Anyway, seems I'm missing credit for Project: 2686 (Run 7, Clone 4, Gen 163) returned on 9/11 after a server outage. I've waited a couple of days to see if time was needed for catch up but I don't see it as yet. Could some kind soul with db access check if it was registered please:
[01:30:25] - Preparing to get new work unit...
[01:30:25] Cleaning up work directory
[01:30:25] + Attempting to get work packet
[01:30:25] Passkey found
[01:30:25] - Will indicate memory of 4000 MB
[01:30:25] - Connecting to assignment server
[01:30:25] Connecting to http://assign.stanford.edu:8080/
[01:30:26] Posted data.
[01:30:26] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:30:26] + News From Folding@Home: Welcome to Folding@Home
[01:30:26] Loaded queue successfully.
[01:30:26] Sent data
[01:30:26] Connecting to http://171.67.108.22:8080/
[01:30:38] Posted data.
[01:30:38] Initial: 0000; - Receiving payload (expected size: 25473161)
[01:31:31] - Downloaded at ~469 kB/s
[01:31:31] - Averaged speed for that direction ~1106 kB/s
[01:31:31] + Received work.
[01:31:31] Trying to send all finished work units
[01:31:31] + No unsent completed units remaining.
[01:31:31] + Closed connections
[01:31:31]
[01:31:31] + Processing work unit
[01:31:31] Core required: FahCore_a5.exe
[01:31:31] Core found.
[01:31:31] Working on queue slot 01 [September 9 01:31:31 UTC]
[01:31:31] + Working ...
[01:31:31] - Calling '.\FahCore_a5.exe -dir work/ -nice 19 -suffix 01 -np 8 -checkpoint 10 -verbose -lifeline 3784 -version 634'
[01:31:31]
[01:31:31] *------------------------------*
[01:31:31] Folding@Home Gromacs SMP Core
[01:31:31] Version 2.27 (Mar 12, 2010)
[01:31:31]
[01:31:31] Preparing to commence simulation
[01:31:31] - Looking at optimizations...
[01:31:31] - Created dyn
[01:31:31] - Files status OK
[01:31:36] - Expanded 25472649 -> 31941441 (decompressed 125.3 percent)
[01:31:36] Called DecompressByteArray: compressed_data_size=25472649 data_size=31941441, decompressed_data_size=31941441 diff=0
[01:31:36] - Digital signature verified
[01:31:36]
[01:31:36] Project: 2686 (Run 7, Clone 4, Gen 163)
[01:31:36]
[01:31:36] Assembly optimizations on if available.
[01:31:36] Entering M.D.
[01:31:43] Mapping NT from 8 to 8
[01:31:45] Completed 0 out of 250000 steps (0%)
[01:47:16] - Autosending finished units... [September 9 01:47:16 UTC]
[01:47:16] Trying to send all finished work units
[01:47:16] + No unsent completed units remaining.
[01:47:16] - Autosend completed
[02:05:42] Completed 2500 out of 250000 steps (1%)
[02:39:44] Completed 5000 out of 250000 steps (2%)
[09:43:53] Completed 247500 out of 250000 steps (99%)
[10:17:50] Completed 250000 out of 250000 steps (100%)
[10:18:02] DynamicWrapper: Finished Work Unit: sleep=10000
[10:18:12]
[10:18:12] Finished Work Unit:
[10:18:12] - Reading up to 52713120 from "work/wudata_01.trr": Read 52713120
[10:18:12] trr file hash check passed.
[10:18:12] - Reading up to 42760216 from "work/wudata_01.xtc": Read 42760216
[10:18:13] xtc file hash check passed.
[10:18:13] edr file hash check passed.
[10:18:13] logfile size: 219325
[10:18:13] Leaving Run
[10:18:15] - Writing 95864045 bytes of core data to disk...
[10:18:18] ... Done.
[10:18:28] - Shutting down core
[10:18:28]
[10:18:28] Folding@home Core Shutdown: FINISHED_UNIT
[10:18:33] CoreStatus = 64 (100)
[10:18:33] Unit 1 finished with 61 percent of time to deadline remaining.
[10:18:33] Updated performance fraction: 0.848128
[10:18:33] Sending work to server
[10:18:33] Project: 2686 (Run 7, Clone 4, Gen 163)
[10:18:33] + Attempting to send results [September 11 10:18:33 UTC]
[10:18:33] - Reading file work/wuresults_01.dat from core
[10:18:33] (Read 95864045 bytes from disk)
[10:18:33] Connecting to http://171.67.108.22:8080/
[10:18:33] - Couldn't send HTTP request to server
[10:18:33] + Could not connect to Work Server (results)
[10:18:33] (171.67.108.22:8080)
[10:18:33] + Retrying using alternative port
[10:18:33] Connecting to http://171.67.108.22:80/
[10:18:34] - Couldn't send HTTP request to server
[10:18:34] + Could not connect to Work Server (results)
[10:18:34] (171.67.108.22:80)
[10:18:34] - Error: Could not transmit unit 01 (completed September 11) to work server.
[10:18:34] - 1 failed uploads of this unit.
[10:18:34] Keeping unit 01 in queue.
[10:18:34] Trying to send all finished work units
[10:18:34] Project: 2686 (Run 7, Clone 4, Gen 163)
[10:18:34] + Attempting to send results [September 11 10:18:34 UTC]
[10:18:34] - Reading file work/wuresults_01.dat from core
[10:18:34] (Read 95864045 bytes from disk)
[10:18:34] Connecting to http://171.67.108.22:8080/
[10:18:35] - Couldn't send HTTP request to server
[10:18:35] + Could not connect to Work Server (results)
[10:18:35] (171.67.108.22:8080)
[10:18:35] + Retrying using alternative port
[10:18:35] Connecting to http://171.67.108.22:80/
[10:18:35] (171.67.108.22:80)
[10:18:35] - Error: Could not transmit unit 01 (completed September 11) to work server.
[10:18:35] - 2 failed uploads of this unit.
[10:18:35] + Attempting to send results [September 11 10:18:35 UTC]
[10:18:35] - Reading file work/wuresults_01.dat from core
[10:18:35] (Read 95864045 bytes from disk)
[10:18:35] Connecting to http://171.67.108.25:8080/
[10:18:37] - Couldn't send HTTP request to server
[10:18:37] + Could not connect to Work Server (results)
[10:18:37] (171.67.108.25:8080)
[10:18:37] + Retrying using alternative port
[10:18:37] Connecting to http://171.67.108.25:80/
[10:18:38] - Couldn't send HTTP request to server
[10:18:38] + Could not connect to Work Server (results)
[10:18:38] (171.67.108.25:80)
[10:18:38] Could not transmit unit 01 to Collection server; keeping in queue.
[10:18:38] + Sent 0 of 1 completed units to the server
[10:18:44] Trying to send all finished work units
[10:18:44] Project: 2686 (Run 7, Clone 4, Gen 163)
[10:18:44] + Attempting to send results [September 11 10:18:44 UTC]
[10:18:44] - Reading file work/wuresults_01.dat from core
[10:18:45] (Read 95864045 bytes from disk)
[10:18:45] Connecting to http://171.67.108.22:8080/
[10:18:45] - Couldn't send HTTP request to server
[10:18:45] + Could not connect to Work Server (results)
[10:18:45] (171.67.108.22:8080)
[10:18:45] + Retrying using alternative port
[10:18:45] Connecting to http://171.67.108.22:80/
[10:18:46] - Couldn't send HTTP request to server
[10:18:46] + Could not connect to Work Server (results)
[10:18:46] (171.67.108.22:80)
[10:18:46] - Error: Could not transmit unit 01 (completed September 11) to work server.
[10:18:46] - 3 failed uploads of this unit.
[10:18:46] + Attempting to send results [September 11 10:18:46 UTC]
[10:18:46] - Reading file work/wuresults_01.dat from core
[10:18:46] (Read 95864045 bytes from disk)
[10:18:46] Connecting to http://171.67.108.25:8080/
[10:18:47] - Couldn't send HTTP request to server
[10:18:47] + Could not connect to Work Server (results)
[10:18:47] (171.67.108.25:8080)
[10:18:47] + Retrying using alternative port
[10:18:47] Connecting to http://171.67.108.25:80/
[10:18:49] - Couldn't send HTTP request to server
[10:18:49] + Could not connect to Work Server (results)
[10:18:49] (171.67.108.25:80)
[10:18:49] Could not transmit unit 01 to Collection server; keeping in queue.
[10:18:49] + Sent 0 of 1 completed units to the server
[10:18:49] + Closed connections
[13:47:07] - Autosending finished units... [September 11 13:47:07 UTC]
[13:47:07] Trying to send all finished work units
[13:47:07] Project: 2686 (Run 7, Clone 4, Gen 163)
[13:47:07] + Attempting to send results [September 11 13:47:07 UTC]
[13:47:07] - Reading file work/wuresults_01.dat from core
[13:47:07] (Read 95864045 bytes from disk)
[13:47:07] Connecting to http://171.67.108.22:8080/
[14:01:17] Posted data.
[14:01:17] Initial: 0000; - Uploaded at ~110 kB/s
[14:01:17] - Averaged speed for that direction ~106 kB/s
[14:01:17] + Results successfully sent
[14:01:17] Thank you for your contribution to Folding@Home.
[14:01:17] + Number of Units Completed: 771
[14:01:21] + Sent 1 of 1 completed units to the server
[14:01:21] - Autosend completed
