Project: 2653 (Run 14, Clone 169, Gen 94) : EUE at 78%
[03:22:50] Project: 2653 (Run 14, Clone 169, Gen 94)
[03:22:50]
[03:22:51] Assembly optimizations on if available.
[03:22:51] Entering M.D.
[03:22:57] Rejecting checkpoint
[03:22:58] Protein: Protein in POPCExtra SSE boost OK.
[03:22:58]
[03:22:59] Extra SSE boost OK.
[03:22:59] Writing local files
[03:22:59] Completed 0 out of 500000 steps (0 percent)
[14:57:19] Completed 390000 out of 500000 steps (78 percent)
[15:00:23] Gromacs cannot continue further.
[15:00:23] Going to send back what have done.
[15:00:23] logfile size: 8782
[15:00:23] - Writing 9318 bytes of core data to disk...
[15:00:23] ... Done.
[15:00:23] - Failed to delete work/wudata_06.sas
[15:00:23] - Failed to delete work/wudata_06.goe
[15:00:23] Warning: check for stray files
[15:00:23]
[15:00:23] Folding@home Core Shutdown: EARLY_UNIT_END
[15:00:23]
[15:00:27] CoreStatus = 63 (99)
[15:00:27] + Error starting Folding@Home core or unexpected system termination of core.
[15:00:32]
[15:00:32] + Processing work unit
[15:00:32] Core required: FahCore_a1.exe
[15:00:32] Core found.
[15:00:32] Working on Unit 06 [April 7 15:00:32]
[15:00:32] + Working ...
[15:00:32] - Calling 'mpiexec -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -np 4 FahCore_a1.exe -dir work/ -suffix 06 -checkpoint 15 -forceasm -verbose -lifeline 2332 -version 800'
[15:00:34]
[15:00:34] *------------------------------*
[15:00:34] Folding@Home Gromacs SMP Core
[15:00:34] Version 1.76 (February 23, 2008)
[15:00:34]
[15:00:34] Preparing to commence simulation
[15:00:34] - Assembly optimizations manually forced on.
[15:00:34] - Not checking prior termination.
[15:00:34]
[15:00:34] Folding@home Core Shutdown: MISSING_WORK_FILES
[15:00:34] Finalizing output
[15:02:39] CoreStatus = 1 (1)
[15:02:39] Client-core communications error: ERROR 0x1
[15:02:39] Deleting current work unit & continuing...
[15:04:59] - Warning: Could not delete all work unit files (6): Core returned invalid code
[15:04:59] Trying to send all finished work units
[15:04:59] + No unsent completed units remaining.
[15:04:59] - Preparing to get new work unit...
Strange behaviour :(
P.S : partial credits submitted using qfix :)
ChelseaOilman
Re: Project: 2653 (Run 14, Clone 169, Gen 94) : EUE at 78%
Post by ChelseaOilman »
toTOW wrote:P.S : partial credits submitted using qfix :)
Your WU (P2653 R14 C169 G94) was added to the stats database on 2008-04-07 10:20:04 for 7.86 points of credit.
