i go to this link, http://fah-web.stanford.edu/awards/cach ... y.4425.jpg
it shows the 4'200 points.
and if i go to this link, http://fah-web.stanford.edu/awards/cach ... key.14.jpg
it shows me my 13 WU banner,
Strange? Yes.
-Epicmonkey
strange...
Epicmonkey
strange...
To All New Members, Welcome to F@h and Enjoy your stay -
Zagen30
Re: strange...
Why is this strange? The Pande Group has always had separate certificates for WUs and points (or at least as far back as 2007).
Epicmonkey
Re: strange...
i have 14 WU's done and showing a 13 WU banner, and i have 4'400+ points and showing 4'200.
Zagen30
Re: strange...
There's probably a decent amount of time between updating the stats and updating the certificates. Also, once you start accumulating a lot of points, the certificates only get updated when you hit milestones; for example, right now my primary username/team combo has 18.8 million points from just under 17,000 WUs, but the certificates only shows 18 million and 16,000, respectively. Your points are already being rounded off to save time, and the WU count will probably go that way soon as well.
