Help! please anwser
doomsday111
Help! please anwser
Post by doomsday111 »
1st question:
does f@H work on ASUS eee pad?
2nd question:
If yes to the first question, does it work for the gpu?
3rd question:
If yes, how do i find the gpu on eee pad?
4th question:
and which download so i click on in the gpu download link?
Re: Help! please anwser
Welcome to foldingforum.org, doomsday111.
FAH works on MS Windows, on Linux, on Mac OS X, and whatever Sony calls the OS that runs on the PS3. Your eee pad probably has an Intel i5 chip in it and probably runs Windows. As such, it can run the SMP version of FAH, whether or not the GPU can be used. (Only designated GPUs are supported, but you'll probably be lucky on this one since the hardware is pretty new.)
FAH is not well suited for battery powered devices so you'll probably choose to run FAH only when the device is connected to wall-power.
Aside from the version that's shown on the download page, you may choose to try the new V7 client which is in open beta. See the discussion here. It's not bug free, but it is MUCH easier for someone new to FAH to install and it's unlikely that any of the bugs will be a problem for you. You can get help with either version here on the forum and there are good install guides on the Stanford site.
bollix47
Post by bollix47 »
I have an Asus eee pad transformer tablet and cannot fold on it.
It uses Google's Android o/s.
It's cpu is an NVIDIA Tegra 2 operating @ 1.0Ghz.
bollix47 wrote:I too have an Asus eee pad transformer tablet and no you cannot fold on it.
Are we talking about an eee-Pad slate or an eee-Pad transformer? I probably should have asked.
http://www.newegg.com/Product/Product.a ... 6834220961 :?:
Android is not supported, as I said, and developing FAH for a new platform is a MAJOR undertaking so the answer the the next question is "not in the foreseeable future"
... and as I said, FAH is not well suited for battery powered devices. If Stanford ever develops an application for the new types of hardware, the application would probably only work while the device is plugged in or in the charging dock.
bollix47
Post by bollix47 »
When I googled Asus eee pad all I could see was the transformer. Didn't know about the slate.
Sorry for my assumption.
