Folding and BOINCing (pardon the expression) and VM
Sciurus Winterwolf
Post by Sciurus Winterwolf »
I've been BOINCing since 1998 :) and only Folding from this month.
I'm building a machine to be dedicated to both BOINCing and Folding.
Is there any benfit to run these separetly in 2 VMs using ms hyper-v?
Re: Folding and BOINCing (pardon the expression) and VM
Folding@home and BOINC can be run simultaneously, though I suspect that very few people actually do it. This can be done either by running multiple VMs or by simply running both clients in your native OS. The two will compete for hardware resources and the fundamental issue that has to be worked out is how your system will allocate those resources to each project.
Folding@home projects are on a strict deadline, and many projects earn more points when returned more quickly, so allocating less that 100% of your system to FAH will reduce the points that FAH earns. Using separate VMs doesn't change this fact. Some BOINC projects are also deadline-critical while for many BOINC projects, the deadline is more of a guideline. (You'll have to get that kind of information from BOINC.)
The BOINC + FAH question has been asked a number of times on this forum. You'll find additional information by searching for topics about BOINC.
Sciurus Winterwolf
ok, I found some BOINC threads. What i'll probably do is run Fah on a dedicated machine and run BOINC on my Win 7 machine. I'm more familiar with BOINC settings.
