Project 6803: (Run 4, Clone 66, Gen 255)
PS3hep48
Hardware configuration: -1-
EVGA GeForce GTX 970 SC
-2-
EVGA GeForce GTX 980 SC
-3-
Post by PS3hep48 »
Received this WU about 11 hours ago for the first time. Core consistently shuts down at approximately 1% completion. AMD 3800+ / GTX-460 Rig is stable having processed over 1500 WUs in the last 9 months. Same result at stock speeds or OC'ed. Also, assignment server keeps re-assigning me this unit. Have uninstalled 6.34 client and re-installed and keep getting assigned this unit. Here is a snippet of the latest experience with this WU:
[16:04:40] + Processing work unit
[16:04:40] Core required: FahCore_15.exe
[16:04:40] Core found.
[16:04:40] Working on queue slot 01 [October 1 16:04:40 UTC]
[16:04:40] + Working ...
[16:04:40]
[16:04:40] *------------------------------*
[16:04:40] Folding@Home GPU Core
[16:04:40] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[16:04:40] Build host             SimbiosNvdWin7
[16:04:40] Board Type             NVIDIA/CUDA
[16:04:40] Core                   15
[16:04:40]
[16:04:40] Window's signal control handler registered.
[16:04:40] Preparing to commence simulation
[16:04:40] - Looking at optimizations...
[16:04:40] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[16:04:40] - Created dyn
[16:04:40] - Files status OK
[16:04:40] sizeof(CORE_PACKET_HDR) = 512 file=<>
[16:04:40] - Expanded 44573 -> 170279 (decompressed 382.0 percent)
[16:04:40] Called DecompressByteArray: compressed_data_size=44573 data_size=170279, decompressed_data_size=170279 diff=0
[16:04:40] - Digital signature verified
[16:04:40]
[16:04:40] Project: 6803 (Run 4, Clone 66, Gen 255)
[16:04:40]
[16:04:40] Assembly optimizations on if available.
[16:04:40] Entering M.D.
[16:04:42] Tpr hash work/wudata_01.tpr:  916250484 3495616449 1129339087 1930084778 199201652
[16:04:42] calling fah_main gpuDeviceId=0
[16:04:42] Working on ALZHEIMER'S DISEASE AMYLOID
[16:04:42] Client config found, loading data.
[16:04:42] Starting GUI Server
[16:05:45] Setting checkpoint frequency: 500000
[16:05:45] Completed         3 out of 50000000 steps (0%).
[16:07:23] Completed    500000 out of 50000000 steps (1%).
[16:07:24] mdrun_gpu returned 52
[16:07:24] NANs detected on GPU
[16:07:24]
[16:07:24] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:07:27] CoreStatus = 7A (122)
[16:07:27] Sending work to server
[16:07:27] Project: 6803 (Run 4, Clone 66, Gen 255)
[16:07:27] - Read packet limit of 540015616... Set to 524286976.
[16:07:27] - Error: Could not get length of results file work/wuresults_01.dat
[16:07:27] - Error: Could not read unit 01 file. Removing from queue.
[16:07:27] - Preparing to get new work unit...
[16:07:27] Cleaning up work directory
[16:07:27] + Attempting to get work packet
[16:07:27] Passkey found
[16:07:27] Gpu type=3 species=21.
[16:07:27] - Connecting to assignment server
[16:07:27] - Successful: assigned to (171.67.108.54).
[16:07:27] + News From Folding@Home: Welcome to Folding@Home
[16:07:28] Loaded queue successfully.
[16:07:28] Gpu type=3 species=21.
[16:07:29] + Closed connections
[16:07:34]
[16:07:34] + Processing work unit
[16:07:34] Core required: FahCore_15.exe
[16:07:34] Core found.
[16:07:34] Working on queue slot 02 [October 1 16:07:34 UTC]
[16:07:34] + Working ...
[16:07:34]
[16:07:34] *------------------------------*
[16:07:34] Folding@Home GPU Core
[16:07:34] Version                2.20 (Tue Aug 2 12:06:37 PDT 2011)
[16:07:34] Build host             SimbiosNvdWin7
[16:07:34] Board Type             NVIDIA/CUDA
[16:07:34] Core                   15
[16:07:34]
[16:07:34] Window's signal control handler registered.
[16:07:34] Preparing to commence simulation
[16:07:34] - Looking at optimizations...
[16:07:34] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[16:07:34] - Created dyn
[16:07:34] - Files status OK
[16:07:34] sizeof(CORE_PACKET_HDR) = 512 file=<>
[16:07:34] - Expanded 44573 -> 170279 (decompressed 382.0 percent)
[16:07:34] Called DecompressByteArray: compressed_data_size=44573 data_size=170279, decompressed_data_size=170279 diff=0
[16:07:34] - Digital signature verified
[16:07:34]
[16:07:34] Project: 6803 (Run 4, Clone 66, Gen 255)
[16:07:34]
[16:07:34] Assembly optimizations on if available.
[16:07:34] Entering M.D.
[16:07:36] Tpr hash work/wudata_02.tpr:  916250484 3495616449 1129339087 1930084778 199201652
[16:07:36] calling fah_main gpuDeviceId=0
[16:07:36] Working on ALZHEIMER'S DISEASE AMYLOID
[16:07:36] Client config found, loading data.
[16:07:36] Starting GUI Server
Folding@Home Client Shutdown.
Would appreciate help in getting another WU assigned so I'm not wasting resources. Thanks in advance.
Mod Note: Marked bad 10-29-2011 (This report plus the two in the database makes three.)
PS3hep48
-2-
-3-
Re: Project 6803: (Run 4, Clone 66, Gen 255)
Post by PS3hep48 »
Didn't read Troubleshooting 'Bad WUs' topic prior to posting. Followed the instructions for getting a new WU and I'm back up and folding.
Folding with the 266.58 nvidia drivers on WinXP/32-bit, no issues other than the downclocking problem...the GTX-460 would downclock at both stock and OC speeds. Since installing Win7/64-bit with 266.58 drivers on the box about a month ago, the downclocking problem has not surfaced again. My GPU temps are consistently in the mid-50C range while folding.
There are two error reports in the WU Database. It will be marks as a bad one once we receive another bad report.
