8080/
[14:58:42] Posted data.
[14:58:42] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:58:42] + Couldn't get work instructions.
[14:58:42] - Attempt #4 to get work failed, and no other work to do.
[14:59:35] + Attempting to get work packet
[14:59:35] Passkey found
[14:59:35] - Will indicate memory of 2046 MB
[14:59:35] - Connecting to assignment server
[14:59:35] Connecting to http://assign.stanford.edu:8080/
[14:59:36] Posted data.
[14:59:36] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:59:36] + Couldn't get work instructions.
[14:59:36] - Attempt #5 to get work failed, and no other work to do.
[15:01:01] + Attempting to get work packet
[15:01:01] Passkey found
[15:01:01] - Will indicate memory of 2046 MB
[15:01:01] - Connecting to assignment server
[15:01:01] Connecting to http://assign.stanford.edu:8080/
[15:01:02] Posted data.
[15:01:02] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:01:02] + Couldn't get work instructions.
[15:01:02] - Attempt #6 to get work failed, and no other work to do.
[15:03:52] + Attempting to get work packet
[15:03:52] Passkey found
[15:03:52] - Will indicate memory of 2046 MB
[15:03:52] - Connecting to assignment server
[15:03:52] Connecting to http://assign.stanford.edu:8080/
[15:03:53] Posted data.
[15:03:53] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:03:53] + Couldn't get work instructions.
[15:03:53] - Attempt #7 to get work failed, and no other work to do.
[15:09:26] + Attempting to get work packet
[15:09:26] Passkey found
[15:09:26] - Will indicate memory of 2046 MB
[15:09:26] - Connecting to assignment server
[15:09:26] Connecting to http://assign.stanford.edu:8080/
[15:09:27] Posted data.
[15:09:27] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:09:27] + Couldn't get work instructions.
[15:09:27] - Attempt #8 to get work failed, and no other work to do.
[15:20:11] + Attempting to get work packet
[15:20:11] Passkey found
[15:20:11] - Will indicate memory of 2046 MB
[15:20:11] - Connecting to assignment server
[15:20:11] Connecting to http://assign.stanford.edu:8080/
[15:20:12] Posted data.
[15:20:12] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:20:12] + Couldn't get work instructions.
[15:20:12] - Attempt #9 to get work failed, and no other work to do.
PC1//C2Q-Q9450,GA-X48-DS5-,2xGTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB WeSata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22"stern
Dead Things
Same issue here with the...
64-bit Linux running the 6.34 client on both 16- and 24-core machines.
edit - I should mention the AS is assign.
Initial: 0000; + No appropriate work server was available; will try again in a bit.edit - I should mention the AS is assign.
Same problem with Win 7 64bit.
Then I set Verbosity to 9 and got this. As you can see by the time stamps this has been down for a while.
[12:20:10] Completed 500000 out of 500000 steps (100%)
[12:20:11] DynamicWrapper: Finished Work Unit: sleep=10000
[12:20:21]
[12:20:21] Finished Work Unit:
[12:20:21] - Reading up to 3712656 from "work/wudata_01.trr": Read 3712656
[12:20:21] trr file hash check passed.
[12:20:21] edr file hash check passed.
[12:20:21] logfile size: 69584
[12:20:21] Leaving Run
[12:20:22] - Writing 3817800 bytes of core data to disk...
[12:20:23] Done: 3817288 -> 3527841 (compressed to 92.4 percent)
[12:20:23] ... Done.
[12:20:23] - Shutting down core
[12:20:23]
[12:20:23] Folding@home Core Shutdown: FINISHED_UNIT
[12:20:26] CoreStatus = 64 (100)
[12:20:26] Sending work to server
[12:20:26] Project: 7133 (Run 0, Clone 66, Gen 240)
[12:20:26] + Attempting to send results [October 8 12:20:26 UTC]
[12:21:14] + Results successfully sent
[12:21:14] Thank you for your contribution to Folding@Home.
[12:21:14] + Starting local stats count at 1
[12:21:18] - Preparing to get new work unit...
[12:21:18] Cleaning up work directory
[12:21:18] + Attempting to get work packet
[12:21:18] Passkey found
[12:21:18] - Connecting to assignment server
[12:21:19] + No appropriate work server was available; will try again in a bit.
[12:21:19] + Couldn't get work instructions.
[12:21:19] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.Code: Select all
[15:55:29] Loaded queue successfully.
[15:55:29] - Preparing to get new work unit...
[15:55:29] - Autosending finished units... [October 8 15:55:29 UTC]
[15:55:29] Cleaning up work directory
[15:55:29] Trying to send all finished work units
[15:55:29] + Attempting to get work packet
[15:55:29] + No unsent completed units remaining.
[15:55:29] Passkey found
[15:55:29] - Autosend completed
[15:55:29] - Will indicate memory of 8189 MB
[15:55:29] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 10, Stepping: 0
[15:55:29] - Connecting to assignment server
[15:55:29] Connecting to http://assign.stanford.edu:8080/
[15:55:30] Posted data.
[15:55:30] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:55:30] + Couldn't get work instructions.
[15:55:30] - Attempt #1 to get work failed, and no other work to do.
[15:55:38] + Attempting to get work packet
[15:55:38] Passkey found
[15:55:38] - Will indicate memory of 8189 MB
[15:55:38] - Connecting to assignment server
[15:55:38] Connecting to http://assign.stanford.edu:8080/
[15:55:39] Posted data.
[15:55:39] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:55:39] + Couldn't get work instructions.
[15:55:39] - Attempt #2 to get work failed, and no other work to do.
[15:56:03] + Attempting to get work packet
[15:56:03] Passkey found
[15:56:03] - Will indicate memory of 8189 MB
[15:56:03] - Connecting to assignment server
[15:56:03] Connecting to http://assign.stanford.edu:8080/
[15:56:04] Posted data.
[15:56:04] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:56:04] + Couldn't get work instructions.
[15:56:04] - Attempt #3 to get work failed, and no other work to do.
[15:56:34] + Attempting to get work packet
[15:56:34] Passkey found
[15:56:34] - Will indicate memory of 8189 MB
[15:56:34] - Connecting to assignment server
[15:56:34] Connecting to http://assign.stanford.edu:8080/
[15:56:35] Posted data.
[15:56:35] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:56:35] + Couldn't get work instructions.
[15:56:35] - Attempt #4 to get work failed, and no other work to do.
[15:57:23] + Attempting to get work packet
[15:57:23] Passkey found
[15:57:23] - Will indicate memory of 8189 MB
[15:57:23] - Connecting to assignment server
[15:57:23] Connecting to http://assign.stanford.edu:8080/
[15:57:24] Posted data.
[15:57:24] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[15:57:24] + Couldn't get work instructions.
[15:57:24] - Attempt #5 to get work failed, and no other work to do.
[15:58:48] + Attempting to get work packet
[15:58:48] Passkey found
[15:58:48] - Will indicate memory of 8189 MB
[15:58:48] - Connecting to assignment server
[15:58:48] Connecting to http://assign.stanford.edu:8080/
[15:58:49] Posted data.
[15:58:49] Initial: 0000; + No appropriate work server was available; will try again in a bit.
I have the same issue and I concur, it has been down for a while. I decided to stop and turn off my windows 7 64 machine when it got to attempt # 18 and log in to see what is happening on the forums.
DocJonz
Bruce - I don't think the log has the specific server addresses in it - see below for an example;bruce wrote:A couple of servers show that they're out of work but the general statement that there's a problem with (all?) SMP servers isn't something I can deal with. Please post your logs or at least specify which server(s) you are having trouble with.
Arguments: -smp -advmethods
[13:28:33] - Ask before connecting: No
[13:28:33] - User name: DocJonz (Team 35947)
[13:28:33] - User ID: 242FE0CB38FF0B6A
[13:28:33] - Machine ID: 1
[13:28:33]
[13:28:33] Loaded queue successfully.
[13:28:33] - Preparing to get new work unit...
[13:28:33] Cleaning up work directory
[13:28:33] + Attempting to get work packet
[13:28:33] Passkey found
[13:28:33] - Connecting to assignment server
[13:28:34] + No appropriate work server was available; will try again in a bit.
[13:28:34] + Couldn't get work instructions.
[13:28:34] - Attempt #1 to get work failed, and no other work to do.
[13:28:49] + Attempting to get work packet
[13:28:49] Passkey found
[13:28:49] - Connecting to assignment server
[13:28:50] + No appropriate work server was available; will try again in a bit.
[13:28:50] + Couldn't get work instructions.
[13:28:50] - Attempt #2 to get work failed, and no other work to do.
[13:29:11] + Attempting to get work packet
[13:29:11] Passkey found
[13:29:11] - Connecting to assignment server
[13:29:12] + No appropriate work server was available; will try again in a bit.
[13:29:12] + Couldn't get work instructions.
[13:29:12] - Attempt #3 to get work failed, and no other work to do.
[13:29:36] + Attempting to get work packet
[13:29:36] Passkey found
[13:29:36] - Connecting to assignment server
[13:29:37] + No appropriate work server was available; will try again in a bit.
[13:29:37] + Couldn't get work instructions.
[13:29:37] - Attempt #4 to get work failed, and no other work to do.
[13:30:20] + Attempting to get work packet
[13:30:20] Passkey found
[13:30:20] - Connecting to assignment server
[13:30:21] + No appropriate work server was available; will try again in a bit.
[13:30:21] + Couldn't get work instructions.
[13:30:21] - Attempt #5 to get work failed, and no other work to do.
[13:31:43] + Attempting to get work packet
[13:31:43] Passkey found
[13:31:43] - Connecting to assignment server
[13:31:44] + No appropriate work server was available; will try again in a bit.
[13:31:44] + Couldn't get work instructions.
[13:31:44] - Attempt #6 to get work failed, and no other work to do.
[13:34:37] + Attempting to get work packet
[13:34:37] Passkey found
[13:34:37] - Connecting to assignment server
[13:34:38] + No appropriate work server was available; will try again in a bit.
[13:34:38] + Couldn't get work instructions.
[13:34:38] - Attempt #7 to get work failed, and no other work to do.
[13:40:08] + Attempting to get work packet
[13:40:08] Passkey found
[13:40:08] - Connecting to assignment server
[13:40:09] + No appropriate work server was available; will try again in a bit.
[13:40:09] + Couldn't get work instructions.
[13:40:09] - Attempt #8 to get work failed, and no other work to do.
[13:50:53] + Attempting to get work packet
[13:50:53] Passkey found
[13:50:53] - Connecting to assignment server
[13:50:57] + No appropriate work server was available; will try again in a bit.
[13:50:57] + Couldn't get work instructions.
[13:50:57] - Attempt #9 to get work failed, and no other work to do.
[14:12:30] + Attempting to get work packet
[14:12:30] Passkey found
[14:12:30] - Connecting to assignment server
[14:12:31] + No appropriate work server was available; will try again in a bit.
[14:12:31] + Couldn't get work instructions.
[14:12:31] - Attempt #10 to get work failed, and no other work to do.
[14:55:14] + Attempting to get work packet
[14:55:14] Passkey found
[14:55:14] - Connecting to assignment server
[14:55:15] + No appropriate work server was available; will try again in a bit.
[14:55:15] + Couldn't get work instructions.
[14:55:15] - Attempt #11 to get work failed, and no other work to do.
[15:43:24] + Attempting to get work packet
[15:43:24] Passkey found
[15:43:24] - Connecting to assignment server
[15:43:25] + No appropriate work server was available; will try again in a bit.
[15:43:25] + Couldn't get work instructions.
[15:43:25] - Attempt #12 to get work failed, and no other work to do.
Waiting before retry.Folding Stats (now via v8 webclient)
