Hi,
This may be more of a Windows question than a FAH question. I'm new to Windows 7...
I just installed the GPU2 systray client on my adminstrator acount, and it seems to be working on the adminstrator account. However, I mainly use my standard user account, and I can open the client in the standard user account, but it doesn't seem to function correctly - can't find the core, can't find the log file. I'm sure it's some simple user priveleges issue that I just don't know how to fix.
Thanks in advance
Windows 7 Standard User
Re: Windows 7 Standard User
Welcome to the F@H Forum BV021,
We are happy to help out with any F@H related issue
How about you right click the shortcut -> Properties -> Compatibility Tab and the last option "Run this program as an administrator" and then try to run it. If it fails, then please post the FAHlog (viewtopic.php?p=160884#p160884) so we can help you troubleshoot the issue.
