Just wondering which client would be best for my computer.
Windows 7 64-Bit
I5-2500k Quad 3.3
8gb ram
2x HD 6850 in crossfire
Which client?
Napoleon
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Re: Which client?
Welcome to the forum, imbigbuck.
That depends on your other uses for the computer, like gaming or other CPU/GPU intensive tasks, if any. Do you leave it running 24/7? If so, and you don't mind running beta SW, at this point I'd tentatively recommend the v7 unified client, set up for SMP folding only. That would be an easy and very unintrusive way to get the ball rolling. It would also leave you the option to configure GPU folding later on (v7 / FahCore16 required for HD6850), once/if you are comfortable with that.
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
