Project 7500 -> Instant EUE, allways
Mactin
Post by Mactin »
On my i7-980x, I usualy run a -bigadv with -smp 10.
This normaly runs without any problems, but this week, I had a few faillures in a row, that resulted in a WU not getting a bonus :-(
So I schwitched back to regular smp units in order to get back my bonus status faster. It happens I did this for nothing because I got the said bonus on the last bigadv, before the schwitch over (you only know you did not get the bonus after you started the next WU, I completed that WU thinkning I would not get again the bonus, the WU after this one was a regular smp).
Then the real problem starts.
I have had since then six p7500 WUs that all instantly EUEed
In between other (regular smp) WUs ran witout any problems.
So :
p6900-r8-c12-g8, 2011-06-29 05:07:55, 8955 points
p6900-r51-c17-g8, 2011-07-01 03:30:29, 81079 points
p7500-r0-c129-g83, 2011-07-01 03:43:40, 0 points, Instant EUE
p7500-r0-c158-g69, 2011-07-01 03:44:10, 0 points, Instant EUE
p7501-r0-c164-g24, 2011-07-01 07:16:18, 4257 points
p7500-r0-c291-g14, 2011-07-01 07:17:38, 0 points, Instant EUE
p7500-r0-c314-g14, 2011-07-01 07:18:08, 0 points, Instant EUE
p7501-r0-c276-g14, 2011-07-01 10:49:39, 3891 points
p7500-r0-c57-g142, 2011-07-01 10:50:59, 0 points, Instant EUE
p6945-r0-c41-g79, 2011-07-01 19:23:48, 4775 points
p7500-r0-c154-g68, 2011-07-01 19:24:46, 0 points, Instant EUE
p7501-r0-c231-g20, Now running
Most recent logs :
--- Opening Log file [July 1 15:09:50 UTC]
                       Folding@Home Client Version 6.34
                          http://folding.stanford.edu
Launch directory: C:\Program Files (x86)\folding\m1 SMP
Executable: C:\Program Files (x86)\folding\m1 SMP\Folding@home-Win32-x86.exe
Arguments: -smp 10 -verbosity 9 -forceasm -config
[15:09:50] - Ask before connecting: No
[15:09:50] - User name: Martin_i7-980x (Team 96377)
[15:09:50] - User ID: 6C6A12517E046D46
[15:09:50] - Machine ID: 1
[15:09:50]
[15:09:50] Configuring Folding@Home...
[15:10:14] - Ask before connecting: No
[15:10:14] - User name: Martin_i7-980x (Team 96377)
[15:10:14] - User ID: 6C6A12517E046D46
[15:10:14] - Machine ID: 1
[15:10:14]
[15:10:14] Loaded queue successfully.
[15:10:14] - Autosending finished units... [July 1 15:10:14 UTC]
[15:10:14] - Preparing to get new work unit...
[15:10:14] Trying to send all finished work units
[15:10:14] + No unsent completed units remaining.
[15:10:14] - Autosend completed
[15:10:14] Cleaning up work directory
[15:10:18] + Attempting to get work packet
[15:10:18] Passkey found
[15:10:18] - Will indicate memory of 8888 MB
[15:10:18] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 12, Stepping: 2
[15:10:18] - Connecting to assignment server
[15:10:18] Connecting to http://assign.stanford.edu:8080/
[15:10:19] Posted data.
[15:10:19] Initial: 8F80; - Successful: assigned to (128.143.199.96).
[15:10:19] + News From Folding@Home: Welcome to Folding@Home
[15:10:19] Loaded queue successfully.
[15:10:19] Sent data
[15:10:19] Connecting to http://128.143.199.96:8080/
[15:10:20] Posted data.
[15:10:20] Initial: 0000; - Receiving payload (expected size: 1766624)
[15:10:22] - Downloaded at ~862 kB/s
[15:10:22] - Averaged speed for that direction ~933 kB/s
[15:10:22] + Received work.
[15:10:22] + Closed connections
[15:10:22]
[15:10:22] + Processing work unit
[15:10:22] Core required: FahCore_a3.exe
[15:10:22] Core found.
[15:10:22] Working on queue slot 04 [July 1 15:10:22 UTC]
[15:10:22] + Working ...
[15:10:22] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 04 -np 10 -checkpoint 10 -forceasm -verbose -lifeline 5064 -version 634'
[15:10:22]
[15:10:22] *------------------------------*
[15:10:22] Folding@Home Gromacs SMP Core
[15:10:22] Version 2.27 (Dec. 15, 2010)
[15:10:22]
[15:10:22] Preparing to commence simulation
[15:10:22] - Assembly optimizations manually forced on.
[15:10:22] - Not checking prior termination.
[15:10:22] - Expanded 1766112 -> 1952000 (decompressed 110.5 percent)
[15:10:22] Called DecompressByteArray: compressed_data_size=1766112 data_size=1952000, decompressed_data_size=1952000 diff=0
[15:10:22] - Digital signature verified
[15:10:22]
[15:10:22] Project: 6945 (Run 0, Clone 41, Gen 79)
[15:10:22]
[15:10:22] Assembly optimizations on if available.
[15:10:22] Entering M.D.
[15:10:29] Mapping NT from 10 to 10
[15:10:30] Completed 0 out of 500000 steps  (0%)
[15:13:01] Completed 5000 out of 500000 steps  (1%)
[15:15:31] Completed 10000 out of 500000 steps  (2%)
[19:18:31] Completed 490000 out of 500000 steps  (98%)
[19:21:03] Completed 495000 out of 500000 steps  (99%)
[19:23:34] Completed 500000 out of 500000 steps  (100%)
[19:23:35] DynamicWrapper: Finished Work Unit: sleep=10000
[19:23:45]
[19:23:45] Finished Work Unit:
[19:23:45] - Reading up to 3698496 from "work/wudata_04.trr": Read 3698496
[19:23:45] trr file hash check passed.
[19:23:45] edr file hash check passed.
[19:23:45] logfile size: 57795
[19:23:45] Leaving Run
[19:23:47] - Writing 3791227 bytes of core data to disk...
[19:23:48] Done: 3790715 -> 3519998 (compressed to 92.8 percent)
[19:23:48]   ... Done.
[19:23:48] - Shutting down core
[19:23:48]
[19:23:48] Folding@home Core Shutdown: FINISHED_UNIT
[19:23:52] CoreStatus = 64 (100)
[19:23:52] Unit 4 finished with 96 percent of time to deadline remaining.
[19:23:52] Updated performance fraction: 0.845172
[19:23:52] Sending work to server
[19:23:52] Project: 6945 (Run 0, Clone 41, Gen 79)
[19:23:52] + Attempting to send results [July 1 19:23:52 UTC]
[19:23:52] - Reading file work/wuresults_04.dat from core
[19:23:52]   (Read 3520510 bytes from disk)
[19:23:52] Connecting to http://128.143.199.96:8080/
[19:24:19] Posted data.
[19:24:19] Initial: 0000; - Uploaded at ~127 kB/s
[19:24:19] - Averaged speed for that direction ~98 kB/s
[19:24:19] + Results successfully sent
[19:24:19] Thank you for your contribution to Folding@Home.
[19:24:19] + Number of Units Completed: 572
[19:24:23] Trying to send all finished work units
[19:24:23] + No unsent completed units remaining.
[19:24:23] - Preparing to get new work unit...
[19:24:23] Cleaning up work directory
[19:24:32] + Attempting to get work packet
[19:24:32] Passkey found
[19:24:32] - Will indicate memory of 8888 MB
[19:24:32] - Connecting to assignment server
[19:24:32] Connecting to http://assign.stanford.edu:8080/
[19:24:33] Posted data.
[19:24:33] Initial: 8F80; - Successful: assigned to (128.143.199.97).
[19:24:33] + News From Folding@Home: Welcome to Folding@Home
[19:24:33] Loaded queue successfully.
[19:24:33] Sent data
[19:24:33] Connecting to http://128.143.199.97:8080/
[19:24:34] Posted data.
[19:24:34] Initial: 0000; - Receiving payload (expected size: 1247936)
[19:24:35] - Downloaded at ~1218 kB/s
[19:24:35] - Averaged speed for that direction ~990 kB/s
[19:24:35] + Received work.
[19:24:35] Trying to send all finished work units
[19:24:35] + No unsent completed units remaining.
[19:24:35] + Closed connections
[19:24:35]
[19:24:35] + Processing work unit
[19:24:35] Core required: FahCore_a3.exe
[19:24:35] Core found.
[19:24:35] Working on queue slot 05 [July 1 19:24:35 UTC]
[19:24:35] + Working ...
[19:24:35] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 05 -np 10 -checkpoint 10 -forceasm -verbose -lifeline 5064 -version 634'
[19:24:35]
[19:24:35] *------------------------------*
[19:24:35] Folding@Home Gromacs SMP Core
[19:24:35] Version 2.27 (Dec. 15, 2010)
[19:24:35]
[19:24:35] Preparing to commence simulation
[19:24:35] - Assembly optimizations manually forced on.
[19:24:35] - Not checking prior termination.
[19:24:36] - Expanded 1247424 -> 2077012 (decompressed 166.5 percent)
[19:24:36] Called DecompressByteArray: compressed_data_size=1247424 data_size=2077012, decompressed_data_size=2077012 diff=0
[19:24:36] - Digital signature verified
[19:24:36]
[19:24:36] Project: 7500 (Run 0, Clone 154, Gen 68)
[19:24:36]
[19:24:36] Assembly optimizations on if available.
[19:24:36] Entering M.D.
[19:24:42] Mapping NT from 10 to 10
[19:24:42] mdrun returned 255
[19:24:42] Going to send back what have done -- stepsTotalG=500000
[19:24:42] Work fraction=0.0000 steps=500000.
[19:24:46] logfile size=6817 infoLength=6817 edr=0 trr=25
[19:24:46] logfile size: 6817 info=6817 bed=0 hdr=25
[19:24:46] - Writing 7355 bytes of core data to disk...
[19:24:46] Done: 6843 -> 2412 (compressed to 35.2 percent)
[19:24:46]   ... Done.
[19:24:46]
[19:24:46] Folding@home Core Shutdown: EARLY_UNIT_END
[19:24:50] CoreStatus = 72 (114)
[19:24:50] Sending work to server
[19:24:50] Project: 7500 (Run 0, Clone 154, Gen 68)
[19:24:50] + Attempting to send results [July 1 19:24:50 UTC]
[19:24:50] - Reading file work/wuresults_05.dat from core
[19:24:50]   (Read 2924 bytes from disk)
[19:24:50] Connecting to http://128.143.199.97:8080/
[19:24:50] Posted data.
[19:24:50] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[19:24:50] - Uploaded at ~7 kB/s
[19:24:50] - Averaged speed for that direction ~88 kB/s
[19:24:50] + Results successfully sent
[19:24:50] Thank you for your contribution to Folding@Home.
[19:24:54] Trying to send all finished work units
[19:24:54] + No unsent completed units remaining.
[19:24:54] - Preparing to get new work unit...
[19:24:54] Cleaning up work directory
[19:24:54] + Attempting to get work packet
[19:24:54] Passkey found
[19:24:54] - Will indicate memory of 8888 MB
[19:24:54] - Connecting to assignment server
[19:24:54] Connecting to http://assign.stanford.edu:8080/
[19:24:54] Posted data.
[19:24:54] Initial: 8F80; - Successful: assigned to (128.143.199.97).
[19:24:54] + News From Folding@Home: Welcome to Folding@Home
[19:24:54] Loaded queue successfully.
[19:24:54] Sent data
[19:24:54] Connecting to http://128.143.199.97:8080/
[19:24:55] Posted data.
[19:24:55] Initial: 0000; - Receiving payload (expected size: 1249157)
[19:24:57] - Downloaded at ~609 kB/s
[19:24:57] - Averaged speed for that direction ~914 kB/s
[19:24:57] + Received work.
[19:24:57] Trying to send all finished work units
[19:24:57] + No unsent completed units remaining.
[19:24:57] + Closed connections
[19:25:02]
[19:25:02] + Processing work unit
[19:25:02] Core required: FahCore_a3.exe
[19:25:02] Core found.
[19:25:02] Working on queue slot 06 [July 1 19:25:02 UTC]
[19:25:02] + Working ...
[19:25:02] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 10 -checkpoint 10 -forceasm -verbose -lifeline 5064 -version 634'
[19:25:02]
[19:25:02] *------------------------------*
[19:25:02] Folding@Home Gromacs SMP Core
[19:25:02] Version 2.27 (Dec. 15, 2010)
[19:25:02]
[19:25:02] Preparing to commence simulation
[19:25:02] - Assembly optimizations manually forced on.
[19:25:02] - Not checking prior termination.
[19:25:02] - Expanded 1248645 -> 2077012 (decompressed 166.3 percent)
[19:25:02] Called DecompressByteArray: compressed_data_size=1248645 data_size=2077012, decompressed_data_size=2077012 diff=0
[19:25:02] - Digital signature verified
[19:25:02]
[19:25:02] Project: 7501 (Run 0, Clone 231, Gen 20)
[19:25:02]
[19:25:02] Assembly optimizations on if available.
[19:25:02] Entering M.D.
[19:25:08] Mapping NT from 10 to 10
[19:25:08] Completed 0 out of 500000 steps  (0%)
[19:27:15] Completed 5000 out of 500000 steps  (1%)
[19:29:21] Completed 10000 out of 500000 steps  (2%)
[20:03:49] Completed 90000 out of 500000 steps  (18%)
[20:05:56] Completed 95000 out of 500000 steps  (19%)
[20:08:03] Completed 100000 out of 500000 steps  (20%)
Re: Project 7500 -> Instant EUE, allways
Could it be because -smp 10 is an issue with P7500? Have you tried -smp 8 or -smp 12?
Mactin
Post by Mactin »
PantherX wrote:Could it be because -smp 10 is an issue with P7500?
Most probably.
PantherX wrote:Have you tried -smp 8 or -smp 12?
No.
patonb
Post by patonb »
hOW ABOUT SMP 7? As I ran into that ossue Awhile back too?
This is definately an issue if we can't run the smp with the number of cores we want to...
