Help will be appreciated
Hi used to fold 2 years ago back then there was a client that could use GPU and CPU cores at the click of a button i was wondering if there was a client that does that still cause i whould like to use what i can
- Hardware configuration: system 1: AMD FX6300 on Ubuntu 17.04 LTS
Re: Help will be appreciated
Currently V7.1.24 beta client is able to handle calculations on CPU and GPU with much ease.
I dedicate my participation to my grandmother died in 1992 because of Parkinson's disease
and to my friend Benoit died of leukemia February 18 2012 ...he was 40 years old.
i have a gtx 465 for some reason the FAH idles all my drivers are updated and i dont even know how to correctly add cpu slots and what not
configure >> slots >> add >> choose "uniprocessor" or "smp" slot (for dual core or more) then click on ok.....the new slot is added and automatically download a WU
anything else i need to change ? GPU goes from running 0.0% to..... Ready 0.0% and keep doing it
EDIT* i got a CPU to start going but my GPU is still hanging up and not starting it says UPDATE CORE now o.0 confused
13:45:59:Unit 00:*------------------------------*
13:45:59:Unit 00:Folding@Home GPU Core
13:45:59:Unit 00:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
13:45:59:Unit 00:
13:45:59:Unit 00:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
13:45:59:Unit 00:Build host: amoeba
13:45:59:Unit 00:Board Type: Nvidia
13:45:59:Unit 00:Core :
13:45:59:Unit 00:Preparing to commence simulation
13:45:59:Unit 00:- Ensuring status. Please wait.
13:46:08:Unit 00:- Looking at optimizations...
13:46:08:Unit 00:- Working with standard loops on this execution.
13:46:08:Unit 00:- Previous termination of core was improper.
13:46:08:Unit 00:- Files status OK
13:46:08:Unit 00:- Expanded 62999 -> 336988 (decompressed 534.9 percent)
13:46:08:Unit 00:Called DecompressByteArray: compressed_data_size=62999 data_size=336988, decompressed_data_size=336988 diff=0
13:46:08:Unit 00:- Digital signature verified
13:46:08:Unit 00:
13:46:08:Unit 00:Project: 10506 (Run 3, Clone 935, Gen 532)
13:46:08:Unit 00:
13:46:08:Unit 00:Entering M.D.
13:46:14:Unit 00:Tpr hash 00/wudata_01.tpr: 1158897411 959933625 1532064289 2077655630 633471705
13:46:14:Unit 00:
13:46:14:Unit 00:Calling fah_main args: 14 usage=100
13:46:14:Unit 00:
13:46:14:FahCore, running Unit 00, returned: UNKNOWN_ENUM (-1)
13:45:59:Unit 00:
13:46:08:Unit 00:
13:46:08:Unit 00:
13:46:14:Unit 00:
13:46:14:Unit 00:
which driver you use ? If have the latest drivers you should download the old driver 266 and test again
UNKNOWN_ENUM (-1) means that the FahCore is not finding your GPU. If you look on the System tab you'll find that V7.1.24 does not detect your GPU correctly. That's a known bug in the current beta version.
See Ticket #661 and search this forum for "whitelist" for more information. The next public beta will fix your problem.
when is the next open beta ?
The Pande Group does not give ETAs on client release dates. It should be coming vaguely soonish, but vaguely soonish covers anywhere from "tomorrow" to "a couple months".
This is a known bug but it is possible to fix this by downloading the old Nvidia driver 266.58 !
I had this problem with a GTS450 fixed with a old driver.
