Strange results - I don't see the "early unit end" in the log like I usually have. Verbosity level set to 4. Version: 7.1.21
01:46:12:Unit 01:Completed 77500 out of 250000 steps (31%)
01:54:18:FahCore running Unit 01 returned: BAD_WORK_UNIT (114)
01:54:19:Sending unit results: id:01 state:SEND project:6515 run:0 clone:224 gen:91 core:0x78 unit:0x0fb0d84c4e078bf2005b00e000001973
01:54:19:Unit 01: Uploading 4.31KiB
01:54:19:Connecting to 171.64.65.62:8080
01:54:19:WARNING: Exception: Failed to send results to work server: Failed to read response packet
*********************** Log Started 25/Jun/2011-22:25:02 ***********************
22:25:03:************************* Folding@home Client *************************
22:25:03: Website: http://folding.stanford.edu/
22:25:03: Copyright: (c) 2009,2010 Stanford University
22:25:03: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:25:03: Args: --lifeline 2216
22:25:03: Config: C:/Documents and Settings/Admin/Application
22:25:03: Data/FAHClient/config.xml
22:25:03:******************************** Build ********************************
22:25:03: Version: 7.1.21
22:25:03: Date: Mar 23 2011
22:25:03: Time: 15:13:48
22:25:03: SVN Rev: 2883
22:25:03: Branch: fah/trunk/client
22:25:03: Compiler: Intel(R) C++ MSVC 1500 mode 1110
22:25:03: Options: /TP /nologo /EHa /wd4297 /wd4103 /wd1786 /Ox -arch:SSE
22:25:03: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
22:25:03: Platform: win32 XP
22:25:03: Bits: 32
22:25:03: Mode: Release
22:25:03:******************************* System ********************************
22:25:03: OS: Microsoft Windows XP Home Edition
22:25:03: CPU: Intel(R) Pentium(R) M processor 1.73GHz
22:25:03: CPU ID: GenuineIntel Family 6 Model 13 Stepping 8
22:25:03: CPUs: 1
22:25:03: Memory: 1.99GiB
22:25:03: Free Memory: 1.29GiB
22:25:03: Threads: WINDOWS_THREADS
22:25:03: GPUs: 0
22:25:03: CUDA: Not detected
22:25:03: On Battery: false
22:25:03: UTC offset: -7
22:25:03: PID: 4084
22:25:03: CWD: C:/Documents and Settings/Admin/Application Data/FAHClient
22:25:03:Win32 Service: false
22:25:03:***********************************************************************
22:25:03:<config>
22:25:03: <service-description v='Folding@home Client'/>
22:25:03: <service-restart v='true'/>
22:25:03: <service-restart-delay v='5000'/>
22:25:03:
22:25:03: <!-- Client Control -->
22:25:03: <cycle-rate v='4'/>
22:25:03: <cycles v='-1'/>
22:25:03: <data-directory v='.'/>
22:25:03: <exec-directory v='C:\Program Files\FAHClient'/>
22:25:03: <exit-when-done v='false'/>
22:25:03: <max-delay v='21600'/>
22:25:03: <min-delay v='60'/>
22:25:03: <threads v='4'/>
22:25:03:
22:25:03: <!-- Configuration -->
22:25:03: <config-rotate v='true'/>
22:25:03: <config-rotate-dir v='configs'/>
22:25:03: <config-rotate-max v='16'/>
22:25:03:
22:25:03: <!-- Debugging -->
22:25:03: <assignment-servers>
22:25:03: assign3.stanford.edu:8080 assign4.stanford.edu:80
22:25:03: </assignment-servers>
22:25:03: <capture-directory v='capture'/>
22:25:03: <capture-sockets v='false'/>
22:25:03: <debug-sockets v='false'/>
22:25:03: <exception-locations v='true'/>
22:25:03: <gpu-assignment-servers>
22:25:03: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
22:25:03: </gpu-assignment-servers>
22:25:03: <stack-traces v='false'/>
22:25:03:
22:25:03: <!-- Error Handling -->
22:25:03: <max-slot-errors v='5'/>
22:25:03: <max-unit-errors v='5'/>
22:25:03:
22:25:03: <!-- FahCore Control -->
22:25:03: <checkpoint v='15'/>
22:25:03: <core-dir v='cores'/>
22:25:03: <core-priority v='idle'/>
22:25:03: <cpu-affinity v='false'/>
22:25:03: <cpu-usage v='100'/>
22:25:03: <no-assembly v='false'/>
22:25:03:
22:25:03: <!-- Folding Slot Configuration -->
22:25:03: <client-subtype v='STDCLI'/>
22:25:03: <client-type v='normal'/>
22:25:03: <cpu-species v='X86_PENTIUM_II'/>
22:25:03: <cpu-type v='X86'/>
22:25:03: <cpus v='1'/>
22:25:03: <extra-core-args v='-forceasm'/>
22:25:03: <gpu v='false'/>
22:25:03: <gpu-id v='0'/>
22:25:03: <max-packet-size v='normal'/>
22:25:03: <os-species v='WIN_XP'/>
22:25:03: <os-type v='WIN32'/>
22:25:03: <project-key v='0'/>
22:25:03: <smp v='false'/>
22:25:03:
22:25:03: <!-- Logging -->
22:25:03: <log v='log.txt'/>
22:25:03: <log-color v='false'/>
22:25:03: <log-crlf v='true'/>
22:25:03: <log-date v='false'/>
22:25:03: <log-debug v='true'/>
22:25:03: <log-domain v='false'/>
22:25:03: <log-header v='true'/>
22:25:03: <log-level v='true'/>
22:25:03: <log-no-info-header v='true'/>
22:25:03: <log-redirect v='false'/>
22:25:03: <log-rotate v='true'/>
22:25:03: <log-rotate-dir v='logs'/>
22:25:03: <log-rotate-max v='16'/>
22:25:03: <log-short-level v='false'/>
22:25:03: <log-simple-domains v='true'/>
22:25:03: <log-thread-id v='false'/>
22:25:03: <log-time v='true'/>
22:25:03: <log-to-screen v='true'/>
22:25:03: <log-truncate v='false'/>
22:25:03: <verbosity v='4'/>
22:25:03:
22:25:03: <!-- Process Control -->
22:25:03: <child v='false'/>
22:25:03: <daemon v='false'/>
22:25:03: <pid v='false'/>
22:25:03: <pid-file v='Folding@home Client.pid'/>
22:25:03: <respawn v='false'/>
22:25:03: <service v='false'/>
22:25:03:
22:25:03: <!-- Remote Command Server -->
22:25:03: <command-address v='0.0.0.0'/>
22:25:03: <command-allow v='127.0.0.1'/>
22:25:03: <command-allow-no-pass v='127.0.0.1'/>
22:25:03: <command-deny v='0.0.0.0/0'/>
22:25:03: <command-deny-no-pass v='0.0.0.0/0'/>
22:25:03: <command-port v='36330'/>
22:25:03: <password v=''/>
22:25:03:
22:25:03: <!-- Slot Control -->
22:25:03: <max-shutdown-wait v='60'/>
22:25:03: <pause-on-battery v='true'/>
22:25:03: <pause-on-start v='false'/>
22:25:03:
22:25:03: <!-- User Information -->
22:25:03: <machine-id v='0'/>
22:25:03: <passkey v='********************************'/>
22:25:03: <team v='0'/>
22:25:03: <user v='GreyWhiskers'/>
22:25:03:
22:25:03: <!-- Work Unit Control -->
22:25:03: <dump-after-deadline v='true'/>
22:25:03: <max-queue v='16'/>
22:25:03: <max-units v='0'/>
22:25:03: <next-unit-percentage v='99'/>
22:25:03:
22:25:03: <!-- Folding Slots -->
22:25:03: <slot id='0' type='UNIPROCESSOR'>
22:25:03: <client-type v='advanced'/>
22:25:03: </slot>
22:25:03:</config>
SNIP
19:18:38:Unit 00:Completed 242500 out of 250000 steps (97%)
19:31:11:Unit 00:Writing local files
19:31:11:Unit 00:Completed 245000 out of 250000 steps (98%)
19:43:43:Unit 00:Writing local files
19:43:44:Unit 00:Completed 247500 out of 250000 steps (99%)
19:43:44:Connecting to assign3.stanford.edu:8080
19:43:44:News: Welcome to Folding@Home
19:43:44:Assigned to work server 171.64.65.62
19:43:44:Requesting new work unit for slot 00: RUNNING uniprocessor from 171.64.65.62
19:43:44:Connecting to 171.64.65.62:8080
19:43:45:Slot 00: Downloading 490.45KiB
19:43:45:Slot 00: Download complete
19:43:45:Received Unit: id:01 state:DOWNLOAD project:6515 run:0 clone:224 gen:91 core:0x78 unit:0x0fb0d84c4e078bf2005b00e000001973
19:56:18:Unit 00:Writing local files
19:56:18:Unit 00:Completed 250000 out of 250000 steps (100%)
19:56:18:Unit 00:Writing final coordinates.
19:56:18:Unit 00:Past main M.D. loop
19:57:18:Unit 00:
19:57:18:Unit 00:Finished Work Unit:
19:57:18:Unit 00:- Reading up to 546096 from "00/wudata_01.arc": Read 546096
19:57:18:Unit 00:- Reading up to 178780 from "00/wudata_01.xtc": Read 178780
19:57:18:Unit 00:goefile size: 0
19:57:18:Unit 00:logfile size: 66413
19:57:18:Unit 00:Leaving Run
19:57:21:Unit 00:- Writing 834953 bytes of core data to disk...
19:57:21:Unit 00:Done: 834441 -> 729925 (compressed to 87.4 percent)
19:57:21:Unit 00: ... Done.
19:57:21:Unit 00:- Shutting down core
19:57:21:Unit 00:
19:57:21:Unit 00:Folding@home Core Shutdown: FINISHED_UNIT
19:57:21:FahCore running Unit 00 returned: FINISHED_UNIT (100)
19:57:22:Sending unit results: id:00 state:SEND project:6530 run:0 clone:1 gen:15 core:0x78 unit:0x1fa6e1ab4e064d95000f000100001982
19:57:22:Unit 00: Uploading 713.32KiB
19:57:22:Connecting to 171.64.65.62:8080
19:57:22:Starting Unit 01
19:57:22:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 01 -suffix 01 -lifeline 4084 -version 701 -checkpoint 15 -forceasm
19:57:22:Started core on PID 2536
19:57:22:FahCore 0x78 started
19:57:23:Unit 01:
19:57:23:Unit 01:*------------------------------*
19:57:23:Unit 01:Folding@Home Gromacs Core
19:57:23:Unit 01:Version 1.90 (March 8, 2006)
19:57:23:Unit 01:
19:57:23:Unit 01:Preparing to commence simulation
19:57:23:Unit 01:- Assembly optimizations manually forced on.
19:57:23:Unit 01:- Not checking prior termination.
19:57:23:Unit 01:- Expanded 501712 -> 2503845 (decompressed 499.0 percent)
19:57:23:Unit 01:- Starting from initial work packet
19:57:23:Unit 01:
19:57:23:Unit 01:Project: 6515 (Run 0, Clone 224, Gen 91)
19:57:23:Unit 01:
19:57:23:Unit 01:Assembly optimizations on if available.
19:57:23:Unit 01:Entering M.D.
19:57:25:Unit 00: Upload complete
19:57:25:Server responded WORK_ACK (400)
19:57:25:Cleaning up Unit 00
19:57:29:Unit 01:Protein: 1CFC_A_1 in water
19:57:29:Unit 01:
19:57:29:Unit 01:Writing local files
19:57:29:Unit 01:Extra SSE boost OK.
19:57:30:Unit 01:Writing local files
19:57:30:Unit 01:Completed 0 out of 250000 steps (0%)
20:07:02:Unit 01:Writing local files
20:07:02:Unit 01:Completed 2500 out of 250000 steps (1%)
20:16:32:Unit 01:Writing local files
20:16:32:Unit 01:Completed 5000 out of 250000 steps (2%)
20:26:04:Unit 01:Writing local files
20:26:05:Unit 01:Completed 7500 out of 250000 steps (3%)
20:35:44:Unit 01:Writing local files
20:35:44:Unit 01:Completed 10000 out of 250000 steps (4%)
20:45:14:Unit 01:Writing local files
20:45:14:Unit 01:Completed 12500 out of 250000 steps (5%)
20:54:46:Unit 01:Writing local files
20:54:46:Unit 01:Completed 15000 out of 250000 steps (6%)
21:05:08:Unit 01:Writing local files
21:05:08:Unit 01:Completed 17500 out of 250000 steps (7%)
21:14:52:Unit 01:Writing local files
21:14:52:Unit 01:Completed 20000 out of 250000 steps (8%)
21:24:26:Unit 01:Writing local files
21:24:26:Unit 01:Completed 22500 out of 250000 steps (9%)
21:36:41:Unit 01:Writing local files
21:36:41:Unit 01:Completed 25000 out of 250000 steps (10%)
21:49:28:Unit 01:Writing local files
21:49:28:Unit 01:Completed 27500 out of 250000 steps (11%)
22:00:47:Unit 01:Writing local files
22:00:47:Unit 01:Completed 30000 out of 250000 steps (12%)
22:11:21:Unit 01:Writing local files
22:11:21:Unit 01:Completed 32500 out of 250000 steps (13%)
22:22:25:Unit 01:Writing local files
22:22:25:Unit 01:Completed 35000 out of 250000 steps (14%)
22:34:06:Unit 01:Writing local files
22:34:06:Unit 01:Completed 37500 out of 250000 steps (15%)
22:43:39:Unit 01:Writing local files
22:43:39:Unit 01:Completed 40000 out of 250000 steps (16%)
23:25:53:Unit 01:Writing local files
23:25:53:Unit 01:Completed 42500 out of 250000 steps (17%)
23:36:09:Unit 01:Writing local files
23:36:09:Unit 01:Completed 45000 out of 250000 steps (18%)
23:46:27:Unit 01:Writing local files
23:46:27:Unit 01:Completed 47500 out of 250000 steps (19%)
23:57:01:Unit 01:Writing local files
23:57:01:Unit 01:Completed 50000 out of 250000 steps (20%)
00:06:59:Unit 01:Writing local files
00:06:59:Unit 01:Completed 52500 out of 250000 steps (21%)
00:16:40:Unit 01:Writing local files
00:16:41:Unit 01:Completed 55000 out of 250000 steps (22%)
00:26:16:Unit 01:Writing local files
00:26:16:Unit 01:Completed 57500 out of 250000 steps (23%)
00:35:56:Unit 01:Writing local files
00:35:56:Unit 01:Completed 60000 out of 250000 steps (24%)
00:46:32:Unit 01:Writing local files
00:46:32:Unit 01:Completed 62500 out of 250000 steps (25%)
00:56:19:Unit 01:Writing local files
00:56:19:Unit 01:Completed 65000 out of 250000 steps (26%)
01:06:48:Unit 01:Writing local files
01:06:48:Unit 01:Completed 67500 out of 250000 steps (27%)
01:16:53:Unit 01:Writing local files
01:16:53:Unit 01:Completed 70000 out of 250000 steps (28%)
01:26:52:Unit 01:Writing local files
01:26:52:Unit 01:Completed 72500 out of 250000 steps (29%)
01:36:38:Unit 01:Writing local files
01:36:38:Unit 01:Completed 75000 out of 250000 steps (30%)
01:46:11:Unit 01:Writing local files
01:54:19:Trying to send results to collection server
01:54:19:Connecting to assign3.stanford.edu:8080
01:54:19:Connecting to 171.67.108.25:8080
01:54:19:News: Welcome to Folding@Home
01:54:19:Assigned to work server 171.64.65.62
01:54:19:Requesting new work unit for slot 00: READY uniprocessor from 171.64.65.62
01:54:20:Slot 00: Downloading 669.08KiB
01:54:20:WARNING: WorkServer connection failed on port 8080 trying 80
01:54:20:Connecting to 171.67.108.25:80
01:54:21:Slot 00: Download complete
01:54:21:Received Unit: id:00 state:DOWNLOAD project:6516 run:11 clone:168 gen:80 core:0x78 unit:0x1b17287d4e07e2cd005000a8000b1974
01:54:21:Starting Unit 00
01:54:21:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 4084 -version 701 -checkpoint 15 -forceasm
01:54:21:Started core on PID 3672
01:54:21:FahCore 0x78 started
01:54:21:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:54:21:Sending unit results: id:01 state:SEND project:6515 run:0 clone:224 gen:91 core:0x78 unit:0x0fb0d84c4e078bf2005b00e000001973
01:54:21:Unit 01: Uploading 4.31KiB
01:54:21:Connecting to 171.64.65.62:8080
01:54:21:WARNING: Exception: Failed to send results to work server: Failed to read response packet
01:54:21:Trying to send results to collection server
01:54:21:Connecting to 171.67.108.25:8080
01:54:21:Unit 00:
01:54:21:Unit 00:*------------------------------*
01:54:21:Unit 00:Folding@Home Gromacs Core
01:54:21:Unit 00:Version 1.90 (March 8, 2006)
01:54:21:Unit 00:
01:54:21:Unit 00:Preparing to commence simulation
01:54:21:Unit 00:- Assembly optimizations manually forced on.
01:54:21:Unit 00:- Not checking prior termination.
01:54:22:Unit 00:- Expanded 684629 -> 3408253 (decompressed 497.8 percent)
01:54:22:Unit 00:- Starting from initial work packet
01:54:22:Unit 00:
01:54:22:Unit 00:Project: 6516 (Run 11, Clone 168, Gen 80)
01:54:22:Unit 00:
01:54:22:Unit 00:Assembly optimizations on if available.
01:54:22:Unit 00:Entering M.D.
01:54:22:WARNING: WorkServer connection failed on port 8080 trying 80
01:54:22:Connecting to 171.67.108.25:80
01:54:23:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:54:28:Unit 00:Protein: proA_12 in water
01:54:28:Unit 00:
01:54:28:Unit 00:Writing local files
01:54:29:Unit 00:Extra SSE boost OK.
01:54:29:Unit 00:Writing local files
01:54:29:Unit 00:Completed 0 out of 250000 steps (0%)
01:55:21:Sending unit results: id:01 state:SEND project:6515 run:0 clone:224 gen:91 core:0x78 unit:0x0fb0d84c4e078bf2005b00e000001973
01:55:22:Unit 01: Uploading 4.31KiB
01:55:22:Connecting to 171.64.65.62:8080
01:55:22:WARNING: Exception: Failed to send results to work server: Failed to read response packet
01:55:22:Trying to send results to collection server
01:55:22:Connecting to 171.67.108.25:8080
01:55:23:WARNING: WorkServer connection failed on port 8080 trying 80
01:55:23:Connecting to 171.67.108.25:80
01:55:24:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:56:59:Sending unit results: id:01 state:SEND project:6515 run:0 clone:224 gen:91 core:0x78 unit:0x0fb0d84c4e078bf2005b00e000001973
01:56:59:Unit 01: Uploading 4.31KiB
01:56:59:Connecting to 171.64.65.62:8080
01:56:59:WARNING: Exception: Failed to send results to work server: Failed to read response packet
01:56:59:Trying to send results to collection server
01:56:59:Connecting to 171.67.108.25:8080
01:57:00:WARNING: WorkServer connection failed on port 8080 trying 80
01:57:00:Connecting to 171.67.108.25:80
01:57:01:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
01:59:36:Sending unit results: id:01 state:SEND project:6515 run:0 clone:224 gen:91 core:0x78 unit:0x0fb0d84c4e078bf2005b00e000001973
01:59:36:Unit 01: Uploading 4.31KiB
01:59:36:Connecting to 171.64.65.62:8080
01:59:36:WARNING: Exception: Failed to send results to work server: Failed to read response packet
01:59:36:Trying to send results to collection server
01:59:37:Unit 01: Uploading 4.31KiB
01:59:37:Connecting to 171.67.108.25:8080
01:59:38:WARNING: WorkServer connection failed on port 8080 trying 80
01:59:38:Connecting to 171.67.108.25:80
01:59:39:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
02:03:50:Sending unit results: id:01 state:SEND project:6515 run:0 clone:224 gen:91 core:0x78 unit:0x0fb0d84c4e078bf2005b00e000001973
02:03:50:Unit 01: Uploading 4.31KiB
02:03:50:Connecting to 171.64.65.62:8080
02:03:50:WARNING: Exception: Failed to send results to work server: Failed to read response packet
02:03:50:Trying to send results to collection server
02:03:51:Unit 01: Uploading 4.31KiB
02:03:51:Connecting to 171.67.108.25:8080
02:03:52:WARNING: WorkServer connection failed on port 8080 trying 80
02:03:52:Connecting to 171.67.108.25:80
02:03:53:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
02:07:52:Unit 00:Writing local files
02:07:52:Unit 00:Completed 2500 out of 250000 steps (1%)
02:10:42:Sending unit results: id:01 state:SEND project:6515 run:0 clone:224 gen:91 core:0x78 unit:0x0fb0d84c4e078bf2005b00e000001973
02:10:42:Unit 01: Uploading 4.31KiB
02:10:42:Connecting to 171.64.65.62:8080
02:10:42:WARNING: Exception: Failed to send results to work server: Failed to read response packet
02:10:42:Trying to send results to collection server
02:10:42:Connecting to 171.67.108.25:8080
02:10:43:WARNING: WorkServer connection failed on port 8080 trying 80
02:10:43:Connecting to 171.67.108.25:80
02:10:44:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
02:21:13:Unit 00:Writing local files
02:21:13:Unit 00:Completed 5000 out of 250000 steps (2%)
02:21:47:Sending unit results: id:01 state:SEND project:6515 run:0 clone:224 gen:91 core:0x78 unit:0x0fb0d84c4e078bf2005b00e000001973
02:21:47:Unit 01: Uploading 4.31KiB
02:21:47:Connecting to 171.64.65.62:8080
02:21:47:WARNING: Exception: Failed to send results to work server: Failed to read response packet
02:21:47:Trying to send results to collection server
02:21:47:Connecting to 171.67.108.25:8080
02:21:48:WARNING: WorkServer connection failed on port 8080 trying 80
02:21:48:Connecting to 171.67.108.25:80
02:21:49:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
02:34:33:Unit 00:Writing local files
02:34:33:Unit 00:Completed 7500 out of 250000 steps (3%)
02:39:44:Sending unit results: id:01 state:SEND project:6515 run:0 clone:224 gen:91 core:0x78 unit:0x0fb0d84c4e078bf2005b00e000001973
02:39:44:Unit 01: Uploading 4.31KiB
02:39:44:Connecting to 171.64.65.62:8080
02:39:44:WARNING: Exception: Failed to send results to work server: Failed to read response packet
02:39:44:Trying to send results to collection server
02:39:44:Connecting to 171.67.108.25:8080
02:39:46:WARNING: WorkServer connection failed on port 8080 trying 80
02:39:46:Connecting to 171.67.108.25:80
02:39:47:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
02:47:56:Unit 00:Writing local files
02:47:56:Unit 00:Completed 10000 out of 250000 steps (4%)
03:01:21:Unit 00:Writing local files
03:01:21:Unit 00:Completed 12500 out of 250000 steps (5%)
03:08:46:Sending unit results: id:01 state:SEND project:6515 run:0 clone:224 gen:91 core:0x78 unit:0x0fb0d84c4e078bf2005b00e000001973
03:08:47:Unit 01: Uploading 4.31KiB
03:08:47:Connecting to 171.64.65.62:8080
03:08:47:WARNING: Exception: Failed to send results to work server: Failed to read response packet
03:08:47:Trying to send results to collection server
03:08:47:Connecting to 171.67.108.25:8080
03:08:48:WARNING: WorkServer connection failed on port 8080 trying 80
03:08:48:Connecting to 171.67.108.25:80
03:08:49:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
03:14:47:Unit 00:Writing local files
03:14:47:Unit 00:Completed 15000 out of 250000 steps (6%)
03:28:12:Unit 00:Writing local files
03:28:12:Unit 00:Completed 17500 out of 250000 steps (7%)
03:41:35:Unit 00:Writing local files
03:41:35:Unit 00:Completed 20000 out of 250000 steps (8%)
03:55:00:Unit 00:Writing local files
03:55:00:Unit 00:Completed 22500 out of 250000 steps (9%)
