No bonus points for 6900
awalleyeguy
Post by awalleyeguy »
Project: 6900 (Run 29, Clone 1, Gen 56)
Started [23:56:12] Working on queue slot 01 [September 22 23:56:12 UTC]
Finished [20:22:44] Folding@home Core Shutdown: FINISHED_UNIT
[20:22:49] CoreStatus = 64 (100)
[20:22:49] Sending work to server
[20:22:49] Project: 6900 (Run 29, Clone 1, Gen 56)
[20:22:49] + Attempting to send results [September 24 20:22:49 UTC]
[20:29:04] + Results successfully sent
No bonus points recieved.
Everything is set up correctly. This machine has been running bigadv for a long time with out issue.
So my question is why no bonus points?
Thanks.
Re: No bonus points for 6900
Hi awalleyeguy (team 111065),
Your WU (P6900 R29 C1 G56) was added to the stats database on 2011-09-24 14:07:51 for 7164 points of credit.
No bonus points were received because you did not return the WU before the Preferred deadline.
WU assigned to donor at: 2011-09-20 13:20:10
Days taken to complete WU: 4.03
awalleyeguy
So it had to be finished in less than than 46 hours?
Grandpa_01
Post by Grandpa_01 »
Look through your log it probably failed and restarted some where along the line. Or it terminated at some time and was reassighned to you a coupple of days latter. The servers will use the orriginal download date and time.
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
awalleyeguy
OK, thanks.
I don't see any failed wu's
awalleyeguy
Grandpa_01 wrote:Look through your log it probably failed and restarted some where along the line. Or it terminated at some time and was reassighned to you a coupple of days latter. The servers will use the orriginal download date and time.
Not seeing any failed wu's.
Grandpa_01
Look through the client log and see if it restarted at some point third party apps usually will not show if it made it to say 95% then restarted and completed it would just show as a completed WU. Look at the orrignal download timeand see what happend.WU assigned to donor at: 2011-09-20 13:20:10
awalleyeguy
I suppose it isn't really that important. The wu was completed. Thanks.
Yes, the WU was completed and you received credit for it as I indicated in my previous post. You did not receive a BONUS. The bonus is computed automatically by a server script and the time that the WU was assigned is determined by the server as well as the time of the final upload so the time computed is reliable, though if the WU was reassigned, it seems deceptive since only the time of the FIRST download is used.
I'm sure if you look in your log for 2011-09-20 04:20:10 UTC, you'll find that Project: 6900 (Run 29, Clone 1, Gen 56) was assigned to you but for some reason it was not completed. I don't have access to information about what happened to that WU except if you find it in your log (or a previous log, if you've restarted your client since that time).
I certainly would be interested in what happened to that WU. I'd also be interested in the 3rd party tool that you're using for Client Stats -- specifically why it doesn't report the disposition of the copy of that WU that was assigned at that time.
