No problems with install. I checked my unitinfo.txt file to see what had been done after a few minutes, and this leads to my questions:
1) I think my PC can handle the extra memory requirements for the 10MB+ files in the configuration settings, so I tried that after running it without that box checked for a while. It doesn't seem to use any more or less memory or CPU resources whether the box is checked or not. Will I not notice any system usage changes until it's completed the current work unit?
2) It appears you give a system with the program installed about 25 days to complete each work unit. I have a fairly quick system, how long can I expect for it to take to finish a work unit, with the default settings? What's a good estimate of time to completion based on whether you accept 10MB+ file sizes or not?
Thanks very much for the information
