black dot on wu?
Epicmonkey
black dot on wu?
just a few days ago, i found a wu with a black dot on it, what does it/that mean? is it bad?
To All New Members, Welcome to F@h and Enjoy your stay -
Re: black dot on wu?
Can you please elaborate the "WU with black dot on it" part? Do you have any screenshots or FAHlog(s) to indicate it? What client were you running?
Epicmonkey
it was on the ps3, and i don't have any FAHlog(s) or screenshots.
Zagen30
If it's this issue, it's apparently a harmless visualization bug that never got fixed.
Epicmonkey
This was my exact problem.oddman wrote:...I did see a small black ball floating disconnected from any structure...
