I didn't know what section to put this in, so put it here.
Name says it all, when fah6.exe is run why not ask teh user to input the amount of threads to be used?
Would be much more efficient (for me at least) to do that rather than keep on editing the client.cfg file.
Be able to choose amount of threads run at start up
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: Be able to choose amount of threads run at start up
Yes. If indeed you are talking about the SMP client, you can try running it with the -smp X flag, where X is the number of threads to use. I'll repeat what one of the admins told me: it is never a good idea to edit the client.cfg file.Jonathan wrote:I didn't know what section to put this in, so put it here.
EDIT: See this page: http://fahwiki.net/index.php/How_do_I_k ... (-switches)_are_and_what_they_do%3F#-smp_x
Also, this page might be helpful http://fahwiki.net/index.php/How_do_I_a ... _client%3F
M-x
- Hardware configuration: Intel Q6600 @ 2.4GHz
6GB DDR2 RAM
MSI P6N SLI-Platinum
nVidia 8800GTS 640MB
SeaSonic 620W 80+ Bronze PSU
Hitachi 320GB 7200RPM SATA 3Gbps
Antec P180B case
As stated, it's never a good idea to edit the client.cfg file because it's not a straight text file. Also, if you want to change the thread number for the SMP client, just use:
Where # is your number of threads
fah6 -smp #Corsair Hydro H80 CPU Cooler
Corsair White 600T Case
MSI Z68A-GD65 (G3) Z68
Corsair TX650 V2 650W
Intel Core i7-2600K (@ 4.2GHz)
Corsair Vengeance 8GB
Seagate 1TB HDD
Seagate 1TB HDD
P5-133XL
Machine #2:
Machine 3:
Have multiple shortcuts each with a different -smp x appended to the target field.
Jesse_V
CPU: i7-6700k
I agree that is a possibility. It would make things very easy if switching threads was a common thing. If not, it might just be easier to change the -smp X in the Shortcut Properties. Oh, I've heard that a few people have had issues using a prime number of threads. It seems pretty rare, so this may or may not be an issue for you, but if something weird happens, try a non-prime value for -smp X first. I don't think its been firmly established why that problem occurs. Just wanted to let you know.P5-133XL wrote:Have multiple shortcuts each with a different -smp x appended to the target field.
Napoleon
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Changing SMP thread count mid-WU isn't recommended, if that was the OP's intention. It could cause data corruption, in which case the WU needs to be rerun from scratch, or something to that effect. Better to finish currently running WU first before making the change.
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
