All the Fermi GPU WUs I've gotten between 30 June and today, 22 July, have been from the P6802/3/4 series. It's some 220 of them now.
I was pondering from the server stats that this project seems to be a "just in time" reprocessing of completed WUs into new WUs along the project trajectories. The profiles seem to be different than those I've seen in other projects - very low WU Available considering the frantic pace of assignments. The stats are showing this server has ~30%+ of the GPU assignments.
[What follows is my pure conjecture about the project design from the server stats.]
When I produce these charts, I don't usually scale the WU Avail and WU Received axes the same since there are usually many, many more avail than received. But, they are scaled the same here.
It seems that a large batch of WUs were generated to start the series out - 4798 per the stats. Then, as the weighting resulted in more of these WUs being assigned, after the seeming runout of the p6801 series, the reservoir went down.
In the last week or so, it seems to have reached a steady state - there are about 850 +/- WUs available against a WU return average of about 400 every 35 minutes.
The back end must be reprocessing those returned WUs just in time to keep barely enough WUs in the reservoir to match the assignments.
No big message here, just observations from a "staring at goats" retiree who tries to understand the project.
Thanks, PG, for keeping it interesting.
