Had a v6.34 smp -advmethods WU fail on my 6 core phenom2, and there was a post at overclockers.com of the same WU failing, so I thought I'd let you know.
- Dana
[14:51:45] *------------------------------*
[14:51:45] Folding@Home Gromacs SMP Core
[14:51:45] Version 2.27 (Dec. 15, 2010)
[14:51:45]
[14:51:45] Preparing to commence simulation
[14:51:45] - Assembly optimizations manually forced on.
[14:51:45] - Not checking prior termination.
[14:51:46] - Expanded 1763188 -> 2249941 (decompressed 127.6 percent)
[14:51:46] Called DecompressByteArray: compressed_data_size=1763188 data_size=22
49941, decompressed_data_size=2249941 diff=0
[14:51:46] - Digital signature verified
[14:51:46]
[14:51:46] Project: 6068 (Run 1, Clone 38, Gen 253)
[14:51:46]
[14:51:46] Assembly optimizations on if available.
[14:51:46] Entering M.D.
[14:51:52] Mapping NT from 6 to 6
[14:51:52] Completed 0 out of 500000 steps (0%)
[14:51:52] mdrun returned 255
[14:51:52] Going to send back what have done -- stepsTotalG=500000
[14:51:52] Work fraction=0.0000 steps=500000.
[14:51:56] logfile size=0 infoLength=0 edr=0 trr=25
[14:51:56] logfile size: 0 info=0 bed=0 hdr=25
[14:51:56] - Writing 642 bytes of core data to disk...
[14:51:56] ... Done.
[14:51:56]
[14:51:56] Folding@home Core Shutdown: EARLY_UNIT_END
[14:52:00] CoreStatus = 72 (114)
[14:52:00] Sending work to server
[14:52:00] Project: 6068 (Run 1, Clone 38, Gen 253)
[14:52:00] + Attempting to send results [August 22 14:52:00 UTC]
[14:52:01] + Results successfully sent
[14:52:01] Thank you for your contribution to Folding@Home.
[14:52:05] - Preparing to get new work unit...
starkreiten
Of course, I could be wrong....
- AMD 1090t Win7/64 2xGTX460 SMP + 2xGPU
- Intel U7300 LMDE/64 2xUniprocessor
Re: Project: 6068 (Run 1, Clone 38, Gen 253)
Thanks for the report. It was, indeed, a bad WU. I've reported it and it will be stopped at 8am. In the 11 days it has been in circulation, a LOT of people received it but you're the first to report it.
keep getting this bad work unit, please delete!
19:31:48] Project: 6068 (Run 1, Clone 38, Gen 253)
[19:31:48]
[19:31:48] Assembly optimizations on if available.
[19:31:48] Entering M.D.
[19:31:54] Mapping NT from 8 to 8
[19:31:54] Completed 0 out of 500000 steps (0%)
[19:32:02] CoreStatus = C0000029 (-1073741783)
[19:32:02] Client-core communications error: ERROR 0xc0000029
[19:32:02] Deleting current work unit & continuing...
[19:32:14] Trying to send all finished work units
[19:32:14] + No unsent completed units remaining.
[19:32:14] - Preparing to get new work unit...
[19:32:14] Cleaning up work directory
rinse and repeat, downloads new cores etc....
Teddy
[19:31:48]
Teddy
