4Gb DDR3
The OS itself is stable but dumps these errors on me now and then.
On the smaller BA units as well as the larger ones 6900 & 6903 for eg.
I have another machine identical to this that floats along no problems
I have thought that it could be the clock speed of the CPU but having wound both the memory and cpu timings right back still produces the error.
I have with & without GPU aswell.
a summation of the error is below. (sometimes at the beginning, sometimes after a day or 2)
[10:02:24] Project: 6903 (Run 3, Clone 6, Gen 16)
[10:02:46] Completed 765 out of 250000 steps (0%)
step 4001399: Water molecule starting at atom 573289 can not be settled.
Check for bad contacts and/or reduce the timestep if appropriate.
step 4001400: Water molecule starting at atom 652852 can not be settled.
step 4001400: Water molecule starting at atom 2431945 can not be settled.
step 4001400: Water molecule starting at atom 573289 can not be settled.
Segmentation fault
[10:15:20] CoreStatus = 8B (139)
[10:15:20] Client-core communications error: ERROR 0x8b
[10:15:20] Deleting current work unit & continuing...
