Project: 10124 (... well all of them apparently)
^w^ing
Hardware configuration: C2D E6400 2.13 GHz @ 3.2 GHz
Asus EN8800GTS 640 (G80) @ 660/792/1700 running the 6.23 w/ core11 v1.19
forceware 260.89
Asus P5N-E SLi
2GB 800MHz DDRII (2xCorsair TwinX 512MB)
WinXP 32 SP3
Post by ^w^ing »
this is on i7-950, win7 64
happens with every 10124 unit I get. until now, the SMP client on this machine finished almost 400 WUs without a hickup
--- Opening Log file [August 30 19:09:51 UTC]
                       Folding@Home Client Version 6.30
                          http://folding.stanford.edu
Launch directory: C:\Folding@Home\SMP
Executable: C:\Folding@Home\SMP\Folding@Home-SMP.exe
Arguments: -smp 7 -forceasm -local -verbosity 9
[19:09:51] - Ask before connecting: No
[19:09:51] - User name: ^w^ing (Team 0)
[19:09:51] - User ID:
[19:09:51] - Machine ID: 9
[19:09:51]
[19:09:51] Loaded queue successfully.
[19:09:51]
[19:09:51] - Autosending finished units... [August 30 19:09:51 UTC]
[19:09:51] + Processing work unit
[19:09:51] Trying to send all finished work units
[19:09:51] Core required: FahCore_a3.exe
[19:09:51] + No unsent completed units remaining.
[19:09:51] Core found.
[19:09:51] - Autosend completed
[19:09:51] Working on queue slot 07 [August 30 19:09:51 UTC]
[19:09:51] + Working ...
[19:09:51] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 07 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[19:09:51]
[19:09:51] *------------------------------*
[19:09:51] Folding@Home Gromacs SMP Core
[19:09:51] Version 2.27 (Dec. 15, 2010)
[19:09:51]
[19:09:51] Preparing to commence simulation
[19:09:51] - Ensuring status. Please wait.
[19:10:01] - Assembly optimizations manually forced on.
[19:10:01] - Not checking prior termination.
[19:10:01] - Expanded 1763492 -> 2250393 (decompressed 127.6 percent)
[19:10:01] Called DecompressByteArray: compressed_data_size=1763492 data_size=2250393, decompressed_data_size=2250393 diff=0
[19:10:01] - Digital signature verified
[19:10:01]
[19:10:01] Project: 6058 (Run 0, Clone 84, Gen 447)
[19:10:01]
[19:10:01] Assembly optimizations on if available.
[19:10:01] Entering M.D.
[19:10:07] Using Gromacs checkpoints
[19:10:07] Mapping NT from 7 to 7
[19:10:07] Resuming from checkpoint
[19:10:08] Verified work/wudata_07.log
[19:10:08] Verified work/wudata_07.trr
[19:10:08] Verified work/wudata_07.edr
[19:10:08] Completed 335784 out of 500000 steps  (67%)
[19:13:12] Completed 340000 out of 500000 steps  (68%)
[19:16:43] Completed 345000 out of 500000 steps  (69%)
[19:20:14] Completed 350000 out of 500000 steps  (70%)
[19:23:44] Completed 355000 out of 500000 steps  (71%)
[22:21:15] Completed 475000 out of 500000 steps  (95%)
[22:25:04] Completed 480000 out of 500000 steps  (96%)
[22:28:51] Completed 485000 out of 500000 steps  (97%)
[22:32:43] Completed 490000 out of 500000 steps  (98%)
[22:36:44] Completed 495000 out of 500000 steps  (99%)
[22:40:44] Completed 500000 out of 500000 steps  (100%)
[22:40:45] DynamicWrapper: Finished Work Unit: sleep=10000
[22:40:55]
[22:40:55] Finished Work Unit:
[22:40:55] - Reading up to 3700224 from "work/wudata_09.trr": Read 3700224
[22:40:55] trr file hash check passed.
[22:40:55] edr file hash check passed.
[22:40:55] logfile size: 60121
[22:40:55] Leaving Run
[22:40:56] - Writing 3795281 bytes of core data to disk...
[22:40:56] Done: 3794769 -> 3522488 (compressed to 92.8 percent)
[22:40:56]   ... Done.
[22:40:57] - Shutting down core
[22:40:57]
[22:40:57] Folding@home Core Shutdown: FINISHED_UNIT
[22:41:00] CoreStatus = 64 (100)
[22:41:00] Unit 9 finished with 93 percent of time to deadline remaining.
[22:41:00] Updated performance fraction: 0.945389
[22:41:00] Sending work to server
[22:41:00] Project: 6990 (Run 0, Clone 82, Gen 170)
[22:41:00] + Attempting to send results [September 1 22:41:00 UTC]
[22:41:00] - Reading file work/wuresults_09.dat from core
[22:41:00]   (Read 3523000 bytes from disk)
[22:41:00] Connecting to http://128.143.199.96:8080/
[22:41:11] Posted data.
[22:41:11] Initial: 0000; - Uploaded at ~312 kB/s
[22:41:11] - Averaged speed for that direction ~192 kB/s
[22:41:11] + Results successfully sent
[22:41:11] Thank you for your contribution to Folding@Home.
[22:41:11] + Number of Units Completed: 397
[22:41:15] Trying to send all finished work units
[22:41:15] + No unsent completed units remaining.
[22:41:15] - Preparing to get new work unit...
[22:41:15] Cleaning up work directory
[22:41:15] + Attempting to get work packet
[22:41:15] Passkey found
[22:41:15] - Will indicate memory of 6135 MB
[22:41:15] - Connecting to assignment server
[22:41:15] Connecting to http://assign.stanford.edu:8080/
[22:41:17] Posted data.
[22:41:17] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:41:17] + News From Folding@Home: Welcome to Folding@Home
[22:41:17] Loaded queue successfully.
[22:41:17] Sent data
[22:41:17] Connecting to http://171.64.65.75:8080/
[22:41:18] Posted data.
[22:41:18] Initial: 0000; - Receiving payload (expected size: 962288)
[22:42:10] - Downloaded at ~18 kB/s
[22:42:10] - Averaged speed for that direction ~108 kB/s
[22:42:10] + Received work.
[22:42:10] Trying to send all finished work units
[22:42:10] + No unsent completed units remaining.
[22:42:10] + Closed connections
[22:42:10]
[22:42:10] + Processing work unit
[22:42:10] Core required: FahCore_a3.exe
[22:42:10] Core found.
[22:42:10] Working on queue slot 00 [September 1 22:42:10 UTC]
[22:42:10] + Working ...
[22:42:10] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 00 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:42:10]
[22:42:10] *------------------------------*
[22:42:10] Folding@Home Gromacs SMP Core
[22:42:10] Version 2.27 (Dec. 15, 2010)
[22:42:10]
[22:42:10] Preparing to commence simulation
[22:42:10] - Assembly optimizations manually forced on.
[22:42:10] - Not checking prior termination.
[22:42:10] - Expanded 961776 -> 2023268 (decompressed 210.3 percent)
[22:42:10] Called DecompressByteArray: compressed_data_size=961776 data_size=2023268, decompressed_data_size=2023268 diff=0
[22:42:11] - Digital signature verified
[22:42:11]
[22:42:11] Project: 10124 (Run 2, Clone 0, Gen 7)
[22:42:11]
[22:42:11] Assembly optimizations on if available.
[22:42:11] Entering M.D.
[22:42:17] Mapping NT from 7 to 7
[22:42:17] mdrun returned 255
[22:42:17] Going to send back what have done -- stepsTotalG=2500000
[22:42:17] Work fraction=0.0000 steps=2500000.
[22:42:21] logfile size=0 infoLength=0 edr=0 trr=25
[22:42:21] logfile size: 0 info=0 bed=0 hdr=25
[22:42:21] - Writing 643 bytes of core data to disk...
[22:42:21] Done: 131 -> 148 (compressed to 112.9 percent)
[22:42:21]   ... Done.
[22:42:21]
[22:42:21] Folding@home Core Shutdown: EARLY_UNIT_END
[22:42:25] CoreStatus = 72 (114)
[22:42:25] Sending work to server
[22:42:25] Project: 10124 (Run 2, Clone 0, Gen 7)
[22:42:25] + Attempting to send results [September 1 22:42:25 UTC]
[22:42:25] - Reading file work/wuresults_00.dat from core
[22:42:25]   (Read 660 bytes from disk)
[22:42:25] Connecting to http://171.64.65.75:8080/
[22:42:26] Posted data.
[22:42:26] Initial: 0000; - Uploaded at ~1 kB/s
[22:42:26] - Averaged speed for that direction ~154 kB/s
[22:42:26] + Results successfully sent
[22:42:26] Thank you for your contribution to Folding@Home.
[22:42:30] Trying to send all finished work units
[22:42:30] + No unsent completed units remaining.
[22:42:30] - Preparing to get new work unit...
[22:42:30] Cleaning up work directory
[22:42:30] + Attempting to get work packet
[22:42:30] Passkey found
[22:42:30] - Will indicate memory of 6135 MB
[22:42:30] - Connecting to assignment server
[22:42:30] Connecting to http://assign.stanford.edu:8080/
[22:42:32] Posted data.
[22:42:32] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:42:32] + News From Folding@Home: Welcome to Folding@Home
[22:42:32] Loaded queue successfully.
[22:42:32] Sent data
[22:42:32] Connecting to http://171.64.65.75:8080/
[22:42:33] Posted data.
[22:42:34] Initial: 0000; - Receiving payload (expected size: 886284)
[22:43:17] - Downloaded at ~20 kB/s
[22:43:17] - Averaged speed for that direction ~90 kB/s
[22:43:17] + Received work.
[22:43:17] Trying to send all finished work units
[22:43:17] + No unsent completed units remaining.
[22:43:17] + Closed connections
[22:43:22]
[22:43:22] + Processing work unit
[22:43:22] Core required: FahCore_a3.exe
[22:43:22] Core found.
[22:43:22] Working on queue slot 01 [September 1 22:43:22 UTC]
[22:43:22] + Working ...
[22:43:22] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:43:22]
[22:43:22] *------------------------------*
[22:43:22] Folding@Home Gromacs SMP Core
[22:43:22] Version 2.27 (Dec. 15, 2010)
[22:43:22]
[22:43:22] Preparing to commence simulation
[22:43:22] - Assembly optimizations manually forced on.
[22:43:22] - Not checking prior termination.
[22:43:22] - Expanded 885772 -> 1924148 (decompressed 217.2 percent)
[22:43:22] Called DecompressByteArray: compressed_data_size=885772 data_size=1924148, decompressed_data_size=1924148 diff=0
[22:43:22] - Digital signature verified
[22:43:22]
[22:43:22] Project: 10124 (Run 3, Clone 6, Gen 9)
[22:43:22]
[22:43:22] Assembly optimizations on if available.
[22:43:22] Entering M.D.
[22:43:28] Mapping NT from 7 to 7
[22:43:28] mdrun returned 255
[22:43:28] Going to send back what have done -- stepsTotalG=2500000
[22:43:28] Work fraction=0.0000 steps=2500000.
[22:43:32] logfile size=0 infoLength=0 edr=0 trr=25
[22:43:32] logfile size: 0 info=0 bed=0 hdr=25
[22:43:32] - Writing 643 bytes of core data to disk...
[22:43:32] Done: 131 -> 149 (compressed to 113.7 percent)
[22:43:32]   ... Done.
[22:43:32]
[22:43:32] Folding@home Core Shutdown: EARLY_UNIT_END
[22:43:36] CoreStatus = 72 (114)
[22:43:36] Sending work to server
[22:43:36] Project: 10124 (Run 3, Clone 6, Gen 9)
[22:43:36] + Attempting to send results [September 1 22:43:36 UTC]
[22:43:36] - Reading file work/wuresults_01.dat from core
[22:43:36]   (Read 661 bytes from disk)
[22:43:36] Connecting to http://171.64.65.75:8080/
[22:43:37] Posted data.
[22:43:37] Initial: 0000; - Uploaded at ~1 kB/s
[22:43:37] - Averaged speed for that direction ~123 kB/s
[22:43:37] + Results successfully sent
[22:43:37] Thank you for your contribution to Folding@Home.
[22:43:41] Trying to send all finished work units
[22:43:41] + No unsent completed units remaining.
[22:43:41] - Preparing to get new work unit...
[22:43:41] Cleaning up work directory
[22:43:41] + Attempting to get work packet
[22:43:41] Passkey found
[22:43:41] - Will indicate memory of 6135 MB
[22:43:41] - Connecting to assignment server
[22:43:41] Connecting to http://assign.stanford.edu:8080/
[22:43:43] Posted data.
[22:43:43] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:43:43] + News From Folding@Home: Welcome to Folding@Home
[22:43:43] Loaded queue successfully.
[22:43:43] Sent data
[22:43:43] Connecting to http://171.64.65.75:8080/
[22:43:44] Posted data.
[22:43:44] Initial: 0000; - Receiving payload (expected size: 885345)
[22:44:27] - Downloaded at ~20 kB/s
[22:44:27] - Averaged speed for that direction ~76 kB/s
[22:44:27] + Received work.
[22:44:27] Trying to send all finished work units
[22:44:27] + No unsent completed units remaining.
[22:44:27] + Closed connections
[22:44:32]
[22:44:32] + Processing work unit
[22:44:32] Core required: FahCore_a3.exe
[22:44:32] Core found.
[22:44:32] Working on queue slot 02 [September 1 22:44:32 UTC]
[22:44:32] + Working ...
[22:44:32] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:44:33]
[22:44:33] *------------------------------*
[22:44:33] Folding@Home Gromacs SMP Core
[22:44:33] Version 2.27 (Dec. 15, 2010)
[22:44:33]
[22:44:33] Preparing to commence simulation
[22:44:33] - Assembly optimizations manually forced on.
[22:44:33] - Not checking prior termination.
[22:44:33] - Expanded 884833 -> 1923476 (decompressed 217.3 percent)
[22:44:33] Called DecompressByteArray: compressed_data_size=884833 data_size=1923476, decompressed_data_size=1923476 diff=0
[22:44:33] - Digital signature verified
[22:44:33]
[22:44:33] Project: 10124 (Run 6, Clone 8, Gen 12)
[22:44:33]
[22:44:33] Assembly optimizations on if available.
[22:44:33] Entering M.D.
[22:44:39] Mapping NT from 7 to 7
[22:44:39] mdrun returned 255
[22:44:39] Going to send back what have done -- stepsTotalG=2500000
[22:44:39] Work fraction=0.0000 steps=2500000.
[22:44:43] logfile size=0 infoLength=0 edr=0 trr=25
[22:44:43] logfile size: 0 info=0 bed=0 hdr=25
[22:44:43] - Writing 643 bytes of core data to disk...
[22:44:43] Done: 131 -> 149 (compressed to 113.7 percent)
[22:44:43]   ... Done.
[22:44:43]
[22:44:43] Folding@home Core Shutdown: EARLY_UNIT_END
[22:44:47] CoreStatus = 72 (114)
[22:44:47] Sending work to server
[22:44:47] Project: 10124 (Run 6, Clone 8, Gen 12)
[22:44:47] + Attempting to send results [September 1 22:44:47 UTC]
[22:44:47] - Reading file work/wuresults_02.dat from core
[22:44:47]   (Read 661 bytes from disk)
[22:44:47] Connecting to http://171.64.65.75:8080/
[22:44:48] Posted data.
[22:44:52] Initial: 0000; - Uploaded at ~0 kB/s
[22:44:52] - Averaged speed for that direction ~99 kB/s
[22:44:52] + Results successfully sent
[22:44:52] Thank you for your contribution to Folding@Home.
[22:44:56] Trying to send all finished work units
[22:44:56] + No unsent completed units remaining.
[22:44:56] - Preparing to get new work unit...
[22:44:56] Cleaning up work directory
[22:44:56] + Attempting to get work packet
[22:44:56] Passkey found
[22:44:56] - Will indicate memory of 6135 MB
[22:44:56] - Connecting to assignment server
[22:44:56] Connecting to http://assign.stanford.edu:8080/
[22:44:59] Posted data.
[22:44:59] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:44:59] + News From Folding@Home: Welcome to Folding@Home
[22:44:59] Loaded queue successfully.
[22:44:59] Sent data
[22:44:59] Connecting to http://171.64.65.75:8080/
[22:45:00] Posted data.
[22:45:00] Initial: 0000; - Receiving payload (expected size: 883553)
[22:45:06] - Downloaded at ~143 kB/s
[22:45:06] - Averaged speed for that direction ~90 kB/s
[22:45:06] + Received work.
[22:45:06] Trying to send all finished work units
[22:45:06] + No unsent completed units remaining.
[22:45:06] + Closed connections
[22:45:11]
[22:45:11] + Processing work unit
[22:45:11] Core required: FahCore_a3.exe
[22:45:11] Core found.
[22:45:11] Working on queue slot 03 [September 1 22:45:11 UTC]
[22:45:11] + Working ...
[22:45:11] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 03 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:45:11]
[22:45:11] *------------------------------*
[22:45:11] Folding@Home Gromacs SMP Core
[22:45:11] Version 2.27 (Dec. 15, 2010)
[22:45:11]
[22:45:11] Preparing to commence simulation
[22:45:11] - Assembly optimizations manually forced on.
[22:45:11] - Not checking prior termination.
[22:45:11] - Expanded 883041 -> 1924148 (decompressed 217.9 percent)
[22:45:11] Called DecompressByteArray: compressed_data_size=883041 data_size=1924148, decompressed_data_size=1924148 diff=0
[22:45:11] - Digital signature verified
[22:45:11]
[22:45:11] Project: 10124 (Run 3, Clone 32, Gen 7)
[22:45:11]
[22:45:11] Assembly optimizations on if available.
[22:45:11] Entering M.D.
[22:45:18] Mapping NT from 7 to 7
[22:45:18] mdrun returned 255
[22:45:18] Going to send back what have done -- stepsTotalG=2500000
[22:45:18] Work fraction=0.0000 steps=2500000.
[22:45:22] logfile size=0 infoLength=0 edr=0 trr=25
[22:45:22] logfile size: 0 info=0 bed=0 hdr=25
[22:45:22] - Writing 643 bytes of core data to disk...
[22:45:22] Done: 131 -> 150 (compressed to 114.5 percent)
[22:45:22]   ... Done.
[22:45:22]
[22:45:22] Folding@home Core Shutdown: EARLY_UNIT_END
[22:45:25] CoreStatus = 72 (114)
[22:45:25] Sending work to server
[22:45:25] Project: 10124 (Run 3, Clone 32, Gen 7)
[22:45:25] + Attempting to send results [September 1 22:45:25 UTC]
[22:45:25] - Reading file work/wuresults_03.dat from core
[22:45:25]   (Read 662 bytes from disk)
[22:45:25] Connecting to http://171.64.65.75:8080/
[22:45:26] Posted data.
[22:45:26] Initial: 0000; - Uploaded at ~1 kB/s
[22:45:26] - Averaged speed for that direction ~79 kB/s
[22:45:26] + Results successfully sent
[22:45:26] Thank you for your contribution to Folding@Home.
[22:45:30] Trying to send all finished work units
[22:45:30] + No unsent completed units remaining.
[22:45:30] - Preparing to get new work unit...
[22:45:30] Cleaning up work directory
[22:45:30] + Attempting to get work packet
[22:45:30] Passkey found
[22:45:30] - Will indicate memory of 6135 MB
[22:45:30] - Connecting to assignment server
[22:45:30] Connecting to http://assign.stanford.edu:8080/
[22:45:31] Posted data.
[22:45:31] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:45:31] + News From Folding@Home: Welcome to Folding@Home
[22:45:31] Loaded queue successfully.
[22:45:31] Sent data
[22:45:31] Connecting to http://171.64.65.75:8080/
[22:45:32] Posted data.
[22:45:32] Initial: 0000; - Receiving payload (expected size: 974212)
[22:45:41] - Downloaded at ~105 kB/s
[22:45:41] - Averaged speed for that direction ~93 kB/s
[22:45:41] + Received work.
[22:45:41] Trying to send all finished work units
[22:45:41] + No unsent completed units remaining.
[22:45:41] + Closed connections
[22:45:46]
[22:45:46] + Processing work unit
[22:45:46] Core required: FahCore_a3.exe
[22:45:46] Core found.
[22:45:46] Working on queue slot 04 [September 1 22:45:46 UTC]
[22:45:46] + Working ...
[22:45:46] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 04 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:45:46]
[22:45:46] *------------------------------*
[22:45:46] Folding@Home Gromacs SMP Core
[22:45:46] Version 2.27 (Dec. 15, 2010)
[22:45:46]
[22:45:46] Preparing to commence simulation
[22:45:46] - Assembly optimizations manually forced on.
[22:45:46] - Not checking prior termination.
[22:45:46] - Expanded 973700 -> 2034944 (decompressed 208.9 percent)
[22:45:46] Called DecompressByteArray: compressed_data_size=973700 data_size=2034944, decompressed_data_size=2034944 diff=0
[22:45:47] - Digital signature verified
[22:45:47]
[22:45:47] Project: 10124 (Run 1, Clone 33, Gen 4)
[22:45:47]
[22:45:47] Assembly optimizations on if available.
[22:45:47] Entering M.D.
[22:45:53] Mapping NT from 7 to 7
[22:45:53] mdrun returned 255
[22:45:53] Going to send back what have done -- stepsTotalG=2500000
[22:45:53] Work fraction=0.0000 steps=2500000.
[22:45:57] logfile size=0 infoLength=0 edr=0 trr=25
[22:45:57] logfile size: 0 info=0 bed=0 hdr=25
[22:45:57] - Writing 643 bytes of core data to disk...
[22:45:57] Done: 131 -> 150 (compressed to 114.5 percent)
[22:45:57]   ... Done.
[22:45:57]
[22:45:57] Folding@home Core Shutdown: EARLY_UNIT_END
[22:46:00] CoreStatus = 72 (114)
[22:46:00] Sending work to server
[22:46:00] Project: 10124 (Run 1, Clone 33, Gen 4)
[22:46:00] + Attempting to send results [September 1 22:46:00 UTC]
[22:46:00] - Reading file work/wuresults_04.dat from core
[22:46:00]   (Read 662 bytes from disk)
[22:46:00] Connecting to http://171.64.65.75:8080/
[22:46:01] Posted data.
[22:46:01] Initial: 0000; - Uploaded at ~1 kB/s
[22:46:01] - Averaged speed for that direction ~64 kB/s
[22:46:01] + Results successfully sent
[22:46:01] Thank you for your contribution to Folding@Home.
[22:46:05] Trying to send all finished work units
[22:46:05] + No unsent completed units remaining.
[22:46:05] - Preparing to get new work unit...
[22:46:05] Cleaning up work directory
[22:46:05] + Attempting to get work packet
[22:46:05] Passkey found
[22:46:05] - Will indicate memory of 6135 MB
[22:46:05] - Connecting to assignment server
[22:46:05] Connecting to http://assign.stanford.edu:8080/
[22:46:06] Posted data.
[22:46:06] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:46:06] + News From Folding@Home: Welcome to Folding@Home
[22:46:06] Loaded queue successfully.
[22:46:06] Sent data
[22:46:06] Connecting to http://171.64.65.75:8080/
[22:46:07] Posted data.
[22:46:07] Initial: 0000; - Receiving payload (expected size: 885398)
[22:46:13] - Downloaded at ~144 kB/s
[22:46:13] - Averaged speed for that direction ~103 kB/s
[22:46:13] + Received work.
[22:46:13] Trying to send all finished work units
[22:46:13] + No unsent completed units remaining.
[22:46:13] + Closed connections
[22:46:18]
[22:46:18] + Processing work unit
[22:46:18] Core required: FahCore_a3.exe
[22:46:18] Core found.
[22:46:18] Working on queue slot 05 [September 1 22:46:18 UTC]
[22:46:18] + Working ...
[22:46:18] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 05 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:46:18]
[22:46:18] *------------------------------*
[22:46:18] Folding@Home Gromacs SMP Core
[22:46:18] Version 2.27 (Dec. 15, 2010)
[22:46:18]
[22:46:18] Preparing to commence simulation
[22:46:18] - Assembly optimizations manually forced on.
[22:46:18] - Not checking prior termination.
[22:46:18] - Expanded 884886 -> 1923476 (decompressed 217.3 percent)
[22:46:18] Called DecompressByteArray: compressed_data_size=884886 data_size=1923476, decompressed_data_size=1923476 diff=0
[22:46:18] - Digital signature verified
[22:46:18]
[22:46:18] Project: 10124 (Run 6, Clone 33, Gen 8)
[22:46:18]
[22:46:18] Assembly optimizations on if available.
[22:46:18] Entering M.D.
[22:46:25] Mapping NT from 7 to 7
[22:46:25] mdrun returned 255
[22:46:25] Going to send back what have done -- stepsTotalG=2500000
[22:46:25] Work fraction=0.0000 steps=2500000.
[22:46:29] logfile size=0 infoLength=0 edr=0 trr=25
[22:46:29] logfile size: 0 info=0 bed=0 hdr=25
[22:46:29] - Writing 643 bytes of core data to disk...
[22:46:29] Done: 131 -> 148 (compressed to 112.9 percent)
[22:46:29]   ... Done.
[22:46:29]
[22:46:29] Folding@home Core Shutdown: EARLY_UNIT_END
[22:46:32] CoreStatus = 72 (114)
[22:46:32] Sending work to server
[22:46:32] Project: 10124 (Run 6, Clone 33, Gen 8)
[22:46:32] + Attempting to send results [September 1 22:46:32 UTC]
[22:46:32] - Reading file work/wuresults_05.dat from core
[22:46:32]   (Read 660 bytes from disk)
[22:46:32] Connecting to http://171.64.65.75:8080/
[22:46:33] Posted data.
[22:46:33] Initial: 0000; - Uploaded at ~1 kB/s
[22:46:33] - Averaged speed for that direction ~51 kB/s
[22:46:33] + Results successfully sent
[22:46:33] Thank you for your contribution to Folding@Home.
[22:46:37] Trying to send all finished work units
[22:46:37] + No unsent completed units remaining.
[22:46:37] - Preparing to get new work unit...
[22:46:37] Cleaning up work directory
[22:46:37] + Attempting to get work packet
[22:46:37] Passkey found
[22:46:37] - Will indicate memory of 6135 MB
[22:46:37] - Connecting to assignment server
[22:46:37] Connecting to http://assign.stanford.edu:8080/
[22:46:38] Posted data.
[22:46:38] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:46:38] + News From Folding@Home: Welcome to Folding@Home
[22:46:38] Loaded queue successfully.
[22:46:38] Sent data
[22:46:38] Connecting to http://171.64.65.75:8080/
[22:46:39] Posted data.
[22:46:39] Initial: 0000; - Receiving payload (expected size: 973892)
[22:46:47] - Downloaded at ~118 kB/s
[22:46:47] - Averaged speed for that direction ~106 kB/s
[22:46:47] + Received work.
[22:46:47] Trying to send all finished work units
[22:46:47] + No unsent completed units remaining.
[22:46:47] + Closed connections
[22:46:52]
[22:46:52] + Processing work unit
[22:46:52] Core required: FahCore_a3.exe
[22:46:52] Core found.
[22:46:52] Working on queue slot 06 [September 1 22:46:52 UTC]
[22:46:52] + Working ...
[22:46:52] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:46:52]
[22:46:52] *------------------------------*
[22:46:52] Folding@Home Gromacs SMP Core
[22:46:52] Version 2.27 (Dec. 15, 2010)
[22:46:52]
[22:46:52] Preparing to commence simulation
[22:46:52] - Assembly optimizations manually forced on.
[22:46:52] - Not checking prior termination.
[22:46:52] - Expanded 973380 -> 2034860 (decompressed 209.0 percent)
[22:46:52] Called DecompressByteArray: compressed_data_size=973380 data_size=2034860, decompressed_data_size=2034860 diff=0
[22:46:52] - Digital signature verified
[22:46:52]
[22:46:52] Project: 10124 (Run 7, Clone 33, Gen 8)
[22:46:52]
[22:46:52] Assembly optimizations on if available.
[22:46:52] Entering M.D.
[22:46:58] Mapping NT from 7 to 7
[22:46:58] mdrun returned 255
[22:46:58] Going to send back what have done -- stepsTotalG=2500000
[22:46:58] Work fraction=0.0000 steps=2500000.
[22:47:02] logfile size=0 infoLength=0 edr=0 trr=25
[22:47:02] logfile size: 0 info=0 bed=0 hdr=25
[22:47:02] - Writing 643 bytes of core data to disk...
[22:47:02] Done: 131 -> 150 (compressed to 114.5 percent)
[22:47:02]   ... Done.
[22:47:02]
[22:47:02] Folding@home Core Shutdown: EARLY_UNIT_END
[22:47:06] CoreStatus = 72 (114)
[22:47:06] Sending work to server
[22:47:06] Project: 10124 (Run 7, Clone 33, Gen 8)
[22:47:06] + Attempting to send results [September 1 22:47:06 UTC]
[22:47:06] - Reading file work/wuresults_06.dat from core
[22:47:06]   (Read 662 bytes from disk)
[22:47:06] Connecting to http://171.64.65.75:8080/
[22:47:07] Posted data.
[22:47:07] Initial: 0000; - Uploaded at ~1 kB/s
[22:47:07] - Averaged speed for that direction ~41 kB/s
[22:47:07] + Results successfully sent
[22:47:07] Thank you for your contribution to Folding@Home.
[22:47:11] Trying to send all finished work units
[22:47:11] + No unsent completed units remaining.
[22:47:11] - Preparing to get new work unit...
[22:47:11] Cleaning up work directory
[22:47:11] + Attempting to get work packet
[22:47:11] Passkey found
[22:47:11] - Will indicate memory of 6135 MB
[22:47:11] - Connecting to assignment server
[22:47:11] Connecting to http://assign.stanford.edu:8080/
[22:47:12] Posted data.
[22:47:12] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:47:12] + News From Folding@Home: Welcome to Folding@Home
[22:47:12] Loaded queue successfully.
[22:47:12] Sent data
[22:47:12] Connecting to http://171.64.65.75:8080/
[22:47:13] Posted data.
[22:47:13] Initial: 0000; - Receiving payload (expected size: 963970)
[22:47:19] - Downloaded at ~156 kB/s
[22:47:19] - Averaged speed for that direction ~116 kB/s
[22:47:19] + Received work.
[22:47:19] Trying to send all finished work units
[22:47:19] + No unsent completed units remaining.
[22:47:19] + Closed connections
[22:47:24]
[22:47:24] + Processing work unit
[22:47:24] Core required: FahCore_a3.exe
[22:47:24] Core found.
[22:47:24] Working on queue slot 07 [September 1 22:47:24 UTC]
[22:47:24] + Working ...
[22:47:24] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 07 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:47:24]
[22:47:24] *------------------------------*
[22:47:24] Folding@Home Gromacs SMP Core
[22:47:24] Version 2.27 (Dec. 15, 2010)
[22:47:24]
[22:47:24] Preparing to commence simulation
[22:47:24] - Assembly optimizations manually forced on.
[22:47:24] - Not checking prior termination.
[22:47:24] - Expanded 963458 -> 2022512 (decompressed 209.9 percent)
[22:47:24] Called DecompressByteArray: compressed_data_size=963458 data_size=2022512, decompressed_data_size=2022512 diff=0
[22:47:25] - Digital signature verified
[22:47:25]
[22:47:25] Project: 10124 (Run 5, Clone 33, Gen 9)
[22:47:25]
[22:47:25] Assembly optimizations on if available.
[22:47:25] Entering M.D.
[22:47:31] Mapping NT from 7 to 7
[22:47:31] mdrun returned 255
[22:47:31] Going to send back what have done -- stepsTotalG=2500000
[22:47:31] Work fraction=0.0000 steps=2500000.
[22:47:35] logfile size=0 infoLength=0 edr=0 trr=25
[22:47:35] logfile size: 0 info=0 bed=0 hdr=25
[22:47:35] - Writing 643 bytes of core data to disk...
[22:47:35] Done: 131 -> 150 (compressed to 114.5 percent)
[22:47:35]   ... Done.
[22:47:35]
[22:47:35] Folding@home Core Shutdown: EARLY_UNIT_END
[22:47:38] CoreStatus = 72 (114)
[22:47:38] Sending work to server
[22:47:38] Project: 10124 (Run 5, Clone 33, Gen 9)
[22:47:38] + Attempting to send results [September 1 22:47:38 UTC]
[22:47:38] - Reading file work/wuresults_07.dat from core
[22:47:38]   (Read 662 bytes from disk)
[22:47:38] Connecting to http://171.64.65.75:8080/
[22:47:39] Posted data.
[22:47:39] Initial: 0000; - Uploaded at ~1 kB/s
[22:47:39] - Averaged speed for that direction ~33 kB/s
[22:47:39] + Results successfully sent
[22:47:39] Thank you for your contribution to Folding@Home.
[22:47:43] Trying to send all finished work units
[22:47:43] + No unsent completed units remaining.
[22:47:43] - Preparing to get new work unit...
[22:47:43] Cleaning up work directory
[22:47:43] + Attempting to get work packet
[22:47:43] Passkey found
[22:47:43] - Will indicate memory of 6135 MB
[22:47:43] - Connecting to assignment server
[22:47:43] Connecting to http://assign.stanford.edu:8080/
[22:47:44] Posted data.
[22:47:44] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:47:44] + News From Folding@Home: Welcome to Folding@Home
[22:47:44] Loaded queue successfully.
[22:47:44] Sent data
[22:47:44] Connecting to http://171.64.65.75:8080/
[22:47:45] Posted data.
[22:47:45] Initial: 0000; - Receiving payload (expected size: 885854)
[22:47:51] - Downloaded at ~144 kB/s
[22:47:51] - Averaged speed for that direction ~122 kB/s
[22:47:51] + Received work.
[22:47:51] Trying to send all finished work units
[22:47:51] + No unsent completed units remaining.
[22:47:51] + Closed connections
[22:47:56]
[22:47:56] + Processing work unit
[22:47:56] Core required: FahCore_a3.exe
[22:47:56] Core found.
[22:47:56] Working on queue slot 08 [September 1 22:47:56 UTC]
[22:47:56] + Working ...
[22:47:56] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 08 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:47:56]
[22:47:56] *------------------------------*
[22:47:56] Folding@Home Gromacs SMP Core
[22:47:56] Version 2.27 (Dec. 15, 2010)
[22:47:56]
[22:47:56] Preparing to commence simulation
[22:47:56] - Assembly optimizations manually forced on.
[22:47:56] - Not checking prior termination.
[22:47:56] - Expanded 885342 -> 1924148 (decompressed 217.3 percent)
[22:47:56] Called DecompressByteArray: compressed_data_size=885342 data_size=1924148, decompressed_data_size=1924148 diff=0
[22:47:56] - Digital signature verified
[22:47:56]
[22:47:56] Project: 10124 (Run 3, Clone 33, Gen 11)
[22:47:56]
[22:47:56] Assembly optimizations on if available.
[22:47:56] Entering M.D.
[22:48:02] Mapping NT from 7 to 7
[22:48:02] mdrun returned 255
[22:48:02] Going to send back what have done -- stepsTotalG=2500000
[22:48:02] Work fraction=0.0000 steps=2500000.
[22:48:06] logfile size=0 infoLength=0 edr=0 trr=25
[22:48:06] logfile size: 0 info=0 bed=0 hdr=25
[22:48:06] - Writing 643 bytes of core data to disk...
[22:48:06] Done: 131 -> 150 (compressed to 114.5 percent)
[22:48:06]   ... Done.
[22:48:06]
[22:48:06] Folding@home Core Shutdown: EARLY_UNIT_END
[22:48:10] CoreStatus = 72 (114)
[22:48:10] Sending work to server
[22:48:10] Project: 10124 (Run 3, Clone 33, Gen 11)
[22:48:10] + Attempting to send results [September 1 22:48:10 UTC]
[22:48:10] - Reading file work/wuresults_08.dat from core
[22:48:10]   (Read 662 bytes from disk)
[22:48:10] Connecting to http://171.64.65.75:8080/
[22:48:11] Posted data.
[22:48:11] Initial: 0000; - Uploaded at ~1 kB/s
[22:48:11] - Averaged speed for that direction ~27 kB/s
[22:48:11] + Results successfully sent
[22:48:11] Thank you for your contribution to Folding@Home.
[22:48:15] Trying to send all finished work units
[22:48:15] + No unsent completed units remaining.
[22:48:15] - Preparing to get new work unit...
[22:48:15] Cleaning up work directory
[22:48:15] + Attempting to get work packet
[22:48:15] Passkey found
[22:48:15] - Will indicate memory of 6135 MB
[22:48:15] - Connecting to assignment server
[22:48:15] Connecting to http://assign.stanford.edu:8080/
[22:48:16] Posted data.
[22:48:16] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:48:16] + News From Folding@Home: Welcome to Folding@Home
[22:48:16] Loaded queue successfully.
[22:48:16] Sent data
[22:48:16] Connecting to http://171.64.65.75:8080/
[22:48:17] Posted data.
[22:48:17] Initial: 0000; - Receiving payload (expected size: 971450)
[22:48:23] - Downloaded at ~158 kB/s
[22:48:23] - Averaged speed for that direction ~129 kB/s
[22:48:23] + Received work.
[22:48:23] Trying to send all finished work units
[22:48:23] + No unsent completed units remaining.
[22:48:23] + Closed connections
[22:48:28]
[22:48:28] + Processing work unit
[22:48:28] Core required: FahCore_a3.exe
[22:48:28] Core found.
[22:48:28] Working on queue slot 09 [September 1 22:48:28 UTC]
[22:48:28] + Working ...
[22:48:28] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:48:28]
[22:48:28] *------------------------------*
[22:48:28] Folding@Home Gromacs SMP Core
[22:48:28] Version 2.27 (Dec. 15, 2010)
[22:48:28]
[22:48:28] Preparing to commence simulation
[22:48:28] - Assembly optimizations manually forced on.
[22:48:28] - Not checking prior termination.
[22:48:28] - Expanded 970938 -> 2034860 (decompressed 209.5 percent)
[22:48:28] Called DecompressByteArray: compressed_data_size=970938 data_size=2034860, decompressed_data_size=2034860 diff=0
[22:48:29] - Digital signature verified
[22:48:29]
[22:48:29] Project: 10124 (Run 7, Clone 34, Gen 3)
[22:48:29]
[22:48:29] Assembly optimizations on if available.
[22:48:29] Entering M.D.
[22:48:35] Mapping NT from 7 to 7
[22:48:35] mdrun returned 255
[22:48:35] Going to send back what have done -- stepsTotalG=2500000
[22:48:35] Work fraction=0.0000 steps=2500000.
[22:48:39] logfile size=0 infoLength=0 edr=0 trr=25
[22:48:39] logfile size: 0 info=0 bed=0 hdr=25
[22:48:39] - Writing 643 bytes of core data to disk...
[22:48:39] Done: 131 -> 150 (compressed to 114.5 percent)
[22:48:39]   ... Done.
[22:48:39]
[22:48:39] Folding@home Core Shutdown: EARLY_UNIT_END
[22:48:42] CoreStatus = 72 (114)
[22:48:42] Sending work to server
[22:48:42] Project: 10124 (Run 7, Clone 34, Gen 3)
[22:48:42] + Attempting to send results [September 1 22:48:42 UTC]
[22:48:42] - Reading file work/wuresults_09.dat from core
[22:48:42]   (Read 662 bytes from disk)
[22:48:42] Connecting to http://171.64.65.75:8080/
[22:48:43] Posted data.
[22:48:43] Initial: 0000; - Uploaded at ~1 kB/s
[22:48:43] - Averaged speed for that direction ~22 kB/s
[22:48:43] + Results successfully sent
[22:48:43] Thank you for your contribution to Folding@Home.
[22:48:47] Trying to send all finished work units
[22:48:47] + No unsent completed units remaining.
[22:48:47] - Preparing to get new work unit...
[22:48:47] Cleaning up work directory
[22:48:47] + Attempting to get work packet
[22:48:47] Passkey found
[22:48:47] - Will indicate memory of 6135 MB
[22:48:47] - Connecting to assignment server
[22:48:47] Connecting to http://assign.stanford.edu:8080/
[22:48:48] Posted data.
[22:48:48] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:48:48] + News From Folding@Home: Welcome to Folding@Home
[22:48:48] Loaded queue successfully.
[22:48:48] Sent data
[22:48:48] Connecting to http://171.64.65.75:8080/
[22:48:49] Posted data.
[22:48:49] Initial: 0000; - Receiving payload (expected size: 974664)
[22:48:55] - Downloaded at ~158 kB/s
[22:48:55] - Averaged speed for that direction ~135 kB/s
[22:48:55] + Received work.
[22:48:55] Trying to send all finished work units
[22:48:55] + No unsent completed units remaining.
[22:48:55] + Closed connections
[22:49:00]
[22:49:00] + Processing work unit
[22:49:00] Core required: FahCore_a3.exe
[22:49:00] Core found.
[22:49:00] Working on queue slot 00 [September 1 22:49:00 UTC]
[22:49:00] + Working ...
[22:49:00] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 00 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:49:00]
[22:49:00] *------------------------------*
[22:49:00] Folding@Home Gromacs SMP Core
[22:49:00] Version 2.27 (Dec. 15, 2010)
[22:49:00]
[22:49:00] Preparing to commence simulation
[22:49:00] - Assembly optimizations manually forced on.
[22:49:00] - Not checking prior termination.
[22:49:00] - Expanded 974152 -> 2034944 (decompressed 208.8 percent)
[22:49:00] Called DecompressByteArray: compressed_data_size=974152 data_size=2034944, decompressed_data_size=2034944 diff=0
[22:49:01] - Digital signature verified
[22:49:01]
[22:49:01] Project: 10124 (Run 1, Clone 34, Gen 7)
[22:49:01]
[22:49:01] Assembly optimizations on if available.
[22:49:01] Entering M.D.
[22:49:07] Mapping NT from 7 to 7
[22:49:07] mdrun returned 255
[22:49:07] Going to send back what have done -- stepsTotalG=2500000
[22:49:07] Work fraction=0.0000 steps=2500000.
[22:49:11] logfile size=0 infoLength=0 edr=0 trr=25
[22:49:11] logfile size: 0 info=0 bed=0 hdr=25
[22:49:11] - Writing 643 bytes of core data to disk...
[22:49:11] Done: 131 -> 148 (compressed to 112.9 percent)
[22:49:11]   ... Done.
[22:49:11]
[22:49:11] Folding@home Core Shutdown: EARLY_UNIT_END
[22:49:15] CoreStatus = 72 (114)
[22:49:15] Sending work to server
[22:49:15] Project: 10124 (Run 1, Clone 34, Gen 7)
[22:49:15] + Attempting to send results [September 1 22:49:15 UTC]
[22:49:15] - Reading file work/wuresults_00.dat from core
[22:49:15]   (Read 660 bytes from disk)
[22:49:15] Connecting to http://171.64.65.75:8080/
[22:49:15] Posted data.
[22:49:15] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[22:49:15] - Uploaded at ~3 kB/s
[22:49:15] - Averaged speed for that direction ~20 kB/s
[22:49:15] + Results successfully sent
[22:49:15] Thank you for your contribution to Folding@Home.
[22:49:19] Trying to send all finished work units
[22:49:19] + No unsent completed units remaining.
[22:49:19] - Preparing to get new work unit...
[22:49:19] Cleaning up work directory
[22:49:19] + Attempting to get work packet
[22:49:19] Passkey found
[22:49:19] - Will indicate memory of 6135 MB
[22:49:19] - Connecting to assignment server
[22:49:19] Connecting to http://assign.stanford.edu:8080/
[22:49:20] Posted data.
[22:49:20] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:49:20] + News From Folding@Home: Welcome to Folding@Home
[22:49:20] Loaded queue successfully.
[22:49:20] Sent data
[22:49:20] Connecting to http://171.64.65.75:8080/
[22:49:21] Posted data.
[22:49:21] Initial: 0000; - Receiving payload (expected size: 963236)
[22:49:29] - Downloaded at ~117 kB/s
[22:49:29] - Averaged speed for that direction ~131 kB/s
[22:49:29] + Received work.
[22:49:29] Trying to send all finished work units
[22:49:29] + No unsent completed units remaining.
[22:49:29] + Closed connections
[22:49:34]
[22:49:34] + Processing work unit
[22:49:34] Core required: FahCore_a3.exe
[22:49:34] Core found.
[22:49:34] Working on queue slot 01 [September 1 22:49:34 UTC]
[22:49:34] + Working ...
[22:49:34] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:49:34]
[22:49:34] *------------------------------*
[22:49:34] Folding@Home Gromacs SMP Core
[22:49:34] Version 2.27 (Dec. 15, 2010)
[22:49:34]
[22:49:34] Preparing to commence simulation
[22:49:34] - Assembly optimizations manually forced on.
[22:49:34] - Not checking prior termination.
[22:49:34] - Expanded 962724 -> 2023268 (decompressed 210.1 percent)
[22:49:34] Called DecompressByteArray: compressed_data_size=962724 data_size=2023268, decompressed_data_size=2023268 diff=0
[22:49:34] - Digital signature verified
[22:49:34]
[22:49:34] Project: 10124 (Run 2, Clone 34, Gen 7)
[22:49:34]
[22:49:34] Assembly optimizations on if available.
[22:49:34] Entering M.D.
[22:49:40] Mapping NT from 7 to 7
[22:49:40] mdrun returned 255
[22:49:40] Going to send back what have done -- stepsTotalG=2500000
[22:49:40] Work fraction=0.0000 steps=2500000.
[22:49:44] logfile size=0 infoLength=0 edr=0 trr=25
[22:49:44] logfile size: 0 info=0 bed=0 hdr=25
[22:49:44] - Writing 643 bytes of core data to disk...
[22:49:44] Done: 131 -> 149 (compressed to 113.7 percent)
[22:49:44]   ... Done.
[22:49:44]
[22:49:44] Folding@home Core Shutdown: EARLY_UNIT_END
[22:49:48] CoreStatus = 72 (114)
[22:49:48] Sending work to server
[22:49:48] Project: 10124 (Run 2, Clone 34, Gen 7)
[22:49:48] + Attempting to send results [September 1 22:49:48 UTC]
[22:49:48] - Reading file work/wuresults_01.dat from core
[22:49:48]   (Read 661 bytes from disk)
[22:49:48] Connecting to http://171.64.65.75:8080/
[22:49:48] Posted data.
[22:49:48] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[22:49:48] - Uploaded at ~3 kB/s
[22:49:48] - Averaged speed for that direction ~18 kB/s
[22:49:48] + Results successfully sent
[22:49:48] Thank you for your contribution to Folding@Home.
[22:49:52] Trying to send all finished work units
[22:49:52] + No unsent completed units remaining.
[22:49:52] - Preparing to get new work unit...
[22:49:52] Cleaning up work directory
[22:49:52] + Attempting to get work packet
[22:49:52] Passkey found
[22:49:52] - Will indicate memory of 6135 MB
[22:49:52] - Connecting to assignment server
[22:49:52] Connecting to http://assign.stanford.edu:8080/
[22:49:53] Posted data.
[22:49:53] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[22:49:53] + News From Folding@Home: Welcome to Folding@Home
[22:49:53] Loaded queue successfully.
[22:49:53] Sent data
[22:49:53] Connecting to http://171.64.65.75:8080/
[22:49:54] Posted data.
[22:49:55] Initial: 0000; - Receiving payload (expected size: 964668)
[22:50:02] - Downloaded at ~134 kB/s
[22:50:02] - Averaged speed for that direction ~132 kB/s
[22:50:02] + Received work.
[22:50:02] Trying to send all finished work units
[22:50:02] + No unsent completed units remaining.
[22:50:02] + Closed connections
[22:50:07]
[22:50:07] + Processing work unit
[22:50:07] Core required: FahCore_a3.exe
[22:50:07] Core found.
[22:50:07] Working on queue slot 02 [September 1 22:50:07 UTC]
[22:50:07] + Working ...
[22:50:07] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:50:08]
[22:50:08] *------------------------------*
[22:50:08] Folding@Home Gromacs SMP Core
[22:50:08] Version 2.27 (Dec. 15, 2010)
[22:50:08]
[22:50:08] Preparing to commence simulation
[22:50:08] - Assembly optimizations manually forced on.
[22:50:08] - Not checking prior termination.
[22:50:08] - Expanded 964156 -> 2022512 (decompressed 209.7 percent)
[22:50:08] Called DecompressByteArray: compressed_data_size=964156 data_size=2022512, decompressed_data_size=2022512 diff=0
[22:50:08] - Digital signature verified
[22:50:08]
[22:50:08] Project: 10124 (Run 5, Clone 34, Gen 7)
[22:50:08]
[22:50:08] Assembly optimizations on if available.
[22:50:08] Entering M.D.
[22:50:14] Mapping NT from 7 to 7
[22:50:14] mdrun returned 255
[22:50:14] Going to send back what have done -- stepsTotalG=2500000
[22:50:14] Work fraction=0.0000 steps=2500000.
[22:50:18] logfile size=0 infoLength=0 edr=0 trr=25
[22:50:18] logfile size: 0 info=0 bed=0 hdr=25
[22:50:18] - Writing 643 bytes of core data to disk...
[22:50:18] Done: 131 -> 149 (compressed to 113.7 percent)
[22:50:18]   ... Done.
[22:50:18]
[22:50:18] Folding@home Core Shutdown: EARLY_UNIT_END
[22:50:22] CoreStatus = 72 (114)
[22:50:22] Sending work to server
[22:50:22] Project: 10124 (Run 5, Clone 34, Gen 7)
[22:50:22] + Attempting to send results [September 1 22:50:22 UTC]
[22:50:22] - Reading file work/wuresults_02.dat from core
[22:50:22]   (Read 661 bytes from disk)
[22:50:22] Connecting to http://171.64.65.75:8080/
[22:50:22] Posted data.
[22:50:22] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[22:50:22] - Uploaded at ~3 kB/s
[22:50:22] - Averaged speed for that direction ~16 kB/s
[22:50:22] + Results successfully sent
[22:50:22] Thank you for your contribution to Folding@Home.
[22:50:26] Trying to send all finished work units
[22:50:26] + No unsent completed units remaining.
[22:50:26] - Preparing to get new work unit...
[22:50:26] Cleaning up work directory
[22:50:26] + Attempting to get work packet
[22:50:26] Passkey found
[22:50:26] - Will indicate memory of 6135 MB
[22:50:26] - Connecting to assignment server
[22:50:26] Connecting to http://assign.stanford.edu:8080/
[22:50:27] Posted data.
[22:50:27] Initial: 40AB; - Successful: assigned to (171.64.65.54).
[22:50:27] + News From Folding@Home: Welcome to Folding@Home
[22:50:27] Loaded queue successfully.
[22:50:27] Sent data
[22:50:27] Connecting to http://171.64.65.54:8080/
[22:50:28] Posted data.
[22:50:29] Initial: 0000; - Receiving payload (expected size: 1765886)
[22:50:40] - Downloaded at ~156 kB/s
[22:50:40] - Averaged speed for that direction ~137 kB/s
[22:50:40] + Received work.
[22:50:40] Trying to send all finished work units
[22:50:40] + No unsent completed units remaining.
[22:50:40] + Closed connections
[22:50:45]
[22:50:45] + Processing work unit
[22:50:45] Core required: FahCore_a3.exe
[22:50:45] Core found.
[22:50:45] Working on queue slot 03 [September 1 22:50:45 UTC]
[22:50:45] + Working ...
[22:50:45] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 03 -np 7 -checkpoint 10 -forceasm -verbose -lifeline 6472 -version 630'
[22:50:45]
[22:50:45] *------------------------------*
[22:50:45] Folding@Home Gromacs SMP Core
[22:50:45] Version 2.27 (Dec. 15, 2010)
[22:50:45]
[22:50:45] Preparing to commence simulation
[22:50:45] - Assembly optimizations manually forced on.
[22:50:45] - Not checking prior termination.
[22:50:46] - Expanded 1765374 -> 2257001 (decompressed 127.8 percent)
[22:50:46] Called DecompressByteArray: compressed_data_size=1765374 data_size=2257001, decompressed_data_size=2257001 diff=0
[22:50:46] - Digital signature verified
[22:50:46]
[22:50:46] Project: 6060 (Run 0, Clone 119, Gen 414)
[22:50:46]
[22:50:46] Assembly optimizations on if available.
[22:50:46] Entering M.D.
[22:50:52] Mapping NT from 7 to 7
[22:50:52] Completed 0 out of 500000 steps  (0%)
[22:54:19] Completed 5000 out of 500000 steps  (1%)
Re: Project: 10124 (... well all of them apparently)
Is the computer overclocked? Back it off a few GHz.
Note that past performance is no guarantee of future stability. FAH is very good at squeezing out more performance, which works the system harder than before, which may push it over the edge of stability.
bollix47
Post by bollix47 »
The first thing I would try is updating the client to version 6.34.
The second would be changing the number of threads being used. If you can't go with -smp 8 for some reason then try -smp 6. Some WUs have a problem with -smp 7. If you end up using -smp 6 then you could run a uniprocessor client on the freed up core.
^w^ing
forceware 260.89
Asus P5N-E SLi
WinXP 32 SP3
Post by ^w^ing »
bollix47 wrote:The first thing I would try is updating the client to version 6.34.
Damn, I thought I already had the latest client... but then again I wasn't sticking around much lately. Well spotted, will update asap.
The second would be changing the number of cores being used. If you can't go with -smp 8 for some reason then try -smp 6. Some WUs have a problem with -smp 7. If you end up using -smp 6 then you could run a uniprocessor client on the freed up core.
I have read about this, and I was under the impression it was only causing issues with high thread count. Good suggestion nonetheless, thanks.
bollix47
Post by bollix47 »
Since you appear to be using a fermi gpu there is another option depending on how much you use the computer for other activities that involve heavy gpu usage.
Add the -advmethods flag to your gpu client. This will get you work units that make much better utilization of your fermi card and less frequent cpu interruption which would enable you to use -smp 8 for your smp client with little or no PPD loss. In fact you will get more PPD on your smp client than you currently do.
There was an announcement that these gpu work units will stay on advanced for the foreseeable future:
viewtopic.php?f=24&t=19390&p=194433#p194433
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
bollix47 wrote:Since you appear to be using a fermi gpu there is another option depending on how much you use the computer for other activities that involve heavy gpu usage.
Careful though, -advmethods will have your card request new/beta WUs from Stanford, which may quit early more frequently than normal. If you read the thread, the reason that the work units will stay on -advmethods is because they stress things more than usual. Sure you may get those WUs that fully utilize your GPU card, but they may be less stable. That's my understanding.
bollix47
Post by bollix47 »
Thanks for mentioning that Jesse. I did have to increase the fan speed on my GTX 480, using MSI Afterburner, to 100% to keep the temperatures down. I've had no EUE or other problems.
^w^ing
forceware 260.89
Asus P5N-E SLi
WinXP 32 SP3
Post by ^w^ing »
I'm using smp -7 because I use the pc alot and I found it this way to be the most efficient, the gpu client uses virtually no cpu since the last time I updated gpu drivers so the gpu client isn't an issue. Also last time I ran some huge beta gpu WUs, my UPS didn't like it, at all ;) but the idea always intrigued me so I'm probably gonna try it anyway.
^w^ing
forceware 260.89
Asus P5N-E SLi
WinXP 32 SP3
Post by ^w^ing »
just wanted to give an update on this, the odd number of threads does indeed seem to be the issue here, just got a new project 10124 WU and it works fine so far with -smp 6. Cheers.
