Folding OS
MillenniumBuilder
Folding OS
Are there any plans to develop a Folding@home dedicated operating system? It could be far more efficient than the normal client, even where Folding@home is the only process running, which would increase in percentage hugely. Dedicated operating systems have the potential to provide major amounts.
orion
- Hardware configuration: 4p/4 MC ES @ 3.0GHz/32GB
4p/4x6128 @ 2.47GHz/32GB
2p/2 IL ES @ 2.7GHz/16GB
1p/8150/8GB
1p/1090T/4GB - Location: neither here nor there
Re: Folding OS
There have been some that have taken LINUX and stripped it down to what is only needed for folding. Here is a link to a few, check out the Diskless folding programs (based on linux) section. viewtopic.php?f=14&t=52
iustus quia...
Re: Folding OS
For the life of me I can't get Notfred's diskless folding program working. I used the ISO maker, built a bootable image on USB disk, and keep getting the "No boot media" message when restarting the computer.
Re: Folding OS
This doesn't seem like a Notfred problem. It does seems like a computer problem. Maybe the bios isn't configured to boot from USB. Or so old it doesn't support it. Can you boot from other USB sticks?
Again, Notfred has a dedicated thread to answering questions on his home forum. Your best bet for assistance is posting over there.
Spitfire19
- Hardware configuration: ATI Phenom II X4 965 BE (stock), 2GB Radeon HD 6950 (Factory-OC), Windows 7 64bit-OS, Kingston 8GB DDR3 1066MHz, ASUS M4A89TD, GPU2 6.23
Re: Folding OS
I like the idea, though a simpler method needs to be developed. I'll try getting F@H working on a USB stick I own and see what I can do. I'll try to get latest Linux SMP working.orion wrote:There have been some that have taken LINUX and stripped it down to what is only needed for folding. Here is a link to a few, check out the Diskless folding programs (based on linux) section. viewtopic.php?f=14&t=52
AMD 965 + Radeon HD 6950 + Win7 Home(x64) + V7.1.52
Currently Working On: Finishing the summer semester.
Spitfire19
Re: Folding OS
I was able to get a LiveUSB of Ubuntu running 6.02. Now the question is if I can run newer version on a 64-bit OS w/ SMP. (Current computer is not capable) Whether or not I can make it as simple as copy pasting the files on the USB for distribution. And try out other LiveUSB like CentOS or Scientific Linux. (Everyone loves stability).Spitfire19 wrote:I like the idea, though a simpler method needs to be developed. I'll try getting F@H working on a USB stick I own and see what I can do. I'll try to get latest Linux SMP working.orion wrote:There have been some that have taken LINUX and stripped it down to what is only needed for folding. Here is a link to a few, check out the Diskless folding programs (based on linux) section. viewtopic.php?f=14&t=52
Spitfire19
Re: Folding OS
Hmm, no persistent storage on CentOS 5 Live USB eh? guess I'll think of work arounds. Or would you guys instead prefer to see it on Scientific Linux? Just to get on Scientificy for the hell of it.
Nathan_P
Not currently folding
Re: Folding OS
If you are struggling check out the forums of the top teams, they have excellent guides for loading up ubuntu and letting rip. Even for a total windophile they are easy to follow
Re: Folding OS
I used to run notfred's usb setup which backs up to a usb stick. Basically, when starting up it would copy the client files from the usb stick to memory. If you copy the latest client to the usb's backup directory (?/?/1/) and rename it to fah6.exe or maybe just fah6(sorry but it's been a while) then it will be restored to memory when the client start's up. What the client does when starting up is create a link to 6.02 but it can't now because a file is already there with that name so the newer client will be used for processing.
When you tried to use notfred did you run syslinux:
"From a command prompt run "syslinux <device>" where <device> is the device or drive letter of the USB stick, e.g. "syslinux X:" for Windows, "./syslinux /dev/sda1" for Linux (should not be mounted). If it complains about unable to lock the device for exclusive access, ignore the warning."
http://reilly.homeip.net/folding/usb.html
Spitfire19
Re: Folding OS
Needs:
Help choose which OSs I should do this with! maybe I'll try Yellowdog even.
Need to get my hands on a new USB drive before trying this though.
- Live USB with persistent storage solution
- latest Linux SMP client. (v7 w/ Wine attempt can come later)
- fahlimit
- lm_sensors
MtM
Re: Folding OS
There are some really small FreeBSD based distro's I find interesting ( mostly because my router is FreeBSD based ).
If you could add the gpu wrapper in a live os you'll have something which has greater functionality then NotFred's.
Spitfire19
Re: Folding OS
Very true, unfortuanately I can not start on the 64-bit attempt until the end of the week because I am actively using the i386 live USB for other projects this week.MtM wrote:There are some really small FreeBSD based distro's I find interesting ( mostly because my router is FreeBSD based ).
Spitfire19
Re: Folding OS
What's the best way to distribute a 7GB file?
Re: Folding OS
8 GB flash drive.
MtM
